POV-Ray : Newsgroups : povray.off-topic : A simple question Server Time
3 Aug 2026 17:00:03 EDT (-0400)
  A simple question (Message 111 to 120 of 153)
Subject: Re: A simple question
Date: 2 Apr 2008 10:15:20
Message: <47f3a308$1@news.povray.org>
Michael Zier wrote:
> Am Wed, 02 Apr 2008 10:45:08 +0100 schrieb Invisible:
>> volition anyway; it's not like it requires a *force* to drive them or
>> anything...
> Well, strictly spoken no. Newtons first law applies to electrons too...
Uhhh.... No, not really. :-)  Indeed, electrons aren't even guaranteed
to move forward in time, let alone in a smooth straight line.
Oh, I guess maybe Newton's laws apply as long as there are no virtual
exchange particles around. And the electron doesn't spontaneously turn
into a couple of photons and back.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 2 Apr 2008 10:18:54
Message: <47f3a3de$1@news.povray.org>
Stephen wrote:
> You forgot to mention RMS or peak to peak watts.
No, I didn't. It's clear the RMS won't be mentioned. I was more worried
if they'll mention more than 2,5W total output, since it's pretty much
impossible (from one USB-connector you can get 500mA of 5V max.).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 2 Apr 2008 10:21:10
Message: <47f3a466@news.povray.org>
Michael Zier wrote:
> Well, as long as you know which one must be on your account... ;)
I have a book on accounting software that has a page designed to be torn
out that says
"You must memorize this:
  Account     Credit     Debit
  Assets      Decrease   Increase
  Expense     Decrease   Increase
  Libilities  Increase   Decrease
Date: 2 Apr 2008 10:25:43
Message: <47f3a577$1@news.povray.org>
Stephen wrote:
> the "bank's" point of view. Go figure why that is useful :)
Because it's the bank doing double-entry bookkeeping, not you. :-)
Date: 2 Apr 2008 10:26:02
Message: <47f3a58a$1@news.povray.org>
Invisible wrote:
> Interesting. I've never seen any car where turning the ignition
> *doesn't* disable all the other electrics in the system [including the
> headlights].
IME disabling all electric devices on startup is still very common
practice, simply because it's a wise thing to do (it makes the voltage
to drop a little bit less than with having them enabled).
> As I understand it, turning the starter motor requires a massive amount
> of current, and is essentially the *only* reason a car has such a
> whopping great battery in the first place. (Certainly it's not necessary
> just to run the spark plugs... or even the headlights...)
Yes. Another reasons for whopping great battery would be a
stereos, that can be used while the engine ain't running.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 2 Apr 2008 10:26:48
Message: <47f3a5b8$1@news.povray.org>
Invisible wrote:
> The part I can't figure out is how you do the accounts of a company, and
> they end up with more money than they started out with, even though it
> hasn't apparently "come" from anywhere... Accounting is weird!
It comes from profits.  Easy enough.
What *I* don't understand is how you do accounting for
fractional-reserve banking. Except to the extent that you're actually
only creating promises in return for promises.
Date: 2 Apr 2008 10:30:55
Message: <47f3a6af$1@news.povray.org>
Invisible wrote:
> Apparently, all I have to do is generate a sufficiently low-frequency
> wave, with V and I sufficiently far out of phase, and we arrive at an
> impossible situation. I could have a system with an arbitrarily large
> current passing through it, for an arbitrarily long time, despite the
> entire system having zero potential difference.
Yes. But the system would have to be arbitrarily large. :-)  That's what
people call "ground potential".
It has to be at least large enough to hold one wave.
> Obviously, electrons don't just move around for the hell of it.
Actually, at the quantum level, yeah, they do. That's why you can't make
abitrarily *small* transistors.
> The equations might make perfect sense in the presence of complex
> numbers, but that doesn't mean they match the real world.
But they do. All current is measured in complex numbers. All the
weirdness of quantum mechanics is caused by probabilities that are
complex numbers.  What's the probability of this electron emitting a
photon?  0.3 + sqrt(-1.4).
Date: 2 Apr 2008 10:33:05
Message: <47f3a731$1@news.povray.org>
Invisible wrote:
> Similarly, a capacitor can store charge such that when you turn off your
> external current source, the capacitor is still presenting a voltage to
> the system, and hence current is still flowing. There is no mystery in
> that. The mystery is in saying that there is actually "no voltage", and
> the current is just magically flowing all by itself.
You can think of external resistor to help. Let's say you'd have a
capacitor and a resistor connected in serial. Connect a voltage meter to
the capacitor (in parallel) and connect this set to a battery. You'll
see how the voltage starts to increase, starting from 0. Right?
The thing is, if you'll connect the capacitor without the resistor, what
happens is actually *exactly the same*. The increase of the voltage is
just so fast that you'll have no chance to actually follow it, so the
full voltage just seems to appear, even though it has raised with (very
little amount of) time.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 2 Apr 2008 10:37:37
Message: <47f3a841$1@news.povray.org>
True. But at the macroscopic level, they don't. Nothing does.
http://blog.orphi.me.uk/
Date: 2 Apr 2008 10:48:23
Message: <via7v3lr0p6ml8234ffkm6l9c98vbek1gj@4ax.com>
On Wed, 02 Apr 2008 18:19:01 +0300, Eero Ahonen
Sorry it was badly phrased, I was really speaking to Andrew.
Regards
