"Hey Andrew, those harddrives that are left over there, can you arrange
for somebody to come and take them away? I mean, we can't just leave
them there. Even if they're been erased, you can still get the data off
them if you want to."
Uh... like, WTF?
I mean, sure, if you take the drive apart and crawl over it with a
microscope, you can recover data. But who the **** is going to bother?
It's not like you could recover any particularly valuable data.
(Personally, I think my boss honestly believes that you can take an
erased harddrive and just plug it in and type "undelete" and all the
data will come back. It doesn't work like that...)
http://blog.orphi.me.uk/
"Invisible" <voi### [at] dev null> wrote in message
news:4863b9a3@news.povray.org...
Um, actually...
http://www.pcworld.com/article/id,108831-page,1/article.html
http://www.guard-privacy-and-online-security.com/how-clean-off-the-hard-driv
e.html
Your boss is right. It may not be as easy as 'undelete' but the data's there
and it doesn't take a microscope to find it, and it could be worth a lot of
money.
Gail Shaw wrote:
> Um, actually...
A study found that some people selling drives hadn't even bothered to
erase them at all. Pressing the "delete" button doesn't erase the file.
This isn't news.
> e.html
This doesn't look terribly convincing to me.
> money.
Right. Well I'll tell you what, you show me an actual technique that
allows you to recover data from a harddrive after every individual block
has been written with zeros, without the use of a microscope. ;-)
Depends how erased it is, of course. Your boss might not know that you
know how to erase a drive correctly. :)
Helpful housekeeping hints:
Check your feather pillows for holes
before putting them in the washing machine.
> money.
It depends how you erased the drive. If you just formatted it, no, the
data's all still there. If you actually overwrote it, it takes special
electronics to retrieve it if you can at all.
If you're the DoD, and large numbers of people die when a foreign
government spends several millions of dollars to recover the data from
the disk, yes, 21 passes is probably good. That, or scrubbing the drive
with a belt sander or wire brush and then soaking it in acid until it
dissolves.
If shredding is good enough for your paper records (vs shred,
incinerate, stir, then dissolve in acid) then the IFIPS standard is
probably good enough for your hard drives.
If you're using Windows, simply running
cipher /w:p:
will overwrite all the spaces on drive p: that don't hold files, first
with zeros, then with ones, then with random patterns. You can do this
while the machine is in use. Of course, if you format P: and then do it,
it'll wipe pretty much everything except (potentially) old file names.
"Gail Shaw" <initialsurname@sentech sa dot com> wrote:
> Um, actually...
> e.html
> money.
This has always bothered me. Something does not hang right.
Could one just copy a couple of version of a linux distro (0.6 to 4 GB) on top
of it? Would THAT be enough to completely obfuscate what was originally on the
disk? If not, then why hasn't anyone yet made a commercial use of the ability
of HDD's to remember everything that has ever been on them?
news:4863bd87@news.povray.org...
Show me where in your original message you said anything about having done a
proper purge of the drive.
"gregjohn" <pte### [at] yahoo com> wrote in message
news:web.4863c87ab122afc76cf3d0b10@news.povray.org...
top
on the
ability
Copying files over won't guarenteed overwrite ever single sector of the
drive
I gave him more credit than to complain about it without having actually
erased the drive. :-)
"Even if they've been erased, you can still get data off them."
Now, if I'd just done something like
delete C:\*.*
then my boss would have a point. With the right tools, it wouldn't be
too hard to get the files back.
What I actually did was
dd if=/dev/zero of=/dev/sda
[Note that that's "sda", not "sda1", meaning the partition table and MBR
are gone too.]
Using random data would be slightly more secure, but we have already
reached the point where drive disassembly [and extremely expensive
specialist equipment] is required. Given the sensitivity of the data
involved... further effort seems overkill.
My boss might not know that there's more than one way to "erase" a drive.
OOC... how much does it cost to recover data from a drive that has had
zeros written to every single byte on the drive? Any estimates?
"Darren New" <dne### [at] san rr com> wrote in message
news:4863d6fc$1@news.povray.org...
Maybe I'm too used to idiots. If someone says they've erased a file, I
assume that was just a delete until informed otherwise
"Orchid XP v8" <voi### [at] dev null> wrote in message
news:4863d8d1$1@news.povray.org...
LOTS. Even recovering from logical failure is Expensive.
I investigated drive recovery after a damaged partition table and a defrag
shuffles sectors of one partition over a second parition. Even to recover 2
directories was far more than I could afford
I'm told if you take the drive apart, you can take advantage of slight
tracking errors in the read/write heads that allows traces of old
signals to remain present at the margins of each track. However, this is
NOT a cheap operations AFAIK. (!!) It requires clean-room conditions,
sophisticated magnetic scanning microscopes, detailed knowledge of HD
construction, etc.
