OK, so here's one for you...
If I put my car into top gear and set the engine to 3,500 revolutions
per minute, my car travels forward at almost exactly 75 miles per hour.
So... how far forward does it travel for a single revolution of the engine??
Similarly, at that speed my car achieves roughly 50 miles per gallon of
fuel. So how much fuel does it inject into each cylinder??
[My car has a four-cylinder, four-stroke internal compustion engine, and
is normally-asperated. And runs on petrol, in case that wasn't obvious.
Presumably the timing is therefore set so that exactly one cylinder
fires for every revolution of the engine.]
http://blog.orphi.me.uk/
> engine??
Nope. Each cylinder fires once for every two revolutions. You have a 4
cyl engine therefore two cylinders fire for each rev.
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
> engine??
574643.
Ah, you want the unit? µm, naturally. This of course doesn't take count
the "almost" you told, neither tires wearing nor possible sliding.
None.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
Or the effects of momentum. ;-)
Jim
Is this a math puzzle, or a real question?
If it's a real question, it's almost impossible to answer from the information
given. You have to take into account acceleration, momentum, friction, etc.
....Chambers
How so?
The engine is directly coupled to the wheels. Unless the car looses
traction, the forward motion of the car and the rotational speed of the
wheels and engine all have a simple linear relationship.
>>> hour. So... how far forward does it travel for a single revolution of
>>> the engine??
>> information given. You have to take into account acceleration,
> How so?
There isn't a linear relationship between the rotational speed of the
wheels and the speed of the engine.
If I take my foot off the gas, the engine revs drop. The car may or may
not slow down (depending on the road and the landscape).
Similarly, if I apply the brakes to a full stop, the engine doesn't die,
it idles.
Then of course if you put the car in neutral, you've completely
disengaged the engine from the wheels.
Jim
Isn't this laughably simple to calculate?
3500 rpm = 3500*60 rph, and in 1 hour it travels 75 miles. Thus divide
75 miles by 3500*60 revolutions, and you have the amount of miles per one
revolution, which would be approximately 0.0003571428 miles.
Given that I'm not sure which whacky units miles are divided into,
I'll just convert those to more understandable units, so 75/(3500*60)
miles is approximately 57.5 centimeters.
Well that's news.
Not true. The engine revs depend on the speed of the vehicle.
If you don't believe me, try rolling down a hill at 30, and then stick
the car into 1st gear. Watch the revs go through the roof, even though
you haven't touched the gas.
> it idles.
Um, yes it does. Unless...
...you disenguage the engine from the wheels. Then there really isn't
any relationship. But as long as the car stays in the same gear, there
is a fixed relationship.
Yes - *if* you can do things like compute 60/75 *mentally*. :-P And also
if you know how many yards there are in a mile, and all kinds of other
random stuff.
[I found myself wondering about this in the car on the way home.]
Now, if you have access to a *computer* - or even better, Google - then
yes, it becomes quite easy.
That's the number I arrived at too.
Google also tells me that 75 mph = 33 m/s. Which frankly seems really
damned fast. (!) I mean, my car is only, like, 4 m long or something...
That means the car covers almost 10x its own length in 1 second! o_O
No wonder hitting anything is an instant fatality...
There is, in a (relatively primitive) manual transmission. There is not,
however, a linear relationship between engine RPM and gasoline usage.
> it idles.
When did you last drive a manual transmission? :-)
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
How many cars use a transmission that would count as "relatively
primitive"? But I do agree that there's not a linear relationship
between RPM and MPG.
>> die, it idles.
D'oh! I was thinking automatic - I learned to drive on a stick....
Jim
> Well that's news.
>> may not slow down (depending on the road and the landscape).
>> die, it idles.
Perhaps in a manual transmission - in my automatic, though, I'll stick
with what I indicated....I s'pose I could ask my father-in-law when I
talk to him next, since his life's work has been working on cars....
Jim
Sure. But the automatic has a clutch built into it. That's why you only
have two pedals.
> primitive"?
One that has distinct manually-shifted gears without synchromesh. Lots
of newer cars have things like variable transmissions.
> have two pedals.
True....
Jim
>> primitive"?
Yeah, that's what I'm thinking of, just didn't know the name of it...
Jim
Sure, 1.885 feet per revolution.
Hmm, yeah, 110 feet per second, wear your seatbelt.
0.0027 tsp of gas per cylinder. (other factors ignored).
> have two pedals.
http://en.wikipedia.org/wiki/Variomatic
just plugging dutch technology that never really caught on.
Oh, well, yeah. Automatic transmission basically means it can change
gear and lock/unlock the clutch at will. And doing both of those things
changes the relationship. ;-)
My car has manual transmission.
