So, you have some equipment for monitoring temparature sensors and
logging their readings. And you supply some software that downloads this
data and lets you organise and examine it on a desktop PC.
Your hardware and software are designed to talk to each other via a
serial cable connecting the hardware to the PC running the software.
Ah, but some people want to actually, you know, have the PC in a
different room to where the hardware is. And they'd like to not have to
dedicate one entire PC to each logger. The answer is simple: your
product needs to communicate over the network!
Now, you *could* redesign your hardware so it has an Ethernet port, and
redesign your software so it understands TCP/IP. But you're not going to.
Instead, what you do is supply your customers with a little black box.
This little black box has a serial connector at one end, and an Ethernet
connection at the other, and it *tunnels* serial traffic over IP.
You also supply your customers with a blob of software which, when
installed on a PC, somehow tricks the PC into thinking it has a new
serial port. All data sent to this port is *actually* tunnelled to the
little black box.
So, between the little black box at one end, and the custom software
driver at the other end, the hardware and software geniunely believe
they're still locally connected, yet actually they can be on different
continents.
Is this a valid solution to a design problem? Or is it a cheap hack?
[Did I mention that the "software" in question appears to be designed to
work with Windows 3.0? Does that change the answer?]
http://blog.orphi.me.uk/
It's a floor wax *and* a salad dressing!
Seriously, that's not at all uncommon in the world of credit card
terminals. You would rather buy 20 $25 serial boxes than replace 20 $300
credit card terminals when you go to a networked cash register thingie.
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
Yes. I see this occasionally with KVM switches (Avocent does this, for
example) as a way of "extending" a connection.
Jim
Heh. A KVM switch would be a *horrible* solution for this particular
problem. I mean, tunneling arbitrary serial data over IP isn't great.
But then, I guess serial is pretty speed limited anyway, so it shouldn't
use too much network bandwidth...
Well... I hate salad anyway, so... ;-)
Subtle nit-pick, but... We're buying a brand new system, not augmenting
an existing one. If we were augmenting an existing one, then yeah, I can
see how just fitting a little extra hardware is clearly the
cost-effective option. I'm not sure how that works when you're buying
something completely brand-new, and it's already partially kludged so
the manufacturers don't have to redesign it... What's your opinion?
My opinion is that if it only works on Win 3, it's because it's
accessing the serial hardware directly, so it's already a kludge even
before the little black box. :-)
Oh no, it *looks* like something from Win 3. It actually *works* on NT4
[and possibly newer, I haven't tried]. ;-)
Well, I wasn't saying a KVM would be a solution (I don't even know the
circumstances really), just that I've seen Avocent/Cybex switches that
use serial-to-ethernet adapters in order to extend the range. Range
extenders have been around for quite a while, though - both for serial
and parallel devices (can't remember the name of the company that did the
parallel extenders I used years ago).
Jim
Just get a temperature logger with a USB interface and a decent API, connect
it to a cheap old PC, which is running some software *you* wrote to read out
the data and send it over LAN to some server in some useful format.
That's what I do here :-)
> connect it to a cheap old PC, which is running some software *you* wrote
> to read out the data and send it over LAN to some server in some useful
> format.
Well, this is for mission-critical stuff, so we have a service contract
and all that kind of thing, so we basically get the hardware and
software they provide. But yeah, if support wasn't an issue, that's
probably what I'd do...
> and all that kind of thing, so we basically get the hardware and software
> they provide. But yeah, if support wasn't an issue, that's probably what
> I'd do...
Yeh, guess you don't want to be held responsible when it breaks for
something mission critical, better to be able to pass the responsibility on
(even if they haven't updated their software since Win3.1!).
Still, you could encourage them to make some updates (like using USB instead
of serial, and writing software for XP/Vista rather than Win3.1), or buy the
system from a more up to date supplier that is less hacky.
> on (even if they haven't updated their software since Win3.1!).
> instead of serial, and writing software for XP/Vista rather than
> Win3.1), or buy the system from a more up to date supplier that is less
> hacky.
Well now, if you want a couple of thermometers and a data logger,
that'll be about £20. Now if you write the words "mission critical" on
it, suddenly the same hardware costs £12,000. Strange, that. But hey,
it's mission critical. What are you gonna do? You simply *have* to have
this thing, so basically you have to pay whatever they charge you. Which
is probably _why_ they charge you so much. ;-)
I wasn't in any way involved in the purchase process, but I gather that
we were quoted tens of thousands of pounds by various parties, and we
eventually went with the lowest bidder. As far as I know...
