>> Ah yes, C++ is a superset of C. But I was thinking (hoping?) that in
>> C++ you have something less hellish than prinf() to play with...
> You do.
> C:
> printf("Number is: %d\n", somenumber);
> ...and be careful types match between format string and arguments
> passed, and particularly that you passed *enough* arguments
> C++:
> cout << "Number is: " << somenumber << "\n";
> ...and there is no duplicated information that could get out-of-sync
> (format and arguments).
> It's just you can still use the C way if you want to.
That does indeed seem like at least *some* improvement...
(In C, almost every single time anybody touched printf(), the compiler
would utter something about "suspicious pointer conversion". To this day
nobody knows what that actually means... Even the tutors didn't seem to
know.)
Assuming that you're writing this simulation for graphics purposes
rather than physical simulation where accuracy is a major concern
there's some other methods that you might consider.
First, a bit of terminology. There's two main paradigms I'm aware of
which are used to simulate fluids: Eulerian and Lagrangian. In the
Eulerian approach you consider what's happening in a small fixed piece
of space and look at how that changes based on the pieces of space
around it. In the Lagrangian approach, on the other hand, you consider
what happens to pieces of the fluid as they move around. The approach
you describe is then a Lagrangian approach.
As you've noticed, stability can be a problem when you integrate out
these sorts of equations to determine how the fluid should move over
time. Changing the integration mechanism (such as to a Runge-Kutta
integrator) or decreasing the time-step can help this to a degree, but
there exist fluid simulation methods which are unconditionally stable.
That is, the simulation will never `blow up' no matter what you do, even
with very large time steps in the simulation.
Probably the simplest such technique is the "Stable Fluids" algorithm
invented by Jos Stam. It uses some concepts from both the Eulerian and
Lagrangian viewpoints, and is this referred to as a "semi-Lagrangian"
method. There's a very easy to ready paper on the algorithm that even
gives some code for how to implement it:
http://www.dgp.toronto.edu/people/stam/reality/Research/pdf/GDC03.pdf
The algorithm itself should be also pretty easy to implement, and is
also useful in a educational sense as it uses some interesting
techniques (such as, iirc, explicitly projecting the flow onto a
divergence-free space to achieve an incompressible flow).
There are also some fully particle based fluid simulation methods which
are more similar to yours in their apploach, but I'm not aware of any
which are as simple to implement as the stable fluids algorithm. You
can check out some early examples:
http://graphics.ethz.ch/Downloads/Publications/Papers/2003/mue03b/p_Mue03b.pdf
http://www.cs.utah.edu/vissim/papers/ParticleFluid/ParticleFluidsLowRes.pdf
Or see a more recent paper on such a method at:
http://graphics.stanford.edu/~barta/research/adams-sig07.pdf
I suspect implementing one of these methods (or one of the newer
Eulerian / semi-Lagrangian ones) would be more work than you care to
spend, but I think stable fluids should be pretty reasonable to do
without a crazy amount of work.
Note, however, that all the stuff I mentioned is based on simulating the
Navier-Stokes equations. If you're only looking for something that
looks sortof-kinda like a fluid rather than behaving as a proper fluid
then there's probably all sorts of shortcuts and hacks you can do, and
in this case I agree with scott's suggestions so I'd start playing
around with using a better integrator and/or adding some sort of
artificial dampening.
Chambers wrote:
> So, just for fun I'm writing a quick liquid simulation. Because I like
> liquids, and I'm learning C#, that's why :)
> Anyway, I'm running into some problems with the simulation. Namely, a
> certain instability. Here's what I'm doing:
> For each particle, I loop through all the other particles (i=0..count-1,
> j=i+1..count), and check the distance between them (I use some
> additional bounding to speed things up, but that's not important to my
> problem here). I compute the forces the two particles place on each
> other, and then add them to each particles' total "force" value.
> Once I'm done computing interactions, I loop through all the particles,
> add the force to the velocity, and reset the force to zero.