Indeed.
> There is not,
No - that would depend on the smoothness of the road, the inclination,
wind speed, and a bunch of other factors. Even so, I would expect it to
be possible to come up with an *approximate* number for fuel used per
cylinder.
It did, when improved enough.
http://www.audiworld.com/news/99/multitronic/content.shtml
Eero "Aero" Ahonen
http://www.zbxt.net
And won't walk across busy motorways at night while dressed only in
black. ;-)
Also, DON'T HIT A TREE!
[A nice mature Oak has brunches going up to 30 feet into the air, and
roots going down to 30 feet into the ground. The entire organism
probably weighs multiple tonnes. If you hit it, IT'S NOT GOING ANYWHERE!]
Hmm, that's actually really small... that's like... 0.015 ml. o_O
That can't be right, surely? That's less than one droplet per cylinder!
How would you portion out such a tiny amount? Surface tension would seem
to make this impossible.
> cylinder.
Yes, ~1/4 of used fuel is used for one cylinder (but not injected in one
- it's injected to the air intake before cylinders;). Just multiply the
~28,75cm with consumption (l/100km) and you'll get the average amount of
fuel .
Just a side-note: given that IIRC your car is <2l naturally aspirated,
I'd guess the maximum possible fuel used per minute per cylinder with
original parts is somewhere around 200cc (the injector capacity), giving
total of 0,8l/min. OTOH, that much is used rarely, basically only when
revving with pedal on the floor at the rpm of maximum power.
Eero "Aero" Ahonen
http://www.zbxt.net
On one rev the car moves 28,75cm, in that time 2 sparks are launched.
Google says 40mpg (US, AFAIK it's pretty near 50imperial MPG) converts
to 5,8l/100km (which is pretty low for 120km/h, but possible, if you
have a modern diesel with long gearbox and good aerodynamics).
5,8l/100km makes
0,058l/km=0,000058l/m=0,00003335l/rev=0,00001668l/spark=0,01668ml/spark.
Yep, we're on the same line - I'd say the differences comes from the
roundings and converts.
To get to that consumption on those speeds you'll need a modern diesel
engine (or a hybrid-system), for example common rail -engine. In those,
the diesel is packed with very high pressure (>1000bar) on a kind of
pipe before the cylinders and released to cylinders very precisely with
piezo-electric injectors. Really fine mechanics, think about a
manufacturing fault in there...
http://en.wikipedia.org/wiki/Common_rail
Eero "Aero" Ahonen
http://www.zbxt.net
HUGE mistake - on HALF rev the car moves 28,75cm and in that time only 1
spark is launched, therefore...
> 5,8l/100km makes
... these last numbers DO NOT MATCH, the correct final number being
0,03335ml/spark.
Also to be noted, if you really have common-rail diesel or something
similar (I recalled you have a non-GDI petrol engine), the fuel actually
is injected to the cylinder, not to the intake.
Eero "Aero" Ahonen
http://www.zbxt.net
> engine??
The fuel consumption of a vehicle is often quoted (in metric) as litres
per 100km. Suppose a medium sized sedan gives 10L/100km to keep the
maths easy.
So we have fuel consumption as a volume per distance. That means it can
be reduced to an area. Think of it as the cross-section area of a
cylindrical line of fuel that the vehicle is consuming as it hurtles
down the road. Of course when you accelerate the engine guzzles more
than this average and while cruising at some optimal speed (around
80km/hour ?) it would sip a bit less so the shape is tapered. It isn't
a simple cylinder but rather a lumpy one.
Lets ignore these variations and work out how large this cross-section
is on average.
Well do the calculation and you get 0.1 mm^2. That is one tenth of a
square millimeter! Depending on the size and resolution of your screen
and the font size that you use it is about the area of a full stop.
So as you cruise along a motorway your vehicle is slurping a stream of
fuel about the same size across as a largish grain of sand, burning it
to produce hot gases and farting them out the rear.
I find the fact that such a seemingly miniscule amount of fuel can be
used to propel quite massive vehicles along at such speeds quite
amazing. The energy density and convenience of petroleum fuels is just
astonishing. As someone once said if you were to write down the ideal
properties of a vehicle fuel you would pretty much define petrol. High
energy density but not (terribly) explosive, liquid over a wide range of
temperatures, cheap (well relatively), easy to handle, not (too) toxic
or corrosive etc.
Second thought though is that when you add up the consumption of tens of
thousands of vehicles along a section of major road each day it does
start to amount to quite a lot. Those fractions of a square millimeter
accumulate to something like the cross section of a fire hose or water
main. Imagine the threads of each vehicle weaving with others to form a
massive cable down the center of the road. Smaller roads might equate
to a garden hose each. Sum this across a city and it is a huge web
spread down every road and tangled across every intersection.
