POV-Ray : Newsgroups : povray.off-topic : ACT! Server Time
19 Oct 2026 17:33:36 EDT (-0400)
  ACT! (Message 1 to 8 of 8)
Subject: ACT!
Date: 8 Jul 2008 10:13:40
Message: <48737614@news.povray.org>
As in,
http://en.wikipedia.org/wiki/Act%21
(I'm really surprised there's an entry for it, but it's definitely there.)
As far as I can tell, this crappy little program (which has a distinctly
Windows 3.1 GUI) just stores contact details. A bit like... the contacts
list feature of Outlook. All it seems to do is store and retrieve client
information. That's its entire function.
Now, if the program did this especially well, you could understand my
company deciding to use it. But it doesn't. It is the most unreliable
crock of junk EVER! It is just so complicated to set up. And sometimes
you set it up, and for no reason, it just won't work. And you have to
set it up all over again. Sometimes it takes several attempts before it
will work correctly. Sometimes it never works quite how it should.
The program keeps a local database in some undocumented proprietry
format. When you first set this thing up, you have to email the
application administrator and ask him to build a "blank database" for
the new user. You put this on the hard drive and point the software at it.
The best part is that these databases are kept synchronised BY SENDING
EMAILS! That's right. When you enter some new data into your local
database and you want to propogate it to the other users in the company,
you press a button and the software builds a database diff and SENDS IT
IN AN EMAIL to the application administrator. He imports this into the
master database. Periodically, he sends out emails to everybody to
import into their local databases to bring them back up to date.
Yes, you heard me correctly. In the year 2008, people are trying to
manually synchronise seperate databases by sending diffs back and forth
by email. And if your database gets out of synch somehow, next time you
send out a sync it can "corrupt" the master database, causing general
disaster. You also have to be very careful about exactly how you update
information in your local database, to avoid lost updates and other
well-known database problems.
(There's also an "optimise database" option that has to be used only at
certain times to avoid corrupting your database next time you import...
You see what I mean about complicated?!?)
The best part is when you've set up a new PC with a blank database. You
then have to import an "initial synch packet". Unlike the regular diffs
which only contain updates, this packet contains EVERYTHING.
I'm doing such a process as we speak, actually. The full packet is a
mere 6 MB in size. And yet, even on brand-new top-of-the-line hardware,
it takes several *hours* to import all the data. The entire time, there
seems to be very little CPU usage, but massive HD thrashing.
Like, WTF? *How* can it possibly take this long to process a mere 6 MB
of data?? What the hell is it *doing*?! x_x
(I started processing at 2 PM today. It is now 3 PM, and currently 32%
processed.)
Throughout all of this, I keep asking why the hell we're using this lump
of crud. The answer I keep getting is "we don't have anything else to
use". Why somebody can't throw together something superior in Access in
about 10 minutes is beyond my powers of comprehension...
http://blog.orphi.me.uk/
Subject: Re: ACT!
Date: 8 Jul 2008 11:08:21
Message: <487382e5@news.povray.org>
> processed.)
...and still it continues... (83% now)
Subject: Re: ACT!
Date: 8 Jul 2008 11:46:46
Message: <48738be6$1@news.povray.org>
>> processed.)
Damnit, IT'S STILL GOING! >_<
This isn't going to complete before I go home, is it? Grr...
Subject: Re: ACT!
Date: 8 Jul 2008 12:34:05
Message: <487396fd$1@news.povray.org>
It used to be all the shizzle ten or twelve years ago. All kinds of
stuff interfaced with it, including form letter generation, tickler
files, etc. Everyone tried to be compatible with ACT!
> format.
According to wikipedia, it's MS SQL Server. Are you running a recent
version, or the Win 3.1 version? :-)
> by email.
Kind of makes sense if you think about traveling salesmen with
disconnected laptops adding new contacts that other people don't really
need to see promptly.  Needing to manually import the stuff seems kind
of odd.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Subject: Re: ACT!
Date: 8 Jul 2008 13:54:52
Message: <4873a9ec$1@news.povray.org>
I see... I guess that would be why we have licenses for it then!
>> format.
The version we have is pretty old. It definitely does NOT use SQL
Server! It uses flat files. And I don't see any Sage branding either...
>> forth by email.
> of odd.
Well, Microsoft Outlook seems to manage to do all this just fine without
any special action on the user's part. You're out on the road, you read
the local copy of your mailbox, you send out a few replies (obviously
they don't "go" anywhere yet), compose new emails, note down new client
contacts, etc. When you get back to the office, you connect, and Outlook
somehow manages to automatically synchronise your local mailbox with the
server copy - and even lets you continue working while it's doing it! It
also never "corrupts the database" if you try to do operations in "the
wrong order".
Why the hell can't ACT do any of this?? And given that it can't, why
don't we just use the existing contact-sharing features already in
Outlook???
Subject: Re: ACT!
Date: 8 Jul 2008 14:49:03
Message: <4873b69f$1@news.povray.org>
Just guessing, offhand, that you're running a version designed to fit in
just a few megabytes of memory. You know, back when the question was
"why would anyone need 64 meg of memory??"  ;-)
What does the copyright in the "about" box say?
Subject: Re: ACT!
Date: 11 Jul 2008 19:41:04
Message: <4877ef90@news.povray.org>
We've had things superior to this for years:  Post-It notes.
John
Subject: Re: ACT!
Date: 12 Jul 2008 02:40:04
Message: <487851c4@news.povray.org>
They also are superior when storing passwords.
> Regards,
> John
Eero "Aero" Ahonen
    http://www.zbxt.net