> Now if you write the words "mission critical" on it, suddenly the same
Not really, I assume the hardware is of a much higher specification than
some *really* cheap consumer version you could get for 20 quid.
> But hey, it's mission critical. What are you gonna do? You simply *have*
> to have this thing, so basically you have to pay whatever they charge you.
> Which is probably _why_ they charge you so much. ;-)
Usually you have the option of other suppliers, so the price should be
pretty competitive for what you're getting. Otherwise they would go out of
business if everyone else could sell the same product for half the price.
> I wasn't in any way involved in the purchase process, but I gather that we
If you were about to spend 10k on something, would you blindly take the
cheapest one without even bothering to see exactly what you were getting?
Sadly a lot of companies do exactly this, often with much larger sums of
money...
Well... It measures temparatures to the nearest 0.1°C. It records them
every 15 minutes. If they go outside a preset range, an alarm goes off.
How much would *you* suggest such a system costs?
>> *have* to have this thing, so basically you have to pay whatever they
>> charge you. Which is probably _why_ they charge you so much. ;-)
> of business if everyone else could sell the same product for half the
> price.
Apparently all the suppliers we could find were charging 5 figures for
something that will do what we want. Seems absurd to me, but... mission
critical, gotta have one, gotta be up and running before date X...
> getting? Sadly a lot of companies do exactly this, often with much
> larger sums of money...
Well, you'd hope so... but as I say, I wasn't really involved in the
process. I believe the hardware was all much the same, so they went with
the cheapest option from a supplier who could actually supply on time.
Depends on far more than just the raw technical performance.
If I'm going to use it check the temperature in my greenhouse, I would
imagine a 50 quid jobby from Maplins would do with some cheap hacked
together Win3.1 program. However, if I'm putting it in a manned spacecraft
that is orbiting the moon, I would expect way higher performance, and an
equally higher price.
BTW, the stuff we make here, we always have to put on the 1st page of the
specification that it is not to be used in anything critical, like plane
instruments, hospital equipment, traffic signals etc, simply because we
don't design or test to high enough standards. If we did, the cost would be
astronomical, for stuff like PC monitors you don't need that level of
reliability so you get them very cheap.
Is the equipment and software certified? Because that adds to the
cost.
Regards
> little black box.
> continents.
If it is an existing system that needs to be made network 'aware' then
it is a valid solution, but one that should be taken with caution.
Recently I built something that does exactly that.
I have some GPS modules that speak serial.
I built a custom serial/ethernet module. But this one is smart - it has
a buffer and built in web page for basic GPS info.
On the computer I run a ethernet/comm port emulator so that programs
that expect only a comm port can work.
But one better, the serial/ethernet module allows for multiple
connections - I can get multiple computers and applications pulling the
same data on comm ports.
IMHO, a serial-ethernet module should be used as a last resort when
there is no viable alternative.
If it is a mission critical application, then you are just introducing
more points for failure. When one of those points die, then it takes
all that much longer to debug.
This reminds me of what would be put in at the GM-Saturn plant I worked
in several years ago. You kludge a bunch of stuff together until it
works, then repeat and put 50 of them on the plant floor. Even tho if
one of them failed it would stop the production line. I ran into some
strange setups - parallel to serial to ethernet to serial to com
port.... and in one case it took 3 days to figure out what piece failed.
Best of luck!
LAter... Tom
>> off. How much would *you* suggest such a system costs?
> spacecraft that is orbiting the moon, I would expect way higher
> performance, and an equally higher price.
Well, we'd like to check that the blood samples we're storing actually
*stay* at -80°C. And if they start to warm up, somebody needs to know
about this fact, urgently.
I'm guessing a temparature sensor that actually *works* at temparatures
that low is going to cost a tad more than your average room thermometer,
but beyond that I don't see why it would need to cost more. It seems the
only reason for the higher price is that this is a critical device, so
the suppliers know they can charge the Earth and we will pay it. We have to.
> the specification that it is not to be used in anything critical, like
> plane instruments, hospital equipment, traffic signals etc, simply
> because we don't design or test to high enough standards. If we did,
> the cost would be astronomical, for stuff like PC monitors you don't
> need that level of reliability so you get them very cheap.
The mass spectrometers we have here all say "for research and
development only; not for diagnostic procedures" on them. I can't
imagine why - it's a mass spectrometer! Either it measures masses
reliably, or it doesn't. If it does, you can use it for anything you
like. If it doesn't, it's a worthless piece of equipment. So... why the
sticker?!
