POV-Ray : Newsgroups : povray.off-topic : Fun with cryptography Server Time
19 Oct 2026 17:33:37 EDT (-0400)
  Fun with cryptography (Message 1 to 50 of 74)
Goto Latest 50 Messages Next 24 Messages >>>
Subject: Fun with cryptography
Date: 2 Jul 2008 08:27:44
Message: <486b7440$1@news.povray.org>
I'm just reading this:
http://www.sans.org/reading_room/whitepapers/vpns/1459.php
I few "interesting" things about this document. (E.g., there's a section
called "what the heck is IPSec?" That's very whitty, but I'm not sure
how seriously you should trust such a document...)
The basic premise seems to be that all VPN systems currently in
existence actually suck, except OpenVPN which is completely perfect. A
suspicious conclusion, obviously.
The document claims this is because "IPSec is too complicated to be
secure", and that "TSL is mature and battle-tested". It also asserts
that running software in user-space is inherantly better from a security
perspective. (While it *is* better, it's hardly the end of the story...)
The document seems to indicate that installing IPSec VPN software on
Windows is excrusiatingly difficult due to the built-in IPSec
functionallity Windows already has. (...is does??) For example,
"On Windows, OpenVPN installs just like any other program. It comes
bundled up as an executable and all you need to do it double click on
the installer. Total installation of the Windows client takes about 10
minutes including configuration. For anyone who has tried to configure
the builtin Windows IPSec client that should be impressive. For people
who have tried to install and configure third party IPSec clients, that
number should be shocking!"
Um... am I missing something? Installing Cisco's IPSec VPN involves...
double-clicking the installer. And that's it. What's so hard about that?
Also amusing is the statement "Blowfish is a very strong algorithm with
no known weaknesses. Its 128-bit key provides us with a large enough key
space to make brute force key attacks impossible in polynomial time."
Erm... like... WTF?
Still, I did learn one useful thing: Apparently the "route" command
exists on Windoze.
http://blog.orphi.me.uk/
Subject: Re: Fun with cryptography
Date: 2 Jul 2008 09:03:07
Message: <486b7c8b$1@news.povray.org>
Weeeee....
http://eprint.iacr.org/2008/166.pdf
There's nothing like cryptanalysis to make you paranoid! ;-)
Date: 2 Jul 2008 09:52:21
Message: <486b8815@news.povray.org>
Ooo, shiny...
http://orion.math.iastate.edu/dept/thesisarchive/MS/EKleimanMSSS05.pdf
Anybody know what a "null space" is?
(Better yet - anybody know of a job where knowing this kind of thing is
actually an advantage?)
Date: 2 Jul 2008 14:38:13
Message: <486bcb15$1@news.povray.org>
I like how they make this assertion, then later on say "you might need
the load balancing that IPsec does, but you can get that with OpenVPN by
running this other complicated program on a spare machine." It sounds
like a lot of the complication is stuff that OpenVPN basically leaves out.
Plus, I'm not really sure how they're running TLS over UDP, given that
TLS is stream-oriented and assumes reliable delivery. It's also not real
obvious from their descriptions that it's possible to run a UDP protocol
over OpenVPN.
Ditto.
> Erm... like... WTF?
Of course, it hasn't been tested as furiously as AES, either.
> exists on Windoze.
Yup.
http://technet2.microsoft.com/WindowsServer/en/library/552ed70a-208d-48c4-8da8-2e27b530eac71033.mspx?mfr=true
Might be worth reading thru the list so you know what's available.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 3 Jul 2008 02:28:10
Message: <486c717a@news.povray.org>
Well, is that a protocol feature or a software feature?
> over OpenVPN.
Hmm, that's a good point.
>> with no known weaknesses. Its 128-bit key provides us with a large
>> enough key space to make brute force key attacks impossible in
>> polynomial time." Erm... like... WTF?
I was more amused by the statement that key size has any relationship to
complexity class.
Blowfish is far more popular than, say, TEA or SQUARE or any number of
other ciphers from the zoo of less-known algorithms out there. I note
however that Blowfish has been "replaced" by Twofish which is meant to
be stronger. (And AES finalist, I believe.)
A lot of people are apparently jumpy about the whole XSL attack thing on
AES.
Date: 3 Jul 2008 12:35:24
Message: <486cffcc$1@news.povray.org>
>> by running this other complicated program on a spare machine." It
>> sounds like a lot of the complication is stuff that OpenVPN basically
>> leaves out.