> The way I see it (and granted, I've never written a liquid sim before),
> there are two forces I need to deal with, pertaining to two stages that
> occur when liquid particles collide:
> 1) When the particles are farther apart, they attract each other. This
> weak attraction would be the driving force behind surface tension.
> 2) When the particles are closer together, they push against each other.
> This force must be much stronger than the first in order to maintain
> some volume.
> Now, so far I'm only actually implementing the second force above.
> However, what I see is that the particles tend to settle pretty quickly
> to the floor, and then they clump together. Apparently, the particles
> on the outside "force" the particles in the middle of the clump closer
> and closer, until they suddenly explode and things go flying everywhere.
> I *think* the problem has to do with conservation of momentum. I
> naively dealt with that by halving the force applied to each particle in
> a pair (one half of the force gets applied to each), but that's not
> quite right, is it? The momentum of each particle shouldn't simply be
> split evenly with every individual particle it collides with... rather,
> I'll need to collect a list of interactions, and split this particle's
> momentum between *all* of those other particles...
> If anyone else here has dealt with similar issues, I'd appreciate
> knowing if I'm on the right track...
scott wrote:
> The only difference is that in the evaluate function without the
> supplied derivative, you don't need to update the state, simply return
> the derivative at time t using the initial state.
>> b = evaluate (v,p) t (dt/2) a
>> c = evaluate (v,p) t (dt/2) b
>> d = evaluate (v,p) t dt c
>> dv = (fst a + 2 * (fst b + fst c) + fst d) / 6
>> dp = (snd a + 2 * (snd b + snd c) + snd d) / 6
>> in (v + dt*dv, p + dt*dp)
> 5) Take a weighted average of all the derivatives you just caluclated,
> a-d, this gives the most accurate derivative.
> 6) Use this weighted average to actually advance your state by dt using
> normal Euler integration.
Here's a question: The derivative is based on the forces applied to the
current particle. The only way these forces change is when a particle
collides with other particles (or ceases to collide).
So, for each of the above, am I to run a full collision detection?
...Ben Chambers
www.pacificwebguy.com
Invisible wrote:
> Ah, grasshopper, you are still thinking in imperative terms. ;-)
BTW, that grasshopper thing... does that come from the old TV show "Kung
Fu"? I could have sworn I saw it in a movie, though. In fact, I asked
at a couple local video stores what movie it was, and nobody knew... :(
...Ben Chambers
scott wrote:
> Seems logical, but without thinking about it too much, how would you
> keep track of the state of the system while it's running? Are you
> basically saying that variables are write-once in Haskell?
AFAIK, yes, since they're defined as immutable.
In other words, Haskell doesn't have variables, only constants.
...Ben Chambers
> A true Haskeller would define a notionally infinite list which notionally
> contains the entire state of the system at every future point in time.
> Examining the elements of this list causes the integration to actually be
> performed, and assuming you let go of the start of the list, the GC will
> delete each state after it has been calculated.
What's that like on performance though? What would it be like if your state
block consisted of hundreds of 4D vectors, and the system was being updated
at 1000 Hz? Would the GC be noticeable?
> (You can't really speak of assigning several values to the same variable
> "one after the other" because [pure] Haskell function don't have any
> notion of "time".)
Ah ok I see, so it's like you every variable is defined as "const" in the
C++ sense, you can't modify it.
> animate state = do
> dispaly state
> let new_state = integrate state
> animate new_state
I assume that the compiler is clever enough to not keep on the stack any
data that is not needed, ie old versions of state that are no longer needed.
If you attempted that method in C++ you would fill up the RAM very quickly
Yes, inside the "acceleration" function, which is called from each
"evaluate" you put your code for calculating the acceleration. This, in
your case, would presumably call the routine to check for collisions and
work out the forces for all the particles.
Note that you need to put all the positions and velocities for every
particle inside some state block and evaluate them in parallel using this
algorithm - you can't do one at a time it doesn't work like that.
You may say that this is 4x as much work per integration step, but it will
allow your time-step to be far more than 4x bigger and still be completely
stable.
