POV-Ray : Newsgroups : povray.off-topic : A simple question Server Time
3 Aug 2026 09:50:48 EDT (-0400)
  A simple question (Message 61 to 70 of 153)
Subject: Re: A simple question
Date: 2 Apr 2008 03:13:58
Message: <47f34046$1@news.povray.org>
>> You try talking about Volt amps in a shop and I wish you well :)
> Trying to explain to me how Volt Amps is different from Watts would
> probably be a bigger challenge. :-P
Read this then ask questions ;-)
http://en.wikipedia.org/wiki/AC_power
Date: 2 Apr 2008 03:15:15
Message: <buf6v31n8e3ucl1sprmf3a91v4l6nunkks@4ax.com>
Volt amps takes into account the phase difference between the volts
and the current. As you know then you pass an ac current through a
capacitor or an inductor there is a phase difference. Volt amps is V *
cos(phase) *A.
Simple, What?
Regards
Date: 2 Apr 2008 03:16:04
Message: <55g6v3plim4hkejh4a8j3o3s2gv5fjv6n7@4ax.com>
>Hehe no way :-)  It took me until I was at my power electronics course in
>1st year University before I finally found out why things had power written
>on them in VA rather than W.  I don't expect the person selling me speakers
>in a shop to have done an Engineering degree.
To true and why should they :)
Regards
Date: 2 Apr 2008 03:22:27
Message: <47f34243$1@news.povray.org>
A friend of mine worked in a mobile phone shop for a bit.  During their
training the trainer asked some technical question about a phone which my
friend answered.  Then she told everyone they were here to sell phones and
not to answer technical questions like that.
Date: 2 Apr 2008 03:35:57
Message: <47f3456d$1@news.povray.org>
scott wrote:
> What's a CRT monitor? Seriously, haven't seen one of them for years now.
In my universe, CRT is still infinitely more popular than LCD. This
might be related to price...
[Obviously, where I work most of the monitors are so ancient that the
plastic is turning interesting colours, so they're mostly CRT. My
monitor at home is also CRT, because this gives it the property that it
can display *any* resolution correctly. Useful for games that won't run
fast enough at high res...]
http://blog.orphi.me.uk/
Date: 2 Apr 2008 03:37:27
Message: <47f345c7@news.povray.org>
> cos(phase) *A.
> Simple, What?
That makes no sense at all.
Since Amps are directly proportional to Volts, how can there possibly be
a phase difference?
Date: 2 Apr 2008 04:00:48
Message: <47f34b40$1@news.povray.org>
> a phase difference?
"Much to learn you have!"
Take a capacitor: initially it's discharged. Now connect it to a voltage
source, the first instant you do, the voltage across the capacitor is
still zero, however a large current (of charges) is flowing in,
accumulating on the cap's plates thus creating an electric field in the
cap. Which is proportional to the plate distance, charges sitting on them
and die dielectric. This field prevents further flow of charges into the
cap and finally you have the full voltage across the cap and no current
flowing. Now repeat the whole thing by applying the opposite of the
voltage, the cap gets charged the other way around, but with the same
principal timing. Repeat, repeat, repeat... you get the picture -> phase
shift (90 degrees).
Same applies to inductors (your speakers' driver coils), only this time
the energy is stored in the magnetic field produced by the current, so I
and V are exchanged in the timing, but still a phase shift.
That's very basic electrical engineering, you know... but maybe your
universe is different after all. SCNR
Michael
Date: 2 Apr 2008 04:06:15
Message: <47f34c87@news.povray.org>
You know Ohm's law, V = I*R, well think what happens if V and I are complex
numbers ... as soon as R becomes complex, the phase of V and I will be
different.
And yes you guessed it, the "resistance" of capacitors and inductors are
complex numbers ;-)
Date: 2 Apr 2008 04:15:03
Message: <47f34e97$1@news.povray.org>
> complex numbers ... as soon as R becomes complex, the phase of V and I
> will be different.
> complex numbers ;-)
That doesn't make any sense.
More precisely, if we assume that V and I are not necessarily in phase,
this immediately allows me to derive a contradiction.
Apparently, all I have to do is generate a sufficiently low-frequency
wave, with V and I sufficiently far out of phase, and we arrive at an
impossible situation. I could have a system with an arbitrarily large
current passing through it, for an arbitrarily long time, despite the
entire system having zero potential difference.
Obviously, electrons don't just move around for the hell of it. They
move in direct response to a potential difference. The very concept of a
current with no force driving it is obviously ridiculous.
The equations might make perfect sense in the presence of complex
numbers, but that doesn't mean they match the real world.
Date: 2 Apr 2008 04:19:38
Message: <47f34faa$1@news.povray.org>
True enough...
> still zero
How on earth do you work that one out?
If you connect a capacitor to a 9 V source, then the potential
difference across the capacitor is... exactly 9 V. In which universe is
that 0 V?
Ah, maybe...
