I've read (in "joel on software") that, to avoid confusion between == and =,
when you sometimes use languages that use = as assignments AND comparisons,
you can do some comparisons like this :
0 == myvalue
instead of
myvalue == 0
the former causes an error if you put = instead of ==, which avoids potential
headaches later.
While it could seem very ordinary to hardcore programmers here, to me it's
very smart, and I would like to know if there's some place where I could
learn other little tricks like this...
any links ?
Fabien.
Subject: Re: Smart little programming tricks, where to find ?
Date: 18 Mar 2008 06:03:58
Message: <47dfa19e@news.povray.org>
Fa3ien <fab### [at] yourshoes skynet be> wrote:
> 0 == myvalue
> instead of
> myvalue == 0
I have always disliked that "trick" because it breaks the logical way
to "read" the line. Nobody says "if zero is equal to this value". The
common expression is "if this value is equal to zero".
I have seen some people go further and extend that "trick" to things
like:
0 < money
This always confuses me. Again, nobody says "if zero is smaller than
the amount of money". That sentence would be quite confusing. Naturally
everyone says "if the amount of money is larger than zero".
Date: 18 Mar 2008 08:23:36
Message: <47dfc258@news.povray.org>
comparisons,
> 0 == myvalue
I think the best "trick" is to use a programming language which was designed
with at least some forethought, so that such tricks are unnecessary.
Date: 18 Mar 2008 10:44:24
Message: <47dfe358@news.povray.org>
Such languages may lack necessary libraries, support or efficiency.
Date: 18 Mar 2008 10:47:27
Message: <47dfe40f$1@news.povray.org>
And that's the sad part. C is a horrid, horrid language, but it's where
all the libraries are. All the "good" languages I've seen have a
crippling lack of half-decent libraries... [And usually, rather limited
documentation and unpolished toolchains.]
http://blog.orphi.me.uk/
Date: 18 Mar 2008 10:49:09
Message: <47dfe475@news.povray.org>
Btw, often people wonder why C++ is so popular, given that there are
so many "better" languages out there.
IMO one very important factor for the popularity of C++ is the staggering
amount of libraries for it. Since almost all C libraries can be used in C++,
the amount of available libraries is simply enormous.
This is, IMO, often one of the major killers for new languages: Lack of
libraries. The language may be the most perfect language in the world, but
if you don't have libraries to do what you want, it's almost useless.
Nobody wants to reinvent the wheel for every little thing that has been
already implemented to death by other people.
Date: 18 Mar 2008 13:06:05
Message: <47e0048d@news.povray.org>
I mostly agree. When I seen that trick, I also thought that it was not
very "natural", being the reverse of "this equals that".
However, there are many areas were programming require some kind
of backwards-thinking or even worse, so that's quite benign.
All in all, I don't recommend the trick or even think I'm gonna
use it myself, it was mostly an example of a small trick that
implies a little thinking, and I was wondering if there were any
other small programming tricks of that kind.
Fabien.
Date: 18 Mar 2008 18:00:59
Message: <47e049ab@news.povray.org>
Heh.
To answer the original question, check out the book "programming pearls".
I do the (0 == X) and it seems quite natural after a time. (And I
occasionally get asked why I do such things in languages where
assignment and equality don't get mixed up, like Tcl. :-)
I also do the "never use the > sign" in comparisons. It's not a question
of how you read it out loud, but a question of putting the things in the
right order. For example:
0 < A & A < B
If A is between zero and B.
A < B | C < A
If A is outside the range B to C.
if (start + 300 < now)
If now is at least 300 seconds past when we started.
Start putting in complicated timestamp calculations, and it becomes very
helpful. Always use < or <=, always add rather than subtract offsets,
and I almost never make a mistake and get the wrong things being compared.
It's kind of like drawing a picture, rather than writing a sentence.
IME, most programmers are more visual than auditory.
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
Date: 18 Mar 2008 18:11:03
Message: <47e04c07@news.povray.org>
That's why I'm looking at Erlang. Decent language, good efficiency,
industrial-strength libraries.
Date: 19 Mar 2008 05:31:27
Message: <47e0eb7f@news.povray.org>
Darren New wrote:
>> where all the libraries are. All the "good" languages I've seen have a
I did look at Erlang. (Let's face it, other than Lisp, it's the only
remotely "popular" functional language. And Erikson is behind it, so
that's a pretty damn big vote of confidence in the soundness of the
technology.)