> cost.
Not by the supplier, I don't *think*. Certainly *we* will be regularly
checking it against an ISO standards-certified reference instrument
[which really *is* insanely expensive]. But I don't *think* the
suppliers actually provide any such guarantees - I'm not sure...
What are the consequences if the temperature goes above -80°C but nobody is
informed? Would you trust a 20 quid meter from Maplin then?
Not really, thermocouples are cheap (like a fiver) and measure down to
below -100 degrees.
> only reason for the higher price is that this is a critical device, so the
Or the fact that there is a much lower chance it will break or mal-function.
A simple example I can think of is that the connector where the thermal
probe plugs in mal-functions somehow so that the electronics thinks that the
temperature is -90 when really it is only -70. Or some solder joint on the
circuit board wasn't made completely correctly and messes up some other
reading in an undetectable way once the temperature and humidity get to a
certain value. There are all sorts of failure mechanisms that needs to be
checked and fixed somehow, and that costs lots of money.
> The mass spectrometers we have here all say "for research and development
> only; not for diagnostic procedures" on them. I can't imagine why - it's a
> mass spectrometer! Either it measures masses reliably, or it doesn't. If
> it does, you can use it for anything you like. If it doesn't, it's a
> worthless piece of equipment. So... why the sticker?!
Because they don't guarantee it will work reliably the whole time. For them
to guarantee that, they would need to do lots of expensive testing on every
unit, probably design in lots of redundant systems, use more expensive
components that have longer lifetimes, use better assembly methods etc.
> is informed? Would you trust a 20 quid meter from Maplin then?
My point exactly - it seems to have nothing to do with how reliable the
device is, only the subjective feeling it gives you in your head knowing
that "I paid lots of money for this, therefore it must be really
reliable". Which isn't terribly scientific...
>> temparatures that low is going to cost a tad more than your average
>> room thermometer,
> below -100 degrees.
Well, maybe you have to be slightly more careful that, e.g., the
insulator on the wire doesn't become as brittle as glass when it gets
too cold or something.
I remember seeing how a metal cylinder costs about £20, but a metal
cylinder that you can put liquid nitrogen into costs £500. Because
somebody has to check it won't break or something when it gets that damn
cold.
>> It seems
>> the only reason for the higher price is that this is a critical
>> device, so the suppliers know they can charge the Earth and we will
>> pay it. We have to.
> mal-function.
Why? Do they actually *do* something different with it? Does the
hardware itself have any actual physical differences to a cheap model?
As far as I can tell, they took a device that normally costs £50, added
a several thousand percent markup, and started marketting it at a
different market segment.
On the other hand, I remember researching printers one time. I ended up
looking at two printers. Both Hewlett Packard. Both print at 1200dpi.
Both have built-in network support. Both do duplex printing. Etc. But
one printer was about 10x the price of the other. Why?
The answer is a little number hidden at the bottom of the page
somewhere: "duty cycle". One printer said 1,000 pages/month, the other
said 100,000 pages/month. And you know what? We ended up buying both
printers, and one is still working to this day, the other one we
eventually threw away because it just kept breaking so often.
In this case, it seems paying 10x the price does, in fact, get you a
device which is *physically different*. I don't know if they use thicker
plastic for the drive gears or what, but the more expensive printer was
far more reliable. The cheap one is basically designed to sit in your
house. [Actually, I have one at home. It works just fine. But then, I
hardly ever print anything!] Put that printer in a busy office and it
just can't cope.
>> the sticker?!
> them to guarantee that, they would need to do lots of expensive testing
> on every unit, probably design in lots of redundant systems, use more
> expensive components that have longer lifetimes, use better assembly
> methods etc.
Well, you're the engineer. But I wonder - if a mass spectrometer that
you can't use for diagnostic procedures costs £250,000... what the HELL
does one you *can* use for diagnostic procedures cost?! o_O
You need to ensure that the cold joint (or in this case the hot joint)
is compensated properly for changes in the ambient temperature.
For medical/critical equipment you need certification to ensure
compliance with the laws of the country. And not just UK laws it
should comply with the laws of the registered country. In your case I
imagine that is the USA.
Regards
On Thu, 15 May 2008 13:52:37 +0100, Invisible <voi### [at] dev null> wrote:
>> cost.
