One example of why LaTeX is better than WYSIWYG.
http://filoxus.blogspot.com/2008/02/deferred-printing-in-latex.html
"That's pretty. Where's that?"
"It's the Age of Channelwood."
"We should go there on vacation some time."
...so LaTeX is better than WYSIWYG for exactly the same reason that SDL
is "better" than a traditional modeller then? [i.e., you can easily
script in new behaviours to add features that aren't already there.]
http://blog.orphi.me.uk/
I suppose that's basically it. LaTeX is a bit like a scriptable HTML on
steroids.
What I like about LaTeX, something which I can't find eg. in OpenOffice
Writer, is that it allows generating much nicer page layouts for many
things. For example, assume that you are writing tons of text with the
following format:
- Some key concept
Explanation text for the key
concept above.
- Another key concept
Explanation for this other key
concept.
etc.
You can create text like that just fine with OO Writer. Its problem is
that the layout becomes ugly when page breaks happen at inconvenient places.
More precisely, when this happens:
- Some key concept
<new page>
concept above.
The "title" and its explanation end up in different pages, which is ugly.
It is possible in LaTeX to define special boxes where you can tie these
"titles" and their explanation texts together and specify some properties
for them. For example, "at least two lines of the explanation part must
be in the same page as the title, else put a page break before the title".
Not only that, if the condition is triggered and an "early page break"
is created, instead of leaving an ugly empty space at the end of the
previous page, LaTeX will just slightly increase the line spacing of that
previous page to fill up that empty space, making it look nicer.
LaTeX does this by default with chapter/section/subsection titles
(ie. it never happens that a subsection title ends up at the end of a
page, while the contents of the section begin at the next page), and
you can configure how it behaves. You can also create your own blocks
which behave in this same way.
Of course this doesn't mean that there aren't things which end up looking
a bit ugly in LaTeX or that there weren't things which are very difficult
or awkward to do, but I just wish eg. OO Writer had this type of feature.
> following format:
> - Some key concept
> concept above.
> concept.
> etc.
> places.
FYI in MS Word this is easy to prevent, simply go into the style definition
for the key concept style and check the "keep with next" option in paragraph
settings. Maybe the same is in OO Writer somewhere?
> steroids.
Of course, what that also ends up meaning is that only one program can
understand it. (Only POV-Ray really understands SDL, and only TeX really
understands TeX files.) OTOH, HTML can be parsed and manipulated with
tools like XSLT by a miriad of programs... For example, Google can take
a HTML document and figure out what useful content is in it in order to
index it, traverse linkes, etc.
> things.
Indeed, TeX has a very nice formatting engine. I could go on for hours
about all the various features it offers and all the sophistication
involved, but the basic end result is that, without *doing* anything in
particular, you tend to more or less automatically end up with a pretty
good layout.
[Altough there are a few places where it routinely goes wrong. For
example, TeX really doesn't like narrow boxes very much...]
I am *told* that M$ Word has a feature ("orphan protection"?) that's
supposed to prevent a title and its body from being seperated. But
that's just one possible kind of undesirable seperation. And I suspect
you have to use styles correctly for it to even work properly anyway.
Which just brings us back to the fact that Word is fundamentally
designed to be a structureless WYSIWYG editor, whereas TeX and HTML are
both structural...
Other things I like about LaTeX are
- It typesets mathematical formulas. [I can hear your gasps of surprise...]
- The default typeface is delicious.
- The end result just looks more "formal" and arguably "professional"
than something thrown together with Word [yet takes about the same
amount of effort].
(Of course, it only looks professional until you notice that you just
spelled "funtcion" wrong... And since only TeX can read TeX, good luck
trying to spell-check your work!)
Correct.
This is about the 8th time *this month* that somebody has agreed with
me... holy crap, I'M ON A ROLL!!!
> understand it.
Basically only MS Word understands .doc files. Your point? ;)
OTOH, HTML sucks for creating publications with good layout.
> amount of effort].
LaTeX creates superb scientifical papers by default. OTOH it's not so
well suitable for other types of publications, for which MS Word may have
ready templates. (I have a concrete example in mind, but it's quite
impossible to find such an example with google. Google only understands
words, not layout formatting... :P )
>> understand it.
There are lots of converters between different 3D file formats - but few
for SDL. This is obviously partly because SDL can describe things that
aren't polygons - but it's also got a lot to do with SDL being scriptable.
I guess if you could split SDL into a scene *description* language and a
scene *construction* language, at least the description part should be
pretty portable. (And if you made it an XML application... OK, I'm
kidding!!)
