POV-Ray : Newsgroups : povray.off-topic : 33rd anniversary of .... Server Time
19 Oct 2026 21:03:05 EDT (-0400)
  33rd anniversary of .... (Message 1 to 24 of 24)
Subject: 33rd anniversary of ....
Date: 4 Apr 2008 10:21:24
Message: <47f64774@news.povray.org>
Bill Gates' and Paul Allen's partnership today
Don't know whether to laugh or cry
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Subject: Re: 33rd anniversary of ....
Date: 4 Apr 2008 12:00:25
Message: <47f65ea9$1@news.povray.org>
Think of it this way - without Microsoft, we probably wouldn't have
enough similarity between hardware platforms that something like Linux
ever got off the ground. :-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 5 Apr 2008 08:01:15
Message: <47f7781b@news.povray.org>
True dammit :-(
Date: 5 Apr 2008 23:55:36
Message: <MPG.2262058b5dd37af198a13c@news.povray.org>
In article <47f7781b@news.povray.org>, doc### [at] gmailcom says...
> True dammit :-(
Well, maybe true. We also might have ended up with a mil-spec system
that is stable, required to operate in a wide range of conditions, and
clearly documented interfaces. What we have is unstable, often doesn't
operate even in the conditions it supposedly was designed for, and even
the clearly documented interfaces, like modem commands, get screwed up
by nonstandard interfaces/drivers/control mechanisms, which where
designed to work only with specific OSes.
In other words, we started with 100 species of machines, none of them
alike, and ended up with something that... has almost as many hacks,
bugs, design short cuts, and stupid compromises as human DNA (and not
because those things "worked" better than the other paths tried). If the
military built aircraft the way Microsoft, to a large degree, and
others, to different degrees, pushed us to produce computers, we would
be losing billion dollar airplanes once a week, half of them in the
first moments of flight, when some obscure set of conditions caused the
wings to fall off.
Its a logical fallacy to presume that Microsoft was "necessary", any
more than just about any other absurd thing that led to the modern world
"had to" happen to get here. Even if true, the real question is, "Was
the price paid to do so *worth* it, given other paths that may have led
to the same thing?"
PCs imho where inevitable. Had Microsoft not shown up, someone else
would have. Eventually, some standard would have appeared. Likely, given
the wide us of Unix, it would have been a *nix standard. And,
interestingly enough, Microsoft is the **only** brand name, other than
in the embedded market, where standardizations isn't necessary as much,
which isn't going that way "anyway". So, did we really need them to muck
things up?
void main () {
  If Schrödingers_cat is alive or version > 98 {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 6 Apr 2008 14:21:19
Message: <47f9149f@news.povray.org>
We might have, but I doubt it.  That would be over-engineering to a
tremendous degree.
Where such things are necessary, they're built without too much trouble
beyond tremendous time and cost.
This is pretty much true of every piece of long-lived general-purpose
software. It's impossible to foresee every eventuality. If your OS
doesn't support removable media or streaming 3D holograms, you're going
to have unstable programs that don't work right when you remove the
media out from under them or stream 3D holograms into their input files.
But we have that mainly because of age and backward compatibility. It's
not like "autoconf" is a gem either, and for exactly the same reason.
> If the
> we would be losing billion dollar airplanes once a week,
They wouldn't cost a billion dollars. They'd cost $1000, and they'd run
pretty well until you put a trailer hitch on them and tried to tow your
RV behind. :-)
Of course.  What do you see as a motivating factor for hardware to get
standardized beyond someone selling a fairly cutting-edge software
package not tied to a particular piece of hardware?
> to the same thing?"
Except they didn't. The world had the chance for 10 or 15 years, and
there were just as many competing incompatible brands when PC-DOS came
out as there were ten years earlier.
I disagree. UNIX puts too many requirements on the hardware for it to
work at the time.  What we *did* get that was vaguely standard was CP/M,
which is what PC-DOS was based on.
And, OK, which UNIX? Why do you think it would have been a standard, and
which one, and would it really have led to there being fewer flavors of
UNIX to program against? Even now, there's a dozen or more flavors of
UNIX in current use. We already *have* a "unix standard". You *still*
need autoconf, and it's broad enough Microsoft managed to implement it
in Windows (for some meaning of the word "implement").
Blame BSD for that, perhaps?
Date: 7 Apr 2008 00:24:03
Message: <MPG.22634fcf50c1a90698a13d@news.povray.org>
In article <47f9149f@news.povray.org>, dne### [at] sanrrcom says...
> > to the same thing?"
Neither did cars, until Ford, and frankly, Ford did it right, while
MS... didn't care about doing it right, so much as doing it profitable.
That is the difference between visionaries getting involved with an
industry, vs. those who just see a clear way to make a more cash.
n
Point was, it didn't have to be PC-DOS. Windows wasn't able to run on
those either.
