POV-Ray : Newsgroups : povray.off-topic : A simple question Server Time
25 Oct 2026 18:19:24 EDT (-0400)
  A simple question (Message 64 to 113 of 153)
<<< Previous 50 Messages Goto Latest 50 Messages Next 40 Messages >>>
Subject: Re: A simple question
Date: 2 Apr 2008 03:22:27
Message: <47f34243$1@news.povray.org>
> To true and why should they :)
A friend of mine worked in a mobile phone shop for a bit.  During their
training the trainer asked some technical question about a phone which my
friend answered.  Then she told everyone they were here to sell phones and
not to answer technical questions like that.
Date: 2 Apr 2008 03:35:57
Message: <47f3456d$1@news.povray.org>
scott wrote:
> What's a CRT monitor? Seriously, haven't seen one of them for years now.
In my universe, CRT is still infinitely more popular than LCD. This
might be related to price...
[Obviously, where I work most of the monitors are so ancient that the
plastic is turning interesting colours, so they're mostly CRT. My
monitor at home is also CRT, because this gives it the property that it
can display *any* resolution correctly. Useful for games that won't run
fast enough at high res...]
http://blog.orphi.me.uk/
Date: 2 Apr 2008 03:37:27
Message: <47f345c7@news.povray.org>
Stephen wrote:
> Volt amps takes into account the phase difference between the volts
> and the current. As you know then you pass an ac current through a
> capacitor or an inductor there is a phase difference. Volt amps is V *
> cos(phase) *A.
> Simple, What?
That makes no sense at all.
Since Amps are directly proportional to Volts, how can there possibly be
a phase difference?
Date: 2 Apr 2008 04:00:48
Message: <47f34b40$1@news.povray.org>
> a phase difference?
"Much to learn you have!"
Take a capacitor: initially it's discharged. Now connect it to a voltage
source, the first instant you do, the voltage across the capacitor is
still zero, however a large current (of charges) is flowing in,
accumulating on the cap's plates thus creating an electric field in the
cap. Which is proportional to the plate distance, charges sitting on them
and die dielectric. This field prevents further flow of charges into the
cap and finally you have the full voltage across the cap and no current
flowing. Now repeat the whole thing by applying the opposite of the
voltage, the cap gets charged the other way around, but with the same
principal timing. Repeat, repeat, repeat... you get the picture -> phase
shift (90 degrees).
Same applies to inductors (your speakers' driver coils), only this time
the energy is stored in the magnetic field produced by the current, so I
and V are exchanged in the timing, but still a phase shift.
That's very basic electrical engineering, you know... but maybe your
universe is different after all. SCNR
Michael
Date: 2 Apr 2008 04:06:15
Message: <47f34c87@news.povray.org>
You know Ohm's law, V = I*R, well think what happens if V and I are complex
numbers ... as soon as R becomes complex, the phase of V and I will be
different.
And yes you guessed it, the "resistance" of capacitors and inductors are
complex numbers ;-)
Date: 2 Apr 2008 04:15:03
Message: <47f34e97$1@news.povray.org>
> complex numbers ... as soon as R becomes complex, the phase of V and I
> will be different.
> complex numbers ;-)
That doesn't make any sense.
More precisely, if we assume that V and I are not necessarily in phase,
this immediately allows me to derive a contradiction.
Apparently, all I have to do is generate a sufficiently low-frequency
wave, with V and I sufficiently far out of phase, and we arrive at an
impossible situation. I could have a system with an arbitrarily large
current passing through it, for an arbitrarily long time, despite the
entire system having zero potential difference.
Obviously, electrons don't just move around for the hell of it. They
move in direct response to a potential difference. The very concept of a
current with no force driving it is obviously ridiculous.
The equations might make perfect sense in the presence of complex
numbers, but that doesn't mean they match the real world.
Date: 2 Apr 2008 04:19:38
Message: <47f34faa$1@news.povray.org>
True enough...
