POV-Ray : Newsgroups : povray.off-topic : Malware is getting nastier and more professional than ever Server Time
3 Nov 2026 12:40:31 EST (-0500)
  Malware is getting nastier and more professional than ever (Message 1 to 34 of 34)
Subject: Malware is getting nastier and more professional than ever
Date: 12 Mar 2008 07:18:05
Message: <47d7c9fc@news.povray.org>
http://www.f-secure.com/weblog/archives/00001393.html
Subject: Re: Malware is getting nastier and more professional than ever
Date: 12 Mar 2008 07:56:32
Message: <47d7d300@news.povray.org>
Don't most BIOSs have some "prevent write to MBR" function?  Would malware
like this be able to get around that?
Date: 12 Mar 2008 08:02:29
Message: <47d7d465$1@news.povray.org>
Ususally, yes. And usually, it's "off" by default. (When you unpack a
brand new PC, what's the first thing you do? Install an OS.)
> Would malware like this be able to get around that?
Unlikely. But this measure isn't commonly enabled.
More interesting is that it can touch the MBR from Windoze in the first
place...
http://blog.orphi.me.uk/
Date: 12 Mar 2008 13:21:07
Message: <47d81f13$1@news.povray.org>
That depends on what type of machine you bought.  If you go out and
purchase a brand-name computer, the OS is already installed.
If you build your own, this is true, but most machines the OS is already
pre-installed.
Jim
Date: 12 Mar 2008 13:45:06
Message: <47d824b2$1@news.povray.org>
> pre-installed.
True. But I'd wager that MBR protection is probably turned off on most
machines out there.
(Similarly, most have a BIOS write-protect feature so malware can't
reflash the BIOS. And that's usually off. But then, any such malware
would only work for one brand of motherboard anyway since there's no
standard interface for that kind of thing...)
Date: 12 Mar 2008 13:46:20
Message: <47d824fc@news.povray.org>
> machines out there.
  What actually happens if some software (for example an OS installer)
tries to modify the MBR and it has been bios-protected?
Date: 12 Mar 2008 13:59:05
Message: <47d827f9$1@news.povray.org>
>> machines out there.
Varies by BIOS.
I believe what it *actually* does is yell "hey, somebody changed this!"
rather than actually _prevent_ the change from happening. But again, it
depends on what the BIOS writer has programmed it to do. To be honest,
I've never tried it myself...
Date: 12 Mar 2008 15:37:22
Message: <47d83f02@news.povray.org>
  How does it do that? The bios cannot have sufficient info about the
graphics card in order to show a message on screen, especially if the
graphics card is currently in non-vga mode.
Date: 12 Mar 2008 15:38:28
Message: <47d83f44$1@news.povray.org>
No - it displays a message during the POST sequence. (And waits for a
keypress.)
Date: 12 Mar 2008 16:05:06
Message: <47d84582@news.povray.org>
> keypress.)
  What's that?
Date: 12 Mar 2008 16:08:34
Message: <47d84652$1@news.povray.org>
>> keypress.)
>   What's that?
Power On Self Test.
In other words, the text-mode screen that briefly flashes past when you
first power on the system. (That's why it waits for a confirmation
keypress - otherwise you'd never SEE the damn thing!)
Date: 12 Mar 2008 18:05:54
Message: <47d861d2@news.povray.org>
> >> keypress.)
> >   What's that?
> Power On Self Test.
  And how would it detect at that stage if something modified the MBR?
And even if it did, wouldn't it be too late? The modification and thus
the damage already happened.
Date: 12 Mar 2008 18:55:11
Message: <47d86d5f@news.povray.org>
>> already pre-installed.
> machines out there.
Very likely.
Actually, I don't think it'd be that hard - it wouldn't be a single brand
of motherboard - there's only 3 or 4 major BIOS brands out there these
days, if that.
Jim
Date: 12 Mar 2008 18:56:08
Message: <47d86d98$1@news.povray.org>
>> keypress.)
>   What's that?
POST = Power On Self Test.  I'm really surprised you don't know that,
it's a very common thing for people who work with computers to know.
<again, scnr>
Jim
Date: 12 Mar 2008 21:11:48
Message: <47d88d64$1@news.povray.org>
> > keypress.)
>   What's that?
You push down on a key until it registers or bottoms out. There's usually an
audible click too.
Date: 12 Mar 2008 22:23:44
Message: <47d89e40$1@news.povray.org>
> place...
Why's that interesting? Run "diskpart" (which comes with Windows) and
tell it to look at the MBR.  Or google mbrfix, and have a program
that'll read *and* write.
