POV-Ray : Newsgroups : povray.off-topic : Liquid Physics Server Time
28 Jul 2026 07:39:15 EDT (-0400)
  Liquid Physics (Message 18 to 27 of 37)
Subject: Re: Liquid Physics
Date: 1 Apr 2008 02:14:52
Message: <47f1e0ec@news.povray.org>
scott wrote:
> Note that you need to put all the positions and velocities for every
> particle inside some state block and evaluate them in parallel using
> this algorithm - you can't do one at a time it doesn't work like that.
That part, at least, seems obvious to me.
It certainly seems like I've got my work cut out for me :)  I almost
feel that, if I'm going to implement something this complex, I may as
well do something useful with it!
...Ben Chambers
www.pacificwebguy.com
Date: 1 Apr 2008 04:38:57
Message: <47f202b1$1@news.povray.org>
scott wrote:
>> A true Haskeller would define a notionally infinite list which
>> notionally contains the entire state of the system at every future
>> point in time. Examining the elements of this list causes the
>> integration to actually be performed, and assuming you let go of the
>> start of the list, the GC will delete each state after it has been
>> calculated.
> What's that like on performance though?  What would it be like if your
> state block consisted of hundreds of 4D vectors, and the system was
> being updated at 1000 Hz?  Would the GC be noticeable?
Erm... without trying it, I couldn't say off the top of my head. Notice
though that since this is "the normal way" to do stuff in Haskell, the
compiler designers will be basing all their design decisions on the fact
that people are going to be writing code this way.
I would say that for *vast* numbers of vectors, you might need to move
over to using mutable arrays (uses less space and less GC time). But
without benchmarking it I couldn't tell you exactly how much of a
difference it makes. (I would also suspect that if you have "hundreds"
of vectors you probably need random access to them too...)
>> (You can't really speak of assigning several values to the same
>> variable "one after the other" because [pure] Haskell function don't
>> have any notion of "time".)
> Ah ok I see, so it's like you every variable is defined as "const" in
> the C++ sense, you can't modify it.
Well, kinda, yeah.
It's like, a function can only have one body. Nobody would find that
surprising. Like in C, you can't write a function, and then later change
that function to something else. (While we're on the subject, in Haskell
a "function name" is just a normal variable who's value happens to be a
function...)
A basic property of Haskell code [and any "pure" functional language] is
that if you take any variable and replace all occurrances of that
variable with the expression that defines its value, the meaning of the
program is unchanged. [Although possibly efficiency is reduced.]
Notationally this is how you "execute" such a program.
>>   animate state = do
>>     dispaly state
>>     let new_state = integrate state
>>     animate new_state
> I assume that the compiler is clever enough to not keep on the stack any
> data that is not needed, ie old versions of state that are no longer
> needed. If you attempted that method in C++ you would fill up the RAM
> very quickly ;-)
Er, yes, in C++ (or most "normal" programming languages) the above loop
would be an *absurdly* bad idea. In Haskell, this is the normal way to
achieve looping, and hence the compiler goes to extreme lengths to
optimise it well.
(If "state" is small enough, it may even get permanently allocated into
CPU registers and updated in-place. It depends on exactly what it
contains... If it's two floats like in the examples, then probably yes.
If it's a set of 200 vectors, obviously no...)
http://blog.orphi.me.uk/
Date: 1 Apr 2008 04:41:18
Message: <47f2033e$1@news.povray.org>
>> Are you
>> basically saying that variables are write-once in Haskell?
> AFAIK, yes, since they're defined as immutable.
> In other words, Haskell doesn't have variables, only constants.
Well, depending on how you define "variable" and "constant".
Take this for example:   double x = 2*x
Every time you call this function, "x" can have a different value. It is
a "variable". However, DURING EACH INVOCATION, "x" can only have one
value. It is a "constant".
Date: 1 Apr 2008 04:43:16
Message: <47f203b4@news.povray.org>
scott wrote:
> Yes, inside the "acceleration" function, which is called from each
> "evaluate" you put your code for calculating the acceleration.  This, in
> your case, would presumably call the routine to check for collisions and
> work out the forces for all the particles.
Question: Would it be worth using some kind of space partitioning to
enable you to process only "nearby" particles?
Date: 1 Apr 2008 05:13:04
Message: <47f20ab0@news.povray.org>
I think he said he was using something like that already.
Date: 1 Apr 2008 06:30:22
Message: <47f21cce@news.povray.org>
Ah, OK.
Date: 1 Apr 2008 14:54:59
Message: <47f29313@news.povray.org>
> surprising.
Unless you're using Erlang, I guess. :-)
"This is beyond dynamic binding. This is
make-up-your-mind-after-it's-already-running binding."
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 1 Apr 2008 15:04:03
Message: <47f29533$1@news.povray.org>
Chambers wrote:
> BTW, that grasshopper thing... does that come from the old TV show "Kung
> Fu"?  I could have sworn I saw it in a movie, though.  In fact, I asked
> at a couple local video stores what movie it was, and nobody knew... :(
I have no idea. My boss used to call me grasshopper. No idea why...
Date: 1 Apr 2008 15:17:55
Message: <u165v353jn1eekrhb3gdl47qfvu73dudat@4ax.com>
On Tue, 01 Apr 2008 21:04:23 +0100, Orchid XP v8 <voi### [at] devnull>
Walk the rice paper and leave no mark, Grasshopper.
Regards
Subject: Re: Wave Physics
Date: 2 Apr 2008 07:06:01
Message: <47f376a9$1@news.povray.org>
While we're on the subject... I've managed to get particle systems like
this to work before. (E.g., my chaos pendulum example, and various other
things.) What I haven't ever managed to do is figure out how to build
myself my own wave tank.
I know I've asked this before, but what's the algorithm for this?