> still zero
How on earth do you work that one out?
If you connect a capacitor to a 9 V source, then the potential
difference across the capacitor is... exactly 9 V. In which universe is
that 0 V?
Ah, maybe...
Date: 2 Apr 2008 04:27:34
Message: <47f35186@news.povray.org>
Oh yes it does, it's the basis for almost all electronic circuit design.
Note that the complex version of Ohm's Law only holds for steady-state
continuous sinusoidal operation, it won't explain what happens when you
first turn on a circuit or suddenly introduce voltage or current
spikes/steps.
In your example, if you have previously charged up a capacitor an arbitrary
amount, then yes, you can then get an arbitrary amount of current out with
no voltage.  Just charge up a capacitor with a constant voltage, then short
the terminals ;-)  But the voltage must be in a sine wave cycle though for
Ohm's law to hold.
Date: 2 Apr 2008 04:29:12
Message: <nek6v35f376gp0bi7icqfj8fesvepeh05u@4ax.com>
One wonders why she asked if not to show the others how
unknowledgeable they were. I hate bosses like that.
Regards
Date: 2 Apr 2008 04:31:26
Message: <kik6v3hfineprtc3j7rhjrfdv9df415pqb@4ax.com>
On Wed, 02 Apr 2008 10:19:21 +0100, Invisible <voi### [at] devnull> wrote:
>True enough...
>> still zero
>that 0 V?
You don't do it directly you use a resistor in series to limit the
current. Michael left this step out for simplicity. Probably not
wanting to overload your brain :)
>Ah, maybe...
Regards
Date: 2 Apr 2008 04:35:55
Message: <brk6v3dapernq4qd3omtnlk8jt3qj64s8i@4ax.com>
Also the rules are different for dc and ac. The ac rules take into
account the frequency of the waveform. This is how the crossover
filters in your speakers work, assuming you have a bass and a tweeter.
It works, trust me man.
Regards
Date: 2 Apr 2008 04:38:33
Message: <47f35419$1@news.povray.org>
>> still zero
> If you connect a capacitor to a 9 V source, then the potential difference
> across the capacitor is... exactly 9 V. In which universe is that 0 V?
A 9V source has an internal resistance, which will initially take all the
voltage as the capacitor draws a huge amount of current (even if it doesn't,
the wires will have some resistance).  So across the capacitor terminals
will be a very low voltage, but a very high current through it.  Once the
capacitor is fully charged, there will be no current flowing, and so no
voltage drop across the internal resistance, and then the full 9 V across
the capacitor.
So you see, in this simple case, voltage across the capacitor is definitely
not proportional to current flowing through it.  Quite the opposite to a
resistor.
Date: 2 Apr 2008 04:41:27
Message: <47f354c7@news.povray.org>
> spikes/steps.
...or rather, it does after you take those spikes and analyse their
component harmonics. (?)
> arbitrary amount, then yes, you can then get an arbitrary amount of
> current out with no voltage.  Just charge up a capacitor with a constant
> voltage, then short the terminals ;-)
But if the capacitor is charged then it *has* a voltage! And current
will flow until that charge has been exhausted. There's nothing
mysterious about that. But claiming such a system has "no voltage" and
yet there's current flowing through it is just silly.
Date: 2 Apr 2008 04:42:51
Message: <47f3551b$1@news.povray.org>
Am Wed, 02 Apr 2008 10:19:21 +0100 schrieb Invisible:
> True enough...
>> voltage source, the first instant you do, the voltage across the
>> capacitor is still zero
Out of continuity?
> that 0 V?
