POV-Ray : Newsgroups : povray.off-topic : I found this interesting Server Time
28 Jun 2026 03:04:02 EDT (-0400)
  I found this interesting (Message 141 to 150 of 154)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: I found this interesting
Date: 10 Apr 2008 06:03:45
Message: <47fde601$1@news.povray.org>
Darren New wrote:
> There are strict rules, tho.
Looking down this list, it seems I'm aware of these on an instinctive
level. I certainly use commas according to these rules, although I've
never learnt these rules explicitly. Good to know!
>> Just don't get me started on apostrophes :)
> Angry Bob's Apostrophe Rules!
I'd say the 90% of apostrophe abuse would be avoided if people could
remember that apostrophes are never, ever, used for pluralising anything.
Date: 10 Apr 2008 13:37:18
Message: <47fe504e@news.povray.org>
Invisible wrote:
> The "get time" function just returns an I/O command object. You can
> replace that function call with the command object it returns and the
> meaning of the program is left completely unchanged. Thus it is
> referentially transparent.
So if I assign the result of "get time" to a variable and use that
variable in multiple places, do I get the same time each place I use it,
or different times?  I think that's what's confusing me.
   S = get_time()
   print(S)
   do_long_task()
   print(S)
I would think you *want* that to do something different from
   print(get_time())
   do_long_task()
   print(get_time())
How would I write each of those in Haskell?
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 10 Apr 2008 15:48:04
Message: <47fe6ef4$1@news.povray.org>
The key is "using".
Recall that the *only* way to *execute* an I/O action is to return it
from the "main" function. And, since you can only return a single
action, it's how you splice each mini-action into the giant-action
returned by "main" that counts. ;-)
If you splice in two copies of the self same action, that action gets
executed twice. It's that simple.
>   S = get_time()
>   print(S)
>   do_long_task()
>   print(S)
>   print(get_time())
>   do_long_task()
>   print(get_time())
In Haskell, if you use the monadic "do" notation, then the syntax for
executing an action and putting its result into a variable is
   do
     x <- do_stuff
This is technically equivilent to
   ... do_stuff >>= \x -> ...
but less messy on paper. In your case, what you're trying to do is simply
   do
     t1 <- get_time
     print t1
     do_long_task
     t2 <- get_time
     print t2
as opposed to something like
   do
     s <- get_time
     print s
     do_long_task
     print s
which just serves no useful purpose at all. Notice that it's the "<-"
that says "execute this *now*". In the second example, you only execute
the thing once, so it only happens once. It's really quite clear on paper.
In case you care, the desugared equivilents are:
   get_time >>= \t1 -> (print t1 >> do_long_task >> get_time >>= \t2 ->
print t2))
and
   get_time >>= \s -> (print s >> do_long_task >> print s)
You can see why people prefer the "do" notation...
http://blog.orphi.me.uk/
Date: 10 Apr 2008 17:26:22
Message: <47fe85fe$1@news.povray.org>
Yah. :-) I'll have to ponder this s'more.
Subject: [Caution: long monad ramble]
Date: 11 Apr 2008 09:12:11
Message: <47ff63ab$1@news.povray.org>
Understanding *all* of the underlying theory takes a bit of getting used
to. (Wasn't it some physacist who said "you never truly understand new
theories, you just get used to them"?) However, *using* it is pretty simple.
   do
     foo
     bar
     baz
It does those things in the order given. If you assign a result to a
variable, that result stays the same thereafter. And you can do
   do
     foo
     let x = print "hello"
     bar
     x
which will print "hello" immediately after performing "bar". Nothing
hard here. ;-)
Now, the *list* monad... that's another matter! ;-) Not to mention the
Continuation monad. Even the documentation states that "incautious use
of this monad will result in completely unmaintainable code". But then,
that monad is basically for implementing new flow control constructs -
need I say more?
<long theoretic lecture on monads>
Consider the Maybe monad. It's useful for functions that might fail. For
example,
   solve :: Double -> Double -> Maybe Double
   solve a b = if a == 0 then Nothing else Just ((0 - b)/a)
Now, what if you wanted to perform *several* operations in sequence,
each of which might fail? This is what the monadic structure of Maybe
implements:
   foo j k = do
     x <- solve j k
     z <- lookup x table
     ...etc...
This is equivilent to
   foo j k =
     solve j k >>= \x -> lookup x table >>= ...