Even with the need to make some adjustments, there is still a basic
standardization to internals, and commands. Windows new shell even
borrows the later, in a form of Bash like shell, since their own sucked
so badly. lol Look at cars. While there isn't much of a standard, and
not *every* part is interchangeable any more between makers, you can
still manage to weld together bits from different cars and have
something that still functions, and you can take parts from dozens, and
use them to build a car that "none" of the manufacturers would produce
themselves, and odds are, despite some specific differences, and a few
adaptions, most of its isn't going to flat out refuse to work right
because you plugged a Ford transmission into a Mitsubishi motor, in a
Chevy frame.
Yes, fragmentations is bound to happen ones the "foundation" is there.
The problem is, how you get to that foundation. MS kind of forced the
industry to build from the top floor down, and as a result often the
stuff on the lowest level doesn't always work reliably, while the OS
itself *is* standard, so it "looks" like the building is intact, even
though its shifting on the loose rubble on the bottom level, like a
drunken sailor on marbles. *nix went the other way. The foundation is
very close to the same, to a degree that it take relatively little to
adjust core processes between them, the hardware, when there is
documentation, and some sort of common interface, just works, without
having to have 234 device drivers (including different versions, and
multifunction devices, which may have 4-5 drivers), for 100 devices.
But, my point is. You can't reliably project from "because it happened
this way.", to, "It needed to happen that way." We have hindsight here,
and we still can't get out of the hole already dug, to try to fix the
problems that arose due to how it did happen.
void main () {
  else
Date: 7 Apr 2008 01:35:58
Message: <47f9b2be$1@news.povray.org>
And what makes you say this?
Sure. But it was.  It had to be someone without a vested interest in one
particular brand of hardware, tho.  You didn't see Sun porting Solaris
to other peoples' chips until they realized they couldn't compete with
Intel as long as Windows was the problem. (Same reason they wrote Star
Office, same reason they've been battling Microsoft all along.)
 > Windows wasn't able to run on those either.
Windows ran on lots of machines where a fuller UNIX wouldn't. I'm not
sure what "those" means, unless you mean 8080-class chips, at which I'll
agree but wonder why you bring it up.
Windows could do a lot more with a lot less hardware. And it was PC-DOS
compatible.
And PC-DOS was very compatible with CP/M, conceptually. Indeed, the
original design was that you should be able to reassemble/recompile your
CP/M programs for 8086 and have them run under PC-DOS.
As with various versions of Windows. Yes?
> Chevy frame.
I see. That's why Apache and MySql and VI don't work at all under
Windows, yes?  I was wondering why that was.
I didn't mean to imply it did. *Someone* had to come along and make some
version of hardware a reasonable target for something like Linux before
Linux could get popular enough to snowball.  Lots of people wrote
operating systems for 8080-class machines, and none of them took off
(except CP/M) because they were all written to specific machinery by the
manufacturers of the machinery.  Once you had someone realize "Gee, we
can write the software *without* building the machinery", that's when
you start seeing "clones."
And while I admire your ability to turn a phrase, the hyperbole really
doesn't manage to communicate anything of interest other than your
distaste for Microsoft's products. You speak as if every day there are
thousands of people dying from Microsoft products, or that every
business that uses Windows goes broke trying to keep it running for more
than a few hours.
Date: 7 Apr 2008 12:24:45
Message: <47fa4acd$1@news.povray.org>
> Chevy frame.
Forget interchange of parts. With cars, if you learn to drive, you can
drive any car of any manufacturer. Doesn't seem to be the case with
operating systems, or with applications.
Date: 7 Apr 2008 19:12:31
Message: <MPG.226458149adb4f998a13e@news.povray.org>
In article <47f9b2be$1@news.povray.org>, dne### [at] sanrrcom says...
True.
> compatible.
Yeah, so what went wrong? lol Lets see. Code bloat, people actually
wanting to be able to transfer documents between unlike systems (with
filenames intact), oh, and an endless list of cases where people
"tried" to make something run on alternatives, but MS changed theirs in
some way that either broke the alternate, or broke their code "on" the
alternate. But sure. If they hadn't tried to rule the world, just live
in it, some of us might not be so annoyed by them.
Umm. Not really.. Half the stuff that doesn't work between 3.1 and XP is
a result of hacks needed to make it work right at all on 3.1, but which
where bugs, hole or unintended interfaces. The other half are cases
where MS changed the underlying implementations, so you just *can't* do
it any more. They are still doing that, releasing .NET, then basically
making it very very hard to code anything with MFC. Sure, it will still
*run*, usually, but its fairly clear that, if they could, they would rip
out all those old libraries and bury them, never mind what inconvenience
it might cause anyone.
> > Chevy frame.
Sorry? Are you saying all of those just had some bits of code lopped
off, some new code tacked on, then recompiled, because... I get the
impression its a *tad* more complicated than that most of the time. lol
Besides, your talking what is basically command line systems, which just
"happen" to have GUIs built to access them. Or, to put it another way.