That's why I said "the first instant". dt (that's a differential "d")
before you contact the cap's terminal, the voltage across the terminals
is zero, right? Why should the potential be different one dt later
(except for a dV)? We live in a continuous world, perhaps you dont, IDK,
where most real-world measures are differentiable. And even if there was
no (ohmic) resistance at all, at t=0 (contact the terminals) there must
be a current into the cap first before the voltage across the cap can
increase (that's causality!). And only if there's no (ohmic) resistance,
you get the full 9V across the cap in finite time (namely 0+dt, and that
may be mathematically sloppy to say so). In the real world, where wires
have ohmic resistance, you'll *never* reach 9V across the cap in finite
time: V(cap)=V(source)*exp(-t/RC)
Date: 2 Apr 2008 04:45:22
Message: <47f355b2@news.povray.org>
> the voltage as the capacitor draws a huge amount of current (even if it
> doesn't, the wires will have some resistance).  So across the capacitor
> terminals will be a very low voltage, but a very high current through
> it.  Once the capacitor is fully charged, there will be no current
> flowing, and so no voltage drop across the internal resistance, and then
> the full 9 V across the capacitor.
> definitely not proportional to current flowing through it.  Quite the
> opposite to a resistor.
Right. So the potential difference between the terminals of a battery is
9 V, unless there happens to be a capacitor connected to them, in which
case the potential difference is magically 0 V despite the fact that a
vast current is being generated?
Right. Sure. Makes perfect sense. Electrons just move of their own
volition anyway; it's not like it requires a *force* to drive them or
anything...
Date: 2 Apr 2008 04:49:48
Message: <47f356bc$1@news.povray.org>
What about solar wind? The sun emits charged particles (of really high
energy). That's a stream of charges, meaning a current. Unless they
dissipate their energy by scattering events, they will move on forever in
the (mostly) empty universe (unless they reach the end of the universe,
may it be spatial or temporal, whereby in the latter case the can visit
Milliway's) or the wrap around when the space/time position overflows...
You could argue that the sun emits isotropically in all directions,
meaning no net current, but where's the difference to a closed electical
circuit (battery, cables, lamp i.e.), from outside the circuit, all
current vectors at all positions sum to zero too...
Date: 2 Apr 2008 04:52:15
Message: <47f3574f$1@news.povray.org>
bah, thats BS, V(cap)=V(source)*(1-exp(-t/RC)) of course.
Date: 2 Apr 2008 04:54:28
Message: <47f357d4$1@news.povray.org>
> And current will flow until that charge has been exhausted. There's
> nothing mysterious about that. But claiming such a system has "no voltage"
> and yet there's current flowing through it is just silly.
As you know, a sine wave is only at zero for an infinitely short period of
time, so actually the voltage is never exactly zero for any finite period of
time.  But at the instant it is zero, it is normal to have a non-zero
current when dealing with capacitors and resistors.
Someone posted this here a while ago:
http://www.falstad.com/circuit/
The default circuit that opens is exactly the point here.  See how the green
and yellow lines on the scopes at the bottom are out of phase?  Green =
voltage, yellow = current.
Date: 2 Apr 2008 04:54:30
Message: <47f357d6$1@news.povray.org>
> the (mostly) empty universe.
Unless my brain is really failing to comprehend reality, wouldn't that
mean there's a high concentration of such charged particles near the
sun, and a lower concentration of them everywhere else, and hence a net
difference in electrical potential?
Date: 2 Apr 2008 04:59:13
Message: <47f358f1$1@news.povray.org>
> Right. So the potential difference between the terminals of a battery is 9
> V, unless there happens to be a capacitor connected to them, in which case
> the potential difference is magically 0 V despite the fact that a vast
Exactly.  A totally uncharged capacitor appears as a short-circuit.  For a
split second it is exactly the same as if you had connected a wire between
the + and - on the battery.
> anything...
I really don't see the problem.  Do you understand what happens if you short
a battery with a wire?  You will get a huge current flowing even though the
voltage across the wire is virtually zero.  If you put a super-conductor
across the terminals of a battery, would you expect a current to still flow?
After all, the voltage across the superconductor would be zero...
