POV-Ray : Newsgroups : povray.off-topic : I think I did something wrong with RK4... Server Time
4 Nov 2024 17:29:24 EST (-0500)
  I think I did something wrong with RK4... (Message 1 to 10 of 22)
Subject: I think I did something wrong with RK4...
Date: 6 Apr 2008 20:55:28
Message: <47f97100$1@news.povray.org>
Here's a test app for Windows:
http://www.pacificwebguy.com/downloads/TestingRK4.zip
(Note that, although the app itself is named "Threaded_Physics.exe", I
haven't gotten around to implementing the "threaded" part yet.  Right
now, I'm just trying to make it work *correctly*).
Click anywhere on the screen to shoot particles in that direction.
Press F1 to switch between Newtonian integration and Rk4 integration.
The main thing to notice, other than the fact that RK4 is *much* slower
than Newtonian, is that using RK4 seems to amplify the forces somehow.
The result is that everything seems rather... well, crazy.  In contrast,
I've reached a point where the Newtonian doesn't look quite so bad
(although I'd still like to work on the speed factor a bit).
Here's the inside of the RK4 integrator, as I implemented it:
  collide(particles_now, forces_now, gravity);
  step(particles_now, particles_stepped, forces_now, dt/2);
  collide(particles_stepped, forces_A, gravity);
  step(particles_now, particles_stepped, forces_A, dt/2);
  collide(particles_stepped, forces_B, gravity);
  step(particles_now, particles_stepped, forces_B, dt);
  collide(particles_stepped, forces_C, gravity);
  for (int i=0; i<size; i++) {
   forces_final[i] =
    (forces_now[i]+2*forces_A[i]+2*forces_B[i]+forces_C[i])/6.0f;
  step(particles_now, particles_now, forces_final, dt);
And stubbed headers for the functions:
collide(data, result, gravity)
This calculates the collisions between particles, and the resultant
forces (gravity is used as the initial, or base, force to start with)
step(data, result, forces, dt)
Applies forces to data with a timestep of dt
PS I just got a collection of all of Chopin's piano music (something
like 15 CDs), and it's great "productivity" music (ie, have on in the
background while I'm working on something else) :)
...Ben Chambers
Subject: Re: I think I did something wrong with RK4...
Date: 7 Apr 2008 02:58:50
Message: <47f9c62a$1@news.povray.org>
If I am guessing correctly, "particles_stepped" includes velocity
information?  Well you need to keep 4 separate copies of the velocity
information just like you did with the force information.
>   forces_final[i] =
Then you need to calculate the weighted sum of the velocities in this manner
too here, and use the weighted velocity in the final step call.
I find it easier if you keep two distinct data structures, one for the state
information (position, velocity), and one for the derivatives
(momentum,force or velocity,acceleration it doesn't matter for point
masses).
Then it is clear that "collide" must return a "derivative of state" data
structure which must be then used in the following step function.  At the
end, you do the weighted average of the "derivative of state" data structure
as a whole.
This allows you to add more stuff easily in future (eg orientation and
angular momentum) without having to worry about the actual RK4 core code.
Date: 7 Apr 2008 03:48:24
Message: <47f9d1c8$1@news.povray.org>
BTW, I get a file not found runtime error with that...
Date: 7 Apr 2008 10:08:40
Message: <47fa2ae8$1@news.povray.org>
Dagnabit, I wish the packaging system would work properly, otherwise I
don't know what dependencies these executables have...
...Ben Chambers
Date: 7 Apr 2008 10:13:53
Message: <47fa2c21@news.povray.org>
Try distibuting executables dynamically linked against GTK+ ;-)
http://blog.orphi.me.uk/
Date: 7 Apr 2008 14:10:01
Message: <web.47fa61df5da3d86b261d9700@news.povray.org>
> >   forces_final[i] =
Sorry, but I have trouble believing that without seeing a proof.  Intuitively,
if I am tracking the velocity information, then why do I need the force
information separate?  But if I integrate the forces, why should the velocity
information be separate?  What I want is a final force value that I can use to
modify my velocity value.
Anyway, looking for other sources on RK4, the Wikipedia article at
http://en.wikipedia.org/wiki/RK4 mentions something that was left out here...
that the weighted average of the forces should be multiplied by the timestep.