Mind you, you get some of the same with Linux, depending on if its X, or
some other GUI you are running, but I get the sense that the gaps you
have to leap are "slightly" less cavernous. Besides, now you are talking
about odometers, gas gages, or steering wheels, which is a bit higher
level than the "core" systems.
> than a few hours.
Which version? lol Seriously though, forgive me if I would prefer to
avoid MS in my critical life saving devices. ;)
Ok, its not that bad, "anymore". It was, not that far back. I might
argue that we have, partly in XP, and hugely in Vista, traded stability
for the equivalent of some goon at the door saying, "Now, you know we
can't do nothing about the bad guys outside, so whys you want to leave?
Just stay here, nice and safe like, and let us decide if that packet
shood get sent or not." Security via not letting you do anything. Or an
admittance that they can't stop the stuff that "requires" that kind of
security. Either way, I didn't like 95/98 because it robbed me of a lot
of control I *used to have* over my system. XP, is kind of getting on my
nerves, and what I have seen of Vista... Well, I am not the only one fed
up at this point.
void main () {
  else
Date: 7 Apr 2008 19:17:34
Message: <MPG.22645948fb578fc798a13f@news.povray.org>
In article <47fa4acd$1@news.povray.org>,
nic### [at] gmailisthebestcom says...
> > Chevy frame.
True too. But just ask my father about that, he might disagree. His
favorite gripe is, "Why the #@$# can't they standardize where basic
controls like windshield wipers, emergency lights, etc. are located?" I
kind of have the same gripe, due to where I work, with how they can't
seem to decide where to put fracking door handles, or how they open the
door. Interestingly, this is one common factor in Windows upgrades too.
They can't decide where to put things, so keep changing them, and every
version you have to rediscover where they put the blasted speed control
from the wipers. Trivial, until you find yourself **needing** to change
it, but trivial enough, its probably "not" going to be the first thing
you try to figure out the new location for.
void main () {
  else
Date: 8 Apr 2008 13:35:42
Message: <47fbacee$1@news.povray.org>
Sure, bloat my OS code with printer drivers. I'll take that over having
six disks of printer drivers distributed with each application any day.
 > people actually
> filenames intact),
Never really had a problem with that...
> alternate.
Well, sure.  Even in the cases where that was deliberate, I'd still say
"well, duh."
Yes. If you take advantage of bugs or undocumented interfaces, or bypass
the API to try to do the same thing yourself without using the API, then
when the API gets upgraded, your program breaks.
It's not like nothing got rewritten since System 7 either. This is all
normal computer stuff that happens on every operating system and
application and framework everywhere.
> it any more.
Sure. See above. If you want a multi-user system, you can't take a
single-user application and expect it to run without giving it undue
privileges.  I mean, heck, even POV-Ray had to get beaten over the head
before it stopped writing per-user configuration into per-computer
directories. How long was Windows doing multi-user systems before Vista
finally said "OK, enough, really, you have to deal with multi-user
configuration"?
Things that are actually written to the documented APIs port
surprisingly well. If you write your own INI file parser, don't expect
the next upgrade of Windows to put your stuff in the right place in the
registry for you.
In what way are they making it hard?
 > Sure, it will still
And this differs from the desires of every single programmer inheriting
a legacy system in what way?
>>> Chevy frame.
No. I'm saying none of those programs "flat out refused to work" on any
OS, including Windows and variants of UNIX.
Well, yes, so? And putting a Ford headlight in a Ford car is going to be
much easier than putting a Ford headlight in a Toyota. (Note that there
used to be two kinds of headlights: Round, and Square. Now there's a
whole bunch.)
I haven't any clue where your analogy is supposed to be going. You seem
to be arguing that since cars are built from physical parts, Windows sucks.
I certainly would too. But then, I'd avoid Linux in those same situations.
IME, hardware is much flakier than software. I have about 40 Linux
servers I'm controlling right now. Between the colo "testing" their
generator and frobbing the power on and off, the bakery dumping a
50-pound bag of flour into the fans, the brand new expensive Dell
servers just deciding the disk controller doesn't exist any more, I've
had way more crashes than anything in software causes.
I've also worked at companies where the servers were running Windows,
and they just never died unless the hardware did.
Indeed, the worst OS I've used is actually Solaris, where we had to
rearchitect a number of services to account for the bugs in the OS that
would (for example) not reap processes spawned by cron such that even
kill -9 didn't stop them, or write file data over top of the inodes just
because the disk got busy.
So I don't know what kind of professional experience you've had with
long-running Windows machines, but "drunken sailor on marbles" is far
from my experience.
I had no problems with keeping Win2000 servers running indefinitely. We
had them locked down in a different state, with the only access being
remote unless you wanted to hop on a plane for a couple hours.
That's 8 years back, now.
Sure, DOS could get locked up pretty easily. WFW worked surprisingly
well for the time and the power of the machines it was on.
Try running Unix on a machine with no virtual memory, no memory
protection, and the kernel in the same address space as the user
programs, and see how well it runs.
