OK, so I realise that nobody else is going to be nearly as excited about
this as I am, but... after about an hour of PostScript coding, I was
able to construct a nomogram that correctly expresses the relationship
"X+Y=Z".
That is, pick any pair of variables, pick values for these, draw a
straight line such that it passes through the values you picked on the
appropriate axies, and the point where it passes through the third axis
indicates the correct value for the third variable.
That was *so* worth it, eh? ;-)
Most of the hour was spent tracking down glitches in my PostScript
coding (e.g., making a loop count from 100 to 1 in steps of +1), and
tweaking the asthetics of the page (I know, I'm fussy).
http://blog.orphi.me.uk/
Download 'nomogram-linear1.pdf' (4 KB)
On Sat, 28 Jun 2008 17:07:53 +0100, Orchid XP v8 <voi### [at] dev null>
>"X+Y=Z".
Nice and clean. Now one for multiplication.
Regards
I don't get it.
My dear boy, do you have *any idea* how awkward it is to draw a
logarithmic scale so all the numbers are readable?
At the bottom of the scale, the distance from 1 to 2 is big enough to
fit a parking lot in. But higher up, the distance between (say) 9 and 10
is so tiny you can bearly fit the numbers on without them overlapping.
It's really frustratingly tricky to pick an arrangement of labels and
tick marks that looks "nice and clean".
Warp wrote:
> I don't get it.
You're not missing much...
This nomogram serves no real useful purpose beyond demonstrating that I
managed to make a working nomogram.
On Sat, 28 Jun 2008 18:34:57 +0100, Orchid XP v8 <voi### [at] dev null>
Isn't that what computers are for? Anyway Napier managed to do it by
hand. Have a look at a slide rule.
http://web.mat.bham.ac.uk/C.J.Sangwin/Sliderules/mannheim.pdf
http://web.mat.bham.ac.uk/C.J.Sangwin/Sliderules/fullrule.pdf
Also see
http://web.mat.bham.ac.uk/C.J.Sangwin/Sliderules/nonlogrule.pdf
Regards
Here ya go...
Could possibly start marking off 1/20ths near the bottom of each octave
- but the tick marks would have to be increadibly narrow. Doesn't seem
worth it. I already had to make the major marks wider to make the
distinction between the 3 different levels of ticks clearer. I've spent
ages tinkering with this thing!
Download 'nomogram-log1.pdf' (6 KB)
On Sat, 28 Jun 2008 19:07:56 +0100, Orchid XP v8 <voi### [at] dev null>
wrote:
>Here ya go...
Well done and fast too, I'm impressed.
Regards
Heh. The linear one was posted at a little after 5, the logarithmic a
little before 7. So only, oh, 2 *hours* to get it right. :-S
Anyway, does it look classy enough yet? ;-)
Orchid XP v8 <voi### [at] dev null> wrote:
> Warp wrote:
> > I don't get it.
What I don't get is why you posted it here, really. Is it something
interesting, amusing, informative or in some way special? What's the
purpose of posting it? Is there anything there anyone can get something
from? I just don't understand.
On Sat, 28 Jun 2008 19:44:51 +0100, Orchid XP v8 <voi### [at] dev null>
Yes
Regards
Why do people post their POV-Ray renderings?
Because they might amuse somebody...
Wondering how long that animation is going to take to complete?
Don't wonder any more! Look at my shiny nomogram! :-D
Mark the number of frames to be rendered on the right-hand scale. Mark
approximately how many seconds each frame takes to render on the
left-hand scale. Draw a straight line through both these points. The
place where this line crosses the middle scale tells you how long your
render will take. I even did all the hard work of converting between
seconds, minutes, hours and, yes, days - because we all know renders
*do* take days!
In case you missed it: I am *seriously* pleased with myself right now.
Most especially, I spent _literally_ hours fidgetting and fussing over
the tick marks on the scale. The right-hand scale just goes up in units
of 10 (with only integers marked), but the other two scales are times,
and times go up in multiples of 60 and 24 - which don't have a
particularly simple ratio. I spent ages and ages seeing how tight the
tick marks can be to still fit the labels, changing the tick widths to
try to make the scales as unambiguous as possible, and generally trying
to make it look pretty. I think I'm quite happy with the result...