But alas, it's not purely functional, and the general style just seemed
untidy and complicated. It's just not my cup of tea...
Date: 19 Mar 2008 06:42:51
Message: <47e0fc3b$1@news.povray.org>
Warp wrote:
> 0 < money
Where that really comes into play is range statements:
if(10 < money && money < 100)
which can be read as "if money is between 10 and 100"
Someone I used to work with insisted that you use the same direction in
comparisons if you had more than 1 comparison. It seemed to make sense
when he used this example. The equivalent (and probably the way most
people are familiar with handling ranges) "money > 10 && money < 100"
isn't as quick to parse what you're looking for. Using that sort of
statement with a single comparison seems a bit ridiculous to me, though.
I have seen and used the [Constant|Literal] == [Variable] syntax before,
it's good for preventing assignment where you meant equality bugs. Of
course, the problem becomes obvious when you begin debugging seemingly
bizarre behavior. But, the objective is to prevent such behavior in the
first place.
My favorite syntactical bug was the following:
for(int i = 0; i < cItems; i++);
... Block of code ...
It's subtle, and if your for loops are any more complex than the above
trivial example, results in headaches. I spent an hour tracking
something similar down in my early days.
Date: 19 Mar 2008 06:58:13
Message: <47e0ffd5$1@news.povray.org>
Nothing wrong with C or it's derivatives. Once you've acquainted
yourself with the syntax, it's quite powerful.
Then you can do such convenient things as:
int * DoStuff(int i)
//... code for DoStuff here ...
int *(*pfunc)(int);
int main(int argc, char **argv)
pfunc = DoStuff;
// This will call DoStuff (In C# pfunc would be called a "delegate")
int *pWhatever = pfunc(4096);
Date: 19 Mar 2008 07:02:42
Message: <47e100e2$1@news.povray.org>
I'd venture to say C# also has an astounding amount of libraries (at
least, on the Windows platform ...) the base library for .NET is pretty
extensive, though not without limitations, but those can easily be
worked around. I don't know whether the base libraries for Mono are as
plentiful, as I only have very limited experience with Mono.
The drawback? It's not viewed as a high performance language.
Date: 19 Mar 2008 10:22:06
Message: <47e12f9e@news.povray.org>
What's wrong with C++? I just found out how to make a dynamic 2d array
and save numbers to a file via binary representation. The possibilities
just opened up...
A very big plus :)
This is why I'm giving up Euphoria. It was great when I has DOS, but now
that I have XP, the best graphics library I could find was a sucky
Allegro implementation. Very buggy and wasteful, since the best it can
do is a difficult version of triple buffering, and only in certain video
modes. I used to arrive at a better result using only *one* virtual
screen...
C++ is great. If I don't like a certain library, I can find a new one.
My current favorites are SDL (for CA sims) and HGE (for games). Irrlicht
looks promising, though I haven't played with it much.
Sam
Date: 19 Mar 2008 10:39:05
Message: <47e13398@news.povray.org>
I don't have any problem in quickly understanding "money > 10 && money < 100"
because I use it so much.
(OTOH, one could argue that understanding "0 < money" becomes easy when
you use it a lot...)
The form you suggest becomes a bit counter-productive when the expression
is not a pure "between x and y", like for example:
if(10 < money*money && money*12 < 100)
Now it becomes much harder to understand quickly what's going on.
> first place.
In most cases the compiler will issue a warning anyways if you make
the mistake. Never been a problem to me.
If the loop of the body uses 'i' (as is rather usual) you'll get a
compiler error.
Date: 19 Mar 2008 10:41:00
Message: <47e1340c@news.povray.org>
And rather Windows-only.
Date: 19 Mar 2008 10:43:10
Message: <47e1348e@news.povray.org>
Some people don't like the fact that memory management requires great care.
Date: 19 Mar 2008 11:00:06
Message: <47e13886$1@news.povray.org>
Yeah. I don't think you could get a real distributed language with
everything being truly functional, could you? Certainly you couldn't do
things like talking to device drivers in a *purely* functional way,
methinks. I mean, what's the functional equivalent of "the machine
running the calculation just burst into flames"? :-) What's the
functional equivalent of "we've just released a new version of this
function"?
