POV-Ray : Newsgroups : povray.off-topic : I think I did something wrong with RK4... Server Time
3 Nov 2026 10:28:37 EST (-0500)
  I think I did something wrong with RK4... (Message 1 to 22 of 22)
Subject: I think I did something wrong with RK4...
Date: 6 Apr 2008 20:55:28
Message: <47f97100$1@news.povray.org>
Here's a test app for Windows:
http://www.pacificwebguy.com/downloads/TestingRK4.zip
(Note that, although the app itself is named "Threaded_Physics.exe", I
haven't gotten around to implementing the "threaded" part yet.  Right
now, I'm just trying to make it work *correctly*).
Click anywhere on the screen to shoot particles in that direction.
Press F1 to switch between Newtonian integration and Rk4 integration.
The main thing to notice, other than the fact that RK4 is *much* slower
than Newtonian, is that using RK4 seems to amplify the forces somehow.
The result is that everything seems rather... well, crazy.  In contrast,
I've reached a point where the Newtonian doesn't look quite so bad
(although I'd still like to work on the speed factor a bit).
Here's the inside of the RK4 integrator, as I implemented it:
  collide(particles_now, forces_now, gravity);
  step(particles_now, particles_stepped, forces_now, dt/2);
  collide(particles_stepped, forces_A, gravity);
  step(particles_now, particles_stepped, forces_A, dt/2);
  collide(particles_stepped, forces_B, gravity);
  step(particles_now, particles_stepped, forces_B, dt);
  collide(particles_stepped, forces_C, gravity);
  for (int i=0; i<size; i++) {
   forces_final[i] =
    (forces_now[i]+2*forces_A[i]+2*forces_B[i]+forces_C[i])/6.0f;
  step(particles_now, particles_now, forces_final, dt);
And stubbed headers for the functions:
collide(data, result, gravity)
This calculates the collisions between particles, and the resultant
forces (gravity is used as the initial, or base, force to start with)
step(data, result, forces, dt)
Applies forces to data with a timestep of dt
PS I just got a collection of all of Chopin's piano music (something
like 15 CDs), and it's great "productivity" music (ie, have on in the
background while I'm working on something else) :)
...Ben Chambers
Subject: Re: I think I did something wrong with RK4...
Date: 7 Apr 2008 02:58:50
Message: <47f9c62a$1@news.povray.org>
If I am guessing correctly, "particles_stepped" includes velocity
information?  Well you need to keep 4 separate copies of the velocity
information just like you did with the force information.
>   forces_final[i] =
Then you need to calculate the weighted sum of the velocities in this manner
too here, and use the weighted velocity in the final step call.
I find it easier if you keep two distinct data structures, one for the state
information (position, velocity), and one for the derivatives
(momentum,force or velocity,acceleration it doesn't matter for point
masses).
Then it is clear that "collide" must return a "derivative of state" data
structure which must be then used in the following step function.  At the
end, you do the weighted average of the "derivative of state" data structure
as a whole.
This allows you to add more stuff easily in future (eg orientation and
angular momentum) without having to worry about the actual RK4 core code.
Date: 7 Apr 2008 03:48:24
Message: <47f9d1c8$1@news.povray.org>
BTW, I get a file not found runtime error with that...
Date: 7 Apr 2008 10:08:40
Message: <47fa2ae8$1@news.povray.org>
Dagnabit, I wish the packaging system would work properly, otherwise I
don't know what dependencies these executables have...
...Ben Chambers
Date: 7 Apr 2008 10:13:53
Message: <47fa2c21@news.povray.org>
Try distibuting executables dynamically linked against GTK+ ;-)
http://blog.orphi.me.uk/
Date: 7 Apr 2008 14:10:01
Message: <web.47fa61df5da3d86b261d9700@news.povray.org>
> >   forces_final[i] =
Sorry, but I have trouble believing that without seeing a proof.  Intuitively,
if I am tracking the velocity information, then why do I need the force
information separate?  But if I integrate the forces, why should the velocity
information be separate?  What I want is a final force value that I can use to
modify my velocity value.
Anyway, looking for other sources on RK4, the Wikipedia article at
http://en.wikipedia.org/wiki/RK4 mentions something that was left out here...
that the weighted average of the forces should be multiplied by the timestep.
That would change the above line to
(forces_now[i]+2*forces_A[i]+2*forces_B[i]+forces_C[i])*dt/6.0f;
This would account for the strange scaling effect I saw.  When I get home
tonight, I'll try it out.
......Chambers
Date: 7 Apr 2008 17:40:37
Message: <47fa94d5$1@news.povray.org>
>   forces_final[i] =
The last time I did a physics simulator (springs and weights), I found
that calculating the change in acceleration, and figuring that into the
new location and velocity data, greatly reduced the error that accumulates.