Indeed, read the first 512 bytes from the file \\.\physicaldisk0 to look
at your MBR.  I just couldn't get it to open for writing.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 12 Mar 2008 22:25:10
Message: <47d89e96$1@news.povray.org>
It stores in the CMOS the checksum of the previous MBR.
MBRs are pretty standard. You know your system is hosed, so instead of
continuing you boot the CD and rewrite the MBR. :-)
Date: 12 Mar 2008 22:25:30
Message: <47d89eaa$1@news.povray.org>
>>> keypress.)
>>   What's that?
> audible click too.
BURN!  :-)
Date: 13 Mar 2008 01:41:23
Message: <47d8cc93$1@news.povray.org>
This only applies to software that uses the BIOS for disk I/O. Basically
this means bootloaders and somtimes first-level bootstrap routines (DOS
also). Modern OS's always have their own hardware drivers for disks.
Basically anything that can gain supervisor privileges on a windows system
can do whatever it wants with the hardware, even bypassing the OS's own
driver if need be (the latter requires that it understand the hardware of
course).
Date: 13 Mar 2008 03:42:42
Message: <47d8e902@news.povray.org>
>> machines out there.
ON mine I get a blue screen alerting me that something is trying to
overwrite the MBR, and do I want to allow the write or not.
Date: 13 Mar 2008 03:51:18
Message: <47d8eb06$1@news.povray.org>
I would imagine it goes something like this:
Interrupt 13 handler (file I/O) code inside BIOS:
Check if trying to write to MBR (always on the same place)
If not, write as usual to the drive, return
Change screen mode to 720x480 (or whatever that one is the BIOS uses at
startup) using an interrupt 10 call
Display some text on the sceeen using the same routines as the BIOS setup
screen etc
Wait for keyboard input (note this totally hangs the system)
If user agrees, write the data as normal to the disc
If not, just exit the interrupt handler
Date: 13 Mar 2008 05:21:00
Message: <slrnfti00c.5fg.bisqwit@bisqwit.iki.fi>
No modern OS uses 16-bit BIOS interrupts.
I have understood so that the MBR write protection simply
discards any writes addressing the MBR, silently.
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 13 Mar 2008 05:41:23
Message: <47d904d3$1@news.povray.org>
Well yeh I doubt it does, but that's how I understood the BIOS MBR
write-protect feature to work that I'd seen in the past on my system.
Date: 13 Mar 2008 09:42:55
Message: <47d93d6f@news.povray.org>
  I program computers, I don't build them.
Date: 14 Mar 2008 02:05:48
Message: <47da23cc@news.povray.org>
You can't call an interrupt from within an interrupt (at least, you
couldn't when I was messing with them, but that was 12 years ago... of
course, I doubt they've changed much since then).
...Ben Chambers
www.pacificwebguy.com
Date: 14 Mar 2008 03:48:45
Message: <47da3bed@news.povray.org>
  Any current OS will override the default interrupt handlers created
by BIOS. There's just no way BIOS can catch a write attempt to the disk
by simply having an interrupt handler. If it needs to catch it, there
has to be some other way. It probably nees cooperation from the disk
controller logic or something.
Date: 14 Mar 2008 10:36:12
Message: <47da9b6c$1@news.povray.org>
I think this is what interrupt priority levels are all about. Depends on
the CPU of course.
Date: 14 Mar 2008 11:21:33
Message: <47daa60d$1@news.povray.org>
When I was starting out in the computer business, I was programming and
using just IBM PS/2s, not building them.  But I knew what it was, and
everyone I knew knew what it was.
It's just so surprising that such a fundamental element of computers is
something you don't know.  I thought everyone knew what it was - even my
mother knows what POST stands for, and she is functionally computer-
illiterate....(OK, not really, but you get my point)
Jim
Date: 16 Mar 2008 17:25:10
Message: <47dd9e46@news.povray.org>
  I'm feeling like Andrew like now. ;)
  Of course I know that the bios makes tests (at least by default) when
booting. I just didn't know what "POST" means.
Date: 17 Mar 2008 04:42:37
Message: <47de3d0d$1@news.povray.org>
Mmm, humility? >:-)
Nobody knows *everything*, even about a specific topic. So let's all
just chill, k people? ;-)
Date: 19 Mar 2008 18:13:13
Message: <47e19e09$1@news.povray.org>
Jim
Date: 19 Mar 2008 18:13:36
Message: <47e19e20$1@news.povray.org>
That was my point to Warp. ;-)
Jim
Date: 19 Mar 2008 21:04:47
Message: <47e1c63f$1@news.povray.org>
Me, I always wondered why the first thing the computer does is POST and
not PRE.
Date: 22 Mar 2008 20:58:41
Message: <47e5b951$1@news.povray.org>
> not PRE.
LOL, good one, Darren.  After last week, I needed a good laugh. :-)
Jim
