POV-Ray : Newsgroups : povray.off-topic : Need a scripting language Server Time
3 Nov 2026 12:43:28 EST (-0500)
  Need a scripting language (Message 1 to 9 of 9)
Subject: Need a scripting language
Date: 15 Mar 2008 04:18:32
Message: <47db9468@news.povray.org>
OK, I don't know if I'll ever get around to doing this, but *if* I
decide to do it, I need a new tool for it...
Basically, I need to write an app that will store user submitted data in
a database, create visual representations of said data, and query
specific web sites based on the data selected.  In other words, a
language that makes it easy to:
) Use forms to enter data
) Store data in a DB
) Query said DB through other forms
) Create graphical presentations
) Fetch a web page
) Process said web page, looking for specific information
Ideally I would also be able to format data for sending to a printer,
but that's optional.
In this particular instance, I don't care about "the right way to do
things", or efficiency (whether in terms of execution speed or memory
use), or anything like that.  All I want is rapid & easy development of
this tool.
Does anyone have any suggestions for a good language to handle these tasks?
...Ben Chambers
www.pacificwebguy.com
Subject: Re: Need a scripting language
Date: 15 Mar 2008 04:28:20
Message: <47db96b4$1@news.povray.org>
> ) Fetch a web page
Hmm... tricky.
I'd say Haskell, except that Haskell will make you do it "properly", no
matter what the cost. That makes for good, strong final applications,
but it's not suited to rapid prototyping at all. Everything you listed
is doable, but it'll take you ages.
I'm struggling to think of any scripting language that's likely to be
able to handle parsing HTML. (Or speak HTTP for that matter.)
I'd suggest Tcl, except that I don't think there's a way to talk to a DB
with that. (Or do the HTML/HTTP part.)
I suppose Perl is insane enough that somebody probably has a binging to
Curl or something, and a half-broken XML parser. Some nutcase wrote a
*game* in Perl, so apparently it has graphical capabilities. [I can't
even begin to imagine how that's even possible...] Obviously, Perl is
not a language to be recommanded to sane human beings.
I can't think of any other scripting languages which might be useful.
Possibly a .Net language if the base libraries provide the
functionallity you want. [Having never seen them, I couldn't say.]
http://blog.orphi.me.uk/
Date: 15 Mar 2008 05:04:03
Message: <47db9f13$1@news.povray.org>
"Chambers" <ben### [at] pacificwebguycom> a écrit dans le message de news:
47db9468@news.povray.org...
> Basically, I need to write an app that will store user submitted data in a
> database, create visual representations of said data, and query specific
> web sites based on the data selected.  In other words, a language that
> makes it easy to:
> ) Fetch a web page
In MS Access : the 4 first tasks are just default behaviour with MS Access
so no scripting is necessary (unless you want specific behaviour for data
checking etc.). Just set up your tables in Access or any other database
(provided you can get the data through ODBC) and create the forms and graphs
through the built-in form editor. If the problem is simple it's a matter of
minutes.
After that a little bit of VBA would be required to open, download and
process the web pages. There's a function named URLDownloadToFile to do
this, but I've never used it, I just know it's possible.
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer art
- Posters
Date: 15 Mar 2008 12:44:02
Message: <47dc0ae2$1@news.povray.org>
In a web browser or on the screen?
How graphical?  Like pie charts?
> ) Fetch a web page
Tcl will do all those things, with minimal work, both for web and GUI.
PHP is probably easiest (bleh) if you're just talking about interacting
via a browser.
Tcl can *format* some stuff for a printer. It's not trivial to get
graphics onto a printer from Tcl. If you're talking about sophisticated
graphics like 3D charts and such, you might want to have Tcl drive
Excel, or output a CSV file that you suck into an Excel spreadsheet.
If you're talking about Windows, any of the .NET stuff will do that.
I bet if you dug around hard enough, you could do it entirely in Word
and Excel, including the DB interface.
There are probably CPAN modules for all that too. I don't do Perl enough
to know, tho.
Also consider breaking it into different parts. Use the scripting
language to do the processing, some image command-line tool to generate
a graphic, something like that...
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 16 Mar 2008 17:38:31
Message: <47dda167@news.povray.org>
> ) Fetch a web page
  I believe the majority of sites out there use PHP for this.
  You can use the web browser as a GUI for the application. This way you
don't need to write a GUI (except in html). PHP has strong tools to parse
webforms and query SQL databases. Many people use this combination for
management purposes.
Date: 16 Mar 2008 22:21:05
Message: <47dde3a1$1@news.povray.org>
>> ) Fetch a web page
I thought about something like that, but then I'd need to either run
Apache on my local machine, or set up a part of my website for that.
Probably the latter would be the easiest option, although I would
appreciate having the data stored locally.
...Ben Chambers
Date: 16 Mar 2008 22:28:39
Message: <47dde567@news.povray.org>
Apache isn't the only webserver that can use PHP ;)
Date: 16 Mar 2008 22:45:39
Message: <47dde963$1@news.povray.org>
You can set up an entire domain name just for this application if you
like. It's pretty trivially straight-forward.
Nothing keeps PHP from accessing the data in a mysql server on your
local machine.  If you want something fast and easy and HTML is good
enough interface-wise, PHP is probably good enough.
PHP isn't what you'd call an elegant language, but it has piles of
poorly-named and poorly-organized functions that do most everything
you'd want to do, and it's easy to find help doing things.
Just remember to escape any string you pass as SQL, and it's probably a
bad idea to mix HTML and PHP in the same file, even tho that's how it's
designed.  Remember that PHP stands for "Phil's Home Page" and grew from
there, and expect quality commensurate with that.
Date: 16 Mar 2008 23:06:37
Message: <47ddee4d$1@news.povray.org>
No, it used to stand for "Personal Home Page Tools", then in PHP3
changed to the recursive acronym "PHP: Hypertext Preprocessor".
But yeah, it started as a bunch of CGI scripts for somebody's personal
homepage and grew from there...