Yep. Altho the language itself seems pretty simple and straightforward,
the infrastructure used to support installs and reliability and such is
pretty dense. Lots of forward references to stuff I haven't read yet,
and I haven't yet found the roadmap to the right order to read things
in. :-)
Date: 19 Mar 2008 11:03:07
Message: <47e1393b$1@news.povray.org>
There's lots wrong with it, and it isn't particularly powerful. On the
other hand, it's straightforward and doesn't take a whole lot of runtime
support, and it's simple enough that pretty much everyone does it the
same way. (Unlike all the flavors of LISP, for example.)
(As for what's wrong with it, I simply cite autoconf and buffer overruns.)
No it wouldn't.
Date: 19 Mar 2008 11:47:32
Message: <47e143a4@news.povray.org>
Um... why?
Throwing an exception, as a guess. Like a division by zero error, but
less deterministic. (??!?!) ;-)
> What's the
> function"?
Now that's an interesting question...
>> and the general style just seemed untidy and complicated. It's just
If by "simple and straight forward" you mean "assumes referential
transparency but doesn't actually enforce it or make any attempt to
check that it's there", then sure. Go knock yourself out. ;-)
> in. :-)
Gotta love documentation where you can't figure out what order to read
it in...
OTOH, try just *finding* a good reference for Haskell for beginners...!
Date: 19 Mar 2008 11:48:28
Message: <47e143dc$1@news.povray.org>
Isn't that the whole point of the Mono project?
Date: 19 Mar 2008 12:12:02
Message: <47e14962$1@news.povray.org>
I don't find it too difficult to delete every "new". Of course, I
haven't coded anything too huge... yet.
Sam
Date: 19 Mar 2008 12:34:11
Message: <47e14e92@news.povray.org>
You would be surprised.
There's a potential memory leak here:
void foo()
char* s = new char[100];
bar();
delete[] s;
class A
char* s;
public:
A(): s(new char[100]) {}
~A() { delete[] s; }
Naturally both of these leaks can be fixed by using cleaner code:
void foo()
std::string s(100, ' ');
bar();
class A
std::string s;
public:
A(): s(100, ' ') {}
No 'new' -> no leaks.
Date: 19 Mar 2008 13:00:04
Message: <47e154a4$1@news.povray.org>
Hey, but there are 'new's in the standard lib :-)
I think it would be more informative to give fixes that do not rely on
the standard library... After all the 'new' operator exists for a
reason, you don't always want to use the standard lib, and knowing what
to do in these cases is useful.
No I won't do it as I'm not even sure I know where the leak is in the
first case :-)
Vincent
Date: 19 Mar 2008 13:01:41
Message: <47e15505$1@news.povray.org>
> void foo()
> bar();
> delete[] s;
If bar throws an exception, s won't be deleted. It can be avoided by
using a smart pointer.
> class A
> char* s;
> public:
Erm... No idea :) I know it could cause a double-free if you copy the
object, since it doesn't have an explicit copy constructor and the
default one doesn't do what we want in this case; but I don't know what
could cause a leak.
> void foo()
> bar();
> class A
> std::string s;
> public:
> A(): s(100, ' ') {}
Of course a string is better for this particular case :) Also avoids
many possible buffer overflows (thought not all; operator[] is unchecked).
Date: 19 Mar 2008 16:02:56
Message: <47e17f80@news.povray.org>
If the standard library cannot be used, then it becomes a bit complicated.
> first case :-)
If bar() throws an exception you have a memory leak.
Date: 19 Mar 2008 16:04:51
Message: <47e17ff3@news.povray.org>
> could cause a leak.
Ok, not a leak per se, but accessing freed memory. (Although that would
require more member functions than I added there...)
Date: 19 Mar 2008 17:15:59
Message: <47e1909f$1@news.povray.org>
>> could cause a leak.
Ahh, then I can say I did figure out both.
Date: 19 Mar 2008 17:36:56
Message: <47e19586@news.povray.org>
Ok, if you want a harder puzzle, here's a curious quirk about C++ (not
related to memory leaks, though):
#include <map>
struct A { int i; };
struct Comp
{ bool operator()(const A& a1, const A& a2) const { return a1.i < a2.i; }
int main()
std::map<A, int, Comp> theMap(Comp());
A a = { 1 };
theMap[a] = 5;
a) This doesn't compile. Without using a compiler, can you tell where
is the problem and what is the exact reason why it doesn't compile?
b) If you can't see it, try it with a compiler. I bet you still can't see
the problem... :P
c) In the erroneous line, can you tell me exactly what that line means?
d) What is the easiest way (smallest amount of extra code) to make it
compile and work as expected?