Buy the cheapest and that is what you get. And is your secondary
calibrator regularly checked against a primary calibrator?
Regards
Surely you check out the specification before buying something? It will
include details about *how* reliable it is, with real numbers, and under
what conditions it has been tested in. Something you buy from Maplins won't
have this.
> cold.
Exactly - someone has to check - and that costs money.
Yes, it is designed to be more reliable, and they test it to prove this so
they can write it in the specification of the device.
> Does the hardware itself have any actual physical differences to a cheap
> model?
Probably, if you're lucky you could get a *really* reliable one from Maplin
that lasted for 1000 years without any problems. *Lucky* being the key word
here, try explaining to someone's family that they died because some monitor
failed, you can't say "we were unlucky".
> As far as I can tell, they took a device that normally costs £50, added a
> several thousand percent markup, and started marketting it at a different
> market segment.
And put in place processes for guaranteeing the reliability of the product,
at least testing each one and working with their suppliers to ensure that
correct procedures are followed to avoid any unreliabilities. You see those
news stories about paint from China causing problems? Without controlling
your suppliers properly stuff like that happens - and if you are supplying
something you claim to be suitable for critical processes, you are in deep
trouble if you allow your suppliers or your own processes to screw up.
> The answer is a little number hidden at the bottom of the page somewhere:
> "duty cycle". One printer said 1,000 pages/month, the other said 100,000
> pages/month. And you know what? We ended up buying both printers, and one
> is still working to this day, the other one we eventually threw away
Exactly.
> hardly ever print anything!] Put that printer in a busy office and it just
> can't cope.
The same way that buying a 20 quid power drill from B&Q is fine if you only
use it once a month to drill a few holes. But if you are a builder and you
use it 20 times a day, it's going to break after a week. Which is why you
invest in a way more expensive model. OK so if you bought the cheap one it
*might* last for several months, but it's not worth the risk if you really
need your drill to work every day.
> Well, you're the engineer. But I wonder - if a mass spectrometer that you
> can't use for diagnostic procedures costs £250,000... what the HELL does
Medical equipment is extremely expensive, precisely because there is so much
at risk when things go wrong. The companies that make this stuff need to do
a huge amount of testing and robust design, way above what most other
industries require. It all costs money.
And lo on Thu, 15 May 2008 14:32:47 +0100, Invisible <voi### [at] dev null> did
spake, saying:
Heh I love it when you get ranty about the price of mission-critical stuff.
Here's a story I was told I forget the exact measurements and prices but
still -
A women approaches a company that make bespoke wooden doors for a new
front door. She can't buy an off-the-rack for £100 because they're two
inches too narrow, they quote her a price of £250. She blows her top
shouting "You're charging me £150 for those two extra inches" and storms
off never to return.
The moral, of course, is that she wasn't be charged an extra £150 she was
being charged £250 to have workmen create for her a uniquely sized door
from scratch.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
In the US, I'd say it's because if the device fails and all your blood
samples warm up and you lose $1M of revenue, you could reasonably expect
to sue the company that made the device to get your money back.
It's called "incidental damages" here.
If that's what you're paying for, then that's a big part of the price
difference. If the company doesn't warrant that the device will actually
work, then I couldn't say. Around here, a $20 thermometer is going to
have a warranty that says "If it breaks, you might be able to get your
$20 back, but that's about it."
> sticker?!
Liability control. If you can't tell when it's broken, and you overdose
someone because your mass spectrometer misread how much drug was in the
solution, it's much more expensive than if you (say) ruin an
experimental car engine by putting the wrong mix of fuel in it.
A freaking *lot* if it's calibrated so it can for sure measure up to
0,1C and not just show that way and the service contract includes yearly
(oslt) re-calibrations.
Mission critical: you take 5 UPS's, 5 PC's, 5 sensors and wire them up
separately. If all five from even the cheapest hardware break down
simultaneously enough, you're having the worst luck of the world
already. OTOH, then you won't have A) service contract, B) scheduled
re-calibrations, C) calibration at the first place.
You weren't involved -> it's not your call -> you shouldn't stress about it.
Eero "Aero" Ahonen
http://www.zbxt.net
aer### [at] removethis zbxt net invalid
>> damn cold.
Well that at least makes sense. You're paying money *for* something.
> so they can write it in the specification of the device.
This somewhat implies that normal stuff is designed to be UNreliable. ;-)
>> cheap model?