Date: 2 Apr 2008 05:01:42
Message: <47f35986$1@news.povray.org>
>> voltage" and yet there's current flowing through it is just silly.
> of time, so actually the voltage is never exactly zero for any finite
> period of time.  But at the instant it is zero, it is normal to have a
> non-zero current when dealing with capacitors and resistors.
Well OK, but you can make the voltage arbitrarily small while making the
current arbitrarily large. Just by asking nicely.
In my experience - and hell, what would I know about reality? - things
don't just move of their own accord. There must be a *force* driving
them. Otherwise we'd all by driving perpetual motion machines to work by
now...
> green and yellow lines on the scopes at the bottom are out of phase?
> Green = voltage, yellow = current.
I've played with this thing before. Never been able to make much sense
out of it though - too much happening at once to really take it all
in... That guy does a lot of really cool physics stuff though. (I'm
currently addicted to the wave tank...)
Date: 2 Apr 2008 05:06:07
Message: <47f35a8f$1@news.povray.org>
> short a battery with a wire?  You will get a huge current flowing even
> though the voltage across the wire is virtually zero.
How the hell do you figure that?
Surely the potential at one end of the wire is +4.5 V, in the middle
it's 0 V, and at the other end it's -4.5 V, and therefore the potential
*difference* across it is 9 V. How is that zero?
> If you put a
> super-conductor across the terminals of a battery, would you expect a
> current to still flow? After all, the voltage across the superconductor
> would be zero...
Where would you measure the difference? You need two points.
Anyway, presumably a superconducting magnet is bizare enough that Ohm's
law doesn't apply. (Hmm, I = V/R where R = 0. Yeah, that looks pretty
undefined to... oh, wait, you're that guy who things that division by
zero is defined, aren't you?)
Date: 2 Apr 2008 05:12:55
Message: <47f35c27$1@news.povray.org>
Of course, but then in another part of the cycle you will have to have a
large voltage with a small current.
> don't just move of their own accord. There must be a *force* driving them.
A capacitor stores energy, this can generate force.
> Otherwise we'd all by driving perpetual motion machines to work by now...
I know you like maths :-)
http://en.wikipedia.org/wiki/Deriving_capacitor_impedance
Date: 2 Apr 2008 05:20:15
Message: <47f35ddf$1@news.povray.org>
Because the resistance of the wire is way lower than the internal resistance
of the battery.  DId you never notice that the more current you draw from a
battery the lower the voltage across its terminals?  If you *short* a
battery, the voltage is pretty much zero.
>> If you put a super-conductor across the terminals of a battery, would you
>> expect a current to still flow? After all, the voltage across the
The two terminals of the battery.  Connect a super-conductor between the two
terminals of a 9V battery and put your volt-meter across the battery
terminals. It *will* be zero volts.
> undefined to... oh, wait, you're that guy who things that division by zero
You don't need to do that, batteries have an internal resistance, Ri, so the
current flowing will simply be Vbattery / Rinternal.  With zero volts across
the super-conductor, but a current flowing.
Ohms law works perfectly well, the fact that R is zero simply means you can
have whatever current flowing you want with no potential difference.  Which
is exactly how superconductors work.
Date: 2 Apr 2008 05:37:25
Message: <leo6v35dc5r9dbme0rlnba7v73b2aknpig@4ax.com>
You are simplifying it to the extreme and using rigorous logic and
that does not work. A battery can be considered as a current source
with an internal resistance. N.B. we are talking dc here and not ac.
When you put a high impedance voltmeter across an open battery you
will get a reading of about 9.5 volts. This is the open circuit PD.
When you put a resistor across the battery it forms a resistor -
resistor circuit. When you put a cap across the terminals it forms a
R-C circuit. You would not normally do this as you should have a
limiting resistor in series with the capacitor. (And in real life a
shunt resistor across the capacitor to slowly discharge it when there
is no power applied) Also remember Michael was talking about
instantaneous voltages which are different from steady state ones
which are different again from ac.