Oh, and by the way... I'm doing a series of renders with 250 frames
each. So at 5 seconds/frame, it takes about 20 minutes, if the render
time rises to a mere 15 seconds/frame, it will take an entire hour to
complete, and by the time you exceed 30 seconds/frame, you're talking
about multiple hours.
The really nice thing is that I can also read it backwards and see that
if I leave my PC running for a 10 your day, each frame must take less
than 2 minutes if the entire render is to be finished by the time I get
home.
Note that the Electric Sheep system seems to spend about 15 minutes *per
frame*. That means that a 140-frame "sheep" constitutes about 1.5 *days*
of computer time. Eeeps!
Download 'nomogram-rendertime2.pdf' (11 KB)
>> Warp wrote:
>>> I don't get it.
It informs us that he is still programming in postscript. That is in a
sense amusing in itself I would say. Many people may not have heard of
nomograms or at least not recently, so it points to an interesting
concept for some of us. You may doubt the value of nomograms in the age
of computers and you are probably right in doing so, but most of the
things here have not much intrinsic value apart from amusement of the
maker and those that see or read it. I grant that it may have been
better at postscript.off-topic but p.o-t is good enough.
> What's the purpose of posting it?
And don't forget the value of the showing off of unusual and cruel skills.
BTW did you realise the recursive value of your post? ;)
Maybe because this is a POV-Ray news server, and people who visit this
server usually are interested in POV-Ray renderings?
I just can't understand what's so amusing about a PDF file which contains
some simple numbers and lines.
Imagine I made a post like this here:
Hey, I just wrote a C program which prints numbers from 1 to 100, with
10 numbers at each line:
#include <stdio.h>
int main(void)
int i;
for(i = 1; i <= 100; ++i)
printf("%i ", i);
if(i % 10 == 0) printf("\n");
return 0;
Ok, so? Why would that be of any interest to anybody? Why would I want
to make such a post? I just don't get it.
Lay off him Warp, and I for one find these things interesting, not
amusing. I've got a small collection of slide rules that I think are
intrinsically beautiful. So just looking at the marks on the paper is
intellectually satisfying, to me. I had forgotten about nomograms
until Andrew posted. I'm glad that he reminded me.
You really don't understand what "information" is at a conceptual
level, do you?
Also this is off topic and it would be a pretty boring party if
everyone talked about the same thing. If Andrew's posts annoy you just
blacklist him then you won't be irritated by his musings. Your tirades
against him are beginning (?) to sound like bullying.
Regards
Seconded.
OMG I've just posted a "Me too" ;-)
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Why are there only extremes? Everywhere there are and can only be
extremes. Someone must either like 100% of everything someone else does,
or he has to hate 100% of it. There are no other possibilities.
(And, of course, the first law of the internet: Everything must be
interpreted in the wost possible way. Always.)
What are you talking about, what extremes? Putting someone on a
blacklist in a newsgroup only means, you won't see his posts not that
he won't be able to post.
Unless you are talking about your own feelings.
That is less true here than on other sites IMO. The vast majority of
posters here are good natured and fair, again IMO.
Regards
I wasn't implying anything else. Read again.
You weren't implying anything else than what?
What is extreme about setting up your newsreader so that you don't see
a person's posts, if that is what you meant? Although I'll tell you
what I think is extreme and that is, beating someone around the head,
metaphorically speaking, until he stops posting content you personally
don't like. If you don't like it then don't read it.
Regards
I wasn't implying that blacklisting someone would affect anyone else
than what I see.
What I was implying is that blacklisting someone means that I detest
everything he writes and don't want to see anything of it. Obviously
this is not the case. Far from it. Blacklisting someone is a rather
radical measure.
It might not be extreme to you, but I find it a rather extreme.
His posts are, in general, enjoyable and I have no reason to censor
them from myself. Such censorship would make absolutely no sense.
It would, indeed, be rather extreme and irrational.
Again, you are implying some kind of extreme. Exactly where did I say,
imply or hint in any way that I didn't *like* the post which started this
thread? The only thing did was to say I didn't understand it, nor the
motivations behind making the post. Sure, many could (and will) interpret
that as an impolite harsh criticism (and "bullying"), but people will
always interpret everything in the worst possible way.