Again, a bizarre analogy. How about explaining what you dislike about XP
by means of a reference to computers rather than to the Godfather movie?
 > Or an
> security.
What kind of "stuff" are you talking about?
Like what?
> up at this point.
Yeah, Vista is certainly a step back in many ways. Many of the problems
it's trying to solve, tho, are people who are saying "I should be able
to do anything I want, oh and when it breaks we'll blame Microsoft."
The thing I don't really understand is the number of people who use
MacOSX, Linux, and Windows, and complain that Windows asks for
confirmation for privileged operations, but equally croon about how
great Linux is that you have to sudo a program so you know it's
something dangerous.
Date: 8 Apr 2008 13:37:14
Message: <47fbad4a$1@news.povray.org>
No more true than with OSes, I think. Try driving a school bus, an
18-wheeler, a formula 1 race car.
It's more like "once you know how to work one Windows app, you know how
to work them all", or "once you know how to work one MacOSX app, you can
figure out how to work all the others."
Date: 8 Apr 2008 20:31:44
Message: <MPG.2265ba7b66df1e7898a140@news.povray.org>
In article <47fbacee$1@news.povray.org>, dne### [at] sanrrcom says...
Umm. Actually, I was referring to Windows there, not the bloat in Linux,
which at its most bloated looks anorexic by comparison. lol
>  > people actually
> > filenames intact),
Well, it didn't come up often, but some times...
s
True enough. One wonders why most of that stuff was so deeply buried in
the first place though. Try, for example, writing your own program,
which doesn't use IE core or export to wsh, so that it can a) run
scripts, b) use "createobject" like COM support *and* also correctly
bond those objects connection points to event managers. Two years I have
been looking for a solution and all I have gotten is "Well, why no just
rewrite everything in .NET, .NET is magical (never mind it seems to have
some similar problems), or 2-3 articles involving work arounds, none of
which supply useful example code, but just babble about theory and how,
"If you are as skilled and well versed as I am, implementing this
wizbang solution should be trivial!". Uh, yeah, that *kind of* why I
went looking for answers, because some of us don't have leet skillz. lol
Even knowing, in theory, all the bits that make it work, I can't find
any damn way to use it, without practically rewriting the entire program
I want to do it in from scratch, and then, it might still not work. Bad
enough when you don't document unknown interfaces, but to intentionally
make every single library so that it *prevents* people from being able
to use the documented interfaces to do anything but use early bound
objects... That is just perverse.
> > it any more.
> configuration"?
> registry for you.
Yes, yes, I can understand that. Tha isn't the problem though. Its not
privilege levels that are being screwed up, its stuff like the patch
that prevents you executing certain types of packets on a network, which
only inconveniences the hackers, but, in some configurations/networks,
also hoses certain tools use to do determine what is wrong with your
network. And then there are issues like deciding that no one is going to
care if you make 99% of all games prior to Vista stop working, because
you think you have a *better* solution for sound support than 20 years
of sound card manufacturers, and it doesn't actually try to support the
old method. Sure, lots of processing power. But, are you *sure* that
**no one** is going to be trying to use any of it for other things
"while" playing the games that need that sound?
Look, we can go back and forth all day about why they decide to do some
things, how its bad, or not bad, etc. Just saying, if you are the guy
that needs something to work the way it did, and not the other 90% who
don't know a phone jack from a cat5e jack, some of this stuff is a pain
in the ass when they start messing with it.
Umm. Other than buying the full compiler because they decided that the
"free" version would only support the newest version, there is the fact
that MFC was a bonehead design to start with, and its not easy to recode
any of it to work under a different library. Mostly, in my case, its
that I never had a reasonably up to date copy of MS' compiler, so I
would have to sell a kidney to be able to make changes to a product
written in something that they don't freely support. Which seems wacky
to me. You would think that writing the .NET system and releasing it
would cost "more" than dropping the 10+ year old MFC libraries on a
website and saying, "we don't support this anymore, but for that that
want it, here you go." They are going to charge me for the stuff that
obsolete, but not the newest stuff?
Yeah, yeah, I know the reason. It doesn't help my mood when I look at
the price tag. lol
s.
No, I mean that I was talking about core features, while you are talking
about a layer higher than that. Its bound to be easier, within limits,
to rewrite something where 90% of the function is "in" the application
and its only a few interfaces and the display that need tweaking. Its a
bit more serious if the heart of your application is relying on some
core feature working, which doesn't work the same on the new OS, or come
close enough to patch over.
Point was, unless its hardware related (and that is a whole new can of
worms), *nix isn't likely to have too many of those, even between
different "versions".
Got an external HD with similar issues. Power goes out, I have to reboot
for some reason (something messed up Halo so bad I had to reinstall,
after rebooting, since it froze solid), and the drivers and drive
monitor both insist that its unformatted... Not as bad as insisting it
doesn't exist, but geeze... Oh, well, they hosed the backup software on
it anyway. It doesn't backup anything not in its "approved" list,
including settings, databases for your browser and email, etc... Oh,
and, just to be real jerks, they don't sell an upgrade that *does* work
like the older version that did do all those things. WTF?