> this algorithm - you can't do one at a time it doesn't work like that.
That part, at least, seems obvious to me.
It certainly seems like I've got my work cut out for me :) I almost
feel that, if I'm going to implement something this complex, I may as
well do something useful with it!
...Ben Chambers
>> notionally contains the entire state of the system at every future
>> point in time. Examining the elements of this list causes the
>> integration to actually be performed, and assuming you let go of the
>> start of the list, the GC will delete each state after it has been
>> calculated.
> state block consisted of hundreds of 4D vectors, and the system was
> being updated at 1000 Hz? Would the GC be noticeable?
Erm... without trying it, I couldn't say off the top of my head. Notice
though that since this is "the normal way" to do stuff in Haskell, the
compiler designers will be basing all their design decisions on the fact
that people are going to be writing code this way.
I would say that for *vast* numbers of vectors, you might need to move
over to using mutable arrays (uses less space and less GC time). But
without benchmarking it I couldn't tell you exactly how much of a
difference it makes. (I would also suspect that if you have "hundreds"
of vectors you probably need random access to them too...)
>> variable "one after the other" because [pure] Haskell function don't
>> have any notion of "time".)
> the C++ sense, you can't modify it.
Well, kinda, yeah.
It's like, a function can only have one body. Nobody would find that
surprising. Like in C, you can't write a function, and then later change
that function to something else. (While we're on the subject, in Haskell
a "function name" is just a normal variable who's value happens to be a
function...)
A basic property of Haskell code [and any "pure" functional language] is
that if you take any variable and replace all occurrances of that
variable with the expression that defines its value, the meaning of the
program is unchanged. [Although possibly efficiency is reduced.]
Notationally this is how you "execute" such a program.
>> animate state = do
>> dispaly state
>> animate new_state
> needed. If you attempted that method in C++ you would fill up the RAM
> very quickly ;-)
Er, yes, in C++ (or most "normal" programming languages) the above loop
would be an *absurdly* bad idea. In Haskell, this is the normal way to
achieve looping, and hence the compiler goes to extreme lengths to
optimise it well.
(If "state" is small enough, it may even get permanently allocated into
CPU registers and updated in-place. It depends on exactly what it
contains... If it's two floats like in the examples, then probably yes.
If it's a set of 200 vectors, obviously no...)
http://blog.orphi.me.uk/
>> Are you
Well, depending on how you define "variable" and "constant".
Take this for example: double x = 2*x
Every time you call this function, "x" can have a different value. It is
a "variable". However, DURING EACH INVOCATION, "x" can only have one
value. It is a "constant".
Question: Would it be worth using some kind of space partitioning to
enable you to process only "nearby" particles?
I think he said he was using something like that already.
Ah, OK.
> surprising.
Unless you're using Erlang, I guess. :-)
"This is beyond dynamic binding. This is
make-up-your-mind-after-it's-already-running binding."
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
I have no idea. My boss used to call me grasshopper. No idea why...
On Tue, 01 Apr 2008 21:04:23 +0100, Orchid XP v8 <voi### [at] dev null>
Walk the rice paper and leave no mark, Grasshopper.
Regards
While we're on the subject... I've managed to get particle systems like
this to work before. (E.g., my chaos pendulum example, and various other
things.) What I haven't ever managed to do is figure out how to build
myself my own wave tank.
I know I've asked this before, but what's the algorithm for this?
Right. Well maybe it would be helpful to fix a few typos...
> evaluate (v,p) t dt (dv,dp) =
> let
> v' = v + dt*dv
> p' = p + dt*dp
> in (v', a (t+dt) v' p')
Err... that's incorrect. The acceleration function ("a") needs to be a
parameter somewhere. Or it needs to be a top-level function. Let's make
it top-level, like in the C++ version:
acceleration t v p = ???
evaluate (v,p) t dt Nothing = (v, acceleration t)
evaluate (v,p) t dt (Just (dv,dp)) =
let
v' = v + dt*dv
p' = p + dt*dp
in (v', acceleration (t+dt) v' p')
[I made the derivatives optional too. Did I get it right?]
