POV-Ray : Newsgroups : povray.off-topic : Simple Windows question Server Time
19 Apr 2026 19:07:10 EDT (-0400)
  Simple Windows question (Message 1 to 10 of 20)
Subject: Simple Windows question
Date: 26 Feb 2008 22:40:13
Message: <47c4db9d$1@news.povray.org>
Does anyone know the UNC syntax for accessing an entire disk under
Windows? I don't mean one partition, but the entire disk, and in
particular the MBR and partition table.
\\.\C: does it for the C: partition, the first 512 bytes of which are
the boot record, for example.
But I want to be able to read the MBR, and I'm wondering if there's
something the equivalent of Linux's /dev/hda, given that the equivalent
of /dev/hda1 exists on Windows.
Thanks for any suggestions to try. Note that \\.\physicaldrive0 doesnt
work. :-)
I will say this for Linux: it's a heck of a lot easier to figure out how
to move system files around. Windows does its damnedest to keep you from
copying the registry to a new, bigger disk. :-)
I can't figure out the "automated system restore" at all. The backup
program won't write to DVDs, and the restore program won't read from the
network or USB drives. How the heck are you supposed to restore the
backup it made without installing a second disk drive or something?
Stupid, stupid, stupid. Even with a windows LiveCD it's tedious and
painful, and assumes your new drive is at least twice as big as the old
partition.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Subject: Re: Simple Windows question
Date: 26 Feb 2008 22:57:12
Message: <47c4df98@news.povray.org>
> work. :-)
Nevermind. The right google term (after 3 days of googling) is "physical
drive". That goes to http://support.microsoft.com/kb/q100027/ which says
\\.\physicaldrive0 should work. I must be doing it wrong.
Date: 27 Feb 2008 01:25:00
Message: <web.47c5012f62deceb35f81c41d0@news.povray.org>
whatever it is, if there is such a thing it may be hidden behind a button
somewhere... ;)
Date: 27 Feb 2008 01:25:01
Message: <web.47c5018962deceb35f81c41d0@news.povray.org>
uh-oh
Date: 27 Feb 2008 01:47:34
Message: <47c50786$1@news.povray.org>
Darren New wrote:
>> work. :-)
And then, five minutes later, trying it one last time out of
frustration, exactly the same as before, it now works. W. T. F??
I guess something had the drive locked or some such, and I wasn't
getting back particularly informative error messages?
Oh well, I guess I'll see if it works where I really want it to work.
Date: 27 Feb 2008 06:35:40
Message: <47c54b0c$1@news.povray.org>
You're slowly getting enough Linux -oriented to get Windows jamming as
others of us have gotten for years ;).
Actually, that's probably a lot better reason.
Note that if it's about locking oslt, you can't be sure that it'll work
always when needed :(.
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 27 Feb 2008 06:41:03
Message: <47c54c4f$1@news.povray.org>
You think that's random? On one of our servers, there are some folders
in the recycle bin which *cannot* be deleted. Every time you try it
complains that they're "in use". Despite the fact that the server has
been rebooted God knows how many times over the years. But still these
files cannot be removed.
Fortunately they're small...
http://blog.orphi.me.uk/
Date: 27 Feb 2008 07:10:41
Message: <47c55341$1@news.povray.org>
Nope. I think that if information needed for one process can be locked
out by some other process, they might get to hit at the same time.
Have you tried booting to fail safe mode and removing there? Right now
someone (I'd guess Darren;) could tell you a Windows-utility equal to
*n?x -sides lsof (LiSt of Open Files), meaning a utility which can tell
you which process is using which open file (we have one at work, but I
don't remember the name, so I won't get it until next week).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 27 Feb 2008 07:16:02
Message: <47c55482$1@news.povray.org>
Eero Ahonen wrote:
>> On one of our servers, there are some folders in the recycle bin which
>> *cannot* be deleted. Every time you try it complains that they're "in
>> use". Despite the fact that the server has been rebooted God knows how
>> many times over the years. But still these files cannot be removed.
People get kinda annoyed if you do stuff to the server they're trying to
use...
> Right now
I believe you can find this information from the "server" applet from
the control panel.
Nope, wait, that's only for Windows NT. They removed it in Windows XP.
Hold on... Ah yes, Computer Management. There's a "Shared Folders" item
in the right pane, with an "Open Files" subitem.
Alternatively, either PS Tools or Process Explorer from System Internals
might help you. [Altough given that M$ now ownes that, maybe not...]
Date: 27 Feb 2008 07:41:23
Message: <47c55a73$1@news.povray.org>
> use...
That's why there are times called "service windows". On a service window
people are *not* using the server so you can do stuff on it.
> the control panel.
I'm not actually sure if that subitem tells you everything, but have you
checked there? Of course, you should check it form the server, not your
workstation (I surely hope your servers are not running XP).
Possibly. Go and find out, who's (ab)using your recycle bins ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
