POV-Ray : Newsgroups : povray.off-topic : Another hardware-related question Server Time
23 Mar 2026 23:51:57 EDT (-0400)
  Another hardware-related question (Message 1 to 10 of 11)
Subject: Another hardware-related question
Date: 22 Mar 2008 14:52:13
Message: <47e5636d@news.povray.org>
I'm still busy specing my new machine.
I'm planning to have dual monitors. One 20" or 22" widescreen and one 19"
4:3 monitor. Most likely the widescreen will be the primary monitor used for
all games.
I'm looking at getting a GeForce 8800 GT graphics card. Can that run 2
monitors, or do I need to have 2 cards? If the latter, are there any
reasonably priced grahics cards that can handle dual monitors and are still
good for modern gaming?
If I need 2 cards (or 1 add-on card and one built-in), does the motherboard
need anything special?
Subject: Re: Another hardware-related question
Date: 22 Mar 2008 20:12:05
Message: <47e5ae65@news.povray.org>
Depends on the card you get.  I believe all current AMD and NVidia
chipsets provide multimonitor support; it is up to the card
manufacturers themselves to enable it, however.
In other words, it's perfectly possible to buy an 8800 (good choice,
btw, the 512MB version is a great card for the money) that supports two
monitors, but just because it's an 8800 doesn't mean that it has to.
As far as the motherboard goes, nothing needs to be added above what's
necessary to run the card itself (some cards have higher power
requirements, for instance, or need more space in the case).
One thing to keep in mind: both NVidia and AMD have recently introduced
technology to do a type of multicard setup using an onboard graphics
chip combined with a discrete card.  You get a boost compared to a
single graphics card, though not as much as using two discrete cards.
Also, when you're not playing games, the discrete card can be
deactivated, and the system will use only the onboard graphics, saving a
*lot* of electricity.  You might consider holding off a month or two for
this (although that's a slippery slope, as there is always something new
about to be released...)
...Ben Chambers
www.pacificwebguy.com
Date: 23 Mar 2008 01:07:16
Message: <47e5f394@news.povray.org>
> all games.
Keep in mind that many games use vsync, and if you plan on using an LCD
monitor (you didn't mention e/o) it might not support vsync, as it will
not have a normal refresh rate. I think LCDs are mostly 60hz, but it
which require vsync to look good don't always perform very well on it
(zsnes for one).
Sam
Date: 23 Mar 2008 02:41:52
Message: <47e609c0@news.povray.org>
"stbenge" <stb### [at] hotmailcom> wrote in message
news:47e5f394@news.povray.org...
19"
for
> > all games.
New monitor will be LCD, but current monitor (the 4:3 one) is a LCD. Been
using that for a couple years already. Haven't noticed any issues.
Date: 23 Mar 2008 03:01:19
Message: <47e60e4f@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> wrote in message
news:47e5ae65@news.povray.org...
motherboard
Good to know
Is there any way to tell which ones support 2 monitors and which don't?
Either there's nothing that says that in the short summary, or I can't read
hardware descriptions any more.
Is Dual DVI the key? Or do I need to go and read through the maunfacturer
website and read through the details
Based on what the suppliers have, these are my options: (currently
preference is for the 2nd one)
Gigabyte NVIDIAr GeForce 8800GT, 512MB 256Bit GDDR3, PCI-E 2.0, Dual DVI,
HDTV, DirectX 10, OpenGL 2.0, SLI Ready, Vista Premium
xfx geforce 8800 gt: XFX T80F-SHE , Pci-E 16x , geforce 8800GTX Extreme
edition , SLi support , Pci-E 16x , 768mb 384bit DDR3 , support DirectX 10.0
+ shader model 4.0 +FP32 HDR + 16x AA ; , max resolution 2560x1600 , HDCP
Compliant , RoPs : 24 , 36.8 billion/sec texture fill rate , 86Gb/sec memory
transfer , 128 stream processors @ 1.35Ghz ( pixel shader engine + vertex
pipelines ) , core/memory : 600/1900mhz , 2 x dvi , HDTV tvout
XFX T88P-YSF , geforce 8800GT Zalman edition , SLi support , Pci-E 2.0 16x ,
512mb 256bit DDR3 , support DirectX 10.0 + shader model 4.0 +FP32 HDR + 16x
AA ; max resolution 2560x1600 , HDCP Compliant , RoPs : 16 , 57.6Gb/sec
memory transfer , 112 stream processors @ 1.5Ghz ( pixel shader engine +
vertex pipelines ) , core/memory : 600/1800mhz , 2 x dvi , HDTV tvout
asus 8800gt 512mb ddr3 en8800gt/g/htdp/512m: geforce 8800GT , SLi support ,
Pci-E 2.0 16x , 512mb 256bit DDR3 , support DirectX 10.0 + shader model 4.0
+FP32 HDR + 16x AA ; max resolution 2560x1600 , HDCP Compliant , 57.6Gb/sec
I looked briefly at crossfire/SLI, but it looks a little overkill at the
moment.
Thanks for the help.
Date: 23 Mar 2008 07:02:32
Message: <op.t8gw2hvg7bxctx@e6600.bredbandsbolaget.se>
On Sun, 23 Mar 2008 09:01:48 +0100, Gail Shaw sa dot com>
They all do.
Any new non-low-profile consumer card will support dual monitors. The only
thing that may differ is the type of connectors (i.e. DVI/D-SUB or dual
DVI).
> moment.
In my experience, Crossfire/SLI is never worth it. Also, keep in mind that
only nForce chipsets (and only some of those) support SLI on
Intel-compatible motherboards.
FE
Date: 25 Mar 2008 04:39:19
Message: <47e8c847@news.povray.org>
Chambers wrote:
>> motherboard
What he said.
Although, an 8800 is a damn expensive GPU, and it's therefore *highly*
likely that any card featuring this chip will have every connector
option going.
(Now, if you were considering something like a 7100, you'd want to check
before you buy. But a high-end 8800? I would think it'll be there.)
http://blog.orphi.me.uk/
Date: 25 Mar 2008 11:37:09
Message: <47e92a35$1@news.povray.org>
> option going.
I have an nVidia 8600GT. It has two DVI ports.
But: I have a Samsung 932N LCD screen. It has one VGA port. So I have to
use a freaking adapter.
(it has two stuck pixels too, and according to their dead pixel policy,
that's still in the "normal" category)
Date: 25 Mar 2008 12:53:38
Message: <47e93c22$1@news.povray.org>
It's evil practice nowadays to mention the most usual faults as normal.
Eg. Audi's manual says it can draw 1l of oil (the damn-expensive
long-life stuff) on 1000km - it makes maximum of 30l between two oil
changes - just to clear out of possible fault responsibility. Sameways
LCD panel makers mention that n dead pixels is "normal", so they don't
need to seriously jump up the quality. For software one crash/week can
be "normal" and for DVB-receiver it can be "normal" to loose subtitles.
We're living in a "normal" world.
</rant>
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 25 Mar 2008 14:50:51
Message: <47e9579b$1@news.povray.org>
My GeForce 7900GT came *with* such an adaptor in the box. (And an
assortment of other adaptors for that matter...)
As far as I'm aware, CTX have a "zero dead pixels within 101 days" policy.
