POV-Ray : Newsgroups : povray.off-topic : C++ structuring help.... Server Time
3 Nov 2026 12:40:22 EST (-0500)
  C++ structuring help.... (Message 1 to 19 of 19)
Subject: C++ structuring help....
Date: 20 Mar 2008 18:21:03
Message: <47e2f15f@news.povray.org>
As I progress in my understanding of C++, I come closer to the
inevitable conclusion that in order to make my code more efficient and
easy to alter, I need to learn more about classes and structs. Simple
concepts, but the problem comes with implementing said features.
A simple (tile based) level editor is my current project. Already, I
have about two dozen global variables. It's getting messy, and I'm
having to rewrite code to handle, say, foreground tile editing as
opposed to background tile editing.
Does anyone have a link to some good tutorials to help me manage this
ever-growing pile of data? I need to encapsulate everything. I'd like to
rid myself of global variables entirely, if that's possible. Thanks~
Sam
Subject: Re: C++ structuring help....
Date: 20 Mar 2008 19:00:03
Message: <47e2fa83@news.povray.org>
  High-quality object-oriented design is far, far from trivial to do.
It requires years of OOD and OO programming experience, and even then
it usually requires several iterations of design-use-redesign.
  Making a good, encapsulated, abstract, flexible and reusable graphical
editor is a rather difficult tasks of OOD in general (regardless of the
programming language used) and C++ programming in particular. I know this
because I have been working on exactly such a thing as my payjob.
  You are on the right track, though: Global variables should and can
be avoided (there are very few exceptions to this rule, of which eg.
std::cout is a good example (I consider std::cout to be a "global" variable
even though it's inside a namespace), where practicality compensates
globality more than enough), and clean abstract designs should be preferred.
Date: 20 Mar 2008 20:46:57
Message: <47e31391$1@news.povray.org>
OOC, do you consider static members to be global? They're not tied to an
instance of an object, but are generally available throughout the
program (if made public)
Date: 21 Mar 2008 00:33:12
Message: <47e34898@news.povray.org>
Thanks, I feel both better and worse.
I'll just have to take baby steps and see what I learn. Thanks!
Sam
Date: 21 Mar 2008 12:43:11
Message: <47e3f3af$1@news.povray.org>
> be avoided
While generally true, I find that if the *meaning* of a variable is
truly global, it can be made a global harmlessly.
FILE * resourcefule;
   // The handle to the resource file if it's open, or NULL if not.
Stuff like that. If there's ever an instant where the definition of the
variable doesn't match its content, then it isn't global, it's just a
backdoor to pass parameters between functions.
Of course, with OO more than procedural code, you're more likely to pull
a class into some other framework where it wasn't expected to be, so
there's less good use for globally-visible variables. (Unless, of
course, your language treats classes as globals, rather than as second
class objects.)
But I've never regretted making a global that was truly global in that
sense, so anyone could reference it.  "Bad" globals are ones that don't
have a meaningful value for the entire duration of the program, from the
first line to the last, methinks.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 21 Mar 2008 16:56:21
Message: <47e42f05@news.povray.org>
stbenge wrote:
> Hi,
The easiest way to get rid of the globals is to declare a class which
has some static members in it:
appdata.h:
class AppData {
     static int AppDataInt;
appdata.cpp:
#include "appdata.h"
int AppData::AppDataInt=0; // or whatever
Everytime you want to use your formerly global data, you include
appdata.h in the file and make sure you use the scope resolution to
access it.
One benefit of this is that you can now borrow code from another project
that uses globals without worrying about those globals conflicting with
your ex-globals.
Additionally, you can make make the static members of AppData private
members, and access them through member functions of AppData, to enforce
sanity checks on the changes you make to the data.
I've been doing C++ since '02, and most of the hands-on involves my
modeling application; it was originally written in C starting in 1999,
and much of the code base remains a product of non-OOP C thinking.
John
Date: 22 Mar 2008 13:47:54
Message: <47e5545a@news.povray.org>
  Not really because they don't garbage the global namespace and, most
importantly, they cannot be pulled out of the class, unlike things inside
namespaces can.
Date: 22 Mar 2008 13:50:26
Message: <47e554f2@news.povray.org>
  There are a few cases where a global instance may be more practical than
harmful. In C++ in particular, though, I still prefer putting those inside
a namespace.
  As I mentioned, I think std::cout is a good example.
Date: 22 Mar 2008 13:58:11
Message: <47e556c0@news.povray.org>
  IMO that only masks the problem, it doesn't solve it.
  If you find yourself using tons of global variables that's usually a
sign of an overall design flaw in your program. Moving the globals inside
a namespace or a class doesn't really solve the underlying design problem.