Over the course of a year the sum cross section along a major road would
be larger than the cross section of a petrol tanker truck. So it is
like every highway and major road being lined with tankers parked nose
to tail.
And all of this is with a liquid that was produced millions of years
ago. It is the captured sunlight that fell on forests in the time of
the dinosaurs.
> astonishing.
On the other hand, steam engines are more efficient. (I.e., transform
more of the available energy into useful work.) But they're really not
"convinient" at all.
Uh, yeah...
> the dinosaurs.
Indeed.
Still, you'd think it would be possible to somehow take plants living
today and transform their tissues into some kind of highly flammable
hydrocardon with reasonably efficiency. This would seem the obvious
sustainable solution.
"Orchid XP v8" <voi### [at] dev null> a écrit dans le message de news:
482fe97c$1@news.povray.org...
> On the other hand, steam engines are more efficient. (I.e., transform more
Stirling engine generator >>> electricity powered wheels...
http://en.wikipedia.org/wiki/Stirling_engine
> Uh, yeah...
>> And all of this is with a liquid that was produced millions of years ago.
>> It is the captured sunlight that fell on forests in the time of the
>> dinosaurs.
> Indeed.
There are researches on hydrocarbon synthesis directly from CO2 and H2.
This could be a better solution because arid (but close to the sea )and
sunny (solar energy) zones could be used instead of fertile lands better for
food production.
Marc
0.0003571428 mile
= 1 foot + 2 hands + 2.6285678 inches
= 22 and 5/8 inch (and something).
http://www.google.com/search?q=1+foot+2+hands+2.6285678+inches+in+miles
http://www.google.com/search?q=%2822+5/8+%29+inches+in+miles
1 mile
= 8 furlongs
= 80 chains
= 1760 yards
= 8000 links
= 5280 feet
= 15840 hands
= 63360 inches
1 furlong
= 10 chains
= 220 yards
= 660 feet
= 1000 links
= 7920 inches
1 chain
= 22 yards
= 66 feet
= 100 links
= 198 hands
= 792 inches
1 yard
= 3 feet
= 9 hands
= 36 inches
1 foot
= 3 hands
= 12 inches
1 hand
= 4 inches
1 inch
= 1000 mils
Tor Olav
http://subcube.com
Tor Olav Kristensen wrote:
> 1 mile
> = 8 furlongs
> = 80 chains
> = 1760 yards
> = 8000 links
> = 5280 feet
> = 15840 hands
> = 63360 inches
> 1 furlong
> = 10 chains
> = 220 yards
> = 660 feet
> = 1000 links
> = 7920 inches
> 1 chain
> = 22 yards
> = 66 feet
> = 100 links
> = 198 hands
> = 792 inches
> 1 yard
> = 3 feet
> = 9 hands
> = 36 inches
> 1 foot
> = 3 hands
> = 12 inches
> 1 hand
> = 4 inches
> 1 inch
> = 1000 mils
THANK GOD FOR METRIC!!! >_<
> 1 mile
> = 8 furlongs
> = 80 chains
> = 1760 yards
> = 8000 links
> = 5280 feet
> = 15840 hands
> = 63360 inches
-clip-
> 1 inch
> = 1000 mils
I think I'll stay preferring the metric system.
Eero "Aero" Ahonen
http://www.zbxt.net
What he said.
On Sun, 18 May 2008 18:44:19 +0200, Tor Olav Kristensen
<tor### [at] TOBEREMOVEDgmail com> wrote:
>1 mile
>= 8 furlongs
>= 80 chains
>= 1760 yards
Where were you when I was at school :-)
Your post looks like the back of my old school jotters :-)
Yes we had to learn all that stuff by heart.
Regards
Assuming the clutch is engaged, yes this is pretty much true, the only tiny
difference can come from twisting in the driveshafts and bending of the
teeth on the gears. So it's pretty much coupled :-)
> Unless the car looses traction, the forward motion of the car and the
> rotational speed of the wheels and engine all have a simple linear
> relationship.
Except pretty much the whole time, part of the tyre has lost traction with
the road, if it hadn't then it would mean there were no forces being
generated, and you wouldn't go anywhere.
There's a quantity called "slip ratio", which is the ratio between the
actual speed the wheel is rotating, and what it "should" be (ie vehicle
speed divided tyre rolling circumference). The slip ratio (SR) is never
exactly 1, only when you are applying no forces to the wheel (ie no power
and no braking). If you brake moderately hard, it can easily go down to
0.8, and under normal acceleration can be 1.05 or so depending on your
tyres.
