POV-Ray : Newsgroups : povray.off-topic : Question about garbage collection (not a flame) Server Time
27 Jul 2026 10:39:15 EDT (-0400)
  Question about garbage collection (not a flame) (Message 5 to 14 of 24)
<<< Previous 4 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Question about garbage collection (not a flame)
Date: 31 Mar 2008 01:20:11
Message: <47f0829a@news.povray.org>
Orchid XP v8 <voi### [at] devnull> wrote:
> Warp wrote:
> >   I assume that it frees all the objects, not just A, but how does it do
> > it efficiently?
> The simplest (non-broken) GC implementation is the mark/sweep type.
  That really didn't answer my question. I didn't ask for the simplest
solution.
> [Note that I do not consider "reference counting" to be a valid GC
> algorithm, since it doesn't actually work properly...]
  Yet many languages use it, such as for example PHP and Objective C.
  It just sounds to me that people object about reference counting because
in theory it's problematic, but some people just go ahead and use it anyways
without problems.
  (Yes, I know that in PHP you can actually get circular references which
get never freed, and that's a known problem, but it doesn't seem to cause
too many problems in practice nevertheless, seeing how popular PHP is.
Circular references seem to be a bit like goto: You can come up with all
kinds of situations where it's "necessary", but in practice it happens
rarely if at all.)
Date: 31 Mar 2008 11:33:52
Message: <47f11270$1@news.povray.org>
> solution.
Well, you're asking about a very complex field that's been evolving for
30 years. And the GC for each language is different.
I'm not sure PHP lets you have a pointer to another object visible at
the user layer. If you do
   $x['hello'] = $y
as far as the user is concerned, $x['hello'] and $y are two different
values. So $y['hello'] = $y doesn't form a circular reference, as far as
I can remember.  I'll try it out as soon as I boot over to Linux.
> without problems.
Not without problems. Firefox, for example, is redoing the entire
plug-in memory management thing because it's too hard for extension
writers to get right.
PHP tends to run for one web page, then exit. That's part of the
solution. Indeed, I ran across this, trying to use PHP in a loop to
insert a few million records from a file into a database.
Since PHP doesn't actually have pointers, it's possible the runtime is
doing things to patch up as well.
But saying "it's good enough, who cares if one out of 20 programs leaks
memory" is a very PHP approach, yah.
> rarely if at all.)
I disagree. Doubly-linked lists, trees with pointers up the nodes,
widgets with child widgets that have parent pointers, etc. Pretty much
everything "OO" is good at winds up generating circular references.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 31 Mar 2008 11:41:05
Message: <47f11421$1@news.povray.org>
>   $x['hello'] = $y
PHP has "references":
$a =& $b;
This behaves like Unix hardlinks. "$a and $b are completely equal here,
that's not $a pointing to $b or vice versa, that's $a and $b pointing to
the same place"
Date: 31 Mar 2008 11:46:51
Message: <47f1157b$1@news.povray.org>
> the same place"
Right. I suspect either they don't get GCed if you wind up with a
reference to $B inside $B, or there's a mark/sweep mechanism that kicks
in. Given my experiences, I'd expect it just leaks. :-)
Date: 31 Mar 2008 12:06:52
Message: <47f11a2b@news.povray.org>
> > rarely if at all.)
  Yet, as I said, languages like PHP and Objective C seem to use
reference counting without too many problems.
Date: 31 Mar 2008 12:08:48
Message: <47f11aa0@news.povray.org>
http://www.derickrethans.nl/circular_references.php
  It seems they are working on something called "cyclic tracing" to
alleviate the problem, whatever that may mean.
Date: 31 Mar 2008 14:45:17
Message: <47f13f4d$1@news.povray.org>
>>> rarely if at all.)
Well given a long chain of objects pointing to objects, and a pure
reference counting system, each scan of the GC will only reclaim *one*
object from the chain. If the chain is long, it could take a damn long
time to reclaim all that memory.
Reference counting really is far too simplistic to work properly. I have
no idea how other languages appear to make it work [probably by
suplimenting it], but I wouldn't trust it as far as I could throw it. ;-)
Date: 31 Mar 2008 15:15:34
Message: <47f14666$2@news.povray.org>
Yeah, I found that.
The naive attempt to make it blow up didn't work, using arrays, so
obviously they're doing something a mite more sophisticated than raw
reference counting. I suspect the fact that there *is* a symbol table
(i.e., that there's really only one pointer to the data structure, and
potentially many pointers to the pointer to the data structure) comes
into it somewhere.
Date: 31 Mar 2008 15:18:03
Message: <47f146fb$1@news.povray.org>
I think they're doing more than reference counting.
Reference counting is also quite slow for things that allocate and
deallocate a lot, as you have to update the counts (atomically, if
threaded) for every assignment.  Plus, if your objects are small (think
LISP), it's a really poor choice.
Here's a decent FAQ I found while looking into the PHP stuff:
http://www.iecc.com/gclist/GC-faq.html
It pretty much covers the basics.  A lot of the cutting-edge stuff
(realtime incremental GC with hardware support etc) is behind a
you-have-to-pay-for-membership portals, like ACM stuff.
Date: 31 Mar 2008 15:25:12
Message: <47f148a7@news.povray.org>
  Hmm, you are mixing reference counting with garbage collection.
  In a pure reference counting system the object is destroyed immediately
when all references to it go out of scope. There are no "GC scans".
(Naturally if it's a long chain of references, destroying the first
object will destroy all the others like dominoes falling.)
  Well, as long as you don't have circular references (there are ways
to make it *difficult* to create them) I don't see a problem.