John
Date: 7 Apr 2008 22:30:45
Message: <47fad8d5@news.povray.org>
That's why I'm calculating forces :)
...Ben Chambers
Date: 8 Apr 2008 02:57:47
Message: <47fb176b@news.povray.org>
>> >   forces_final[i] =
>> manner
> Intuitively,
Because you are performing two integrations in parallel here.  You are
integrating the accelerations to get velocities, and you are also
integrating velocities to get positions.  The way RK4 works is to calculate
the gradients at certain points and then take a weighted sum to work out the
most accurate gradient.  You must do this for the gradients of velocity (ie
acceleration or force) *AND* position (ie velocity).  If you only do it for
one you are not doing it properly.
Because you are also integrating the velocities to get position.
But you also need a final velocity value to modify your position.  This also
has to be calculated using the RK4 method.  So you need to work out the
velocity at each step and remember it, just like you did with the forces.
> here...
> timestep.
No that is wrong, I assume your "step" function already multiplies the
forces by dt when it does the Euler integration?  If not then it should, you
certainly don't need dt to calculate the weighted force.  The weighted force
is the result of the RK4 method, and simply says "this is the best guess of
constant force to be applied over the next dt to get nearest to the true
value of velocity dt time later".
Your code is missing the bit that says "this is the best guess of constant
velocity to be applied over the next dt to get nearest to the true value of
position dt time later".
That is why I said it is best to keep your state information separate from
the derivative information, it is confusing because velocity appears in
both, and if you don't have them separate it can be hard to know which one
to use where.
Have something like:
State {position , velocity }
Derivative {velocity , acceleration }
You can put anything else in your state block, but you must put the
corresponding derivative in the derivative block.  For example, I could
have:
State {position , angle , temperature}
Derivative {velocity , angluar velocity , temperature gradient }
And that would work fine with RK4.
Your algorithm for RK4 is then:
Derivative A = EvaluateDerivative( currentState , dt )
tempState    = Step( A , currentState, dt*0.5 )
Derivative B = EvaluateDerivative( tempState , dt*0.5 )
tempState    = Step( B , currentState, dt*0.5 )
Derivative C = EvaluateDerivative( tempState , dt*0.5 )
tempState    = Step( C , currentState, dt )
Derivative D = EvaluateDerivative( tempState , dt )
BestGuessDerivative = (A + 2*(B+C) + D)/6
newState = Step( BestGuessDerivative , currentState , dt )
And then, Step would simply do an Euler integration step, of *all* members
of your state block, using the corresponding members of the derivative
block.
Step( derivative , state , dt )
  newState = state;
  newState.position += derivative.velocity     * dt;
  newState.velocity += derivative.acceleration * dt;
  newState.angle    += derivative.angularVelocity * dt;
  newState.temp     += derivative.tempGradient * dt;
  return newState;
and EvaluateDerivative will work out the derivative block at that point
EvaluateDerivative( state , dt )
  derivative deriv;
  deriv.velocity        = state.velocity;
  deriv.acceleration    = CalculateAccelerations( state );
  deriv.angluarVelocity = CalculateAngularVelocity( state );
  deriv.tempGradient    = 50;  // example
  return Out;
The line that says "deriv.velocity = state.velocity" is the key to linking
the two integrations of acceleration and velocity.  It makes the output from
the acceleration integration be used as the input for the velocity
integration.  But it does this at each step inside RK4, not just at the end.
Date: 8 Apr 2008 04:05:36
Message: <47fb2750$1@news.povray.org>
Thanks, I'll give it another go tomorrow (too late tonight, unfortunately).
...Ben Chambers
Date: 8 Apr 2008 07:41:41
Message: <47fb59f5@news.povray.org>
>> the new location and velocity data, greatly reduced the error that
>> accumulates.
Well, yeah.  But whereas force goes to the second derivative of location
over time, it's also helpful to calculate the third derivative over
time, and figure that into the updates for both position and velocity.
The differential calculus behind it isn't that hard, and provides a
better solution than dampening to the wild oscillations produced by sims
that only go to the second derivative over time.
John
Date: 12 Apr 2008 16:34:00
Message: <48011cb8@news.povray.org>
OK, so I did all of that, and I *still* have the problem of the forces
in RK4 appearing to be a different scale from the forces using the
Newtonian method.
Shouldn't I be able to just swap out the two, choosing Newtonian for
speed, or RK4 for accuracy, and see relatively equal* results?
*Obviously not exactly equal, else there's no point.  And also
obviously, the errors inherent in Newtonian will compound over time,
meaning the two sets of results will diverge.
