POV-Ray : Newsgroups : povray.off-topic : Design patterns Server Time
19 Apr 2026 07:02:41 EDT (-0400)
  Design patterns (Message 1 to 10 of 11)
Subject: Design patterns
Date: 4 Jul 2008 22:19:26
Message: <486eda2e$1@news.povray.org>
Is it me, or is the GoF book "Design Patterns" really over-hyped? Every
time I hear it mentioned, it's along the lines of "wow, isn't it great
they teach you all these tricks?"  When really, all they're doing is
naming stuff that everyone does, most of which predates OO programming
to start with.
I mean, really.  <Warp> I don't get it. </Warp>
Factory Method - you don't know what class to instantiate, so put the
class in a variable. A kludge only when a language isn't OO enough to
have objects that represent classes.
Abstract Factory - you don't know which collection of classes to
instantiate, so put the collection of classes in a variable.
Singleton - you only want one, so use a global variable.
Adapter - you have two incompatible libraries, so write routines that
translates between the two.
Bridge - abstract class, opaque pointer.
Proxy - this word has meant the same thing since Latin-speaking romans
invented it.
Iterator - In any actually fully-OO language, this is the only way to
access the elements of an aggregate object sequentially, let alone with
or without exposing the underlying representation.
Memento - for languages too lame to be able to reflect.
Mediator - MVC, around 30 years ago, and also pretty obvious given the
problem it's supposed to solve.
Observer - Part of MVC, also around 30 years ago, and a pretty obvious
way of structuring programs.
Template method - the normal way of using virtual methods.
Chain of responsibility - multiple functions might handle this, so call
them one at a time until one handles it, duh.
Facade - You didn't finish writing the code to be useful, so I'll finish
it and call it a facade.
Seriously, how are you supposed to use this book? Are you supposed to
not know that you can have a method in a superclass that does different
things by calling methods implemented in its subclasses? Did you not
know that if you want to enforce only having one of something, you can
put it in a global variable and use that? Or is somehow giving a special
name to "global variable" somehow make it easier to communicate with
someone? How does it help to give special names to different types of
compatibility layers, depending on whether the layers involve single
classes, single methods, or collections of classes?
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Subject: Re: Design patterns
Date: 5 Jul 2008 03:17:00
Message: <486f1fec@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:486eda2e$1@news.povray.org...
> to start with.
I haven't read it, though I have read some other books on patterns, so this
is just my take.
Firstly, having standard names for things makes communication easier. System
designer can just say "I want you to use a Abstract Factory" and in theory
the developer nows exactly what to do.
I've seen patterns described as 'documented good practices'. They're
probably more useful for the average developer than for the gurus because
they show something that does work (if used in the right circumstances)
Date: 5 Jul 2008 04:40:34
Message: <486f3381@news.povray.org>
There really *are* design patterns which might sound obvious to you
and me, but are not all that obvious to many programmers who are starting
to dig into OOP.
  One example I like (and which name I rather ironically cannot remember
now) is the design pattern which you can use to create primitives and
unions of primitives, so that the union itself is a primitive (thus
allowing a union to contain other unions, containing other unions,
thus forming a whole hierarchy of primitives).
  For example, let's assume that you have three primitives: Line, rectangle
and circle, and you also want to be able to make compound objects containing
any amount of those (so that you can, for example, transform all of them
as if they were one single primitive). Of course it would be nice if such
a compound object could contain other compound objects as well. Thus this
compound object should be a primitive itself.
  Hence the inheritance hierarchy would be something like this:
Primitive
  '--> Line
  '--> Rectangle
  '--> Circle
  '--> Union
         '--Contains: List of <Primitive>
  In other words, if that was drawn as an UML diagram, there would be
a "contains" arrow from 'Union' back to 'Primitive', making the hierarchy
recursive.
  This is a simple idea and might be obvious to some, but it certainly
might not obvious to the new OO programmer.
  The book Design Patterns is full of tidbits like this, making it
potentially quite useful to someone.
Date: 5 Jul 2008 05:03:51
Message: <486f38f7$1@news.povray.org>
> to dig into OOP.
It's called Container or Composite or something like that. (Also related
to the Decorator pattern - although that does the same thing for a
different reason.)
Many good ideas seem obvious *after* somebody told you. ;-)
For example, (A*B)^2 - 4*(A+B) = (A-B)^2. Obvious once you know, but
DAMN... I've have never thought of it!
http://blog.orphi.me.uk/
Date: 5 Jul 2008 05:07:00
Message: <486f39b4@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:486f38f7$1@news.povray.org...
Which is as good a reason as any to make the patterns known. So we don't get
novice programmers who just don't know the tried and trusted ways
reinventing the wheel, usually badly.
Date: 5 Jul 2008 07:56:23
Message: <486f6167$1@news.povray.org>
Well that is true for some values of A an B - But probably not as many
as you think.
Whereas (A+B)^2 - 4*(A+B) = (A-B)^2 is true a few more cases.
Unless you have redefined the * and + operators :)
Date: 5 Jul 2008 08:28:48
Message: <486f6900$1@news.povray.org>
> as you think.
NAAAAARGH!!! >_<
Why must every point I make be compromised by flawed typing?!
Date: 5 Jul 2008 11:27:09
Message: <486f92cd$1@news.povray.org>
"Paul Fuller" <pgf### [at] optusnetcomau> wrote in message
news:486f6167$1@news.povray.org...
> as you think.
Still, not true for as many cases as
(A+B)^2 - 4*A*B = (A-B)^2
Date: 5 Jul 2008 17:39:10
Message: <486fe9fe$1@news.povray.org>
Warp wrote:
> Primitive
>   '--> Line
>   '--> Rectangle
>   '--> Circle
>   '--> Union
I was doing that before I knew what "Design Patterns" were.
Actually, I think it would be extremely beneficial to me, just for the
standard terminology.  While there are patterns I don't know, more
important to me is being able to communicate with other people the ideas
in my head.
...Chambers
Date: 5 Jul 2008 17:44:14
Message: <486feb2e@news.povray.org>
>> as you think.
> NAAAAARGH!!! >_<
Because you don't type enough?
I recommend you spend *more* time on these forums, and tell your boss
you're improving your work skills :)
...Chambers
