A long time since I posted here so "Hi, there everyone. Good to see
you're still posting, Invisible (and listening to Enigma, Enya et al).
Ditto John Van Sickle, Warp, Jim H and others too numerous to mention."
I'm considering another move of abode and have thus been sorting through
the accumulated rubbish of a lifetime to decide what gets thrown out and
what gets kept.
In amongst the detritus I found a Toshiba T-1850 laptop. It powers up
but seems to suffering from bit rot so not a great deal happens from
power up onwards :-(
In the light of DKB's posts over on p.b.i it seems a good idea to
attempt to reinstall the OS (iirc win3) and then install DKBTrace -
always assuming that I can find the original sources.
Anyone want a trip down memory lane?
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Here's the original sales flyer
http://resource.toshiba-europe.com/europe/bv/computers/flyers/classics/t1800_1850_c_e.pdf
John
It seems to be a 386, so linux should install just fine. Even X might
work with some light window manager (avoid KDE and Gnome). Likewise
POV-Ray should compile and might even run without running out of memory.
It will be slow like h***, but I don't think DKB-trace would be any faster
either. :P
Hey, John - good to hear from you again!
Jim
> either. :P
25 MHz 386SX, 4MB RAM, 60 MB Disk, 9.5" Mono screen :-)
You're probably right about going the linux route but which kernel? I
know for certain that it won't run 2.6.22 :-))
John
>> memory. It will be slow like h***, but I don't think DKB-trace would be
>> any faster either. :P
I'd probably go with a 2.0 or a 2.2 kernel - something like DSL or one of
the other minimalist Linux distros should come with one of those older
kernels.
Jim
> Jim
Thanks for the welcome :-))
How do you know that?
The linux kernel developers have somewhat of a friendly competition with
the NetBSD developers about who supports the most platforms. (NetBSD
supports over 54 hardware platforms, comprising around 17 different
processor architectures. The Linux 2.6 kernel supports even more than
this, although any single Linux distro supports less.)
I would be surprised if the Linux 2.6 kernel wouldn't support old 386's.
(Just because the kernel can use features of newer processors doesn't
necessarily mean it cannot be compiled for older ones.)
> kernels.
Does anyone actually have a reference to 2.6 not supporting 386?
>> of the other minimalist Linux distros should come with one of those
>> older kernels.
I don't, and I'm sure it does work, but the memory requirements are
typically higher for the newer kernels, so an older kernel is often
preferred.
Jim
> preferred.
I believe that the memory requirements for new kernels are higher
only if you compile *everything* into it. Being a monolithic kernel,
it has tons and tons and tons of device drivers, and each version of
the kernel has more and more of them.
However, I think it's possible to compile the kernel so that it's
optimized for the target platform, with everything unneeded removed.
This reduces the size of the kernel considerably because unneeded drivers
are not included.
After all, 2.6 has been used for embedded systems.
What you can try is to take a live linux distro which fits in a floppy
disk and try booting with that. That way you can test how it works.
Something like:
http://en.wikipedia.org/wiki/Devil_Linux
http://en.wikipedia.org/wiki/LEAF_Project
http://en.wikipedia.org/wiki/Fli4l
http://en.wikipedia.org/wiki/Tomsrtbt
>> preferred.
<snip> ...
> are not included.
Thinking about it you're probably right. I'm making a start on the job
tomorrow evening. Can't do it this p.m. due to 6 Nations and tomorrow
afternoon there's a rather important match between Chelsea and some
obscure team from North London :-) (In case you haven't guessed I'm a
Chelsea supporter)
Of course when we win I'll be in no fit state to do anything remotely
techy so Monday evening then.
John
<snip> ...
> Something like:
Thanks for those links
John
>> preferred.
> only if you compile *everything* into it. Being a monolithic kernel, it
> has tons and tons and tons of device drivers, and each version of the
> drivers are not included.
True, I'm just remembering that the low memory footprint stuff typically
has used older kernels.
Jim