> integrate t dt a (v,p) =
> let
> a = evaluate (v,p) t dt -- er... where's the rest?
...and if we're using a top-level acceleration function, you don't need
that "a" parameter there (which incidentally causes a name clash).
integrate t dt (v,p) =
let
a = evaluate (v,p) t dt Nothing
b = evaluate (v,p) t (dt/2) (Just a)
c = evaluate (v,p) t (dt/2) (Just b)
d = evaluate (v,p) t dt (Just c)
I'll have to try this out later and see if it actually works...
You know what? Screw it. Let's start again...
data State = State {velocity, position :: !Double}
data Derivative = Derivative {dvelocity, dposition :: !Double}
evaluate :: State -> Double -> Double -> Maybe Derivative -> Derivative
evaluate s t dt Nothing = Derivative {dvelocity = acceleration s t,
dposition = velocity s}
evaluate s t dt (Just d) =
let
s' = State {velocity = velocity s + dvelocity d * dt, position =
position s + dposition d * dt}
in Derivative {dvelocity = acceleration s' (t+dt), dposition =
velocity s'}
integrate :: State -> Double -> Double -> State
integrate s t dt =
let
a = evaluate s t dt Nothing
b = evaluate s t (dt/2) (Just a)
c = evaluate s t (dt/2) (Just b)
d = evaluate s t dt (Just c)
dv = (dvelocity a + 2 * (dvelocity b + dvelocity c) + dvelocity d) / 6
dp = (dposition a + 2 * (dposition b + dposition c) + dposition d) / 6
in State {velocity = velocity s + dv * dt, position = position s +
dp * dt}
acceleration :: State -> Double -> Double
acceleration = error "not implemented yet"
Does that look correct?
Well, I just ran it on a simple harmonic oscilator and got a sine wave,
so that's always a good start...
The wave equation.
http://en.wikipedia.org/wiki/Wave_equation
2nd time differential of "wave value" is proportional to the 2nd spatial
2nd time differential is just acceleration (use it in an integrator like RK4
to get the new positions).
2nd spatial differential in 2D is just d2u/d2x + d2u/d2y
See attached POV code.
Download 'us-ascii' (3 KB)
> The wave equation.
> RK4 to get the new positions).
Right. So for each pixel, measure the difference against the four
neighboring pixels, total that up, multiply by the wave propogation
constant, and that's the total acceleration for this pixel. Seems simple
enough.
What happens if the wave propogation medium propogates different
frequencies at different velocities?
> enough.
The wave propagation constant is not constant, but a function of
frequency (dispersion relation).
Well then your c is a function of frequency, it's also probably a function
of "wave value" and "wave steepness" too in real life. (higher and steeper
waves might propogate faster than lower waves). Good luck calculating the
frequency at a point though :-) I'm thinking you might be able to do
something clever with fourier though...
> function of "wave value" and "wave steepness" too in real life. (higher
> and steeper waves might propogate faster than lower waves). Good luck
> calculating the frequency at a point though :-) I'm thinking you might
> be able to do something clever with fourier though...
Well, Reaktor's "Steam Pipe" instrument simplates dispersion using a
simple all-pass filter in the feedback loop. OTOH, it's only trying to
simulate a 1D wave. At exactly 1 point in space. Hmm, maybe you could do
some sort of interesting convulation operation?
I think if you are simulating a musical instrument, it would be better to
get the resonant parts working first before you start trying to simulate
different propagation speeds at different frequencies. I would imagine that
is a much smaller secondary effect.
>>> (higher and steeper waves might propogate faster than lower waves).
>>> Good luck calculating the frequency at a point though :-) I'm
>>> thinking you might be able to do something clever with fourier though...
>> do some sort of interesting convulation operation?
> to get the resonant parts working first before you start trying to
> simulate different propagation speeds at different frequencies. I would
> imagine that is a much smaller secondary effect.
Oh yeah, sure. I'm just going off at a tangent now. ;-)