I'm saying that they mock IPsec for solving problems *they* don't have,
because it was "designed by a committee".  I suspect the people on the
"committee" actually *did* have those problems, so incorporated
solutions to them into the standard, instead of making everyone solve it
themselves with ad hoc solutions consisting of interacting layers which
could easily introduce a security hole if you don't know what you're doing.
> complexity class.
Yes, I understood the WTF. :-) Of course, if it's running over TLS, you
can put whatever cipher both sides agree on in there.
And actually, key size *can* have a relationship to complexity class,
perhaps. If you can pre-compute something that lets you look up in
polynomial time the key that someone is using, except that the key is
too long to store the precomputed somethings for every key, I can see
where that can happen. (Technically, the same complexity class, but in
practice, you can break something in polynomial time if you discount the
precomputation, perhaps.)
But yeah, the whole discussion was full of WTFs like that. Plus, they
say basically "IPSec is too complicated to deploy, OpenVPN does the same
thing only its easy to deploy", without giving any evidence at all of
either. Most of the paper is a description of SSL, and I'm pretty sure
there aren't fundamental security problems with IPSec that aren't in SSL.
(And apparently the authors don't know that actual difference between
SSL and TLS.  Hint: OpenVPN seems to use SSL.)
Date: 3 Jul 2008 13:57:54
Message: <486d1322$1@news.povray.org>
Hmm. I just wanted to know whether this piece of software was worth using.
I think I have my answer now...
Date: 3 Jul 2008 15:56:14
Message: <486d2ede$1@news.povray.org>
Oh. I imagine if it solves the problem you have, it's probably worth
using, assuming you can get it working and it's sufficiently widespread
you trust it.
That the people writing the *paper* didn't write it in a convincing way
doesn't really say much about the *code*.
Date: 3 Jul 2008 16:02:03
Message: <486D3071.9050802@hotmail.com>
Invisible wrote:
> Weeeee....
It lead to a discussion in parliament here and a bad time for one of our
ministers. Introduction of the country-wide OV chipcard (OV is the
abbreviation for public transport) is postponed now.
At the last election in some cities voting was done again by paper and
red pencil because somebody showed that you could listen to what people
voted by putting a radio receiver close to it and a few more
insecurities of the digital voting machines.
What these examples have in common is that they were badly designed and
they relied on people not knowing the details as an important security
measure. The latter is of course an absolute sin in cryptography, but
apparently not (yet) when designing voting equipment or identification
cards.
Date: 3 Jul 2008 17:06:48
Message: <486d3f68$1@news.povray.org>
> cards.
Security through obscurity = hmm, it doesn't work. ;-)
Date: 3 Jul 2008 17:08:29
Message: <486d3fcd@news.povray.org>
True. But given that it seems to be a one man project... Well I'm sure
it *works*, but that's not the same as being secure. [Not that any sane
person is going to bother trying to hack my systems unless it's
sufficiently easy.]
Date: 3 Jul 2008 17:29:35
Message: <486d44bf$1@news.povray.org>
I see. I hadn't followed it up.  No, if the author of the code is the
author of the paper, I'd definitely go with IPSEC. :-)
Date: 4 Jul 2008 04:08:07
Message: <486dda67$1@news.povray.org>
It appears the report was written by somebody other than the author. But
then, comments like "OpenVPN seems to be using SSL" make me suspicious.
As does the fact that SSL and TLS both run over TCP, yet OpenVPN seems
to be using UPD. That looks like a big enough deviation from the
standard that I'm left wondering how many design decisions have been
made with potential security implications.
It's not like OpenVPN just calls the OpenSSH crypto library to do its
bidding; it looks like a complete new implementation.
Date: 4 Jul 2008 05:22:11
Message: <486debc3$1@news.povray.org>
That sentence made me laugh.  Of course, it's 3 AM here (almost 3:30), so
I'm a little sleepy, but can I just say THANK YOU?  I *really* needed a
laugh.
Tough night, and this really helped.
Thank you.
Jim
Date: 4 Jul 2008 05:24:59
Message: <486dec6b@news.povray.org>
> laugh.
> Thank you.
No problem. There's no charge for this service. Please contact Phil Cook
in my absence. ;-)
Date: 4 Jul 2008 06:11:36
Message: <486df758$1@news.povray.org>
>> so I'm a little sleepy, but can I just say THANK YOU?  I *really*
>> needed a laugh.
>> Thank you.