Or are you just having fun winding us up? :)
Regards
Date: 2 Apr 2008 05:45:32
Message: <47f363cc$1@news.povray.org>
>>> you short a battery with a wire?  You will get a huge current flowing
>>> even though the voltage across the wire is virtually zero.
> resistance of the battery.  DId you never notice that the more current
> you draw from a battery the lower the voltage across its terminals?  If
> you *short* a battery, the voltage is pretty much zero.
I thought the voltage of a battery only decreases if you try to draw
current faster than the chemical processes inside the battery can
restore it? (I.e., it's a flaw parculiar to chemical batteries.)
>> Ohm's law doesn't apply. (Hmm, I = V/R where R = 0. Yeah, that looks
>> pretty undefined to... oh, wait, you're that guy who things that
>> division by zero is defined, aren't you?)
> the current flowing will simply be Vbattery / Rinternal.  With zero
> volts across the super-conductor, but a current flowing.
> can have whatever current flowing you want with no potential
> difference.  Which is exactly how superconductors work.
Heh. Superconductors truly *are* weird...
Date: 2 Apr 2008 05:51:13
Message: <47f36521@news.povray.org>
> that does not work.
Well, let me put it this way.
As I understand it, moving electrons round a wire is like moving water
round a pipe. You need a *force* to push it. However, you confidently
claim that you can make electricity move with no force at all. If
somebody claimed that they could push water round a network of pipes
just by writing an equation, they'd be laughed at. And yet you claim the
exact same thing is possible with electricity.
Personally, I don't believe it. I believe that electrons won't go
anywhere unless you *drive* them there. And that the amount they move
must be directly proportional to the amount of force driving them and
inverstly proportional to the force resisting them. But you
[collectively] claim that actually the amount of movement is unrelated
to the force applied or the resistance to be overcome. If that really is
true then as far as I can see, all of electronics is pure black magic
and every electronic circuit I've ever built shouldn't have worked...
Date: 2 Apr 2008 06:07:06
Message: <47f368da$1@news.povray.org>
> current faster than the chemical processes inside the battery can restore
No, it decreases the instant start to draw any current.  Maybe trying to
teach you about complex AC circuit theory and power electronics was a bad
starting point :-)
When you connect a resistance, R, to a battery, the circuit you have made is
identical to a true, fixed voltage source (say 12V), with two resistances
connected in series.  One of the resistances is R, the one you connected,
the other, called the internal resistance, Ri, is representing the resistive
parts of the battery that you have no control over.
You can analyse this circuit easily.  You have a voltage, V of say 12 V, and
a combined resistance of R+Ri.  So the current is found by Ohm's Law, and is
equal to 12 / (R + Ri).
Now that you know the current in the circuit, you can work out the voltage
across each resistor, again using Ohm's law.
For the resistor you just connected, R, the voltage across it will be given
by I * R.  You know I because we just calculated it, so the voltage is 12*R
/ (R + Ri).
If Ri is very small compared to R, then this is approximately just 12 volts.
But when R gets small enough the voltage can no longer be approximated by 12
volts.  And when R gets very much smaller than Ri, the voltage essentially
becomes zero.
If the voltage R *is* zero, ie you have connected a thick wire or
super-conductor between the terminals, then the voltage will be given by
12*0/(0+Ri), ie zero volts.  *But* the current is still defined by 12 /
(R+Ri), so that simply becomes 12/Ri.  This is the maximum current a battery
can deliver.
This explains why on old cars the radio switches off momentarily as you
start your car - due to the huge current drawn from the starter motor the
battery voltage drops, often to as low as 6 or 8 V.  Also when charging the
battery the opposite happens, and the voltage often goes up to 13 or 14
volts.
I'll leave it as an exercise to work out the maximum power the battery can
output...
Date: 2 Apr 2008 06:10:51
Message: <b1q6v3lsm9e9li4v4nrcf0ns0dht4k3t6d@4ax.com>
A quick reply with out thinking too much.
