POV-Ray : Newsgroups : povray.off-topic : Have a laugh Server Time
19 Oct 2026 18:21:12 EDT (-0400)
  Have a laugh (Message 1 to 50 of 51)
Goto Latest 50 Messages Next 1 Messages >>>
Subject: Have a laugh
Date: 20 Jun 2008 05:47:34
Message: <485b7cb6$1@news.povray.org>
OK, picture the scene:
I walk down the corridore to my office, open the door... and the handle
snaps off in my hand.
Yes, you heard me correctly. The handle on the door of my office fell off.
Here's the rub: My door never used to shut properly. The latch didn't
drop into the slot in the door frame, so you could actually open the
door without turning the handle.
But they fixed that on Tuesday. So now you actually need to turn the
handle or the door won't open. (I mean, you turn the handle
instinctively anyway. But now it's mandatory.) The net result is that,
thanks to the builders fixing my door, I am now locked out of my office.
Stop and think about that for a moment: I'm locked out of my office. I
have nowhere to sit. No PC to use. Can't get at any of my paperwork,
tools or spare parts. I'm homeless.
So I wandered into the tearoom. At was at this point I realised I can't
actually have a cup of tea either - my cup is... in my office. (As is my
coat, although technically I'm unlikely to have need of that today.)
Everybody else seemed to think this state of affairs was both utterly
unbelievable and extremely amusing. I was less amused. (!!)
Anyway, by pure fluke, it turns out there is in fact a solution. I have
a key that opens the locked server room door. In the process of doing
this, I discovered that if you turn the key the wrong way, instead of
locking the door, it lifts the latch. And apparently my key is a "master
key" that opens several other doors as well. (Doesn't that mean all the
locks are identical??)
Once I figured out that the lock on *my* door rotates in reverse
direction [because the door opens the opposite way - WTF?], I was able
to get back inside. I wasn't going to bother with a cup of tea, but I
felt I needed it!
And now I've drunk the tea, a thought occurs to me: I am now sitting
inside my office, with a door that nobody except me can open. (Because
only I and two managers have any actual door keys.) So... basically
nobody can come into my office to pester me. I'm locked in, and nobody
can bother me! :-D :-D
Let the surfing begin!!!
http://blog.orphi.me.uk/
Subject: Re: Have a laugh
Date: 20 Jun 2008 06:05:12
Message: <u40n54h70dbant2gss9lb23t3ndemrsof1@4ax.com>
On Fri, 20 Jun 2008 10:47:34 +0100, Invisible <voi### [at] devnull> wrote:
>I am now sitting
So you are not operating "an open door policy" today? :)
Regards
Date: 20 Jun 2008 06:21:43
Message: <485b84b7@news.povray.org>
  No. Why would you think that?
Date: 20 Jun 2008 06:31:22
Message: <485b86fa$1@news.povray.org>
Because any given key only opens locks of the exact same shape?
Date: 20 Jun 2008 06:31:42
Message: <485b870e$1@news.povray.org>
Oh God, that surely desurves a rimshot! ;-)
Date: 20 Jun 2008 06:35:07
Message: <cu1n549epbqa34iao6l08o50m05g189gfp@4ax.com>
<g>
Regards
Date: 20 Jun 2008 06:38:07
Message: <342n549sl8elq1o2qb1k6b88d2j6juhr5h@4ax.com>
http://en.wikipedia.org/wiki/Key_(lock)
Regards
Date: 20 Jun 2008 06:41:50
Message: <485b896e@news.povray.org>
Locks can be designed to be opened by two different keys (usually a unique
key and a master key common to several locks).
Date: 20 Jun 2008 06:46:06
Message: <485b8a6e@news.povray.org>
> unique key and a master key common to several locks).
Really? Hmm... sounds physically implausible to me, but OK.
Date: 20 Jun 2008 06:58:15
Message: <t93n54d5ti5gsknr9ctkuftbs08bped9ft@4ax.com>
That is because you don't know how a lock and key work. They are very
simple physical devices.
Regards
Date: 20 Jun 2008 07:00:30
Message: <485b8dce$1@news.povray.org>
The shape of the key aligns a series of pins. By design, exactly one
shape of key does this. It's difficult to see how you'd make two
unrelated shapes both have this property.
Date: 20 Jun 2008 07:12:21
Message: <485b9094@news.povray.org>
  The simplest lock type is the pin lock: the shape of the key raises each
pin a different amount. Each pin is cut in two parts. If the pin is raised
the correct amount, it will free the pin (as the cut will coincide with the
edge of the lock cylinder). If all the pins are raised the correct amount,
the entire lock will be freed and can be turned.
