POV-Ray : Newsgroups : povray.off-topic : How far we have come Server Time
3 Nov 2026 05:22:47 EST (-0500)
  How far we have come (Message 1 to 33 of 33)
Subject: How far we have come
Date: 13 Jul 2008 15:38:02
Message: <487a599a$1@news.povray.org>
You remember the days when programmers struggled to fit as much program
as possible into 64 KB of RAM?
I just realised something. The Haskell program I wrote the other day?
It's 1.5 MB in size. This single executable program is actually *too
big* to fit on a single [high-density] floppy disk.
The worrying part is, it doesn't even *do* anything! It's just a wrapper
around a seperate program...
http://blog.orphi.me.uk/
Subject: Re: How far we have come
Date: 13 Jul 2008 16:34:52
Message: <487a66ec@news.povray.org>
  Is there *any* programming language designed after the early 80's which
actually cares about memory usage?
  (No need to mention the obscure languages designed for embedded systems
because in those cases they are forced to care.)
Date: 13 Jul 2008 17:30:49
Message: <487a7409$1@news.povray.org>
Ada? FORTH?
My take on it is that if you're concerned about memory usage, use one of
the languages that's good at memory usage. How many of them do you need?
What's missing that would make life a lot easier that you can
nevertheless fit into a small memory footprint?  If you don't have a lot
of memory, chances are your program isn't big enough to need a really
sophisticated and/or unusual language to code it in. Pick one like C,
C++, Ada, BASIC, or FORTRAN, and use it. If you need something
"stronger", use LISP or FORTH or Smalltalk.
Fitting Mathematica, Prolog, or Haskel into 64K just isn't worth it -
there isn't enough data to be processed that you need particularly
sophisticated processing methods.
Sure, languages like Java waste memory if you allocate each integer as a
separate object, so you make an array of integers to hold your bitmap,
and deal with the minor pain that architectural decision entails.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 13 Jul 2008 17:36:57
Message: <487a7579@news.povray.org>
> Ada?
  1983.
> FORTH?
  1970's.
  What if you want objects with two or three integers inside them?
Or an integer and a floating point value?
Date: 13 Jul 2008 18:08:45
Message: <487a7ced$1@news.povray.org>
Warp wrote:
>> Ada?
>   1983.
Ada-95, then? ;-)
>> FORTH?
>   1970's.
Oh. Yeah, OK, it was around a lot longer than I knew. Standardized a lot
later, tho.  Thanks. :-)
You still put it in an array, or two parallel arrays. Or use C# instead.
Don't attribute Java's limitations to every safe/GCed language :-)
I think the basic problem is that after the early 80's, people weren't
designing programming languages based on 8-bit processors with 16-bit
address spaces. I mean, C and FORTRAN were considered terribly wasteful
of resources back when 1K of RAM was a lot of memory. :-)
I guess most people doing that stuff figured memory-restricted languages
were pretty much a solved problem. Pick from C, Fortran, COBOL, Ada,
FORTH, Assembler, Pascal, BASIC, APL, LISP, Algol, PL/1, C++, ... as you
like. Why make another like that? What's missing? All those languages
ran comfortably in and could do considerable (for the time) computation
on a 64K machine. If you don't have the memory to run Excel, write it in
APL. If you don't have the memory to run Perl, write it in COBOL. If
Prolog is too big, use LISP.
It seems obvious to me that if one is interesting in developing new
languages, it's a good idea to target the machines with new
capabilities. You want to solve in your language the kinds of problems
that don't come up when you only have small machines, like how to
efficiently organize terabytes of data spread over a dozen cities in a
way that you never, ever have an outage.
Of course, you also have things like befunge, brainfuck, intercal, and
all the other joke languages which can nevertheless be interpreted with
a handful of memory. :-)  I suspect this isn't what you meant, tho.