I think that you are getting mixed up between Potential Difference and
voltage at a point. Consider opening a drain pipe in a tank, the
pressure at the tap is ambient (or a little above) this equates to
zero volts but the head of water is still high this is the PD of the
battery.
The fault is with your thinking you are analysing a childish analogy
with an educated adults reasoning power.
You are wrong we are right if you find out why you are wrong life will
not be any easier :)
Regards
Date: 2 Apr 2008 06:12:56
Message: <47f36a38$1@news.povray.org>
Capacitors and inductors can STORE ENERGY!
> If somebody claimed that they could push water round a network of pipes
What if I connected a vertical pipe several metres high to your pipe network
in the middle somewhere?  As you applied some external force through your
system, I opened up a valve for a second to let water flow into my vertical
pipe, then closed it.  You would notice a slight increase in force needed.
Then, once you switched off your external force later, I open my valve and
let my water flow back into the system and it would force more water out the
other end.
Would you be puzzled that after you switched off your force water kept
coming out for a bit longer?
That is exactly what capacitors and inductors are doing in an electrical
circuit, they store up energy during parts of the AC cycle, and let it out
at others.
Date: 2 Apr 2008 06:34:59
Message: <47f36f63$1@news.povray.org>
Am Wed, 02 Apr 2008 10:45:08 +0100 schrieb Invisible:
> anything...
Well, strictly spoken no. Newtons first law applies to electrons too...
(Think of Vacuum tubes, particle accelerators, synchrotron storage ring
although with these electrons lose energy simply by getting accelerated
*radially* [to remain on cirular course], and by some magic not covered
by mechanics, they lose energy through radiation, which is the whole
point of synchrotrons)
Date: 2 Apr 2008 06:52:19
Message: <oos6v3lrdo2prd8127vn8i8qg4t0v8ut37@4ax.com>
>> anything...
I think Invisible was being ironic.
But why do you say "synchrotron storage ring although with these
electrons lose energy simply by getting accelerated *radially*"?
Why lose energy not gain energy? They are being accelerated is it
considered a negative acceleration?
Regards
Date: 2 Apr 2008 06:59:08
Message: <47f3750c$1@news.povray.org>
scott wrote:
> Maybe trying to
> bad starting point :-)
Hmm... maybe.
> start your car.
What do you mean "old cars"?
Date: 2 Apr 2008 07:01:58
Message: <47f375b6$1@news.povray.org>
No - really?
> network in the middle somewhere?  As you applied some external force
> through your system, I opened up a valve for a second to let water flow
> into my vertical pipe, then closed it.  You would notice a slight
> increase in force needed. Then, once you switched off your external
> force later, I open my valve and let my water flow back into the system
> and it would force more water out the other end.
No - because there is positive pressure at the value you just opened,
and this pressure is what is pushing the water along.
Similarly, a capacitor can store charge such that when you turn off your
external current source, the capacitor is still presenting a voltage to
the system, and hence current is still flowing. There is no mystery in
that. The mystery is in saying that there is actually "no voltage", and
the current is just magically flowing all by itself.
Date: 2 Apr 2008 07:03:37
Message: <47f37619$1@news.povray.org>
Am Wed, 02 Apr 2008 12:50:58 +0100 schrieb Stephen:
> electrons lose energy simply by getting accelerated *radially*"? Why
> lose energy not gain energy? They are being accelerated is it considered
I said "radially" not "tangentially". They must be accelerated towards
the center, otherwise  they'd fly straight-line (it's done by bending
magnets, so it's not a circle but a N-gon with rounded corners). In spite
of having the radial force perpendicular to the flight path, yielding
zero for the scalar product Work=Force \times distance and therefore
can't change the energy of the electrons, the will lose energy in form of
electromagnetic radiation (depends on the facility, but most will produce
X-Rays for all kinds of useful experiments). That comes from
electrodynamics: accelerated charges emit radiation.