Gah.. Ok, that is just nuts. Yeah, if someone can manage to fowl up
something that is *usually* stable, they will find a way to do it.
> from my experience.
Oh, Windows 95 worked great, so did Win3.1, as long as I was careful
what I let it patch over. XP has been good so far. 98... Lets not talk
about it. lol
Because, its like having a goon sitting "inside" your house telling you
what *you* are allowed to do sometimes, instead of standing "outside"
the house, to protect you from the real problems. Sure, some people
*need* the goon, since they are not too bright and will do dumb things.
I get a bit annoyed trying to learn how to "not" do dumb things and
having the goon tell me, "Yous sure you wanna do that?", all the time,
even when I know that it will work. Its almost as bad, but less
intrusive, than the stupid paperclip thing they had/have in certain
applications.
>  > Or an
> > security.
Umm. People making your machine a zombie. They seemed to figure that no
one has a legitimate reason to create certain types of arbitrary
packets, so no one would mind if they limited what zombies could do,
even though it also torpedoed things that used the same principle to
work, and where legitimate products. Heh, its just one I ran into
recently, not a huge issue, but its not the only thing I hear people
griping about with how they did Vista's security model (and also partly
XP).
> Like what?
Mostly trying to fix things if they broke, or changing settings that
even the admin user doesn't necessary have clear access to. I haven't
run into it recently, since for the most part the case where you needed
to do those things where ones where it was just easier to find some
other way to solve the problem. I am not going to go into a list, since
its been a while since I used either OS, and I don't remember half the
annoying things I tried to adjust in them. (some there cases where you
could only change the setting via regedit though).
d
> > up at this point.
lol Yeah. Though, at times I wish Sudo existed on Windows. Frankly, I am
running, and shouldn't be, in a full access user, precisely because I
know if I change to a protected one I am going to be spending way too
much time arguing with the OS about what I am doing, or situations where
a sudo would solve an issue real easy, but where only logging out and
back in as admin would fix in Windows (and having to close down
applications that I either don't want to, or can't afford to if they are
doing something, like BeyondTV. Mind you, once in a while you get one of
the system updates that the OS **incists** you reboot with, and you
don't even realize it happened until the next morning when you find that
a) the applications you had open are all closed and b) what ever you had
it doing overnight never finished... There doesn't seem to be a "let me
fracking reboot when "I" want to option. Instead it keeps popping up
ever 5-10 minutes to ask you, "Heh! You done yet. Want to reboot?" No
frell you!!
void main () {
  else
Date: 8 Apr 2008 21:15:15
Message: <47fc18a3$1@news.povray.org>
I was too. I guess you never actually used DOS or something.
What "stuff"??
Don't even *start* talking about sound being poorly supported on Windows
until you've made sound work on Unix.
I agree. Of course. I'm just disagreeing that this is unique to one
operating system, or even that it's avoidable.
So, by "hard to support", you mean "commercial."  Come on, it's not
*that* expensive.
> the price tag. lol
Well, why are you even supporting Windows, then? It's a commercial
product. If you want to work on stuff for free, there are excellent
alternatives available.
I'm not sure what you consider a "core" feature. Me, it's starting a
program, reading and writing files, using internet connections, normal
windows widgets like scrollbars and text entry, etc. I have zero problem
moving my core programs between Windows and Linux with appropriate
libraries underlying.
Well, yes.
I disagree. Where's /dev/mt?  Do you have /proc under Solaris?
And again, I point to autoconf as a trivial counterexample. Take a look
at all the things autoconf can configure, and tell me which of those are
hardware related, and which you're unlikely to need in a "core" application.
> about it. lol
Yeah, some of the older OSes could have problems if you installed
crapware. If you didn't, no problem.
The analogy police are on their way. You've been warned.
How does this differ from UNIX saying you're not allowed to delete
something out of /bin for your own good?
> Sure, some people
I think it isn't that they aren't too bright. It's that they know
nothing about how the computer works.
It's asking permission to elevate your privilege. If you're running as
administrator, you're already doing something wrong, so complaining that
you're being annoyed by the warnings is kind of silly, methinks.
>>  > Or an
>>> security.
> XP).
I expect they actually have a different interface of some sort for
creating those alternate packets, and people are griping that it
changed, but that's just a guess.
>> Like what?
Sorry. "Admin user" in 95?  Impress me by explaining what you're talking
about, given that Win95 is a single-user OS.
And UNIX is better at this, is it? ;-)
>>> up at this point.
Um, it does. It's called "runas".
> Frankly, I am
You'd be surprised, actually. I mean, unless you've got really old
crappy software.
> or situations where
Why would you log out just to log in as administrator? Just lock the
screen, and log in while the other user is still logged in.