  In pin locks designed for master keys some of the pins are cut in three
parts instead of two. This means that two differently-shaped keys can open
the lock. When all the locks designed for a given master key have the same
secondary cuts, all of them can be opened with the master key. An individual
such lock can also be opened with the individual key assigned to that lock
(but can't be opened with any other key, except the master key, of course).
  Thus a series of locks with a master keys have all the same pin cut
assignment, plus some of the pins have a second cut, for the lock-specific
key.
  (Of course pin locks are quickly falling out of use, at least in Europe,
because they are so easy to lockpick. Other, more secure lock types are
usually used, but the master key idea is basically the same.)
Date: 20 Jun 2008 07:17:53
Message: <ne4n54d0dqsordurgphug7cbiek5lhepgi@4ax.com>
Think of a house key, a Yale. The zig zag shape fits into a mask of a
similar shape allowing the key to turn. As you say.
But if on the key one of the high points is reduced then the key will
still turn, as the key will still fit through the mask. With me so
far? Once through the mask the zig zags have to engage a mechanism to
turn the lock. So if you flattened the key to the lowest point it
would turn but not engage the lock. A master key has the relevant zig
zags to engage the lock but not enough to be blocked by the various
masks on different locks.
This is reduced to being too simple.
Regards
Date: 20 Jun 2008 07:19:13
Message: <485b9231$1@news.povray.org>
> the lock.
I see...
Actually, I wonder. They call them "pins", but just how strong are they?
Couldn't you open the lock just by breaking all the pins?
Yeah, they all involve the shape of the key moving the internal
components of the lock around...
Date: 20 Jun 2008 08:33:19
Message: <485ba38e@news.povray.org>
  Depends on the quality and width of the pins. There are, in fact, locks
(even on the main doors of houses at some places) which can be broken by
simply turning then with enough force. A friend of mine who has lived in
Vancouver says that most locks there were of that type. They were completely
insecure. You could open a door by simply turning the knob with enough
force.
  More high-quality pin locks cannot be broken so easily, but they are
still so easy to lockpick that it's better to use a safer design (for
example a disc tumbler lock, which is common here, and which is extremely
hard to lockpick, and while not impossible, requires very sophisticated
tools).
Date: 20 Jun 2008 08:54:13
Message: <485ba875@news.povray.org>
Oh, that's cute.
> tools).
Yeah, well, devise an unpickable lock and somebody will just rip the
door off its hinges, or break in through a window or something. ;-)
Weakest point and all that... All you really need is for the lock not to
be the weakest part of the system.
Date: 20 Jun 2008 11:39:56
Message: <485bcf4c$1@news.povray.org>
We have cool locks on the doors of our houses, designed especially for
builders. Basically, all the locks can be opened with the master key,
until the first time you use the lock-specific key that the builder
gives to the new homeowner.  So, the first time you unlock your own
door, you lock the builder's master key out. I have only the vaguest
idea of how they accomplish that.
  Helpful housekeeping hints:
   Check your feather pillows for holes
    before putting them in the washing machine.
Date: 20 Jun 2008 12:09:40
Message: <op.uc11rkqqc3xi7v@news.povray.org>
And lo on Fri, 20 Jun 2008 16:39:56 +0100, Darren New <dne### [at] sanrrcom>
did spake, saying:
They use little ball-bearings between the pins, when the builders use
their key they shear at the top of the bearings and the bearings stay in
the plug. When you use your key you raise the pins so the shear line is at
the bottom of the bearings and when you turn they fall into holes set in
the plug and are thus removed.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 20 Jun 2008 12:28:25
Message: <485bdaa9$1@news.povray.org>
Well. Now I know. Thanks! :-)
Date: 23 Jun 2008 08:19:12
Message: <485f94c0$1@news.povray.org>
And do not lose your keys :-)
It's all nice and well to have an unbreakable door and lock until you
have to destroy your own wall to go into your own house because the keys
were lost somehow...
Vincent
Date: 23 Jun 2008 08:34:52
Message: <485f986c$1@news.povray.org>
I almost never have this problem. ;-)
My mum has a habit of losing her keys all the time. But then, she just
slings them wherever she happens to be when she stumbles in through the
door. And then she wonders why she can't remember where they are. MY
keys are always in one of exactly two places: In my pocket, or next to
my computer.
Date: 23 Jun 2008 10:29:10
Message: <485fb336@news.povray.org>
  If you are the only person owning keys to your house, then the next
step is to contact a legalized locksmith. They have their means to open
doors without breaking too much property. (Usually they can lockpick the
door open with their advanced tools, or if the lock is too secure for
that, they can remove the lock by force, in which case you only have to
pay for a new lock.)