  As I have already mentioned, not all global variables are bad, and it's
not like you would have to avoid them like the plague. However, usually
the vast majority of global variables, especially if you find yourself
writing tons of them, are a sign of bad design.
  It's usually a sign that you are not using proper encapsulation and
proper abstraction, which are key concepts in creating high-quality reusable
and flexible code.
  Note that the problem with global variables is *not* exclusively that
the garbage the global namespace. That's actually the smallest of the
problems involved. That's why simply masking this one problem isn't really
the answer to the bigger design problems.
  With small projects good OOD doesn't really matter. However, the larger
the project, the more it becomes really useful.
Date: 22 Mar 2008 14:25:19
Message: <47e55d1f$1@news.povray.org>
> harmful.
Yeah. Kind of like "goto". :-)
> a namespace.
Certainly if you can give it a name that groups it appropriately, that's
an improvement.  I just call anything whose lifetime and scope are both
"the entire execution of the program" a global, regardless of how the
name is qualified.  I don't think putting it inside a namespace prevents
too many of the traditional problems associated with globals.
Exactly. It means one thing, and it means that thing throughout the
entire lifetime of the program. Unlike, say, "errno", whose semantics
are poor due to not meaning anything obvious if the immediately
preceding system call didn't fail - i.e., there are far too many caveats
on when errno is "valid" for it to count as a good use of globals. It's
more a kludge due to C not being able to return multiple values.
Of course, throw in threads and everything gets more confusing. :-)
Date: 22 Mar 2008 14:31:18
Message: <47e55e85@news.povray.org>
> > harmful.
  I disagree. I have been writing C++ for hobby and professionally for
over 10 years, and the total amount of C++ I have written is probably
closer to 100k lines of code. I don't remember *ever* writing even a
single "goto".
  It's not like I avoid it. I just don't need it. (Usually good basic
encapsulation takes automatically care of anything that would be an
"acceptable use of goto" otherwise.)
  Global variables (inside namespaces or not) is not something I have used
a lot, but I have a few times. I believe I can rationally argue for the
rationality of each one.
Date: 22 Mar 2008 14:36:45
Message: <47e55fcd$1@news.povray.org>
> single "goto".
Note that calling "return" in the middle of a function is equivalent to
"goto". :-)  Arguably "continue" and "break" and exceptions as well.
Those are all non-structured constructs.
And, of course, depending on your language, "goto" may be more or less
common.  Take break and continue out of your loops, take try/finally out
of your exception handling, and suddenly there's places where "goto" is
cleaner.
Admittedly, not a lot. Indeed, Tcl doesn't even have a goto. For a
language where it's pretty trivial to implement your own control
structures, I think I'd have a hard time implementing "goto" in Tcl.
Agreed.  I was just trying to say that there are people who think "goto"
is inherently evil, and that globals are inherently evil, because that's
what they've been taught, but that's really just lies-to-children until
they have enough experience to learn the few places where it really does
make more sense.
And then as programming languages evolve, they incorporate the good
places to use a goto into the syntax of the language and call it
something else, like "try/catch" or "return".
Go back to Pascal with no break, no early return, no exceptions, and
you'll realize where you miss your "return". :-)
Yep.
Date: 22 Mar 2008 14:42:48
Message: <47e56138@news.povray.org>
> > single "goto".
  I really think that when Dijkstra wrote "goto considered harmful" he
really meant "goto", as in "jump to a label", and not other control
structures (such as returns, loops and conditionals).
  The idea is that "goto" (ie "jump to a label") makes the code more
obfuscated than other control structures, and usually needlessly so.
> make more sense.
  I don't think goto is inherently evil. I think it's inherently unnecessary,
and overusing it is a bad idea. In the vast majority of cases there are
better alternatives.
  At least those state more clearly their intention and are not so easy
to misuse.
Date: 22 Mar 2008 18:40:04
Message: <47e598d4$1@news.povray.org>
I think when he wrote it, he was primarily addressing a generation of
FORTRAN programmers. :-)  The people he was talking to generally didn't
have things like "if/then/else" in the language they came from.
Right. Structured programming is where each statement has an entrance
and an exit. That's what (IIRC) Dijkstra was talking about.
Returning from the middle of a function also *can* make code more
obfuscated. Certainly it isn't structured. Maintaining a function with
internal returns when you need to put something at the end is as bad as
making a function work that can throw exceptions when you have no
"finally" type of functionality.
Take a look at something like Eiffel, where there's no goto, no return,
no break or continue, and exceptions either abort your function or start
over at the beginning of it, depending on whether you catch them or not.
I can imagine situations where a goto might be handy in such a language.