Never had that happen. The worst I get is the little yellow shield in
the corner saying "please let me know when I should install these patches."
> There doesn't seem to be a "let me fracking reboot when "I" want to option.
Of course there is. Or do you think people have production servers all
over the internet randomly rebooting on patch day?
Go to the control panel, under automatic updates. If you want it to
reboot after installing patches, tell it when and on what day of the
week in the drop-downs. Otherwise, set it to "download updates but let
me pick when to install them."  Or "notify me but dont download them."
> frell you!!
If you let it get to that point at all, you can stop it by (surprise)
stopping the windows update service.
"Gee, this CD player keeps playing this CD over and over! It's driving
me nuts!"
     "Did you try stopping the CD player?"
"Oh. No. Didn't think of that."
Date: 10 Apr 2008 01:22:48
Message: <MPG.22674f1418600f3298a142@news.povray.org>
In article <47fc18a3$1@news.povray.org>, dne### [at] sanrrcom says...
I have. Yes, things could crash in it, and in later years changes to
sound cards (like ones where the firmware needed to be hotloaded to the
card, so took up a bigger chunk of memory), it got to the point of being
damn annoying to work with. In some ways it was still easier to deal
with. lol
> What "stuff"??
I gave you an example. IE's object support. I have read lots of
documents, books, etc. on the subject and it *should* take about 10
lines of code to do it, if you use raw C++ without anything but the COM
libraries, but half the other libraries, which make coding applications
easier, put steel doors and brick walls in between you and the code to
do it, nor, unless some of the code they leaked a while back involving
IE included the code for this, is there clear documentation of how the
hell you actual use it. Its buried, deep in the bowels of the libraries,
such that it automates so much stuff "for you" that you can't do a damn
thing with it. .NET's solution wasn't BTW to give you access to the
original core either. In that you "cast" events, i.e., redirect the ones
your own application can't handle to a function that *maybe* can, if you
know how to code it right. Only one problem, you still need to know how
to figure out where the event came from, and thus what to do with it,
and its *still* easier to do that at compile time than at run time, so
you *still* can't replicate the object support in IE simply.
And all for what reason? Because they don't want to provide a system
call in any library that would support binding event connection points
to event sinks, unless the compiler did it for you. Argh!!!
Oh, give me a break. Sure, there may be issues, especially with newer
cards, but we are talking about basically throwing out *years* of
working hardware, in trade for something that won't even support,
without the help of someone that doesn't even *work for* Microsoft, or
the card manufacturers, *any* sound, since the library replacing the
original system doesn't provide legacy support for functions and methods
that have been standard in drivers for, well, since fracking DOS, when
they first started writing device drivers, instead of just letting the
software talk to the sound card. This isn't a case of, "well, they made
some changes to the driver design, so old drivers won't work." Its a
case of, "We don't want you to even use any of the cards you ever
bought, except as a sort of more powerful version of the speaker clicks
used in the Tandy."
There is a huge difference. As huge a difference as when the day they
created the first Soundblaster card and people where "asked" to use it,
because it produced better sound. That isn't even the excuse this time.
There is no real evidence the new design *can* produce better results,
and they are trying to force it as a "requirement" for new games, not an
optional one for if the designer thinks it would work better.
> *that* expensive.
> > the price tag. lol
Going to cover both of these at one time, since your contention makes no
damn sense. They are "phasing out" all prior libraries, and giving away
the compiler for the "new" one, .NET for free. The only thing they are
"asking" you to pay for is basically some better IDE features, their
help library, which is online for free anyway, and *legacy* library
support. So, my objection is the assumption that I would want to pay
them 2-3 times what I already paid for the OS, to get a bunch of stuff I
don't necessarily need, or can already get from them for free, just so
that I have the legacy support for some application someone else
wrote... The complaint isn't that its commercial, the complaint is that
if all I wanted to do is code for windows, I wouldn't need to buy it
anyway. Its only the fact that I am trying to fix, or convert, something
in an older legacy library that make it *necessary* to buy the full
product in the first place. To me this makes about at much sense as if
they decided to add support for old 3.1 applications, but then told
everyone that they had to pay $500 for the addon to do so.
Ok, we can agree to disagree then. I said, "isn't likely", not, "isn't
possible".
Wasn't aware that there was a huge threat of someone "outside" your
system deleting /bin, or that simply not letting you delete things that
are stupid to delete was on the same level as, "I am sorry, but despite
the fact that it won't have an effect on the OS at all, and the language
appears to allow it, we won't let you do it anyway, because *we* think
that you might not know what you are doing, or that you might not be the
one doing it."
But, what ever.
No, in the specific case I was trying to do something it had **nothing**
to do with privilege levels. MS deemed it more likely that some
*outside* entity would be using the feature to do bad things with your
computer, without you knowing, so disabled it for *everyone*, regardless
of if you where Admin, or fracking God. You don't even get a warning. It
just flat out doesn't work, when the same identical thing on earlier
patches of XP, earlier versions of Windows, and even *nix "does" work.