And of course you have problems that push the limits of big machines
too. Video games, artificial intelligence, physics simulations (of
various accuracies), data mining (say, google), etc. But a lot of those
kinds of problems can be broken into a more-core part that you write in
a difficult efficient language and a less-core part that you write in a
more powerful less efficient language. Which is kind of the same all the
way down the stack - C is a lot easier than VHDL to get some piece of
functionality out of, but you might need a dozen C instructions to do
what one custom VHDL blob of gates could do in a couple of clock cycles.
Why is software less reliable than hardware? One reason is that software
is used to do the stuff that is far too complex to do in hardware. Why
do people build languages like Java or Erlang or Haskel that compile
down to C? To build the systems you couldn't build in C because it's too
low-level conceptually, lacking vital flexibility.
Date: 13 Jul 2008 18:49:51
Message: <487A86C7.1030100@hotmail.com>
POV-Ray?
Date: 13 Jul 2008 19:14:26
Message: <487a8c52@news.povray.org>
> POV-Ray?
  Except that POV-Ray isn't a programming language but a renderer.
Date: 13 Jul 2008 21:12:06
Message: <487aa7e6@news.povray.org>
HTML
(Dodges tomatos!)
----> If you cut here, you'll ruin your monitor. <----
                    /  \/  \ u e e n     /  \/  a w a z
                        >>>>>>mue### [at] nawazorg<<<<<<
                                    anl
Date: 14 Jul 2008 00:29:13
Message: <487ad619$1@news.povray.org>
Have you ever heard of premature optimization?
Don't bother solving a problem until it's a problem.  Sure, modern
programs use WAY more resources than older ones... but is it even a problem?
Unless you're running out of memory on your computer, don't even try to
optimize it for size.
Let's face it: on a modern computer with, say, 3Gb of RAM, if you have a
program that's running out of memory, are you going to care about
a) The data structures using up 4Gb of RAM that you need to optimize, or
b) The default libraries linked in using .0015 Gb of RAM?
...Chambers
Date: 14 Jul 2008 00:29:50
Message: <487ad63e$1@news.povray.org>
> HTML
> (Dodges tomatos!)
If you mean, it's designed to care about using AS MUCH AS POSSIBLE? ;)
...Chambers
Date: 14 Jul 2008 01:43:21
Message: <487AE7B2.8070600@hotmail.com>
>> POV-Ray?
it is both.
Date: 14 Jul 2008 03:12:13
Message: <487afc4d@news.povray.org>
Darren New wrote:
>>> FORTH?
>>   1970's.
I can't believe a computer expert wouldn't know that. I mean, FORTH is
only, like, the most important programming language *ever*! Next you'll
be telling me you don't know who Babbage is...
[I'm only kidding of couse...]
Date: 14 Jul 2008 06:06:29
Message: <487b2525$1@news.povray.org>
Orchid XP v8 wrote:
> Darren New wrote:
>>>> FORTH?
>>>   1970's.
>> lot later, tho.  Thanks. :-)
Didn't he write programs with the alphabet soup his wife Ada made for him?
...Chambers
Date: 14 Jul 2008 10:35:41
Message: <487b643d@news.povray.org>
> >> POV-Ray?
> it is both.
  If you are referring to the SDL as a "programming language", that is
a real memory hog.
Date: 14 Jul 2008 10:36:37
Message: <487b6475@news.povray.org>
> HTML
> (Dodges tomatos!)
  Even if it was a "programming language", HTML is probably one of the
*least* memory-efficient languages ever.
Date: 14 Jul 2008 14:28:50
Message: <487B9B1B.2040602@hotmail.com>
>>>> POV-Ray?
>> it is both.
> a real memory hog.
No I am referring to the way SDL handles datastructures. I assume that
they are designed to let the scene use as little memory as possible. I
could be wrong, but I shouldn't. ;)
Date: 14 Jul 2008 14:30:14
Message: <487b9b36@news.povray.org>
  If you make, for example, an array of objects with the SDL, it is
a memory hog.
Date: 14 Jul 2008 14:31:19
Message: <487b9b77$1@news.povray.org>
Heh. To be fair, I've written at least two complete FORTH interpreters.
:-) Still, it wasn't actually popular until the 80's.