So you see that ">>=" takes a Maybe and a function that returns a Maybe,
and... well, let me just write the code, it's faster:
   (Just x)  >>= f = f x
   (Nothing) >>= f = Nothing
So when you do "solve j k >>= f", if solve returns Nothing, just skip f
completely and return Nothing directly. Otherwise, take whatever data
came from solve, fish it out of the Maybe value, and feed it to f.
In other words, we can now have a chain of actions where a single
failure triggers an escape from the whole sequence - but doesn't clutter
up the logic of the program on paper.
Now we can do exactly the same thing with lists. If you think about it,
a Maybe stores either 0 or 1 results. Well, a list can store 0 or 1 or 2
or 3 or...
   xs >>= f = concat (map f xs)
As should be clear, if xs is the empty list, f is never run at all, and
you just get an empty list as the result. This is like the Maybe case.
Assuming xs is a nonempty list, run f for every element in xs and merge
the results.
It gets slightly confusing when you start using do-notation, but it's
quite powerful:
   factors k = do
     x <- [1..10]
     y <- [1..10]
     if x * y == k then [(x,y)] else []
This is a very stupid algorithm for finding all factors of k, but it
illustrates how you can use the monadic structure of lists. Saying "x <-
xs" basically means "x takes on all values in xs". Having two such lines
causes the second one to cycle faster than the first one, yielding a
Cartesian product.
Now notice that
   do
     x <- xs
     y <- ys
     f x y
is rather like the list comprehension syntax
   [ f x y | x <- xs, y <- ys ]
In fact, not "rather like", but "mathematically equivilent". Apparently
in older versions of Haskell, comprehensions were permitted for
*arbitrary monads*! But it was eventually decided that this is just "too
insane" and so they removed it. Heh!
Notice that if you write
   factors k = do
     x <- [1..]
     y <- [1..]
you get an infinite loop. It tries all possibilities for y before moving
on to the next possibility for x. To overcome this, you need a custom
monad. My book at home shows you how to implement a "diagonal list"
monad. It looks just like a list, but the [very complicated] monadic
bind tackles combinations in diagonal order. [(1,1), (2,1), (1,2),
(3,1), (2,2), (1,3), (4,1), (3,2), (2,3), etc.] The bind function given
is possibly the most terrifying snippet of Haskell I have ever seen in
my life...
</long theoretic lecture on monads>
PS. If you've got a moment, there's a Tcl implementation of my logic
solver over in the povray.off-topic.haskell. I'd be interested to know
if you can make it any less... butt-ugly, for want of a better word!
Subject: Re: [Caution: long monad ramble]
Date: 11 Apr 2008 12:12:46
Message: <47ff8dfe$1@news.povray.org>
OK. Same as Erlang. :-)
> And you can do
>   do
>     foo
>     bar
>     x
> hard here. ;-)
Same as Erlang, except you'd have to make it explicitly a fun (aka lambda).
> example,
solve(A,B) when A == 0 -> nothing;
solve(A,B) -> ((0-B)/A).
(Note that "nothing" here is just an "atom", i.e., an interned string, a
LISP "symbol", a Smalltalk "symbol", etc. It's not a special value or
type. Just something you can match on later.)
do_maybe(Fun, X) when X == nothing -> nothing;
do_maybe(Fun, X) -> Fun(X).
Probably not equivalent in a deeper sense.
But you're giving me some ideas for some higher-order functions I
probably need. I still miss "while" loops, but I've been trying to
figure out how to make while() into a function that takes two lambdas. :-)
Yep.
> or 3 or...
> the results.
> quite powerful:
>   factors k = do
>     x <- [1..10]
>     y <- [1..10]
In Erlang:
factors(K) ->
   Seq = lists:seq(1,K),
   [ X*Y || X <- Seq, Y <- Seq, X * Y == K ].
Thanks for the explanation. I'm still not 100% sure what the "value" in
the monad returned by getclock looks like, tho. I know it's supposed to
be opaque, but what in theory is in there, could you say?
Wow. You have your own newsgroup. :-)
I'll take a look.
Date: 11 Apr 2008 14:46:50
Message: <47ffb21a$1@news.povray.org>
>> For example,
Heh. I remember using symbols in Smalltalk. Just for the love of God,
don't try to mutate them...!
No, that's more or less exactly it. Oh, except that "f" is type
constrained to *also* return a Maybe value. (But not necessarily
containing the same type of data.)