Date: 19 Mar 2008 18:08:32
Message: <47e19cf0@news.povray.org>
> the problem... :P
Well I have no real idea of what goes wrong but I have a proposition for
d) :-) Down below...
Replacing
with
Comp c; std::map<A, int, Comp> theMap(c);
seems to do the trick as far as I figure. I don't like those anonymous
objects anyhow ;-)
A trouble with references or some such ? That prevents the full
instanciation of the map template ?
Vincent
Date: 19 Mar 2008 18:24:48
Message: <47e1a0c0$1@news.povray.org>
> #include <map>
> struct Comp
> int main()
> A a = { 1 };
> theMap[a] = 5;
Hrm, I never used map myself. I think I'll go search documentation on
what the template parameters are.
> the problem... :P
Oh I think I know. I took a while without noticing anything wrong, but
now I remember having read about it in C++ FAQ Lite. theMap(Comp())
*declares a function* instead of instantiating an object. Good to know
all the time I wast^H^H^H^H spent reading that website was actually useful.
Okay, *after* remembering that and writing that paragraph, I went and
searched for what I remembered having read. Maybe that counts as
cheating... I wouldn't have searched if I had read question D before, so
I could try figuring out the solution myself :)
http://www.parashift.com/c++-faq-lite/ctors.html#faq-10.2
The solution is:
std::map<A, int, Comp> theMap = Comp();
Date: 19 Mar 2008 18:52:53
Message: <47e1a755$1@news.povray.org>
Say I wrote
int** foo = NULL;
int nx = 22, ny = 17;
void matrixfunc(){
foo = new int*[nx];
for (int x = 0; x < nx; x++)
foo[x] = new int[ny];
and called matrixfunc();, but before I could delete it
delete[] foo[x];
delete[] foo;
foo = NULL;
the code crashed. Do I have a memory leak?
Sam
Date: 19 Mar 2008 19:10:55
Message: <op.t8af4hfr7bxctx@e6600>
On Thu, 20 Mar 2008 00:52:55 +0100, stbenge <stb### [at] hotmail com> wrote:
> Say I wrote
> int** foo = NULL;
> void matrixfunc(){
> foo = new int*[nx];
Much better to use std::vector instead. Avoid raw pointers like the
plague; it will save you many headaches.
> delete[] foo[x];
> delete[] foo;
> foo = NULL;
If by "crash" you mean unexpected program termination, then not really
(not because of the crash anyway). Any modern desktop OS will reclaim th
e
resources held by a program when said program terminates.
FE
Date: 19 Mar 2008 22:02:36
Message: <47e1d3cc@news.povray.org>
Yes, it takes practice.
If money squared is more than ten or money times twelve is less than a
hundred. Makes sense to me. :-) But then, I'm used to it.
I've noticed since this came up that I'll even do things like
if (i > 0^H^H^H^H^H0 < i) ....
It depends on the language, and the compiler. A lot of embedded
compilers aren't too smart, and a lot of languages that adopted C syntax
(PHP, Java, etc) aren't too smart about that too.
Date: 19 Mar 2008 22:07:01
Message: <47e1d4d5$1@news.povray.org>
> Um... why?
Because it's nondeterministic? It's I/O driven? It's asynchronous?
I mean, to the extent that you think a tail-recursive function accepting
asynchronous messages and sending asynchronous messages in return can be
"functional," then it looks like Erlang is functional.
>> I mean, what's the functional equivalent of "the machine running the
Who throws the exception? The machine running the calculation isn't in
any shape to do so.
>> What's the functional equivalent of "we've just released a new version
>> of this function"?
Let me know when you figure it out. ;-)
Where do you think it doesn't assume referential transparency?
By "simple and straightforward" I meant in the sense that there are
relatively few types and primitives and interactions between them. More
like Tcl or C than Ada or C++.
> it in...
It's not unusual. It's how I learned most of the languages I know. But
then, most of the languages I learned that way didn't have 1500+ pages
of documentation for the libraries. :-) A two-pass read of the library
docs is going to take a while.
Date: 19 Mar 2008 22:09:38
Message: <47e1d572@news.povray.org>
My understanding is that there are piles and piles of gotchas you have
to learn about before you can make reliable programs, even if you stay
within the definition of the language and don't start doing threads or
dynamic code loading or things like that.