That would change the above line to
(forces_now[i]+2*forces_A[i]+2*forces_B[i]+forces_C[i])*dt/6.0f;
This would account for the strange scaling effect I saw.  When I get home
tonight, I'll try it out.
......Chambers
Date: 7 Apr 2008 17:40:37
Message: <47fa94d5$1@news.povray.org>
>   forces_final[i] =
The last time I did a physics simulator (springs and weights), I found
that calculating the change in acceleration, and figuring that into the
new location and velocity data, greatly reduced the error that accumulates.
John
Date: 7 Apr 2008 22:30:45
Message: <47fad8d5@news.povray.org>
That's why I'm calculating forces :)
...Ben Chambers
Date: 8 Apr 2008 02:57:47
Message: <47fb176b@news.povray.org>
>> >   forces_final[i] =
>> manner
> Intuitively,
Because you are performing two integrations in parallel here.  You are
integrating the accelerations to get velocities, and you are also
integrating velocities to get positions.  The way RK4 works is to calculate
the gradients at certain points and then take a weighted sum to work out the
most accurate gradient.  You must do this for the gradients of velocity (ie
acceleration or force) *AND* position (ie velocity).  If you only do it for
one you are not doing it properly.
Because you are also integrating the velocities to get position.
But you also need a final velocity value to modify your position.  This also
has to be calculated using the RK4 method.  So you need to work out the
velocity at each step and remember it, just like you did with the forces.
> here...
> timestep.
No that is wrong, I assume your "step" function already multiplies the
forces by dt when it does the Euler integration?  If not then it should, you
certainly don't need dt to calculate the weighted force.  The weighted force
is the result of the RK4 method, and simply says "this is the best guess of
constant force to be applied over the next dt to get nearest to the true
value of velocity dt time later".
Your code is missing the bit that says "this is the best guess of constant
velocity to be applied over the next dt to get nearest to the true value of
position dt time later".
That is why I said it is best to keep your state information separate from
the derivative information, it is confusing because velocity appears in
both, and if you don't have them separate it can be hard to know which one
to use where.
Have something like:
State {position , velocity }
Derivative {velocity , acceleration }
You can put anything else in your state block, but you must put the
corresponding derivative in the derivative block.  For example, I could
have:
State {position , angle , temperature}
Derivative {velocity , angluar velocity , temperature gradient }
And that would work fine with RK4.
Your algorithm for RK4 is then:
Derivative A = EvaluateDerivative( currentState , dt )
tempState    = Step( A , currentState, dt*0.5 )
Derivative B = EvaluateDerivative( tempState , dt*0.5 )
tempState    = Step( B , currentState, dt*0.5 )
Derivative C = EvaluateDerivative( tempState , dt*0.5 )
tempState    = Step( C , currentState, dt )
Derivative D = EvaluateDerivative( tempState , dt )
BestGuessDerivative = (A + 2*(B+C) + D)/6
newState = Step( BestGuessDerivative , currentState , dt )
And then, Step would simply do an Euler integration step, of *all* members
of your state block, using the corresponding members of the derivative
block.
Step( derivative , state , dt )
  newState = state;
  newState.position += derivative.velocity     * dt;
  newState.velocity += derivative.acceleration * dt;
  newState.angle    += derivative.angularVelocity * dt;
  newState.temp     += derivative.tempGradient * dt;
  return newState;
and EvaluateDerivative will work out the derivative block at that point
EvaluateDerivative( state , dt )
  derivative deriv;
  deriv.velocity        = state.velocity;
  deriv.acceleration    = CalculateAccelerations( state );
  deriv.angluarVelocity = CalculateAngularVelocity( state );
  deriv.tempGradient    = 50;  // example
  return Out;
The line that says "deriv.velocity = state.velocity" is the key to linking
the two integrations of acceleration and velocity.  It makes the output from
the acceleration integration be used as the input for the velocity
integration.  But it does this at each step inside RK4, not just at the end.
Date: 8 Apr 2008 04:05:36
Message: <47fb2750$1@news.povray.org>
Thanks, I'll give it another go tomorrow (too late tonight, unfortunately).
...Ben Chambers