> dissolves.
...or just incinerate the platters? (Heat tends to disrupt magnetic
domains rather efficiently - as does the platters being reduced to
molten glass and deformed beyond recognition!)
Anyway, hypothetically supposing somebody magically recovered every
single file from these drives, they would get... the names of the drugs
we were working on 5 years ago, and possibly some analytical results
data. Which won't mean a damned thing, because they won't know what
"sample 39" actually *is*.
It's more the fact that the drives had licenced software on them that
other people shouldn't have...
Mmm... better to be pleasently surprised than horribly dissapointed? ;-)
> LOTS.
I thought so.
Presumably it's something you only bother doing if the data is worth
more than the cost of recovery...?
Ouch.
I always thought this kind of service was only of use to intelligence
agencies and people with poor backup procedures. ;-)
Yes. That's why the DoD doesn't actually erase disks that contain
*really* sensitive information. Unless you consider a grinding stone
"erasing".
> ....or just incinerate the platters? (Heat tends to disrupt magnetic
No, I believe the actual rule is "grind off the surface, then dissolve
the platters."
Right. Simple overwriting is enough. Like all security, the point is to
make it more expensive to recover the data than the data is worth.
news:4863dac5$1@news.povray.org...
Yup.
news:4863db04$1@news.povray.org...
Well, seeing as I lost data in the process, I guess that you'd put me in
category 2?
In limited defence, I had a fairly complete backup (DVD) a few months old
and a partial backup a week or so old (flash drive). I only lost a few
things. Most were recreatable.
> category 2?
Fact: When I was at uni, every single time assignment hand-in date came
around, you would not *believe* how many 3.5" disks went faulty! ;-)
What amused me was the scene that unfolded the other day...
Jane: Hey Andrew, you know that safe you used to use to hold the backup
tapes? You don't need that any more, do you?
Me: ...er, YES.
Jane: Oh. Really??
Me: Um, yes.
Jane: ...Oh. What, even in the new building?
Me: Er, yes.
Jane: Oh. Don't you use DVDs or something now?
Me: ...?
Jane: So I can't have that safe then?
Me: Er, no.
Jane: Oh, OK. Well anyway, it's been moved to the lab now.
Me: ...right, OK. That's a procedure violation then.
Jane: OK. Bye...
Fact: Capacity of a DVD = 4 GB. Capacity of a single DDS-4 tape = 20 GB
= 5 DVDs. Capacity of a single LTO1 tape = 100 GB = 25 DVDs. Transfer
speed of a DVD = 1.35 MB/sec. LTO1 = 15 MB/sec. Why in the name of God
would we use DVDs?!
news:4863f9fb@news.povray.org...
> > category 2?
old
We had a simple solution to that problem. Faulty disk = 0%. Suddenly the
disks got more reliable. Must have been a faulty batch.
Even more interesting: At hand-in time, there was *always* at least one
laser printer that was faulty.
[This was almost always traced back to some DILBERT putting the wrong
kind of transparency into it. Do NOT do this!!]
>> Um, actually...
>> e.html
>> money.
Because to go back through the information that used to be on the drive
takes advantage of the flaws in the drive it self. The read/write head
goes over the drive and writes a pattern, let's say 1111 overtop of what
used to be 0101. While the drive it sending out digital data, the
magnetic pattern on the disk doesn't exist in just a 0 or 1 state.
Think of it as just a bar refrigerator magnet, facing up/down | is one,
sideways - is 0. but the bar could be oriented like / or \. Given that
those don't appear to be past 45 degrees off vertical, I'd guess they
would both read like 1 instead of 0. Now, you have a visual of a
collection of bar magnets that aren't lined up perfectly. To write them
all to 1s, you would just rotate each one to a more vertical position.
Knowing the strength of the write head's magnet, you could guess how
much that change would be. So, you read the drive head in a less digital
and more analogue manner, and then remove the affect of the last write
phase. The more accurate the initial reading and the knowledge of the
write magnet's properties, the better you can guess past that first phase.
The drive it self just doesn't work that way. After a point, it's a
statistical guess as to how accurate the data you get back is. But some
people are willing to spend a lot of money on just a guess for certain data.
Imagine the date approaching for 300 of us to hand in our 4th year project
reports. Most reports were around 100 pages, and we needed to hand in two
copies. At the Engineering department we had 2 or 3 laser printers that
were *free* to use (as opposed to college computer rooms where you had to
pay). You can imagine the total carnage that happened the days before, I'm
sure they got in an extra pallet of A4 paper for that week.