With C, for example, there are only a handful of gotchas you have to
learn about. Stuff like "don't run off allocated memory", "don't fail to
declare types of function arguments and returns", "make sure your
definitions match your declarations", "put parens around your macros", etc.
Date: 20 Mar 2008 03:41:51
Message: <47e2234f@news.povray.org>
> Replacing
> with
That's not the shortest possible solution.
No.
Date: 20 Mar 2008 03:45:39
Message: <47e22433@news.povray.org>
But why? Doesn't "Comp()" create an object? How can you declare a function
with an object (instead of a type)?
What kind of function? What does it return? Does it take parameters?
What is the type of those parameters?
> The solution is:
Alternatively you can do:
std::map<A, int, Comp> theMap((Comp()));
(which would be necessary if the map constructor took more than one such
parameter...)
Date: 20 Mar 2008 03:48:12
Message: <47e224cc@news.povray.org>
> > Say I wrote
> > int** foo = NULL;
> > void matrixfunc(){
> > foo = new int*[nx];
Yeah. You can do that with a one-liner:
std::vector<std::vector<int> > foo(nx, std::vector<int>(ny));
And you don't have to delete anything.
Date: 20 Mar 2008 05:29:15
Message: <47e23c7b$1@news.povray.org>
>> Um... why?
Haskell supports random number generators. And I/O. And asynchronous
exceptions. It just cleanly seperates what *is* deterministic from what
is *not*, that's all. ;-)
> any shape to do so.
I would presume the exception is just thrown to whoever is waiting for
the answer?
>>> version of this function"?
To be honest, I'm not really seeing a clean way to handle this in *any*
language, but I haven't thought about it for that long yet.
Please reparse my sentence. I said it *does* assume referential
transparency yet does nothing to *enforce* or even *check* for it.
In other words, if you're not careful, you can easily cause the system
to massively malfunction with a few incautiously chosen commands.
I consider Haskell to be quite simple in this respect too. Until you
start digging things up out of the standard libraries, the language
itself gives you lists, tuples, integers, reals, booleans, characters,
and that's more or less it. And the language is nearly devoid of
keywords. (Decide for yourself if that's good or bad.)
>> it in...
I'm looking at you, Oracle. Trying to figure out where to start reading
to actually comprehend this stuff is *far* too hard!
It's not that Oracle is hard to understand - just that the [multiple]
manuals explain it quite poorly.
Date: 20 Mar 2008 06:42:29
Message: <47e24da5@news.povray.org>
Right, and I don't think I'd dare use that form for a set of comparisons
like that. But for simple ranges, it makes sense.
Until you're working on some project where someone has set the Warning
level so low that there are no warnings. (I have run into that, and
setting the warning level any higher scared me ... so many warnings...)
> compiler error.
Without opening the argument on MS compiler vs a truly ANSI compliant
compiler, that is not the case with Visual C++. It happily compiles the
code because i is still declared after the for loop.
(I dislike this sort of behavior, and IIRC, they fixed it in more recent
versions, but have an option to keep it compatible with code written in
older versions)
Date: 20 Mar 2008 06:45:47
Message: <47e24e6b@news.povray.org>
>>> pretty extensive, though not without limitations, but those can
>>> easily be worked around. I don't know whether the base libraries for
>>> Mono are as plentiful, as I only have very limited experience with Mono.
I thought so. But the caveat is this:
Programs written to the MS .NET Framework, will not run under the Mono
.NET Framework, and vice-versa. Though you can write software in C#
using Mono as the framework, and have it run under Windows, and various
Linux flavors.
Date: 20 Mar 2008 07:00:52
Message: <47e251f4$1@news.povray.org>
> No it wouldn't.
Aside from multicast delegates, Doesn't a delegate act similar to a
function pointer?
Date: 20 Mar 2008 16:23:59
Message: <47e2d5ef@news.povray.org>
Hmm, I'll consider using this in the future. If I'm lucky, I can even
change my existing code to accommodate it. Thanks!
Sam
Date: 20 Mar 2008 17:19:10
Message: <47e2e2dd@news.povray.org>
Nobody probably cares, but the answer is:
declares a function called 'theMap' which returns a value of type
std::map<A, int, Comp> and takes one parameter: A pointer to a function
which takes no parameters and which returns a value of type Comp.
The reason *why* this is so is apparently because of backwards
compatibility with old C code, and something the C++ standardization
committee really didn't want to include in the standard, but they had
little alternatives (lest they break a lot of existing code).