> in my absence. ;-)
And another laugh.  I might actually get some sleep yet tonight. :-)
Jim
Date: 4 Jul 2008 06:27:28
Message: <486dfb10$1@news.povray.org>
>> in my absence. ;-)
Yeah - dude, what the hell?? WHY ARE YOU AWAKE?! x_x
Date: 4 Jul 2008 07:01:07
Message: <486e02f3$1@news.povray.org>
>>> Cook in my absence. ;-)
Right now because I'm talking to you.  5 AM now.
Today's the 4th of July here, so I don't have to work today.
Jim
Date: 4 Jul 2008 07:06:46
Message: <486e0446$1@news.povray.org>
Ooo, Independence Day. This can mean only one thing...
...it's Jamie's birthday tomorrow! :-D
Date: 4 Jul 2008 07:47:31
Message: <486e0dd3$1@news.povray.org>
Which Jamie?
Jim
Date: 4 Jul 2008 07:51:28
Message: <486e0ec0$1@news.povray.org>
> Which Jamie?
The one I ordered a birthday card from Zazzle for but which hasn't
turned up yet... :-S
Seriously, Zazzle boasts that you can have your order within 24 hours,
but that's only actually true if you line in North America. For the rest
of the world... it takes rather a long time. :-( I wish they would set
up a facility somewhere in mainland Europe...
Date: 4 Jul 2008 08:29:33
Message: <486e17ad$1@news.povray.org>
>> Which Jamie?
Ah, I see.  There are so many Jamies' in the world.  But hey, it sounds
like you've got at least *one* friend.  Actually, though, I know you have
more than that. ;-)
Seems a lot of companies operate that way.  We have a similar experience
when ordering DVDs from amazon.co.uk as well.
Jim
Date: 4 Jul 2008 08:30:31
Message: <486e17e7$1@news.povray.org>
>>> Which Jamie?
> have more than that. ;-)
>> rest of the world... it takes rather a long time. :-( I wish they would
>> set up a facility somewhere in mainland Europe...
And not just DVDs (hit send too soon).  Just got a copy of the Uxbridge
English Dictionary, and it (actually surprisingly because we ordered from
a US site) also was sent via Royal Mail from the UK.
Jim
Date: 4 Jul 2008 08:33:52
Message: <486e18b0$1@news.povray.org>
And I kinda promised that if I ever have children... well, there'll be
*another* Jamie in the world. ;-)
> But hey, it sounds
> more than that. ;-)
Meh. There are people I sometimes speak to on teh interwebs. But human
beings that I can actually go hang out with? Now that's a tiny list. :-(
Really? I usually find Amazon to be quite good...
Date: 4 Jul 2008 10:17:28
Message: <op.udrtznssc3xi7v@news.povray.org>
And lo on Fri, 04 Jul 2008 12:01:07 +0100, Jim Henderson
<nos### [at] nospamcom> did spake, saying:
But I charge by the word.
Too many giant spaceships hovering over the cities causing congestion?
Pfft uppity colonials, you don't see us celebrating Consitutional Monarchy
Day.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 4 Jul 2008 11:31:27
Message: <486e424f$1@news.povray.org>
He does, you know...
Date: 4 Jul 2008 12:10:58
Message: <486e4b92@news.povray.org>
Yes, exactly. That, and all the other things you might want to do (like
be behind a NAT) that OpenVPN doesn't handle.
Note that SSL and TLS are both technologically the same thing. The
difference is in provisioning. That is, it's SSL if you start the
protocol dance as soon as you open the port (because you're talking on
port 443 instead of port 80, for example). It's TLS if you open the
connection, do some negotiation, *then* start encrypting, such as with
BEEP or Secure SMTP or anything else that has a "STARTTLS" command.
Date: 4 Jul 2008 13:40:52
Message: <486e60a4$1@news.povray.org>
I thought I saw somewhere that OpenVPN *does* work with NAT, but IPSec
doesn't. (Because NAT involves packet modification, which IPSec is
obviously designed to prevent.)
Date: 4 Jul 2008 13:43:42
Message: <486e614e@news.povray.org>
No, what they said was that if you want IPSec to work with NAT, you had
to exclude the IP addresses from the hash calculation with a
configuration. Since OpenVPN never even offers the opportunity to
include the IP addresses, it's "simpler" and therefore more secure.
Huh?
Date: 5 Jul 2008 12:34:57
Message: <9l8v649hlmisa7v2ul7ruh99jcv6hlpegg@4ax.com>
On Fri, 04 Jul 2008 15:17:37 +0100, "Phil Cook"
>Day.