I can think of several ways you could "erase" the data on a hard drive:
1. Delete all the files. (E.g., delete C:\*.*)
2. Format every partition with, say, NTFS.
3. Delete all partitions.
4. Low-level format the drive (using, e.g., Maxtor PowerMax).
5. Write zeros to every byte. (E.g., dd if=/dev/zero of=/dev/sda)
6. Write random data to every byte. (...of=/dev/urandom)
7. Physically disassemble the drive, seperate the platters, magnetise
them, scratch them, smash them to pieces, and melt the pieces in a vat
of heated acid.
As I understand it, option #1 is fairly easy to reverse. (Especially if
you just delete all the files and then throw away the disk. All file
data is guaranteed to still be there, you just have to find it somehow.)
Option #2 destroys some of the filesystem metadata, but AFAIK the blocks
holding file data will still be intact. (Formatting with, say, ext2
takes a tiny fraction of the time that FAT or NTFS formatting takes, so
I'm assuming that NTFS overwrites more data. But I don't *think* it
overwrites everything.)
Option #3 should be pretty simple to reverse, AFAIK.
I am unsure as to whether #4 and #5 are different in any way. Both seem
to take the same amount of time...
As far as I know, both option #5 and option #6 make it impossible to
read any useful data from the drive just by plugging it in and asking
the drive electronics to read the data off the disk surface. In either
case, you would have to physically dismantle the drive and crawl over it
with a microscope - which is damned expensive. Using random data (and
multiple passes of it) reputedly makes this process harder - but not
impossible. Non-sequential writes are supposed to make it harder still.
As far as I can tell, option #7 gives 100% guaranteed data destruction.
But I don't have any star-drive screwdrivers. :-P [Or heated acid -
unless you count my stomach. And I am *not* putting shards of shattered
glass in there!]
PGP shredder it is free
Regards
I wonder if you actually asked many non-geeks, what they would say if you
asked them how they would go about erasing all their data from their
computer? I guess if you try to select-all and delete the contents of drive
C from within windows it's going to get stuck at some point.
Oh, I thought that "format" really went over every byte of the partition and
wrote to it? IIRC there is a "quick format" option, which I assumed just
did the headers and stuff to make it look like it was formatted.
> I am unsure as to whether #4 and #5 are different in any way. Both seem to
I think that writing zeros to the disk would make it easier to recover the
data, but that's just a guess.
> But I don't have any star-drive screwdrivers. :-P [Or heated acid - unless
> you count my stomach. And I am *not* putting shards of shattered glass in
> there!]
Just chuck it on a hot fire. Saw it in half first if you want things to go
quicker.
> you asked them how they would go about erasing all their data from their
> drive C from within windows it's going to get stuck at some point.
If you just want to delete "your" files, you can certainly do this. If
you want to delete the OS, you'll definitely have to do it while running
under something else. (Obviously.) I have an external USB enclosure for
this exact purpose. It's shiny. The company paid for it. :-D
>> blocks holding file data will still be intact.
> and wrote to it? IIRC there is a "quick format" option, which I assumed
> just did the headers and stuff to make it look like it was formatted.
Formatting a drive with ext2 just rewrites the inode tables. (Or...
something like that.) Doesn't touch most of the disk surface, and
typically takes about 20 seconds for a large partition.
A "normal" format with FAT or NTFS seems to touch more of the disk
surface, but I'm not 100% sure whether it rewrites every single block,
or just the first block in each cluster. The "quick format" option just
rewrites the file allocation table, AFAIK. (That's why it takes seconds.)
>> seem to take the same amount of time...
> the data, but that's just a guess.
Writing random data is theoretically best. But in either case, once data
has been overwritten, the drive electronics can't read it back. You're
into microscope territory. The question is whether a low-level format
actually overwrites everything or not.
> go quicker.
Have you ever *tried* to make a hot fire?
It's way harder than it sounds...
1. Is it still free? IIRC they changed the licence a while back.
2. Can it erase an entire drive? I know it could do individual files,
one at a time, and I think there was a free space wipe too. But a whole
drive?
Better yet, didn't PGP used to offer a whole-drive encryption option? If
you keep your entire drive encrypted, all you need to do is delete the
encryption key. ;-)
Hot enough to melt aluminium or glass - no problem.
Shredding is free so is encrypting files and IM
>drive?
Yes it can but not with the free version, I think. I'm not going to
try it on my own HD :)
>encryption key. ;-)
True
Regards
It does IM now?
Heh, I used to like PGP. Before it became all commercial and
closed-source and expensive and stuff...
I've experimented with GPG, but that only encrypts files. It doesn't
offer any other functionality. Oh well! I don't have any sensitive data
anyway, what do I need cryptography for?
