POV-Ray : Newsgroups : povray.off-topic : Speaking of conserving memory... Server Time
28 Jun 2026 13:11:45 EDT (-0400)
  Speaking of conserving memory... (Message 1 to 10 of 21)
Subject: Speaking of conserving memory...
Date: 18 Jul 2008 00:25:55
Message: <48801b53$1@news.povray.org>
http://thedailywtf.com/Articles/That-Wouldve-Been-an-Option-Too.aspx
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Subject: Re: Speaking of conserving memory...
Date: 18 Jul 2008 03:41:48
Message: <4880493c@news.povray.org>
WTF?
http://blog.orphi.me.uk/
Date: 18 Jul 2008 05:31:39
Message: <op.uehd2kwgc3xi7v@news.povray.org>
And lo on Fri, 18 Jul 2008 05:25:55 +0100, Darren New <dne### [at] sanrrcom>
did spake, saying:
"a developer had to step in and restart the site to release resources"
Wouldn't that suggest that bunging some more memory in would only increase
the time it took to fill up?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 18 Jul 2008 10:52:01
Message: <4880ae11@news.povray.org>
> did spake, saying:
  You have a very good point. If the memory was filling up slowly, it means
there was some kind of leak. Buying more memory doesn't fix any memory leaks,
it only delays the symptoms.
  Leaks also often go hand-in-hand with other bugs in the software, so
fixing the leaks not only make the program stabler, but other bugs may
be caught in the process.
  Unless more "WTF" details are given about this story, I'd have to say
this is a "false WTF". It might sound like a WTF at first, but isn't.
The priorities should be "fix bugs first, then buy more hardware", not
the other way around.
Date: 18 Jul 2008 11:15:43
Message: <4880b39f@news.povray.org>
For me, the WTF moment is that everybody else thought that just throwing
more hardware at the problem would somehow be a "better" solution than
actually fixing the underlying problem. But maybe that's just me...
Date: 18 Jul 2008 11:35:00
Message: <web.4880b708e9f53ba6808feb1f0@news.povray.org>
My first thought was the new employee came from Microsoft.
Isaac
Date: 18 Jul 2008 11:38:42
Message: <4880b902@news.povray.org>
I am fairly confident that using more hardware resources is an explicit
*design goal* for M$. (After all, who are their main customers?)
Date: 18 Jul 2008 12:26:34
Message: <4880c43a$1@news.povray.org>
> increase the time it took to fill up?
Not necessarily. Sure, if you have a leak, you need to fix it. But it's
entirely possible to have problems from not having enough memory that
are solved by adding memory. The linux OOM killer won't kick in, you
won't thrash, you won't have race conditions caused by thrashing, you
won't have exceptions causing you to fail to release resources because
you are thrashing, etc.
"Had to restart the system to free up resources" could mean "we're
thrashing because we have 5000 connections open to the server at once,
because they're not closing, because we're thrashing." For example.
But sure, if there's a leak, you'll eventually fill up memory. If 2 gig
changes it from being "restart the server once every day" to "restart
the server more rarely than we upgrade the software anyway", it's a win.
Date: 18 Jul 2008 14:35:08
Message: <4880e25c$1@news.povray.org>
End users?
Date: 18 Jul 2008 14:42:36
Message: <4880e41c$1@news.povray.org>
Mike Raiford wrote:
>> explicit *design goal* for M$. (After all, who are their main customers?)
> End users?
That's the mistake everyone makes.