Date: 14 Jul 2008 14:49:46
Message: <487BA003.2050202@hotmail.com>
> a memory hog.
Well, lets change that in POV4.
Date: 14 Jul 2008 15:02:57
Message: <487ba2e1@news.povray.org>
> > a memory hog.
  I bet it won't be too different in that regard.
Date: 14 Jul 2008 17:02:21
Message: <487bbedd$1@news.povray.org>
...it was actually popular? :-P
Date: 14 Jul 2008 17:19:39
Message: <487bc2eb$1@news.povray.org>
>>> is only, like, the most important programming language *ever*!
>> interpreters. :-) Still, it wasn't actually popular until the 80's.
> ....it was actually popular? :-P
Actually, yeah. For example, every Sun Sparcstation had FORTH in ROM,
and a number of other embedded systems used it (like printer drivers and
such).
But it was never popular like C is, no. Certainly more popular in the
80's (after a standard came out for it) than in the 70's.
Date: 14 Jul 2008 18:27:13
Message: <487bd2c1$1@news.povray.org>
I still do ...
-- Chris
Date: 14 Jul 2008 22:55:08
Message: <487c118c@news.povray.org>
I learned to micro-optimize with LEGO Mindstorms. It *interprets* bytecode,
and the interpreter runs on a tiny slow H8 microcontroller. I was writing
in NQC, btw, not the graphical system it comes with (the one connecting
command blocks like puzzle pieces). You could really notice the difference
of speed by just moving switch case labels around (most common/important
ones first so that it needs to do fewer comparisons before reaching them).
The hardcore guys were writing alternate firmwares :) I heard someone added
floating point support in less than 2KB, complete with the NaN and infinity
mess.
(And their children were probably using the graphical programming language
with the same robotics kit. Clearly a toy for all ages.)
Date: 14 Jul 2008 22:56:57
Message: <487c11f9@news.povray.org>
Wow, Warp didn't comment on that line yet? :)
(a "look who's speaking" kind of comment)
Date: 16 Jul 2008 12:44:58
Message: <487e258a$1@news.povray.org>
Wow. Now we're getting meta-nasties. :-)
Date: 16 Jul 2008 16:23:24
Message: <487e58bc@news.povray.org>
Some computer archeology: http://www.pagetable.com/?p=32
Date: 16 Jul 2008 16:26:44
Message: <487e5984$1@news.povray.org>
Wow! LOL.
I did have a tape for a C64 laying around somewhere and I was going to
attempt to decode it... but then I found an illegal copy of the data
online, so I didn't need to bother.
(Did you know, you can actually get C64 sound emulator plugins for
WinAmp?? Retro, much?)
Date: 16 Jul 2008 16:28:32
Message: <487e59f0@news.povray.org>
  Emulators for old consoles and game computers are very popular among
certain demographic groups of computer nerds.
Date: 16 Jul 2008 16:51:30
Message: <487e5f52$1@news.povray.org>
Apparently.
Now, the fact is, when I listen to this thing, I can't help but think
that the filter responses aren't quite correct. What the HELL does that
make me? o_O
Date: 16 Jul 2008 16:53:11
Message: <487e5fb7@news.povray.org>
> make me? o_O
  Honestly, IMO the sound quality of the C64 sucks. For example the NES
and the Spectrum128 had much better sound.
Date: 17 Jul 2008 10:50:01
Message: <web.487f5b8365648d1ed3fe36d90@news.povray.org>
For the jurassic computer nerds, see http://www.hercules-390.org/.
An emulator for old IBM 360/370 mainframes.  You too can have an IBM
mainframe on your desktop. Running MVS 3.8 on a 2.4G P4 is about as fast
as an IBM 3033U circa 1980.
Isaac
Date: 20 Jul 2008 17:16:20
Message: <4883ab24@news.povray.org>
Yes, I downloaded all of Sonic the Hedgehog music in its "original format"
(file format is basically a dump of the commands the main SEGA CPU sent to
the YM2612 sound chip).
Lots of SEGA music can be downloaded from http://project2612.org/