Date: 23 Jun 2008 10:45:51
Message: <op.uc7h19rsc3xi7v@news.povray.org>
And lo on Mon, 23 Jun 2008 13:19:07 +0100, Vincent Le Chevalier
<gal### [at] libertyALLsurfSPAMfr> did spake, saying:
>> to be the weakest part of the system.
I think I'd try a window first ;-)
Phil Cook
Date: 23 Jun 2008 12:23:14
Message: <485fcdf2$1@news.povray.org>
> my computer.
I once spent 2 or 3 hours looking for my keys, because they were in the
wrong pocket of the trousers hanging on the hook. I checked my pocket!
They're not there!
Date: 23 Jun 2008 13:46:27
Message: <485FE1A8.2020401@hotmail.com>
The keys in my hospital have at least three levels.
I can open my door. There is a master for the floor and there is one
that opens all doors (and possibly even a level in between). I think you
can also have more than one master per lock. Then if more than one
department is on one floor, each department can have a master key and
the cleaners have one for the floor. Also if the department is split on
two floors...
And they are all mechanical. The master keys have one extra groove, I
don't know about the general master.
Date: 23 Jun 2008 14:04:17
Message: <485fe5a1$1@news.povray.org>
For that matter, there are cool things you can do with cryptography and
math that let you have similar relationships with passwords. Stuff like
"this file can be decrypted by any three of the seven officers of the
company, or by unanimous application of the keys of the department heads
of the company. Oh, and we can invalidate any key without invalidating
the others."
Date: 23 Jun 2008 15:25:21
Message: <485FF8D5.4090508@hotmail.com>
> the others."
I personally think doing it in hardware with nuts and bolts is more
impressive, but that may be just me.
Date: 23 Jun 2008 16:38:28
Message: <486009c3@news.povray.org>
  I suppose it's simply a question of cleverly allocating combinations
of pin assignments to locks and keys. I can imagine at least one simple
way of achieving a hierarchy of master keys with pin locks:
  In all locks, all pins have a cut for the highest-order master key,
as well as the secondary cut for the lock-specific key.
  The locks are divided into groups of locks (eg. on a per department
basis). All the locks in one group have the exact same secondary cut
for the first pin, but this secondary cut is different in different groups.
This way a master key for a specific group of locks uses the group-specific
setting for the first pin, and for the rest of the pins it uses the setting
for the highest-order master key. This way it can open all the locks in its
own group, but it can't open the locks of the other groups (the first pin
being different stops it).
  (If there are too many groups, using just one pin to differentiate between
them might not be enough, but in that case more pins can be used for this
purpose. The amount of combinations increases exponentially.)
  If each group should be further divided into smaller sub-groups, the
same technique can be used with the second pin, the third pin, etc.
  Then there's the reverse problem: All keys, including lock-specific ones,
should open a common lock (eg. the door leading to the entire department).
A lock-specific key should open, naturally, its own lock *and* the common
lock, but it nevertheless must not be a master key which could be used to
open your work pal's office. Obviously master keys should also open these
common locks as well. However, the lock should not be openable by a key
not related to the company at all.
  In other words, the situation is kind of a reversal: The common lock is
a "master lock": It should be openable by a group of keys, but not by any
keys outside that group.
  I have difficult time bending my mind into resolving how exactly it is
done, but I can perfectly imagine there's a simple way. Ingenuous, but simple.
Date: 23 Jun 2008 18:28:04
Message: <48602374$1@news.povray.org>
I definitely agree. I wasn't disparaging. I was simply saying you can
make it even *more* complex with math. The fact that the program doesnt
have to enforce the cryptography stuff is what makes *that* impressive
to me. You can't unscramble the stuff without 3 or 9 keys due to the
nature of the keys, not the nature of the lock, so to speak. :-)
Date: 23 Jun 2008 18:32:01
Message: <48602461$1@news.povray.org>
Math professor writes an equation on the board, and says "The proof is
trivial.  Wait, is it?"  He wanders back to his office, returns in 20
minutes to the classroom, and says "Yes, indeed, the proof is trivial."
Date: 24 Jun 2008 00:38:52
Message: <48607a5c$1@news.povray.org>
>>> the locks are identical??)
Go and find a copy of the MIT Guide to Lock Picking.  Seriously.  It
explains this and you learn a lot about the mechanics of mechanical locks
from reading it.
Jim
Date: 24 Jun 2008 00:39:58
Message: <48607a9e$1@news.povray.org>
Two shearing points in the pins.
Jim
Date: 24 Jun 2008 03:12:16
Message: <48609e50@news.povray.org>
>> simple.
