POV-Ray : Newsgroups : povray.off-topic : Failing Gracefully... iTunes doesn't Server Time
15 Aug 2025 17:36:39 EDT (-0400)
  Failing Gracefully... iTunes doesn't (Message 1 to 10 of 32)
Subject: Failing Gracefully... iTunes doesn't
Date: 5 Jul 2008 17:50:15
Message: <486fec97$1@news.povray.org>
To me, one of the most important things a piece of code (whether it's an
entire program, or just a single routine) can do is fail gracefully.  If
it fails, enough context and information should be given that you know
why it failed.
iTunes is absolutely horrible at this.  Apparently, Apple thinks that
"failing gracefully" means quietly ignore the error with no record of it
being kept anywhere.  In other words, you don't even *know* there's an
error.  Your only clue is that the expected result didn't actually
occur.  Once you figure out there's been an error, you have no idea what
caused it.
Talk about bad practice.
...Chambers
Subject: Re: Failing Gracefully... iTunes doesn't
Date: 5 Jul 2008 22:41:55
Message: <487030f3$1@news.povray.org>
I remember spending 15 minutes or so on an original Mac trying to figure
out why I couldn't save my work, or make a copy of it on the floppy, or
etc etc etc, because the floppy was write-protected. No message or
anything - just failure to highlight the drive icon when you drag the
folder over it, a greyed-out save menu, etc.
I liked the Amiga mechanism much better. You drag a file onto a disk
icon, it pops up a window saying the drive is write-protected, you take
the disk out, unprotect it, put it back in, and it automatically clicks
"retry" for you.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 6 Jul 2008 00:20:01
Message: <web.4870470320c25d9a1a157cba0@news.povray.org>
> why it failed.
> caused it.
> ...Chambers
I've had repeated problems over the years with Quicktime to the
point where I dread installing it.
-Mike
Date: 6 Jul 2008 03:37:05
Message: <48707621$1@news.povray.org>
> why it failed.
> caused it.
For the average iTunes user (think:  grossly ignorant teenager),
feedback would be useless.
John
Date: 6 Jul 2008 04:47:30
Message: <487086a2$1@news.povray.org>
I disagree.
If you're an idiot, you won't understand what the error message is
saying. But knowing that there was an actual error is still useful.
PS. Not all teenagers are ignorant. Some of them use WinAmp. *rimshot*
http://blog.orphi.me.uk/
Date: 6 Jul 2008 05:18:43
Message: <48708df3@news.povray.org>
> "retry" for you.
That can't be good, 'cause it assumes that user can and will do
something to prevent the error, while computers Should Just Work (or be
delivered to service company).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 6 Jul 2008 05:39:44
Message: <487092e0@news.povray.org>
>> take the disk out, unprotect it, put it back in, and it automatically
>> clicks "retry" for you.
> something to prevent the error, while computers Should Just Work.
Yes. Silently refusing to do what the user asked without telling them
why would be a far superior solution. Especially when the problem is
trivially fixable.
Date: 6 Jul 2008 06:41:34
Message: <4870A195.8040408@hotmail.com>
You had always the option of cancelling in stead of solving the problem.
I also like the MS solution of giving the error but no retry option (at
least unto XP). Works great when copying lots of files and after 10
minutes one of the last ones encounters a disk full.
Date: 6 Jul 2008 07:58:41
Message: <4870b371$1@news.povray.org>
Ooo yes, it's *great* when a file copy or move operation fails.
Especially with a move - half the files are now in one place, and half
in another place. Good luck manually undoing the operation so you can
try again! ;-)
(Particularly if you have millions of files in a complex directory
structure. Merging the two halves back together is really not fun...)
Date: 6 Jul 2008 12:28:07
Message: <4870f297$1@news.povray.org>
I haven't any idea what that means, I'm afraid.
Not even knowing that there was something I could do to un-dim the
option on the Mac is what confused me. I had no idea it was done on
purpose, and it wasn't just something I was doing wrong.
Kind of like in an adventure game where there's no difference between
"you can't do that" and "I don't understand that" and "you can't do that
here and now".