Date: 21 Mar 2008 11:46:07
Message: <47e3e64f$1@news.povray.org>
To be clear, I think it's harder to understand because it's nonsensical,
not because the comparisons are in the wrong order. Is it any harder to
understand that than
if(money*money > 10 && money*12 < 100)
?? I'd say the failure here is naming the "money" variable incorrectly
and not abstracting out the meaning.
interest_basis = money * money;
total_interest = money * 12;
if (10 < interest_basis && total_interest < 100) ...
Date: 21 Mar 2008 12:01:15
Message: <47e3e9db@news.povray.org>
So does Erlang, from what I can see. Every statement always works the
same way. It's nondeterministic because it depends on the timing of
statements between asynchronous events. But once a message is in your
queue, you'll process it the same way every time. Again, as far as I can
tell from my reading so far...
Now, Erlang does have stuff like the "process dictionary" that is
imperative, but every mention of it is followed by "don't use this if
you don't know what you're doing, because it's stateful and imperative!"
>> any shape to do so.
> the answer?
Right. As an asynchronous message, unless you're not trapping it, in
which case you too throw the same message.
(You don't wait for results. You send a message, and optionally wait for
one to come back, perhaps with a timeout. But you can "link" processes,
which means a failure of one of them will cause the others to fail with
the same exit code, unless they're "trapping exits", in which case the
failure will be translated into a notification.)
So, overall, still functional.
Erlang does it by running the old version and new version at once. As
long as your code only makes local calls, it keeps running the old code.
If it makes a tail-recursive call to a fully-qualified method, then the
latest version of that method gets run.
So you have code like this (not in actual erlang syntax):
method myserver::loop(State)
receive {request, Params} from Sender ->
{Result, NewState} = calculate(Params, State);
send Result to Sender;
loop(NewState);
receive {upgrade, TransformFunction} ->
NewState = TransformFunction(State);
myserver::loop(NewState);
end.
So it runs along happily, processing requests, in the loop. If you want
to upgrade, you recompile the code, load the new version, write an
anonymous function that transforms the data the server is holding from
what the old version uses to what the new version uses, and tell the
server to restart the loop after passing the state through the transform.
And this is all managed by the release management code, too. *That* is
the complicated part: all the infrastructure already built.
Like what? I mean, that's true in some sense, but it's true of any
system depending on what you mean by "massively malfunction". Since
processes *can* have side-effects, you don't get referential
transparency. But I don't think you have that with monads in Haskell,
either, yes? Are references to the IO monad referentially transparent?
I thought that was kind of the point of monads.
>> More like Tcl or C than Ada or C++.
Yes, exactly.
Just Oracle, or SQL in general? But yah, giant lumps of code like that
are a mess to grok.
I once was looking at a program called Scopus (functionality not unlike
SAP), and I spent literally a full work day trying to get a record
entered into the database.
Me: Create a contact.
It: You first have to create the company the contact works for.
Me: Create a company.
It: You have to create the city the company is in.
Me: Create a city.
It: You first have to create the salesman responsible for that city.
Me: Create a salesman
It: You first have to create the department the salesman works for.
Literally. I gave up after about 40 of these indirections, some of which
seemed circular.
Date: 21 Mar 2008 12:02:29
Message: <47e3ea25$1@news.povray.org>
Mike Raiford wrote:
>> No it wouldn't.
> function pointer?
Only if you disregard that they're multicast and object-oriented and can
be targets of events. I'll grant you that "delegate" is as close as C#
has to the concept of "pointer to function". :)
Date: 21 Mar 2008 12:03:24
Message: <47e3ea5c$1@news.povray.org>
> ..NET Framework, and vice-versa.
It depends on the program. ASP.NET stuff runs quite smoothly. Stuff
you write that depends on libraries that haven't been ported yet
doesn't, no. :-)
Date: 21 Mar 2008 20:16:18
Message: <47e45de2$1@news.povray.org>
What does Haskell do to enforce referential transparency, by the way? I
don't really understand monads any more, but it would seem to me that if
you piped the standard output of a Haskell program into a second Haskell
program, then the output of the second one back into the first one, you
could see some odd "non-transparent" things happen as each program's
output affected its input, yes?
Otherwise, I'm not sure where Erlang falls down, other than, as I said,
the obvious places where you're actually actively writing things to
disks and reading them back later.