I'd say that about 90% or more of cars sold here in Europe the transmission
is a "relative primitive" manual. The reason is for efficiency, any extra
junk in the transmission (like fancy fluid couplings or multiple-clutches
etc) just increases fuel consumption. You connect the engine as directly to
the wheels as you possibly can, otherwise you're just wasting energy.
> If I put my car into top gear and set the engine to 3,500 revolutions per
> minute, my car travels forward at almost exactly 75 miles per hour. So...
I'll assume the other answers are correct, 0.57 meters.
50 miles per gallon = 5.6e-5 litres per meter according to google.
Which is about 3.22e-5 litres per revolution.
Let's use units of mass here, because I think it's easier to imagine the
amount, so we have about 24 mg of petrol being used per revolution.
So in your engine, that means 12 mg of fuel is being injected each time into
each cylinder (the fuel is injected every 2nd revolution into each
cylinder).
> I find the fact that such a seemingly miniscule amount of fuel can be used
> to propel quite massive vehicles along at such speeds quite amazing.
And they are improving all the time - I'm pretty sure that in my new car
I'll be able to do 1000 km on a single 50 litre tank if I take it easy (just
got 780 km on my first tank, but a lot of that was going over 160 km/hr!).
Even 5 years ago that would have been impossible in most cars.
> amazing.
Once the car is moving it only requires the amount of fuel necessary
to overcome the friction which would otherwise stop the car. Given that
the car has an enormous amount of momentum, the amount of energy needed
to keep it against such small things as air friction isn't all that large.
Compare it to the amount of fuel needed to get the car from 0 to 100 km/h
in a relatively short amount of time.
At 75 mph air friction isn't small. A lot of small cars give up not much
faster than this because their engine cannot generate enough power to
overcome the air friction.
Much less than getting to 100 km/h in a long time...
IMO, the surprise at the small amount of fuel needed comes from the fact
that the energy density of petrol is so high. We hear figues like 6 litres
per 100 km, but 6 litres of petrol equals around 200 MJ of energy, enough to
lift a 747 plane 100 metres in the air!
They do something of the sort - Biodiesel
But that's what politicians are blaming on the food shortages and price
increases. Go figure....
Tom
And for screwing up engines.
How about this classical physics problem:
You drop a rock into a water well. Then you hear the splash. Exactly
10 seconds pass between you letting go of the rock and when you hear the
splash. How deep is the well?
We can assume that air friction is negligible, that g = 9.81 m/s^2,
and that the speed of sound is 340 m/s.
Don't just give the answer, also write your whole reasoning.
Hmm, takes me back to school.
10 = t(sound) + t(rockfall)
t(sound) = x/340 where x is the well depth
x = 1/2 * g * t(rockfall)^2
so
t(rockfall) = sqrt(2x/g)
substituting back in,
10 = x/340 + sqrt(2x/g)
sub y = sqrt(x), rearrange
(1/340)*y^2 + sqrt(2/g)*y - 10 = 0
solve quadratic for positive y, square y to get x
I get x = 393.25m, sounds about right but my arithmetic might be wonky.
Hmm, the object has an initial velocity v0 = 0 m/s.
Assuming zero air resistence, the object as infinite terminal velocity
and accelerates uniformly at 9.81 m/s^2. This yields
vt = 9.81 t
The integral of this would be the object's position:
pt = 9.81/2 t^2 = 4.905 t^2
We hear the splash at t=10. Assuming that sound is initiated at time t=K
and it propogates towards the observer at 340 m/s, we have
K = 10 - d/340
where d is the distance to the bottom of the well.
So, we know that d must obey
K = 10 - d/340 and 4.905 K^2 = d
Rearranging, we have
K - 10 = -d/340
340 (K - 10) = -d
340 K - 3,400 = -d
-340 K + 3,400 = d
So d = -340 K + 3,400 = 4.905 K^2.
At this point, I have insufficient knowledge of algebra to deduce a
solution, although obviously one exists.
You should learn how to calculate the solution to equations like this, they
come up everywhere:
http://en.wikipedia.org/wiki/Quadratic_equation
> they come up everywhere:
Solving a single quadratic equation is trivial. Solving a pair of linear
equations is trivial. But I have no idea how to solve a pair of
equations where one is linear and the other isn't.
[Actually, I can still remember sitting down and deriving the quadratic
formula from first principles. It's quite instructive! Whoever it was
that figured out that A*B - 4*(A+B) = A-B is some kind of genius if you
ask me... The next day I tried to do the same with a cubic, but... uh...
failed.]
What do you call that equation you got at the top there?
A pair of equations welded together?
A = B = C implies that B = C, no?