You have a kind of similar thing with XSLT. With XSLT, you can take a
hand-written document and transform it into something more elaborate by
a sequence of fairly arbitrary transformations, resulting in a new document.
[I think that's the difference really. When you "run" an SDL script, you
don't end up with a new, finished, description. It exists only
temporarily while the scene renders. Mind you, in many cases it would be
*huge*...]
Well, HTML itself doesn't [or shouldn't] do layout. That's what CSS is
for. And either way, the technology is definitely *not* designed for
paper. It's designed to look good on a computer screen. Hence a while
different set of design decisions...
>> amount of effort].
> ready templates.
You're probably right about that.
In fact, trying to write my CV with LaTeX proved more or less
impossible. LaTeX is trying to do all this cleaver automatic layout for
me, and I'm trying to control it and make it put elements in specific
places so it fits on one page... I ended up using OO instead.
Similarly, if you wanted to put together something like an advert or
poster, TeX would be a very bad choice. It's really designed for writing
long documents, not 1-page custom-layout things like that.
No, You're not :-)
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
"Invisible" <voi### [at] dev null> a écrit dans le message de news:
47c4258e$1@news.povray.org...
No, you're just at the end of an over-extended phase of beta testing. Just a
few remaining bugs to iron out and you will be a Release Candidate for
procreation. You already got the hardware, it's really a programming issue.
G.
http://www.oyonale.com
- Graphic experiments
- POV-Ray, Cinema 4D and Poser computer images
- Posters
I don't think MS Word would be the best tool for that either...
I hope you don't mean the ones Knuth designed...
Technically, it was designed for writing mathematics text books. :-)
Best? No. (Not sure what would be, but NOT Word...)
Better than TeX? Probably. ;-)
Wooohoo! RC FTW!
Maybe it's just all that "be positive" stuff from Hot Sales Girl
inspiring me or something...
>> writing long documents, not 1-page custom-layout things like that.
Maybe that's why it suits me so much? ;-)
Gee, I don't know. I just install the TeX package, write a LaTeX
document, compile it and go. I'm not even exactly sure which typeface it
uses - only that it looks cool...
But of course everybody uses it for that. And with Comic Sans MS font.
From Microsoft, probably MS Publisher.
For other alternatives, maybe Adobe InDesign or QuarkXPress. In the
open source side of the world, maybe Scribus.
OK. The "computer roman modern" or "computer modern roman" or whatever
it was called was pretty poorly designed, from a typographical point of
view. Nowadays, most LaTeX's I've seen use Adobe fonts, which are
sigificantly better, as they come from a typesetting company rather than
a computer mathematician. :)
Hmm, well that explains it then. I've never heard of any of the products
you just mentioned.
(I hypothesize that this is because I don't produce posters for a living...)
>> it uses - only that it looks cool...
A mathematician who spent several years studying 3 classic works of
high-end typography though. :-P
Anyway, I thought the Type-2 fonts were just straing conversions of the
MetaFont versions?
Good to know you know Knuth. That man is a true barroque in spirit.
Only because of TeX. (And, obviously, that large tome he wrote, who's
exact name currently escapes me.) I couldn't tell you much else about him.
Apparently...
"Hey, I wanna write a book. Ah, damn it, let me just quickly dash off a
state-of-the-art digital typesetting system and design a set of
cutting-edge portable custom typefaces first, and then I'll get right on
it..."
Like, WTF?
[Actually, that sounds exactly like something *I* would do. Except that
I'd get about 1% through it, and then be forced to give up. This dude
actually pulled it off...!]
And lo on Tue, 26 Feb 2008 19:26:01 -0000, Warp <war### [at] tag povray org> did
spake, saying:
I never got on with Publisher it felt like I had to constantly battle to
get it to do what I wanted and not what it wanted.
Scribus? I'll have to take a look at that, thanks.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
The Art of Computer Programming
http://www-cs-faculty.stanford.edu/~knuth/taocp.html
> Apparently...
he also plays Bach on the organ... I said Bach was a mathematician's
favorite. Fugue is recursion after all...
> it..."
not to mention that large tome covers pretty much every algorithm known
to man.
>> him.
Yeah, that one. I know it's about programming, couldn't remember the
precise title.
(How many friggin' volumes is it now?)
> to man.
Well, yeah - reputedly. It's certainly big enough! :-P
I do sometimes think about trying to read it - but it's probably way
over my head, so...
