POV-Ray : Newsgroups : povray.off-topic : I found this interesting Server Time
7 Jul 2026 14:33:24 EDT (-0400)
  I found this interesting (Message 135 to 144 of 154)
Subject: Re: I found this interesting
Date: 9 Apr 2008 17:44:32
Message: <47fd38c0$1@news.povray.org>
"Fredrik Eriksson" <fe79}--at--{yahoo}--dot--{com> wrote in message
news:op.### [at] e6600bredbandsbolagetse...
> On Wed, 09 Apr 2008 22:39:53 +0200, Orchid XP v8 <voi### [at] devnull> wrote:
>> Question: is "comelia" a word?
> "Comelia" is a name.
    Ah, ok, so perhaps the lyrics went: "Karma, karma, karma Comelia"?
     Very possible.
      ~Steve~
> FE
Date: 9 Apr 2008 22:09:08
Message: <47fd76c4$1@news.povray.org>
>      Very possible.
>       ~Steve~
Or "Karma Chameleon".
Wait, why am I admitting to remembering this song?
Date: 10 Apr 2008 00:25:43
Message: <47fd96c7$1@news.povray.org>
Orchid XP v8 wrote:
>> Erlang has first-class functions as well as closures. Indeed, there
>> are warnings in the docs saying things like "take care if you store a
>> closure in a database that when you fetch it back out to run it,
>> you're running the same version of the interpreter." :-)
> Ooo. So much for "you can upgrade stuff in-place without shutting down".
> :-P
Heh. Well, you know, I don't think you can actually upgrade the
interpreter itself without shutting down the node you're running on. On
the other hand, you could in theory start up a new interpreter, ship the
running stuff over to it, then shut down the old one.
Upgrading without shutting anything down is easier when it's only Erlang
code you're upgrading, and not the VM itself, but you *can* do it with
enough forethought.
> [Mind you, persistent *closures*? That's got to be a fairly rarely used
> feature...]
Yah.  That they even mention it boggles my mind.
> The I/O monad is unusual as monads go, but essentially the I/O functions
> return I/O command objects instead of actually *performing* I/O,
Yeah, that I figured out. I'm just trying to wrap my head around how
that would work with (say) the clock, or the status of whether your ISP
is currently screwy, or something like that, just in terms of
"referential transparency".
I'm trying to figure out conceptually how you represent "the clock" for
example in a way that it's "referentially transparent".  Or can you not
actually do that, and that's the point of a monad?
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 10 Apr 2008 01:12:20
Message: <47fda1b4$1@news.povray.org>
"Sabrina Kilian" <"ykgp at vtSPAM.edu"> wrote in message
news:47fd76c4$1@news.povray.org...
>>      Very possible.
>>       ~Steve~
  LOL! That's it!
  I know, I can't stand it either...
     ~Steve~
Date: 10 Apr 2008 04:31:27
Message: <47fdd05f$1@news.povray.org>
>> used feature...]
5th rule of software design: If it's technically possible to use your
product in a certain way, somebody will try to actually use it that way.
You *know* this to be true! ;-)
>> functions return I/O command objects instead of actually *performing*
>> I/O,
I'm going to go with "you can't - hence the monad".
The "get time" function just returns an I/O command object. You can
replace that function call with the command object it returns and the
meaning of the program is left completely unchanged. Thus it is
referentially transparent.
The Haskell runtime actually *gets* the clock time, and it does this
theoretically "after" the Haskell code has already been run and
generated its giant command object, so...
http://blog.orphi.me.uk/
Date: 10 Apr 2008 04:32:36
Message: <47fdd0a4$1@news.povray.org>
 >:-D Hahahaha!
Date: 10 Apr 2008 06:03:45
Message: <47fde601$1@news.povray.org>
Darren New wrote:
> There are strict rules, tho.
Looking down this list, it seems I'm aware of these on an instinctive
level. I certainly use commas according to these rules, although I've
never learnt these rules explicitly. Good to know!
>> Just don't get me started on apostrophes :)
> Angry Bob's Apostrophe Rules!
I'd say the 90% of apostrophe abuse would be avoided if people could
remember that apostrophes are never, ever, used for pluralising anything.
Date: 10 Apr 2008 13:37:18
Message: <47fe504e@news.povray.org>
So if I assign the result of "get time" to a variable and use that
variable in multiple places, do I get the same time each place I use it,
or different times?  I think that's what's confusing me.
   S = get_time()
   print(S)
   do_long_task()
   print(S)
I would think you *want* that to do something different from
   print(get_time())
   do_long_task()
   print(get_time())
How would I write each of those in Haskell?
Date: 10 Apr 2008 15:48:04
Message: <47fe6ef4$1@news.povray.org>
The key is "using".
Recall that the *only* way to *execute* an I/O action is to return it
from the "main" function. And, since you can only return a single
action, it's how you splice each mini-action into the giant-action
returned by "main" that counts. ;-)
If you splice in two copies of the self same action, that action gets
executed twice. It's that simple.
>   S = get_time()
>   print(S)
>   do_long_task()
>   print(S)
>   print(get_time())
>   do_long_task()
>   print(get_time())
In Haskell, if you use the monadic "do" notation, then the syntax for
executing an action and putting its result into a variable is
   do
     x <- do_stuff
This is technically equivilent to
   ... do_stuff >>= \x -> ...
but less messy on paper. In your case, what you're trying to do is simply
   do
     t1 <- get_time
     print t1
     do_long_task
     t2 <- get_time
     print t2
as opposed to something like
   do
     s <- get_time
     print s
     do_long_task
     print s
which just serves no useful purpose at all. Notice that it's the "<-"
that says "execute this *now*". In the second example, you only execute
the thing once, so it only happens once. It's really quite clear on paper.
In case you care, the desugared equivilents are:
   get_time >>= \t1 -> (print t1 >> do_long_task >> get_time >>= \t2 ->
print t2))
and
   get_time >>= \s -> (print s >> do_long_task >> print s)
You can see why people prefer the "do" notation...
Date: 10 Apr 2008 17:26:22
Message: <47fe85fe$1@news.povray.org>
Yah. :-) I'll have to ponder this s'more.