"break" and "continue" and "return" and "catch" are all just limited
versions of "goto" that give you the way to do the good stuff with
"goto" without giving you the way of doing the "bad" stuff with goto.
Agreed. But again, it depends on the language. Something like the
original version of Pascal? Not uncommonly the best way to get out of a
nested loop, or to have several bits of code all clean up in a "finally"
kind of way.  Something like the original BASIC?  Unquestionably
necessary as it was the only way to build a while loop.
Much of the control structure research in "normal" languages
(single-threaded etc) consists of better ways of expressing "goto". :-)
> to misuse.
Exactly. And take them out of the language (like when Dijkstra was
writing) and he's talking about using "goto" in good ways, namely in
structured ways.
Date: 22 Mar 2008 19:48:45
Message: <47e5a8ed@news.povray.org>
  Dijkstra advocated structured programming as a replacement for the
heavily "goto-based" programming of the time. Structured programming
introduced concepts which are common in most current languages. The
more the reason to not to use goto...
Date: 22 Mar 2008 19:58:44
Message: <47e5ab44$1@news.povray.org>
Exactly. And the structured programming he introduced also eschewed
early returns, break, continue, etc. That's all I'm trying to say. :-)
If your language has *no* unstructured control-flow statements (such as
early returns, break, continue, etc) then you probably wind up using
goto about as much as you wind up using globals.
Date: 22 Mar 2008 21:28:43
Message: <47e5c05b$1@news.povray.org>
Actually, this discussion lead to an interesting insight (for which I
thank you).
The real problem with "goto" is not so much the "goto" as the "come
from". I.e. you see a label, and anything in scope of that label might
branch there. In something like COBOL or (dartmouth) BASIC, anywhere in
the entire program might branch to any label in the entire program.
If you refactor a program to take some commonality out of a handful of
functions, and that commonality doesn't really stand on its own, you
haven't really structured it. You've just used a function as a goto.
I have a bit of program that takes an audio sample and tries to find a
match. It does some stuff up front, and then depending where it looks
for it, it makes different decisions to see if it "matches". It may or
may not take timezones into account. It may or may not take time into
account at all. It may or may not take the character set of the returned
metadata into account, or the source of the metadata.  Depending what we
match it again, there's four or five or six (depending on how you count)
matching routines. I remember at one point wishing I had the FORTRAN
"entry" declaration available. :-)
In any case, when I refactored the part that actually ran on *that*
particular sort of computer, I actually wound up with a routine that's
pretty much meaningless outside that matching mechanism, and which gets
a whole bunch of variables that used to be local and don't make any
sense as independent parameters (e.g., the logging information so far
onto which I append more heuristic results so I can tell why it does or
doesn't work after the fact, which of the fault-tolerance servers were
queried and whether the first one worked or not, which column of the
database to pull character set information out of, etc.) Stuff going in
and out which you'd never have put in there had you not ripped the
routine out of three copy-and-paste(*) functions and modularized it.
That's really not structured programming. That's three functions all
using "goto" to go to the start of that function and passing any locals
it uses in and out as parameters.  It's just another way of writing a
goto, and it really doesn't clarify the code any as you might otherwise
expect from "lifting common functionality into a subroutine."
Interesting.
(*) That's maybe the fourth or fifth time here I've changed
"cut-and-paste" to "copy-and-paste" on this forum. I'm not sure whether
to thank Warp for correcting me or be annoyed at him. ;-)
Date: 24 Mar 2008 18:21:24
Message: <47e83774@news.povray.org>
> make more sense.
C++ FAQ Lite:
One size does not fit all. Stop. Right now, take out a fine-point marker
and write on the inside of your glasses: Software Development Is
Decision Making. "Think" is not a four-letter word. There are very few
if any "never..." and "always..." rules in software — rules that you can
apply without thinking — rules that always work in all situations in all
markets — one-size-fits-all rules.
[and from another FAQ:]
It really bothers me when people think they know what's best for your
problem even though they've never seen your problem!! How can anybody
possibly know that multiple inheritance won't help you accomplish your
goals without knowing your goals?!?!?!?!!!
Date: 25 Mar 2008 06:51:36
Message: <47e8e748@news.povray.org>
> if any "never..." and "always..." rules in software ??? rules that you can
> apply without thinking ??? rules that always work in all situations in all
> markets ??? one-size-fits-all rules.
  Maybe "never use goto" is wrong, but "in the over 10 years I have programmed
I have never needed goto" is right. I think it's rather telling.
  I completely disagree with anyone who says that multiple inheritance
is a bad thing.
  Sure, multiple inheritance can be misused. But so can regular inheritance.
So can variable and function naming. *Anything* can be misused.