Well now, doesn't that rather depend on what this loop is supposed to
*do*? ;-) In Haskell, we have several different while loops, all for
different jobs.
There's takeWhile, dropWhile and span which chop up segments of lists.
There's "unfoldr" which builds lists. There's "until", which repeats a
computation until a condition holds, and returns the final result. And
so on...
>>   factors k = do
>>     x <- [1..10]
>>     y <- [1..10]
> In Erlang:
> factors(K) ->
Like I said, Haskell also possesses list comprehensions, and they are
intimately related to monadic expressions. In Haskell, one could write
   [ x*y | x <- seq, y <- seq, x * y == k ]
Interestingly, Haskell possesses a "guard" function:
   guard (x*y == k)
   return (x,y)
If the condition fails, guard aborts the rest. Otherwise it continues.
Similarly "when" runs or doesn't run just one part of a computation.
I should perhaps also mention "return" and "fail" somewhere. All monads
have a "return" method that inserts a single element into the monad:
   return 5 >>= print
is the same as just "print 5". The "fail" method takes a text message
and aborts the computation. For Maybe or lists, the message is ignored,
but for the IO monad it throws an exception. There are monads that allow
you to actually *use* the description for something useful. It's
basically so that pattern match failures inside a monad trigger the
monad's error-handling abilities rather than throw an exception...
Theoretically, you might have something like
   data IO x =
     CMD_GET_CHAR Handle |
     CMD_PUT_CHAR Handle |
     CMD_TEST_EOF Handle |
     CMD_GET_CLOCK_TIME |
But in reality, I believe GHC actually implements it as a structure
holding a raw pointer to a C function that actually does the work. Note
that it's 100% compiler-specific how IO is actually implemented though.
It's completely outside the language spec... ;-)
So, when you hold an "IO Int", you're probably just holding a pointer to
a C function which, when executed, is going to return an integer.
Where *have* you been dear boy? ;-)
> I'll take a look.
TY.
Date: 11 Apr 2008 21:30:22
Message: <480010ae$1@news.povray.org>
> so on...
Erlang has all that stuff. They aren't "while" loops, tho, they're "for"
loops. No way to stop foldr() early, no way to have it get its stuff by
(say) reading lines from a file instead of a list, etc.
No way to say "while you haven't gotten to a directory entry that starts
with the letter 'T' in /tmp, ...."
>   guard (x*y == k)
>   return (x,y)
That's what the "when" stuff above is - guards.
And a case statement and an if statement both use guards, as does the
message receiving.  The languages do seem very close to each other in
capability, from my naive view.
>   return 5 >>= print
Odd name. Not sure what that means. :-)
And Erlang crashes the process out, which sends "I crashed" messages to
anyone "linked" to that process, which in turn either crashes them out
or just queues a message saying they crashed.
>   data IO x =
Hrm. OK.
Well, I remember it being created as a joke, but I never subscribed. :-)
Date: 12 Apr 2008 02:50:59
Message: <48005bd3@news.povray.org>
>> so on...
foldr is a for-loop, but unfoldr *is* a while-loop, as are the others I
quoted.
do
   fs0 <- getDirectoryContents "/tmp"
   let fs1 = sort fs0
   let fs2 = takeWhile (\f -> head f /= 'T') fs1
   mapM (stuff) fs2
>>   return 5 >>= print
Definitely an odd choice of name! "insert" or something would at least
make more sense. (That's what it does after all - insert a pure value
into a monadic wrapper...)
>> ignored, but for the IO monad it throws an exception.
Haskell has a function called "error" which takes a message and then
throws an exception containing that message. Unless exceptions are
caught somewhere [which can only happen in the IO monad], the default
behaviour is for the program to exit and write a message to stdout.
"fail" is different to "error" in that it is specific to a particular
monad. So for the IO monad, fail = error. But for Maybe, fail just
returns Nothing. And for some other user-defined monad, it could do
something else instead.
factors k = do
   x <- [1..10]
   y <- [1..10]
   if x*y == k then return (x,y) else fail "not a factor"
That does the same as the other example, while being [debatably] clearer.
Better yet: As far as anybody knows, messages never expire! >:-)
Date: 12 Apr 2008 12:46:04
Message: <4800e74c$1@news.povray.org>
> quoted.
I see the confusion. Erlang isn't lazy.
Immortally famous!