That caused great confusion about how atoms could be stable and resulted
in the advent of quantum mechanics. How could electrons circle around the
atom's core, without radiation emission and finally plunging into the
core? Bohr's model of standing particle waves as electrons was the first
explanation of atoms, that didn't involve accelerated charges (and as we
know today, was not quite correct).
Yes, I admit it, I'm a physicist. Now you know it...
Date: 2 Apr 2008 07:05:43
Message: <47f37697$1@news.povray.org>
Am Wed, 02 Apr 2008 07:03:37 -0500 schrieb Michael Zier:
Ahh, and yes: I consider a body being accelerates whenever it's velocity
vector changes. That includes cases, where only the magnitude changes
(either + or -) or where only the direction changes (and of course
combinations).
Date: 2 Apr 2008 07:20:31
Message: <r5u6v3103bp279m28jmkpd79jis8ii7ahn@4ax.com>
>combinations).
As an engineer I agree, so it must be true :)
Does an electron have less energy in a circular path than a straight
one. You are pumping energy into the system so I would have thought
that it would be a gain in energy for the electron and a loss of
energy to the magnetic field.
BTW I also have problems with credit and debit when working on
financial systems ;)
Regards
Date: 2 Apr 2008 07:43:29
Message: <47f37f71$1@news.povray.org>
> The mystery is in saying that there is actually "no voltage", and the
Well, the quick way to explain is to look up the formula for an inductor:
V(t) = L * dI / dt
So, the voltage is proportional to the rate of change of current.  This is
because a magnetic field is generated by the flowing current, and when the
current changes the magnetic field generates a reverse-voltage to try and
cancel out the current change.
Nowhere does it say that a voltage of zero means no current flows.
If you've got 5 V and 5 A flowing through an inductor and you then suddenly
switch the current to 10 A, it's quite possible that the inductor will
generate a back-emf of -5V (so giving a sum of zero across the inductor) to
try and keep the current at 5A.  During the split second that the voltage is
zero, it is behaving exactly like a piece of wire with no resistance.
Or for a capacitor:
I(t) = C * dV / dt
This says that the current is proportional to the rate of change of voltage.
Nowhere does it say that no current can flow if the voltage is zero.  But,
note, the rate of change of voltage can't be zero, otherwise no current
would flow.
But for a resistor:
V(t) = I(t) * R
In this case, I=0 means V=0 whatever is going on (for non-zero R)
Date: 2 Apr 2008 07:57:14
Message: <47f382aa$1@news.povray.org>
Am Wed, 02 Apr 2008 13:19:09 +0100 schrieb Stephen:
> As an engineer I agree, so it must be true :) Does an electron have less
> energy in a circular path than a straight one. You are pumping energy
> into the system so I would have thought that it would be a gain in
> energy for the electron and a loss of energy to the magnetic field.
No. If there was no such thing as "synchrotron radiation", the electrons
would neither gain nor lose energy in a circlular path, not different
from a stone tied to a teather and swung around in a circle (neglecting
the friction forces for a moment) or the earth orbiting the sun.
BUT, we have syncrotron radiation, so after one traverse of the storage
ring, the electrons have a little less energy than before. To maintain a
steady operation, the lost (or better: transferred to the experiment
hall) energy must be given back to the electrons, and that's why in the
storage ring there's a acceleration section (this time truly tangential)
which adds energy to the travelling electrons (exactly the amount emitted
by the radiation).
