POV-Ray : Newsgroups : povray.off-topic : USB Hardware riddle Server Time
3 Nov 2026 12:43:28 EST (-0500)
  USB Hardware riddle (Message 1 to 17 of 17)
Subject: USB Hardware riddle
Date: 6 Mar 2008 08:43:13
Message: <47cff4f1$1@news.povray.org>
Hello there!
A friend of mine has bought a new Laptop and tried to plug her USB
Headset by Logitech into it. Skype and TeamSpeak don't recognize it, but
when she puts it into the "right" USB Slot (she has two slots on the
side of her laptop), it works.
Can anyone tell me why there's a difference which USB slot you pick?
I've noticed that before on my PC and my Mac. On my PC, if I used a USB
slot for my Headset or mouse I've already used, everything's dandy, if I
put it into a new one, it wanted to recognize the hardware again. On my
Mac, if I put a USB Harddrive into the wrong slot, it wouldn't find it,
in the other one, it did.
*shrugs*
Any ideas? Is there a USB Hub Priority or some such idiotic "feature"?
I'm just curious, it's not that big trouble to just check a different
USB slot, but I actually thought it was invented to just plug stuff in
and have fun...
Tim
aka "Tim Nikias"
Subject: Re: USB Hardware riddle
Date: 6 Mar 2008 08:57:24
Message: <47cff844$1@news.povray.org>
IIRC with USB 1 on WinXP there were some "feature" whereby if you plugged
the same device into a different socket Windows would think it was a new
device and try to install it again (rather than assuming it was the same as
the identical device plugged into a different socket 2 minutes ago).  If to
install it you needed some special driver, then plugging it into a different
socket would mean you needed to supply those drivers again.  (Just like if
you open up your computer and plug some PCI card into a different slot, when
you next boot Windows will want to install the drivers again as it thinks it
is new hardware)
I thought this had been fixed with USB 2 and/or Vista, but maybe not if your
friend is running a new laptop.
BTW a friend of mine had exactly the same problem with a card reader that
needed specific drivers.
You can look in the device manager and see what goes on when you plug/unplug
into different sockets.
Date: 6 Mar 2008 10:18:51
Message: <7q20t393gokd2bi5115371h3d4bupan0ok@4ax.com>
On Thu, 06 Mar 2008 14:43:13 +0100, Tim Nikias
>and have fun...
Hmm! At my last job I had my graphics tablet installed on my works laptop from
my own disc. The laptop would only recognise the tablet if it was plugged into
the USB port it was in when it was installed.
Regards
Date: 6 Mar 2008 11:05:37
Message: <op.t7lqy2cwc3xi7v@news.povray.org>
And lo on Thu, 06 Mar 2008 13:43:13 -0000, Tim Nikias
<JUS### [at] gmxnetWARE> did spake, saying:
Just to second Scott's assessment I've noticed it can depend on what host
controller is being used. I know on one of the XP computers I have the
front two sockets are on a different host then the rear four and things
plugged in the front need to be "found" again when plugged into the back
and vice-versa.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 6 Mar 2008 23:31:42
Message: <47d0c52e@news.povray.org>
You could try to enable, 'Legacy USB Support' on the Setup of the
Motherboard if the USB product is old, or maybe is new and uses version
2.0 USB specification while you're trying to plug it into a USB 1.1/1.0.
I hope this brigs you some light, good luck.
Date: 7 Mar 2008 14:37:13
Message: <47d19969$1@news.povray.org>
No. The problem is that each USB device is supposed to have a unique
serial number, so the OS knows when you plug the same device into a
different port. On a sufficiently cheap piece of USB hardware (espcially
those where it doesn't matter, like a mouse), they don't manufacture the
bits that are different for each item.
Hence, when you plug the same device into the same port, Windows says "I
saw that before, but it doesn't have a serial number, so I'll assume
it's the same thing." When you plug it into a different port, Windows
assumes it's a different device, and goes through the install dance again.
Same thing happens if you wipe out the serial number on the drive inside
a USB disk enclosure - Windows doesn't know it's the same disk, and
reinstalls it.
(Reading the USB specs, and how you're supposed to handle such things,
is actually the correct way of figuring this out, rather than guessing. ;-)
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 7 Mar 2008 15:40:14
Message: <47d1a82d@news.povray.org>
  What I don't understand is why Windows can't do "hmm, I *already* have
the driver for this device installed, I don't need to install it again,
I'll just support the device right away". It's not like connecting it to
a different usb port would make recognizing the type of device more difficult
than connecting it to the same port as yesterday.