> Maplin that lasted for 1000 years without any problems. *Lucky* being
> the key word here, try explaining to someone's family that they died
> because some monitor failed, you can't say "we were unlucky".
I'm just wondering whether they actually did anything different at all
for the extra money, that's all.
It's like when you order stuff online. You can pay £2, and they tell you
it'll take up to 15 days to arrive. But actually it arrives within 12
hours. Or you can pay £15 to have it guaranteed to arrive within 12
hours. And it still arrives within 12 hours. Do they actually do
anything different? Or is it just a tax on stupidity?
On the other hand, consider the printers example. Clearly something *is*
actually different, because the printers really do perform differently.
So in this case, you *are* getting something for your money.
I'm not sure which category this temparature monitor falls into.
>> HELL does one you *can* use for diagnostic procedures cost?! o_O
> much at risk when things go wrong. The companies that make this stuff
> need to do a huge amount of testing and robust design, way above what
> most other industries require. It all costs money.
Heh. And I thought a device that costs more than my house (!!) was
already expensive. ;-)
[Seriously - WTF does a mass spectrometer even have in it? It's just an
empty tube, some vacuum pumps, an electrode and some magnets. So is my
TV! Well, apart from the vacuum pumps anyway... And yet, my TV doesn't
cost more than a small housing estate. Wuh??]
BTW, wasn't there some famous disaster with a device for radiotherapy
that accidentally overdosed a few people?
> it.
Oh, hey, I'm not *stressing* about this! I couldn't care less. ;-) I'm
merely curios about the design of it...
On Thu, 15 May 2008 22:10:07 +0100, Orchid XP v8 <voi### [at] dev null>
He said "more" reliable. Have you heard of tolerances?
Regards
Of course it is, everything has a designed lifetime, even the on/off button
on the front of your computer. Why put a switch that is guaranteed to have
a minimum of 1 million operations over -40 to 100°C on an ordinary PC? Some
situations call for this sort of reliability though, and you pay for it.
The tiny plugs/sockets that are used inside laptops and mobile phones etc
often have a designed lifetime of just *ONE* operation! It means everything
can be made much smaller and thinner and hence cheaper, but of course you
wouldn't use one of these if you were expecting to actually use the plug
regularly.
> I'm just wondering whether they actually did anything different at all for
Well they must have done if they are guaranteeing it for critical use. If
they didn't they risk being in a lot of trouble when things do fail (or
maybe there is even some law that is relevant, I don't know). Are they ISO
9000 accredited?
> hours. Or you can pay £15 to have it guaranteed to arrive within 12 hours.
> And it still arrives within 12 hours. Do they actually do anything
Again, paying extra is guaranteeing next day delivery, it means more work
for them, more work for the delivery company, and hence is more expensive.
Of course if they happen to have space on the truck they'll probably fill it
up with non-next-day orders - but it's not guaranteed. If the truck is full
and they still have next day orders to ship, they get another truck over,
which isn't free.
> empty tube, some vacuum pumps, an electrode and some magnets. So is my TV!
> Well, apart from the vacuum pumps anyway... And yet, my TV doesn't cost
How many TVs do you think have been made in total? How many mass
spectrometers?
What do you think is the tolerance on TVs? Would you care if the green on
the UK weather map looks a slightly different shade to your neighbour?
> from scratch.
Hehe, or a more extreme example would be wandering into PC World and saying
you want a 1921x1200 resolution monitor custom made. Ermm, that will be
several million pounds sir.
> etc often have a designed lifetime of just *ONE* operation! It means
> everything can be made much smaller and thinner and hence cheaper, but
> of course you wouldn't use one of these if you were expecting to
> actually use the plug regularly.
I think my grandparents have used up the one connection on their mobile
phone. It is simply no longer possible to get a reliable USB connection.
You have to try about 8 or 9 times. The connector is just useless...
> If they didn't they risk being in a lot of trouble when things do fail
> (or maybe there is even some law that is relevant, I don't know). Are
> they ISO 9000 accredited?
That's the thing. I don't *think* the company in question is actually
guaranteeing it will work. They're just charging lots of money. We're
the ones who do all the calibration checking and so forth.
>> an empty tube, some vacuum pumps, an electrode and some magnets. So is
>> my TV! Well, apart from the vacuum pumps anyway... And yet, my TV
>> doesn't cost more than a small housing estate. Wuh??]
> spectrometers?
If you were asking "particle accelerators", it would be a different
story. ;-) Mass spectrometers are fairly rare, but not all that rare.