>> drive?
You could see if the button's there or not. :-P
Heh. I had enough trouble trying to burn through a tree stump!
Now if I had *thermite*... >:-D
"Invisible" <voi### [at] dev null> a écrit dans le message de news:
4864acb4$1@news.povray.org...
good quality coke (not the drink), good air-flow, in one word : a forge
fire
Marc
Most people in my street make fires daily in the winter that are hot enough
to burn tree stumps. You just need to start off with some paper, then thin
bits of dry wood, then bigger bits of wood, until it gets hot enough to put
on whole pieces of tree.
And how do you plan to ignite the thermite?
> enough to burn tree stumps. You just need to start off with some paper,
> then thin bits of dry wood, then bigger bits of wood, until it gets hot
> enough to put on whole pieces of tree.
I wouldn't mind, but this way in the middle of a hot summer drought. The
wood was dry as hell, the sun is beating down on us, and yet the fire
keeps going out...
We never did get it to turn in the end. Burned a whole heap of paper and
cardboard, but the tree never got more than mildly scorched.
By remote control from a distance of more than 3 km?
On Fri, 27 Jun 2008 10:52:03 +0100, Invisible <voi### [at] dev null> wrote:
>It does IM now?
It says it does AIM, AOL IM
Me too but Dr John said that he would not drink with someone who did
not have it on their HD :)
As Dr John ;)
>>> drive?
OK there is a button but you need a licence :(
Regards
Not true! I said i wouldn't _buy_ a drink for someone etc.
> As Dr John ;)
GPG shreds files on all my machines. It can also encrypt a whole
filesystem. What else do you need?
>>>> drive?
So install Linux :-) and use GPG
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
On Fri, 27 Jun 2008 11:42:20 +0100, Doctor John <doc### [at] gmail com>
That's true
Regards
That you give me no Soooooul,
I hear you call-innng.
Oh baby pleeeease,
give a little respeeect,
toooooououo meeeeee.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Looks like you needed some smaller bits of wood first, don't expect to light
a tree with cardboard and paper.
If you had that sort of kit, you'd probably find easier ways to destroy a
mere hard drive.
> Oh baby pleeeease,
...who let HIM out?!? o_O
*facepalms*
Damn it Phil, it's too early on a Friday!! >_<
And lo on Fri, 27 Jun 2008 12:03:36 +0100, Invisible <voi### [at] dev null> did
spake, saying:
>> Oh baby pleeeease,
You wound me little one, you wound me to the quick :-P
The annoying thing is that this reminded me that I was going to look up a
song I heard last night and both this and hearing Living on the Ceiling by
Blancmange just on the radio has wiped it; damn now I'm stuck with the
image of people treadmill dancing.
Phil Cook
m_a_r_c wrote:
> good quality coke
Snort! :-D
John
No you don't, the cover of right wood (what's koivu in English?) is
usually a lot easier to use than paper (it starts to burn as easily, but
it burns with higher temperature). Or...
...if you have thin enough bits of really dry wood, just use them.
They'll ignite pretty nicely and have warm enough flame to ignite
another bits of dry wood.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
get one of these:
http://www.youtube.com/watch?v=sQYPCPB1g3o
This is sad:
http://www.youtube.com/watch?v=uQs5hchKCAM
Maybe you misunderstood, I start with paper just because it's easy to ignite
with a match (plus it saves filling up the paper bin!). I make a nice
stack, starting with paper and cardboard at the bottom, then gradually
bigger and bigger bits of wood on the stack. Then all I need to do is
ignite the paper at the bottom with a match for 2 seconds, and 5 minutes
later the whole lot is always burning very well.
> ignite with a match (plus it saves filling up the paper bin!). I make a
> nice stack, starting with paper and cardboard at the bottom, then
> gradually bigger and bigger bits of wood on the stack. Then all I need
> to do is ignite the paper at the bottom with a match for 2 seconds, and
> 5 minutes later the whole lot is always burning very well.
Ah yes, I missed the one-pile -idea, but basically all the other
arguments stay the same - certain trees have a cover that's better
igniter than paper and really dry and thin bits of wood have no problem
there either.
The point of filling paper bin is naturally true ;).
Eero "Aero" Ahonen
http://www.zbxt.net
Kyle wrote:
> get one of these:
I could identify at least 2 (IBM?) server discs (SCA sleds), 1 Deathstar
and 1 Fireball. I also think I saw a second fireball going in, but due
to crappy image I can't be sure.
Note to self: never try to put your hand in there.
> This is sad:
Yes :(.
Eero "Aero" Ahonen
http://www.zbxt.net