A bit late but I always celebrate "Good Riddance Day" ;)
Regards
Date: 5 Jul 2008 15:16:44
Message: <486fc89c$1@news.povray.org>
IPSec can work over NATted connections, you just need a router that will
handle it.  The last couple Linksys routers I've had (and the Belkin I
currently own, IIRC) have supported IPSec over NAT.
Jim
Date: 5 Jul 2008 15:19:59
Message: <486fc95f@news.povray.org>
>> But hey, it sounds
Hey, the same goes here.  Offhand, I can think of about 2 people outside
of work that I will just hang out with - and they're my immediate
family.  I'll occasionally have lunch with one of my instructors or
coworkers at lunch.  Very occasionally, I'll get together with the
neighbors across the alley from us, or the ones next door to us.
>>> would set up a facility somewhere in mainland Europe...
>> experience when ordering DVDs from amazon.co.uk as well.
You're not in the US ordering from a.co.uk, though.  When I order from
Amazon US, delivery time is just fine - but from the UK, it takes a while
longer.
Jim
Date: 5 Jul 2008 15:23:16
Message: <486fca24$1@news.povray.org>
Yeah, something like that.
> Monarchy Day.
Heh, well, I know a number of Brits who celebrate having rid themselves
of us, so that's fair. ;-)  As for us, we celebrated by calming cats
during the fireworks - but the fireworks themselves have been very muted
this year out here.
Oh, and I cooked us some *excellent* steaks.  I managed - for the first
time - to cook medium-rare steaks instead of cooking them until they were
charcoal.  You'd be able to see more about it in my LJ.
It's kinda ironic - I'm perfectly happy having some reheated pizza or
canned soup, but I somehow do seem to pull together some pretty good home
cooked food every once in a while - and I enjoy it, which just really
surprises me.
Jim
Date: 5 Jul 2008 15:23:32
Message: <486fca34$1@news.povray.org>
>>Monarchy Day.
See, Phil?  This is what I was just saying. ;-)
Jim
Date: 6 Jul 2008 04:34:44
Message: <487083a4$1@news.povray.org>
> longer.
Heh. My boss gave me some gift vouchers from Amazon.com for Christmas.
So I guess I won't be using them then. :-/
(Just another example of the self-evident fact that Americans typically
don't comprehend that there are parts of the world that aren't America.)
Date: 6 Jul 2008 14:17:21
Message: <48710c31@news.povray.org>
>> while longer.
You can send them to me. ;-)  (Seriously, you can place the order, it
might just take a little longer to get there)
Be careful about generalizations.  There are quite a few of us who do
understand that we're not the entire world.
Jim
Date: 6 Jul 2008 14:42:43
Message: <48711259.4050102@hotmail.com>
>>> while longer.
I have used both the UK and the USA ones and it does work. Presumably if
you order something from .com you get a box with .uk on it anyway. At
least when I order something at .uk I always get packages from .de even
when the item is not listed at .de
I would say everyone that is regular in this NG to begin with.
Date: 6 Jul 2008 16:54:46
Message: <48713116@news.povray.org>
More to the point: apparently I have to sign up for a new, seperate
account. (I can't just reuse my UK one.) FTW?
I did say "typically". I'm sure there are plenty of Americans who know
more geography them me. (Wouldn't be hard, would it?) But unless it's
just the policy of my particular company to only hire stupid people,
most of them seem to interlectually comprehend the fact that the UK
isn't the USA, but on a practical level forget this fact at every
possible juncture.
Date: 7 Jul 2008 05:14:33
Message: <op.udwzv4q6c3xi7v@news.povray.org>
And lo on Sat, 05 Jul 2008 20:23:16 +0100, Jim Henderson
Oh they're no good unless they charcoal briquettes on the outside and raw
on the inside :-)
> canned soup,
The food group of the gods.
> surprises me.
Well I've just got an oven back so I'll be able to return to home-cooked
meals; found that I had to go buy a new wok though.
Phil Cook
Date: 7 Jul 2008 06:04:22
Message: <qdq374dgquqmiol5lvlg7pro9q53s4agur@4ax.com>
On Mon, 07 Jul 2008 10:13:06 +0100, "Phil Cook"
Strange, using a wok in an oven :)
I must admit that home cooked food is just about all I eat. Except for breakfast
and when I have to eat out.
Regards
Date: 7 Jul 2008 06:32:36
Message: <op.udw3hzb2c3xi7v@news.povray.org>
And lo on Mon, 07 Jul 2008 11:04:20 +0100, Stephen <mcavoysAT@aolDOTcom>
did spake, saying:
Does great roast potatoes. Heh no a shiny new hob to match the oven.