Although obviously rarer than TVs.
> on the UK weather map looks a slightly different shade to your neighbour?
That might have something to do with it...
Yeah.
Did you know 10% resistors show a curios bimodel distribution?
Wanna guess where the 5% resistors come from? ;-)
[And they charge you more for that stuff...]
On Fri, 16 May 2008 09:19:07 +0100, Invisible <voi### [at] dev null> wrote:
>Yeah.
When I worked in the semiconductor industry (CMOS chips) the sorting
was done by individual sampling after the ICs were encapsulated.
Resistors and caps were by materials used in manufacturing. But that
was when the Ark was new :)
Regards
Kind of, but not exactly. It might be reliable, it might not be.
Really it all comes down to luck - which, in the end, makes it unreliable :)
But it's not like a bunch of guys in suits sat down and said, "Now we
need to design a version that's going to fail really soon."
Yeah, they guaranteed that it won't fail within certain tolerances.
Those tolerances are *much* stricter than for the cheap version.
It's a guarantee. Sure, you order something online and you could get it
in 12 hours. Or, you could get it in 2 weeks. I've had both occur.
When you pay extra for shipping, you're paying for a guarantee that it
will arrive within a certain timeframe. If you're ordering a gift for
someone's birthday, for instance, and their birthday is 3 days from now,
do you want to gamble that the gift won't arrive on time? Or do you
want to know *for a fact* that it will arrive within 3 days?
As trite as the old saying is, "You get what you pay for". A lot of the
time, people decide that the quality really is worth the extra money
(like your printer). The trick is knowing when to pay for quality, and
when to go cheap.
...Chambers
Well, certainly for resistors, they have a machine that just churns out
resistors. They vary all over the place. The ones that are more than 10%
wrong get thrown away [or perhaps recycled, IDK]. The ones that are
within 10% of the correct value get sold cheap. And the ones that are
within 5% of the correct value get sold expensive. But it all comes out
of the same machine, and costs the same to produce. [Although I guess
the 5% ones are rarer, assuming a normal distribution...]
>> you it'll take up to 15 days to arrive. But actually it arrives within
>> 12 hours. Or you can pay £15 to have it guaranteed to arrive within 12
It's like when I paid extra to have my package from Zazzle arrive fast.
The ones I didn't pay extra for arrived within 6 days. The ones I paid
extra for never arrived at all. In the end, I had to drive to the depot
and get them my ****ing self! >:-[ NOT AMUSED!
[And then they tried to invoice me for unpaid VAT. I never did pay them
that back...]
If only it was a *fact*. It's not like you can demand your money back
when the item still turns up 3 weeks late...
> when to go cheap.
For something like a printer, which actually wears out, it can be worth
paying more. For something that passively measures a temparature and has
almost no possible way of malfunctioning... well, I know what I'd do. ;-)
That's the way, keep up the good work ;).
Eero "Aero" Ahonen
http://www.zbxt.net
NTSC - Never The Same Color!
You sure? How many devices have you had that failed within days of the
warranty expiring? ;-)
You know how traffic lights always turn red just as you get to them?
Well, one day I decided to ignore them when that happens. But each time
I arrive at a set of traffic lights just as they turn green, I'm all
like, "woo! I got the green!"
Now almost every single set of traffic lights I come to turn green
immediately. Seriously, you should try it!
The Jedi were right - your focus determins your reality. :-D
Heh. I think I shall. :-)
>>> all for the extra money, that's all.
Of course they're rarer. If they weren't, some other company would
charge a lower price for them.
>> now, do you want to gamble that the gift won't arrive on time? Or do
>> you want to know *for a fact* that it will arrive within 3 days?
Actually, you can. At least for the shipping.
...Chambers
None, actually. But that's probably a fluke :)
I bet what really happens is more along the lines of, "OK, we're at the
point where it will outlast the warranty, we can stop spending money
improving it now."
...Chambers
Sorry but you are wrong, there. Electronic components can fail under
normal usage also electronic circuits can drift and need recalibrated
from time to time. A temperature measuring device that has a range of
-100 ºC to +100 ºC to an accuracy of 0.1 ºC has a tolerance of 0.05.
That is very accurate.
Regards
Famous last words...
Seriously, how much would *you* be willing to bet that a temperature
measurement system from Maplin doesn't fail during 5 years use? $1, $100,
$100000 ? This is exactly what bet companies have to make, and if the bet
is millions of dollars, you don't get a $50 meter from Maplin.