> BTW I also have problems with credit and debit when working on financial
> systems ;)
Well, as long as you know which one must be on your account... ;)
Date: 2 Apr 2008 08:00:23
Message: <47f38367$1@news.povray.org>
Double entry book keeping FTW! :-D
Date: 2 Apr 2008 09:00:47
Message: <8947v3tagq3gj6qeel82nih8tbgsi4m8ib@4ax.com>
Aye! WTF :) I understand it but the terms are reversed. For instance,
if you put £1 into your account that is called debiting and taking £1
out is crediting. This is because (so I've been told) that it is from
the "bank's" point of view. Go figure why that is useful :)
Regards
Date: 2 Apr 2008 09:05:51
Message: <47f392bf$1@news.povray.org>
It's quite simple. All money comes *from* somewhere, and goes *to*
somewhere else. Conservation of finance! :-D
The part I can't figure out is how you do the accounts of a company, and
they end up with more money than they started out with, even though it
hasn't apparently "come" from anywhere... Accounting is weird!
Date: 2 Apr 2008 09:05:56
Message: <47f392c4$1@news.povray.org>
>> start your car.
On most new cars the entertainment system must function correctly for supply
voltages over a very wide range, like down to 6 or even 4 volts, and up to
16 or 18 volts.  This means that the radio (and all the other stuff like
satnav, climate control display etc) won't turn off while you start the car.
In the past the radio wasn't specced this high, and it was ok to only work
down to say 10 volts.  Of course this meant that when you started the
engine, the voltage dropped down to 6 or so volts and the radio turned off.
Date: 2 Apr 2008 09:07:28
Message: <47f39320$1@news.povray.org>
From your point of view, the bank is your debtor; so, by giving them £1
you have increased their debt to you. Simple innit (as they say here)
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 2 Apr 2008 09:07:54
Message: <tm47v35vr9fflnc0arpg7gggr5di43bh26@4ax.com>
Nope! I'm not going down that road. Ultrarelativistic particles, I'll
stick to Newton thank you very much :)
Regards
Date: 2 Apr 2008 09:11:21
Message: <6t47v39sqgmlubgupg8rb7megt2kno51u3@4ax.com>
On Wed, 02 Apr 2008 15:07:30 +0100, Doctor John <doc### [at] gmailcom>
Yeh! But try explaining that to a hairy (something-ed) engineer who
doesn't want to put your system in, in the first place :)
Regards
Date: 2 Apr 2008 09:17:31
Message: <47f3957b@news.povray.org>
>>> you start your car.
> supply voltages over a very wide range, like down to 6 or even 4 volts,
> and up to 16 or 18 volts.  This means that the radio (and all the other
> stuff like satnav, climate control display etc) won't turn off while you
> start the car.
> work down to say 10 volts.  Of course this meant that when you started
> the engine, the voltage dropped down to 6 or so volts and the radio
> turned off.
Interesting. I've never seen any car where turning the ignition
*doesn't* disable all the other electrics in the system [including the
headlights].
As I understand it, turning the starter motor requires a massive amount
of current, and is essentially the *only* reason a car has such a
whopping great battery in the first place. (Certainly it's not necessary
just to run the spark plugs... or even the headlights...)
Date: 2 Apr 2008 10:15:20
Message: <47f3a308$1@news.povray.org>
>> anything...
Uhhh.... No, not really. :-)  Indeed, electrons aren't even guaranteed
to move forward in time, let alone in a smooth straight line.
Oh, I guess maybe Newton's laws apply as long as there are no virtual
exchange particles around. And the electron doesn't spontaneously turn
into a couple of photons and back.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 2 Apr 2008 10:18:54
Message: <47f3a3de$1@news.povray.org>
Stephen wrote:
> You forgot to mention RMS or peak to peak watts.
No, I didn't. It's clear the RMS won't be mentioned. I was more worried
if they'll mention more than 2,5W total output, since it's pretty much
impossible (from one USB-connector you can get 500mA of 5V max.).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 2 Apr 2008 10:21:10
Message: <47f3a466@news.povray.org>
I have a book on accounting software that has a page designed to be torn
out that says
"You must memorize this:
  Account     Credit     Debit
  Assets      Decrease   Increase
  Expense     Decrease   Increase
  Libilities  Increase   Decrease