>than what I see.
>radical measure.
Well I've never done it myself tho' I've been close to it on occasion.
see
It is not the impression I got but since you say so I believe you.
My opinion is that his motivation is his own business and I will sift
the dross (sorry Andrew) to find the gems. I just ignore all the
Haskell stuff the same way I, most of the time ignore you and Darren,
when you go on about C and C++ etc. It is of little interest to me as
I can't program for toffee :) But it is of interest to a lot of
people.
It does come across to me that you are down on him more than is good
for both of you. And you are wrong if you think people will always
interpret everything in the worst possible way. At least on this
newsgroup at this period of time.
Regards
> #include <stdio.h>
> int main(void)
> int i;
> printf("%i ", i);
> return 0;
It's kinda funny. Usually I open 'offtopic' and my eyes glaze over at
the usual avalanche of postings by Orchid on topics I can't relate to.
This nomogram thing is one of the few things that Orchid has posted that
I *do* find I can relate to! Maybe because it actually results in
something visual.
Meanwhile, I enjoy reading your posts, Warp, and one of the things you
did that *most* interested me, for all time, was a comparative series of
simple sort algorithms expressed in SDL.
> something visual.
If he had made a postscript which creates something like this, I would
have been truely impressed... :P
http://upload.wikimedia.org/wikipedia/commons/7/76/Visual_Smith_Chart.png
That was a *really* long time ago. The memories...
Well, this is how I found out what "nomogram" actually *is*. ;-)
Now, if I actually understood for a second what the hell this nomogram
is supposed to compute... maybe I could repeat it. :-P
>> something visual.
The whole discussion reminds of perhaps the only remotely useful
postcript program I have written, to draw the parts of an Astrolabe. I
really ought to finish that project in fact, so far I have done it on
paper and cardboard, but I'd really like to build one in plywood...
Even had fun putting in transformations that leave a very funny looking,
but still theoretically working astrolabe, as attached :-) (this is just
one of the most visible parts, of course).
Thing is, I'm not sure I'd understand how that program works, 3 years
later :-D
Anyway, is that kind of thing called a nomogram as well?
Vincent
Download 'astropart.png' (62 KB)
Preview of image 'astropart.png'
Apparently not just the internet.
A wide body of psychological research shows that on any number of
hot-button issues, people seem hard-wired to believe the worst about
those who disagree with them. ... said Glenn D. Reeder, a social
psychologist at Illinois State University ... "We find it difficult to
grant that other people come to their conclusions in good faith if they
reach a conclusion that is different than ours." ...
http://www.washingtonpost.com/wp-dyn/content/article/2007/03/11/AR2007031101439.html
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
On Sun, 29 Jun 2008 21:02:19 -0700, Darren New <dne### [at] san rr com>
I think that behaviour is probably more prevalent on the internet
because people hide behind the anonymity of their handles (is that
term still used?) and don't feel threatened by RL peer pressure.
I think modern life is making this a bit worse :(
Regards
Spoken like a true oldie!
John (a callow youth)
On Mon, 30 Jun 2008 09:28:04 +0100, Doctor John <doc### [at] gmail com>
Yes, I'm beginning to sound like my grandparents :)
BTW did you catch your mice?
Nay, a sweet faced youth :)
The Comedy of Errors, Act 5, Scene 1
Regards
Yup! No problemo!
The idiot walked straight into my trap. Prosecution to follow unless the
BoD chicken out
Details at 11
John
I thought it was pretty lame of you to make fun of Andrew by posting a small
C program in comparison.
Whether it's your intention or not, your posts certainly seem to be trying
to discourage him to make such postings, which is a shame. Just because you
may already know everything about nomograms and postscript coding, don't
make fun of other people who are just learning and sharing their
experiences.
I was thinking, "Why would Andrew be getting a mammogram?" then I reread the title.
That would perhaps be more interesting, though. ;-)
> #include <stdio.h>
> int main(void)
> int i;
> printf("%i ", i);
> return 0;
Ohh, wow! That is just sooo cool. and the use of the modulus operator!
Brillant!