If you didn't read the patch information and know what it was and why
they did it, you wouldn't have any clue why the program didn't work,
what Windows was doing to prevent it working, or why the same, or
virtually the same, code worked on *every other* OS on the planet. That
is just bloody stupid imho. It doesn't even have the common decency of
popping up an error dialog that says, "Due to changes in service pack
blah, program X's attempt to do Y has been disabled."
> >>  > Or an
f
> >>> security.
> > XP).
You would be wrong. You just can't do it anymore. They changed it so
that the packet management in Winsock, or some other key component
detects that the packet doesn't "look" like its big enough, contains the
right sort of data, or "something" when using certain protocols, then
simply doesn't send it, without warning, without an error, and without
any indication that it didn't work, other than the discovery that the
application isn't doing anything any more.
> >> Like what?
Sorry, got confused about which OS I was talking about. lol Point being,
you just couldn't change them *period*.
At least in *nix you probably can find information on "how" to change
it. Some of the stuff in 95 where settings you needed to change to make
even stuff like networking work right, with certain situations, but
where the "setting" wasn't available from "any" control panel or
application installed, nor was their a "default" setting in the registry
for it. I have no clue how people even figure out what half the damn
settings where that I ended up tweaking to make the OS run better.
Neat. Had no idea that was there. Makes things nicer. Though, I suppose
if I didn't want to lose my mind trying to use it I might have to
install the Bash copycat CLI they came up with. Trying to do anything in
DOS, never mind Windows 'Run', which is basically the same thing,
without about 500 DOS utilities that a) don't come with the OS anymore,
or b) never did, but where written by PC-Magazine, was always a
nightmare. Worst day of my life was when I realized that 4DOS didn't
work right with 98. lol So much nicer, with a wonderful text file lister
built in, etc... Sigh.. Never could figure why, even today, Windows
basic method of dealing with large documents is either to a) send it
through "type", with "more", b) try and fail to load it (all at once)
into Edit, or c) try, and previous fail, to load it in notepad... 4DOS's
built in loaded one "page" at a time and showed it, so that only what
you "needed" was in memory at any given moment. Loved that command...
> > Frankly, I am
> crappy software.
Might be OK. I have found "some" stuff that oddly insists on only
installing as single user though, which kind of gets annoying. Right
now, as a super user, I just move the icon from "my" user to the main
directory for programs, it maybe asks if I am sure I want to let all
users get to it, and bam, there is it. Still, I have had some annoyances
with the My Documents folder, some things *cleaning it up* and deleting
files it shouldn't, which is why I moved it, and now, some older
programs (and even newer ones that don't recheck the location when
accessing files), looking in the "old" location. Had that problem with
Yahoo! Widgets, which *is* supposed to be XP compatible, but had that
bug. It *assumed* that once it knew where the files "should be", they
should always be there. Problem was, when I mover the folder location, I
"lost" access privileges to the original location for those files, so it
was trying to aggregate all widgets to some place it didn't have access
to, and due to a stupid bug, it would delete the file anyway (or maybe
loaded it, got ready to copy it, deleted the original, then tried to
save the file to the disallowed location. How ever it was doing it, it
fowled things up royally.
Bound to happen though, when someone changes your security model and
half the people writing for it don't think about the fact that the
folder "can" be moved.
Yeah. I need to adjust mine back to that. Got annoyed with having that
show up, when the patch took hours to download. Dialup remember... It
was easier to "let it" install and do things, than have to deal with it
when I finally realized it "had" patched. lol
What is it with people that use Windows that they tell you where to
change a setting in the control panel, by referencing it as though its
an option *in* the main page of the control panel? They do it on
websites too. The real method is like, "open bing in the control panel
and select bong, then pick the ding tab.", but all they give you is "Go
to Ding in the control panel and change these setting." I just don't get
it...
And don't bother being more specific. I figured out where it was. lol
> > frell you!!
Which I don't really want to do... Now, the damn update service for
Arcsoft, which came with my camera.. That I disabled, then when it
wouldn't *stay* disabled I finally deleted the fracking thing. Stupid
thing would crash if it came up and no internet connection existed for
it to update over, and you had two options, "disable" or "don't bug me
for the next 7 days", and, like I said, "disable" didn't seem to work at
all. Oh, and it was a service, but for some damn reason there was no
"disable" or "turn off" option in the service manager, unlike with many
of the others. I hate third party programs that "should" be helpful, but
only manage to be a severe pain in the ass. Its not like they could
have, I don't know, had the relevant application check for updates, like
"most" of the ones I use...
void main () {
  else
Date: 10 Apr 2008 13:34:50
Message: <47fe4fba$1@news.povray.org>
> cards,
No. I'm talking about 25 years of UNIX not supporting sound properly.
How long ago did UNIX start supporting sound when logged in from an X
terminal? How long ago did UNIX start supporting mixers?