> breakfast and when I have to eat out.
Ditto. I'll nuke the odd meal if I know I'm going to be running around or
get a pizza or something in if I'm just feeling lazy (way too many
takeaways around here), but the majority of my meals are home-cooked.
Phil Cook
Date: 7 Jul 2008 06:46:15
Message: <4is374t6qgq124pns1q5mt5uci9h28mfod@4ax.com>
On Mon, 07 Jul 2008 11:31:01 +0100, "Phil Cook"
I take it that you have a metal handle, lucky you.
You should see where I live, two Caribbean take-a-ways, three Chinese, six
Iranian/Iraqi/Persian, one African restaurant and a really good fish and chip
shop. All within ten minutes walk. But to counter that we have lots of
Caribbean, Iranian and Chinese food shops as well. Oh! I forgot about the Indian
restaurants and the English butcher.
Regards
Date: 7 Jul 2008 09:24:00
Message: <op.udxbjo0mc3xi7v@news.povray.org>
And lo on Mon, 07 Jul 2008 11:46:12 +0100, Stephen <mcavoysAT@aolDOTcom>
did spake, saying:
Yep, best way to gauge the heat of the pan.
>> or get a pizza or something in if I'm just feeling lazy (way too many
> six Iranian/Iraqi/Persian, one African restaurant and a really good fish
> and chip shop. All within ten minutes walk. But to counter that we have
> lots of
> the Indian restaurants and the English butcher.
Well we don't have the variety, but four chippies, two Indian restaurants,
three Chinese, and two pizza/kebab houses; plus the Subway and three other
sandwich shops and four independent butchers. Plus the caff, a tea shop
and a cross between a restaurant and a tea room; the cake shop and the
sweet shop. Oh I'm not counting pub food that would be another
three/fourish depending on who you count and how far out you go. Come the
renovations in town they're expecting coffee shops and more tea shops.
Phil Cook
Date: 7 Jul 2008 12:07:03
Message: <cff474ho2sl4s60hdj7pg7nktu8kopreo5@4ax.com>
On Mon, 07 Jul 2008 14:24:50 +0100, "Phil Cook"
It sure is ;)
I work away from home a lot and appreciate home cooking, even my own. I can't
understand why "homely" is not attractive in certain societies ;)
> Come the renovations in town they're expecting coffee shops.
Hmm!
Regards
Date: 7 Jul 2008 12:42:11
Message: <48724763@news.povray.org>
It amazes me how many companies don't understand the idea of identity
management.  I work with a company on course evaluations and I have 3 or
4 different logins for different "roles".  I should go work for them and
show them how to manage the identities - would make it so much easier for
their customers.
>>> typically don't comprehend that there are parts of the world that
>>> aren't America.)
> possible juncture.
Sorry, were you talking? ;-)  (Just kidding)
Well, I don't know where your company's offices are here in the US or how
widespread they are, nor do I know how big your location is in the UK.  I
worked once for a company that was headquartered in Austria - never
actually did have any dealings with people in that office, but we were
run *mostly* independently of the parent, too.  I think in the 3 years I
worked there, my boss made 2 trips to Austria and Germany.  I never knew
anything about their infrastructure at all, other than that they had an
AS/400 of some sort.
Jim
Date: 7 Jul 2008 12:42:37
Message: <4872477d$1@news.povray.org>
Yep.  :-)
Jim
Date: 7 Jul 2008 12:43:29
Message: <487247b1$1@news.povray.org>
>> were charcoal.  You'd be able to see more about it in my LJ.
> raw on the inside :-)
LOL, not quite to my taste, but a good sear is hard to beat, I'll agree
with that.
>> canned soup,
LOL
>> but I somehow do seem to pull together some pretty good home cooked
>> surprises me.
I was thinking some stir-fry veg would have been good with the steaks.
Jim
Date: 7 Jul 2008 12:44:39
Message: <487247f7$1@news.povray.org>
Best?  Maybe most effective, but I can think of better ways than having
to put burn gel on your hand...
Jim
Date: 7 Jul 2008 12:48:16
Message: <487248d0$1@news.povray.org>
> Jim
Before you put oil in the pan, a quick touch of the surface will tell
you if it's hot enough. Don't do it after you put oil in the pan,
though.. that'll land you squarely in the burn ward.
Date: 7 Jul 2008 13:00:30
Message: <48724bae$1@news.povray.org>
>> Jim
An IR thermometer will also tell you if it's hot enough or not - and
won't even singe your fingers. :-)
Jim