:D
OK, a bit more serious now. I don't quite understand why they're
interesting either, but he felt compelled to share what he did because
someone else might be interested in it. Andrew has a profound interest
in mathematics, and perhaps here's something deeper to these nomograms
that I don't get.
*walks away slowly*
I still fail to see the relevant difference.
> experiences.
No, I don't know anything about nomograms and little about postscript,
but the post seemed so trivial that I asked why it should be of any
interest. Is there something there I'm not seeing?
Mike Raiford <mra### [at] hotmail com> wrote:
> Andrew has a profound interest in mathematics
Which is precisely why I didn't understand his post.
I'm profoundly interested in programming, but that doesn't mean I would
post every single little piece of trivial software I make. If I come up
with something *really* ingenuous then I might be compelled to share it
with the few others here who might be interested in clever programming
tricks.
Thus maybe I just missed something in his post. That's what I asked.
Drawing some lines and a few numbers on a sheet of paper *looks* pretty
easy. However, you try making it so that when you draw the lines, you
actually get the *right* answer.
This is more difficult than it sounds...
Sure, the result might just be a few numbers on a page, but it took me
ages to get it to produce the correct answers. (Do you know the
mathematical properties of similar triangles? I had to look them up...)
Great, so you're publically calling someones work so trivial it shouldn't
have been posted, and asking if there is any "more" to it that would make it
interesting to you (which in itself is considered pretty rude when the OP
has explained pretty clearly what it's about), and all this when you confess
to knowing little about the subjects involved!
> have been posted
Where exactly?
Yes, always interpret everything in the worst possible way.
So let me get this straight: I don't know much about the subject, and
thus I ask for reasons for the subject to be interesting, and this, in
your opinion, is wrong and rude.
Yeah, sure. Whatever you can come up with that will make things look
worse.
>> have been posted
> Where exactly?
> worse.
It's the language barrier, Warp.
Backhanded complements and snide remarks are an art form in English, and
exploited throughout drama and comedies. While you were just asking
'What makes this interesting?' it comes across as though you are
suggesting that the math and lines are 'too simple to actually be
interesting or useful.'
I wouldn't ask about a Rube Goldberg machine, 'So, what does it actually
do?' because the tone suggest that I find it useless for 'just' breaking
an egg.
>> have been posted
> Where exactly?
"What I don't get is why you posted it here, really."
> worse.
Keep digging!
> >> have been posted
> > Where exactly?
You are reading more than there is in my text.
> > worse.
> Keep digging!
Was that a note to self or something?
OK I'll give you the benefit of the doubt, and explain to you that in
English it is considered rude to give the *impression* of pretending
ignorance to undermine someone elses work. Even if you really are ignorant,
don't write something that others may take as you pretending to be
ignorant - because you'll be labelled as rude and offensive. If you are a
clever person, you need to be even more aware of this, as people will often
think you are pretending not to understand if you say so.
In this case Andrew clearly stated exactly what he had done and posted his
results. People who read this ng regularly will have guessed that you
probably understood exactly what Andrew had done, yet you seemingly
pretended you "didn't get it" and asked "what else is there that i didn't
get". That's rude, when there obviously isn't any more to it.
Another example, if you are seeing someone give a bad presentation, you
don't then ask at the end "please send me the final version when you've
finished it". Or at a dinner party, you don't say after a small main course
"great starter, what's the main?". I'm sure you can think of more examples,
maybe it's acceptable in Finnish?
You just made an excellent essay on the first rule of the internet:
If something can be interpreted more than one way, someone will interpret
it in the worst possible way.
Basically the rationale is: "He wrote something which I feel can be
considered rude, ergo he was being deliberately rude, ergo I should
get angry with him for being deliberately rude."
This alternative rationale is completely out of question: "He wrote
something which could be interpreted as rude, but maybe he didn't mean it
that way."
While both interpretations are possible, the principle of maximization
of indignation requires for the worst possible interpretation to be chosen.
Whatever.
One other point that need to be taken into consideration is that this
is an ongoing thing. You, yourself, said that you must stop baiting
Andrew and you did.
I thought that the first rule of the internet was not to explicitly
trust people who you don't know.
Regards