Old but still gold :-)
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 24 Jun 2008 03:30:53
Message: <kj81641e9uin8ibi5ki6ulq8shjioc5qbi@4ax.com>
On Tue, 24 Jun 2008 08:12:00 +0100, Doctor John <doc### [at] gmailcom>
wrote:
>>> simple.
That happened in one of my high school maths classes (true). Now I
think the teacher just went for a fag. (Cigarette)
Regards
Date: 24 Jun 2008 04:13:00
Message: <4860ac8c@news.povray.org>
> the others."
Sounds like BluRay encryption to me :-)
Date: 24 Jun 2008 04:15:27
Message: <4860ad1f$1@news.povray.org>
Our office keys have the normal jagged key cut for the pins in the lock, but
then they also have another "key" feature engraved on the side, like a
series of recesses drilled at certain points.  Maybe some locks only work on
one set of features, or some on both, I don't know.
Date: 24 Jun 2008 05:15:13
Message: <4860bb21$1@news.povray.org>
> They're not there!
Yeah, I've done this.
Also, if my pockets are too small to hold all my items, and I know I
don't need one of them, I leave it behind. I then spend the whole day
thinking I've lost something because my pockets are not the correct
weight. o_O
Date: 24 Jun 2008 05:19:38
Message: <4860bc2a$1@news.povray.org>
>> keys were lost somehow...
I was assuming that the windows were armoured in the same unbreakable
fashion as the door, of course :-p
Vincent
Date: 24 Jun 2008 06:07:04
Message: <4860c748$1@news.povray.org>
> from reading it.
> Jim
Or just simply take one lock apart and check what it has eaten :).
Preferably a one that has master-key -functionality, then you'll
understand that also ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 24 Jun 2008 06:29:19
Message: <op.uc80rmfqc3xi7v@news.povray.org>
And lo on Tue, 24 Jun 2008 10:15:12 +0100, Invisible <voi### [at] devnull> did
spake, saying:
>> They're not there!
> weight. o_O
Heh had this yesterday, parked my car on the drive and got out to open the
garage door and fell into conversation with my neighbour. Put my hands in
my pockets and thought "Where are my car keys?". I've been doing the same
with my camera case it feels weird to go out without it now.
Phil Cook
Date: 24 Jun 2008 08:15:47
Message: <4860e572@news.povray.org>
> from reading it.
  Every lockpicking guide I have seen talks only about pin locks. Thus
they help understanding how pin locks work, but they don't really help
understanding how other types of lock (such as disc tumbler locks) do.
Date: 24 Jun 2008 13:33:11
Message: <48612fd7$1@news.povray.org>
>> locks from reading it.
But for Andy's points, he's dealing with a pin lock, so it would be an
appropriate reference.
Jim
Date: 24 Jun 2008 13:33:31
Message: <48612feb$1@news.povray.org>
>> Jim
True, taking one apart would teach you a lot as well.
Jim
Date: 24 Jun 2008 14:49:49
Message: <48614200.7050706@hotmail.com>
Our keys are more or less saw shaped, if you know what I mean. The
master keys have this extra groove. It also has bigger indentations on
some points. Put another way, if you have 3 or more keys that have the
same master, all you need is a mechanical workshop to make a master. But
don't tell anyone, I am not supposed to know.
Date: 24 Jun 2008 15:57:49
Message: <486151bd@news.povray.org>
Yes, except there you need the players to actually enforce the
encryption and the key invalidation, to a large extent. (How much, I
don't know for sure, since they kind of conflate a number of different
operations in one structure.)
But yes, that sort of encryption stuff fascinates me. :-)
Date: 24 Jun 2008 15:58:49
Message: <486151f9$1@news.povray.org>
Yeah, like not to take apart a lock anywhere near shag carpet if you
ever expect to put it back together again.
Date: 24 Jun 2008 16:00:49
Message: <48615271$1@news.povray.org>
I think rather than "pick locks", what you're looking for there is
"crack safes". :-) That sort of thing teaches you how the rotary-dial
locks work. Between tumbler locks and rotary-dial locks, it's pretty
easy to figure out how the variants work (like the ones with dents in
the keys, or teeth cut on angles, etc.)
Date: 24 Jun 2008 17:09:11
Message: <48616277$1@news.povray.org>
...or just not to expect to put a lock back together, ever?
Date: 24 Jun 2008 17:54:46
Message: <17r264d4mkv67vemdcseh6a48rsfu4gauf@4ax.com>
On Tue, 24 Jun 2008 12:58:49 -0700, Darren New <dne### [at] sanrrcom>
LOL how true :)
You need a wooden floor to hear where those bits bounced to ;)
Regards
Date: 24 Jun 2008 18:56:45
Message: <48617bad@news.povray.org>
This is also true. :-)
Jim
