POV-Ray : Newsgroups : povray.off-topic : Completely pointless Server Time
30 Mar 2026 08:11:33 EDT (-0400)
  Completely pointless (Message 1 to 10 of 12)
Subject: Completely pointless
Date: 28 Feb 2008 12:02:57
Message: <47c6e941$1@news.povray.org>
And now for something... completely pointless.
Take a look at the attachment. The trace marked "original" is just some
random data I made up. [It's the output of a random number generator fed
through a band-pass FIR filter with a wide pass-band.] This trace
basically consists of 256 double-precision numbers.
I then took this data, compressed it using the Fractal Transform
(yielding 32 positive integers and 64 double-precision floats), and then
decompressed it again.
As you can see, the two signals correlate reasonably closely. As you can
*also* see, they're not exactly identical by any stretch. Hmm... I think
my program is buggy. :-S
http://blog.orphi.me.uk/
Download 'compress1.png' (22 KB)
Preview of image 'compress1.png'
Subject: Re: Completely pointless
Date: 28 Feb 2008 14:03:39
Message: <47c7058b@news.povray.org>
it looks to me as if the volume got turned down slightly.
Tom
Date: 28 Feb 2008 15:18:42
Message: <47C71739.4020601@hotmail.com>
As this Fractal Transform is not lossless, what exactly is your problem?
Other than that it is apparently the wrong compression technique for
this kind of signal of course.
Date: 29 Feb 2008 04:17:53
Message: <47c7cdc1@news.povray.org>
>> can *also* see, they're not exactly identical by any stretch. Hmm... I
>> think my program is buggy. :-S
I was hoping for a closer fit than that.
Mind you, I started out applying this to image data. Only problem is
that the decompressed image bears *no resemblance* to the original. I
don't know what I've done wrong, but it's clearly horrifically broken.
So I thought I'd try the simpler 1-dimenional 1-channel case. And as you
can see, it more or less works...
Or rather, I couldn't find a good signal to test it with. ;-)
Date: 29 Feb 2008 04:18:12
Message: <47c7cdd4$1@news.povray.org>
Yes - I couldn't help noticing that one...
Date: 29 Feb 2008 04:40:17
Message: <47c7d301$1@news.povray.org>
I tried changing the block size from 8 samples to 4 samples. The fit is
now closer, yet the overshoots and undershoots are more extreme.
I also tried changing it to 2 samples, but then the whole thing just
malfunctions horribly.
Just for fun, I also tried 16 samples per block. This also produces a
"reasonable" fit, though not as good as 8 or 4.
So it seems that smaller block sizes produce a better fit [yet with less
compression]. No real surprises there then.
I'm now going to experiment with different similarity metrics, to see
what difference that makes...
Date: 29 Feb 2008 05:07:54
Message: <47c7d97a$1@news.povray.org>
Well, actually it turns out that which metric you use makes a pretty
small difference to the result - and overall, simple signal correlation
seems to work just about as well as any elaborate system I can come up with.
(Total deviation squared comes out identical to signal correlation.
Total absolute deviation is slightly different, with more overshoot. And
signal derivative correlation comes out more "noisy".)
Oh well - I guess this is the closest fit I'm going to get...
Date: 29 Feb 2008 05:33:43
Message: <47c7df87@news.povray.org>
Well, I've run a few signals through my program, and they all seemed to
work kinda OK. But just now I threw together a simple fractal noise
generator. (Midpoint displacement method.) And then I ran that through
the program, and WOAH! Something has gone terribly wrong here...
Download 'compress2.png' (56 KB)
Preview of image 'compress2.png'
Date: 29 Feb 2008 15:50:25
Message: <47c87011@news.povray.org>
It reminds me of when I first heard of the Mandelbrot set in the late 80's.
My first try on my 48k ZX spectrum resulted in a rather skew Mandelbrot set.
Then I realised I had been adding a -1 in the recursion, that shouldn't be
there... :-P
- Nekar X -
Date: 29 Feb 2008 16:00:04
Message: <47c87254@news.povray.org>
> there... :-P
Yeah, implementing an algorithm for the very first time is always way
hard. Especially if you don't have a working reference implementation to
go from! :-S [And let's face it, those are usually in C.]
Spare a thought for me when I wrote my first ray tracer! All I had was
the POV-Ray user manual. From that, I eventually figured out that you
can find the intersections between a ray and a sphere by solving a set
of simultaneous equations. And then, I managed to work out that since
the ray equation is parametric, if you *substitute* it into the sphere
equation, you get an equation in only 1 unknown. And then I had to shift
algebra around to discover the final form of this equation. And then I
spent 4 BONEHEAD hours trying to work out how to solve this equation.
(After which, obviously, I remembered that "oh yeah, there's a formula
for that". DUH!)
And then I went upstairs and implemented it in Borland TurboPascal 5.5
for DOS, in 16-colour VGA glory. And it freakin' worked! First damn
time. I was amazed...
Yeah, it's much better if you have a reference implementation!
[Of course, today you do. Warp has kindly added one to the POV-Ray
manual. But I should emphasise that wasn't there back when I worked all
this out the hard way. Damn, if only you could get meddles or something...]
