POV-Ray : Newsgroups : povray.off-topic : A couple of amusements... Server Time
24 Mar 2026 01:50:00 EDT (-0400)
  A couple of amusements... (Message 1 to 10 of 11)
Subject: A couple of amusements...
Date: 26 Feb 2008 12:24:51
Message: <47c44b63$1@news.povray.org>
Conversation overheard:
"The Z key on this keyboard is acting flakey."
    "That's because it's too close to the Windows key."
http://chidori.animecrew.org/chidoris_pc.jpg
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Subject: Re: A couple of amusements...
Date: 26 Feb 2008 13:07:59
Message: <47c4557f$1@news.povray.org>
Have you ever seen a real crowbar? I didn't realise this, but they're
FREAKING HEAVY! Seriously, there's no way you could just flick one
around with your wrist like that...
http://blog.orphi.me.uk/
Date: 26 Feb 2008 13:33:50
Message: <47c45b8e@news.povray.org>
Yes there is, it's more technical thing than force one. Same goes with
axes (the ones actually ment to chop wood - not the ones ment to take
with you to urban nightlife). Guess what's my other tool in Project
Floor ;).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 26 Feb 2008 14:19:58
Message: <47c4665e$1@news.povray.org>
> Floor ;).
Well, I don't know about that, but I do know that me and my dad wasted
several hours trying to get through one quite thin tree trunk with an
axe one time. Brand new axe. Took seconds to go through the bark, but
did little or nothing to the wood beneith.
And then my dad lent against the tree in exhaustion, and it snapped off
Date: 26 Feb 2008 16:45:15
Message: <47c4886b$1@news.povray.org>
Check the difference between these:
http://www.fiskars.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10101&categoryId=10277&productId=10526
http://www.fiskars.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10101&categoryId=10277&productId=10534
The first one is the one I have, there a significant difference ;).
28inch is 72cm - which is pretty much for an axe. Still it's stable and
fast to handle, when you know it.
Making a tree come down with an axe ain't easy. You'll need to cut with
the right angle to get optimal get-trough time and still the mess will
be awful. I'd advice a saw for even a little bit bigger trees and one of
these to the smallest ones:
http://www.fiskars.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10101&categoryId=10277&productId=10532
Even then it's technical thing to get the tree down, actually :p.
Usually it's one hit with that brush axe to one little tree.
Heh, that's life :).
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 27 Feb 2008 04:23:02
Message: <47c52bf6$1@news.povray.org>
This kind of maul works great for splitting wood,
but you probably couldn't hit a headcrab with it =P
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200325119_200325119
Date: 27 Feb 2008 04:32:38
Message: <47c52e36$1@news.povray.org>
> several hours trying to get through one quite thin tree trunk with an axe
> one time. Brand new axe. Took seconds to go through the bark, but did
> And then my dad lent against the tree in exhaustion, and it snapped off at
Couldn't you have used a saw?  We had this saw once which was really good
for cutting down small trees (anything between 5 and 30 cm diameter) - the
teeth were pretty beefy and much bigger than a normal saw you would use for
woodwork, made light work of chopping up lots of wood.
Date: 27 Feb 2008 04:34:57
Message: <47c52ec1$1@news.povray.org>
In hindsight, that would seem to be significantly less work, yes...
Date: 27 Feb 2008 05:55:58
Message: <47c541be$1@news.povray.org>
I almost hesitate to ask, but you were using a *felling* axe, yes? Not a
hand axe? ;-)
Date: 27 Feb 2008 05:59:57
Message: <47c542ad@news.povray.org>
> hand axe? ;-)
I have no idea. All I know is dad wanted to remove the tree, so we want
out and came home with a small axe...