Date: 8 Mar 2008 14:26:44
Message: <47d2e874$1@news.povray.org>
It's not actually installing new code for the device. It's installing
the configuration for that particular instance of that particular kind
of device. It doesn't prompt you for a CD or anything. It just writes
the configuration into the registry, starts up any services need to
support it, and so on.
Date: 9 Mar 2008 00:28:23
Message: <MPG.223bab1abc53bd8398a118@news.povray.org>
In article <47d1a82d@news.povray.org>, war### [at] tagpovrayorg says...
y
e
I
in.
cult
It will, for things like thumb drives. Why it won't for *other* things
is beyond me, especially given that a significant number of items are
now USB based... :(
void main () {
  If Schrödingers_cat is alive or version > 98 {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 9 Mar 2008 05:23:33
Message: <47d3baa5@news.povray.org>
> now USB based... :(
  So much for the much-touted plug&play... :P
  (With some devices plug&play works and is really nice. For example,
if you connect a simple game controller to an USB port, it just works.
Why can't all USB devices be like that?)
Date: 9 Mar 2008 17:19:18
Message: <47d46266$1@news.povray.org>
That's exactly what keeps me wondering as well. The Laptop (about 4
months old, BTW) recognizes the USB Headset on one USB, but not on the
other, AND it doesn't usually need any installation whatsoever, you just
plug it in and it gets recognized as a pair of headphones and a mic.
I just don't get whats going on. Of course, always using the same USB
slot solves the problem, but it IS kinda strange, given the actual idea
behind USB, right?
aka "Tim Nikias"
Date: 9 Mar 2008 17:41:24
Message: <47d46794@news.povray.org>
> behind USB, right?
Doesn't solve, but works around usually. Think the possibility of having
a memory stick with open files (wait, *gasp*, that's... POSSIBLE) on
that very USB-connector, when in need to put in the headset.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 11 Mar 2008 14:50:53
Message: <47d6e29d@news.povray.org>
They can. It just costs a few pennies more to put a distinct serial
number on every device.
Date: 11 Mar 2008 14:51:54
Message: <47d6e2da$1@news.povray.org>
> behind USB, right?
And you're following up on a message where I explained what's going on,
ya know...
Date: 12 Mar 2008 06:39:34
Message: <47d7c0f6@news.povray.org>
>> now USB based... :(
There are some USB standard protocols that are understood by the OS without
the need for any drivers, like for keyboards, mice, game controllers, data
storage etc.  Of course a manufacturer is not forced to use these standards,
but if they don't they will need to provide some extra driver software
(usually providing some extra functionality above the standard OS protocol).
Also what Darren said, for things like game controllers it is very expensive
to add some unique serial number, as there is no other need to have any
non-volatile information stored inside it (unlike a pen-drive or camera).
To store a serial number you will need to add some extra chip and program
it, or hard-code some bit-pattern circuitry inside the device - both
extremely expensive compared to just assembling parts in exactly the same
way.
Date: 12 Mar 2008 18:13:32
Message: <47d8639c@news.povray.org>
>> idea behind USB, right?
> ya know...
Well, to my defense, I did say that the Headset doesn't actually require
installing or has any disk for that matter. So no matter if there's a
serial number or not, plug&play is what should be happening, not "plug
in one slot and recognize it, plug it in the other and the system has no
frickin clue what the USB device is".
If it would ask to reinstall some weird OS-given drivers that aren't
installed with the basic OS, but are found on the OS' Install CD, I
would have agreed, but since *nothing* is required when plugging it in,
it DOES seem kinda strange that one USB recognizes the Headset and the
other doesn't.
I've got the same headset. Plugging it into any of the 7 USB ports on my
PC (Windows XP) or the two on my Mac (Leopard) doesn't make a
difference, but it does on the two USB slots of my friend's laptop
running Vista.
Tim
aka "Tim Nikias"
Date: 12 Mar 2008 22:13:42
Message: <47d89be6$1@news.povray.org>
> running Vista.
That was my bad. I got confused between the game controller and the
headset.  Yeah, it should recognise the headset in both USB slots, I'd
think.