...Ben Chambers
Date: 13 Apr 2008 04:39:04
Message: <4801c6a8$1@news.povray.org>
> OK, so I did all of that, and I *still* have the problem of the forces in
> RK4 appearing to be a different scale from the forces using the Newtonian
> method.
Yes, if your time-step is small enough for Newton to work roughly correctly.
Do you still get the same difference if you reduce the time step by a factor
of 100?  If you do, then it's a coding error, if you don't then it's simply
the fact the Newton is not doing very well at your previous time step
amount.
Did you try a simple system first, eg constant force or very soft spring
from one point?  With a constant force you should be able to calculate the
exact velocity and position by hand and compare with what your algorithm
gives out.
Date: 13 Apr 2008 14:32:56
Message: <480251d8$1@news.povray.org>
>> Newtonian method.
> correctly. Do you still get the same difference if you reduce the time
> step by a factor of 100?  If you do, then it's a coding error, if you
> don't then it's simply the fact the Newton is not doing very well at
> your previous time step amount.
> the exact velocity and position by hand and compare with what your
> algorithm gives out.
OK, I "fixed" the timestep at 1/200th of a second, and removed all
particle collisions - now the only force is that of gravity.
Using the two integrators, the particles follow roughly the same path,
but using RK4 they appear to have an increased velocity - they follow
the same path much more quickly.
Which means I've got an error somewhere in my code...
...Ben Chambers
Date: 14 Apr 2008 03:24:17
Message: <480306a1@news.povray.org>
> Using the two integrators, the particles follow roughly the same path, but
> using RK4 they appear to have an increased velocity - they follow the same
It should be very easy to debug, simply print out (to a file?) the "state"
and "derivative of state" information at each step of RK4 for one particle
(that starts at zero velocity would make things simpler).  eg Just print out
position and velocity in the gravity direciton.
Attached is a spreadsheet I made that matches up with the code I posted
before, it shows you the values at each step for a constant acceleration,
and compares the results with the Euler method and the exact solution.
Hopefully you can spot the mistake in your code...
Download 'rk4.xls.dat' (44 KB)
Date: 14 Apr 2008 11:01:56
Message: <480371e4$1@news.povray.org>
> "state" and "derivative of state" information at each step of RK4 for
> one particle (that starts at zero velocity would make things simpler).
> eg Just print out position and velocity in the gravity direciton.
Thanks, I got it sorted out.  I still don't know what the error was, but
switching from preallocating the arrays to allocating new ones every
step & throwing them away when done solved the problem.
So there must have been some carryover somewhere that I missed.
Anyway, I'll post a binary soon.  I've been going through the forums for
XNA studio, and apparently there's no easy way to distribute games for
windows yet (the whole thing is a work in progress, and they're about to
release yet another version of it).
...Ben Chambers
Date: 14 Apr 2008 13:14:15
Message: <480390e7$1@news.povray.org>
Ah, the evils of mutable state...
...er, wait, ignore me. [Oh, you already are...]
Date: 14 Apr 2008 17:20:44
Message: <4803caac@news.povray.org>
Orchid XP v8 wrote:
>> but switching from preallocating the arrays to allocating new ones
>> every step & throwing them away when done solved the problem.
> ....er, wait, ignore me. [Oh, you already are...]
You know, it's not all that hard to accidentally carry over incorrect
state in a language without mutable state, too. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 14 Apr 2008 22:18:06
Message: <4804105e$1@news.povray.org>
I'm not ignoring you.  It was from reading all your posts on Haskell
that I got interested in immutable values to begin with.  While I'm
still not using them very much, at least now they're in the back of my
mind :)
...Ben Chambers
Date: 15 Apr 2008 03:44:05
Message: <48045cc5$1@news.povray.org>
Cool :-)
Date: 15 Apr 2008 08:21:17
Message: <48049dbd@news.povray.org>
Heh. Do you have *any idea* how long it took me to finish debugging this
JavaScript snippet?
function Bindings_Lookup(key)
   if (this.Key  == key) return this.Value;
   this.Next.Lookup(key);
It took an absurd amount of time to figure this out - especially given
the strange way Firefox responded to it...
Sure, they'll never make a programming language where mistakes are
impossible. But mutable state just offers *so many* ways to shoot
yourself in the foot. :-/
Date: 15 Apr 2008 11:41:37
Message: <4804ccb1$1@news.povray.org>
I don't understand what that has to do with mutable state, since you're
not mutating anything there. It looks like you have the bug of too much
recursion and the bug of not checking for the end of the list, assuming
I'm reading it right.
And yes, firefox seems to crash my machine at least once a day, which is
rather annoying. I've taking to running anything on a remote machine
that takes more than 5 minutes as a nohup job, just in case my machine
locks up.