Trust me. I worked at Bellcore in the 90's. UNIX didn't "support" sound
for long, *long* after Windows did.  And it's still a kludge on Linux.
Yes, Vista fucked up sound, but they did it on purpose.
> damn sense.
I don't see what's nonsensical about it. If you're making a commercial
product and that's why you need to support Windows, then shell out the
$100 and recoup it with your first couple of sales. If you're not
planning to sell the results, why are you complaining that Windows
development software is expensive? It's a hobby. Use Linux. :-)
Makes sense to me. They don't want you developing to old APIs. The
longer people use the old stuff, the longer they have to support it. If
it isn't worth money for you, it's not worth them supporting it.
You'd be surprised. cf "the Morris worm" for example.
> or that you might not be the one doing it."
That's really the problem, I think. There are way, way more people using
Windows who don't know what they're doing than there are people using
UNIX who don't know the difference between "firefox" and "firewall".
'k.
They either ask someone at Microsoft, or they figure it out the same way
they find buffer overflows. :-)
Google for "Windows command line" and find a whole bunch of good stuff.
Also, read the documentation for "find" and "for" in the CLI, which do a
lot more than you probably know.
Now, if I could find a command line to "eject" a USB device, I'd be
happy. :-)
No. Set it to download, then inform you. Then you can just turn off the
machine, and it'll install the patches as it shuts down.
> it...
The icon at the top level of the control panel is called "automatic
updates". It's a one page panel with three radio buttons. I fail to see
how my description was confusing?
>>> frell you!!
Uh, why not? Note I didn't say disable it. I said stop it. Then it wont
bug you, until you reboot, which is all it's going to do until you
reboot anyway.
Date: 10 Apr 2008 13:59:29
Message: <op.t9epler97bxctx@e6600.bredbandsbolaget.se>
> happy. :-)
http://quick.mixnmojo.com/usb-disk-ejector
http://www.codeproject.com/KB/system/RemoveDriveByLetter.aspx
FE
Date: 10 Apr 2008 17:23:26
Message: <47fe854e$1@news.povray.org>
>> happy. :-)
You wouldn't believe how long I tried to figure out what to google on
Microsoft's site to find which function will do that. :-)
Date: 10 Apr 2008 23:13:50
Message: <MPG.2268851c6d2ec51098a145@news.povray.org>
In article <47fe4fba$1@news.povray.org>, dne### [at] sanrrcom says...
You shut off your computer? Didn't know you could do that... lol But
seriously, mine is always on and up, since I work odd hours, may be
running things I need to keep going, or even downloading a torrent,
etc., all of which are a bit hard to do if you turn it off all the time.
The only time I ever reboot, never mind turn it off, is to
update/upgrade something, or there is a big storm over the city and
leaving it on risks frying it.
t
> > it...
No it isn't. On mine its "Performance and Maintainence", then "System",
in which there is a tab which is called "Automatic Updates". Now, if you
have a link to the "systems" control panel on your desktop, like someone
that makes changes there a lot might do, then yes, it would be. ;)
This is, of course, one of the fun things about Windows. Nothing is ever
where you, never mind they, left it. lol
> >>> frell you!!
> reboot anyway.
Well, yeah, that is true. Not something that would have normally
occurred to me though. Mute point now anyway, its now set back to,
"Download, but don't install until requested."
void main () {
  else
Date: 10 Apr 2008 23:23:01
Message: <MPG.22688749e7aabf6c98a146@news.povray.org>
In article <47fe854e$1@news.povray.org>, dne### [at] sanrrcom says...
> >> happy. :-)
Know the feeling..
void main () {
  else
Date: 11 Apr 2008 11:44:17
Message: <47ff8751$1@news.povray.org>
Yeah. When I'm not using it.  I'm rather annoyed at how flakey the
suspend code is on my Media Center.  Never another HP, I'll tell you.
Huh. What are you running?  Not XP, I assume?
Yep. It takes forever to find all that stuff on each big upgrade.
Glad to be of service. :)
Date: 11 Apr 2008 17:43:49
Message: <47ffdb95@news.povray.org>
>> "System", in which there is a tab which is called "Automatic Updates".
XP by default has the Control panel in its stupid "Category mode".
Date: 11 Apr 2008 20:36:55
Message: <MPG.2269b214d1a5ed7998a147@news.povray.org>
In article <47ff8751$1@news.povray.org>, dne### [at] sanrrcom says...
What Nicolas said. XP Pro, unmodified install, SP2. You either changes
it, or you bought the machine with it installed, and that had it set up
the other way. But what you get to start with is a list of "related"
features, instead of the "everything as an icon in the control panel",
that existed in 98.
void main () {
  else
Date: 11 Apr 2008 21:23:05
Message: <48000ef9$1@news.povray.org>
Oh! Right! I turned that off in about the first 10 seconds, along with
"hide known extensions." It never occurred to me...
