POV-Ray : Newsgroups : povray.off-topic : Really epic Server Time
3 Nov 2026 13:46:33 EST (-0500)
  Really epic (Message 1 to 50 of 55)
Goto Latest 50 Messages Next 5 Messages >>>
Subject: Really epic
Date: 14 Feb 2008 09:40:57
Message: <47b452f9$1@news.povray.org>
http://hpaste.org/5637
I have no idea whether this is actually executable or whether it does
anything interesting, but somebody *clearly* has a lot of free time on
their hands....
http://blog.orphi.me.uk/
Subject: Re: Really epic
Date: 14 Feb 2008 10:07:08
Message: <47b4591c@news.povray.org>
> their hands....
You haven't seen the International Obfuscated C Code Contest, have you?
Date: 14 Feb 2008 10:09:21
Message: <47b459a1@news.povray.org>
> their hands....
  What language is that?
Date: 14 Feb 2008 10:12:01
Message: <47b45a41$1@news.povray.org>
It parses as valid Haskell. I have no idea what in the name of God it
actually does...
Date: 14 Feb 2008 10:15:10
Message: <47b45afe$1@news.povray.org>
Yeah, I have. IIRC, there was a program there in the shape of a
character from Tolkin Elvish, which, when run, prints out the Elvish
character set. Or. Something.
See also:
http://www.haskell.org/haskellwiki/Obfuscation
Obfuscated for sure. But not as impressive, somehow...
Date: 14 Feb 2008 10:20:45
Message: <47b45c4d$1@news.povray.org>
> actually does...
Well, if you look at it from a distance, it reads "RSA". So that gives
you a hint.
Date: 14 Feb 2008 10:21:53
Message: <47b45c91$1@news.povray.org>
>> actually does...
> you a hint.
Sure. But given that it defines a bunch of functions called "un", "po"
and so on... uh...
Date: 14 Feb 2008 10:30:05
Message: <47b45e7d$1@news.povray.org>
>>> actually does...
>> you a hint.
> and so on... uh...
It's not obfuscated if it has readable function names.
Date: 14 Feb 2008 10:35:15
Message: <47b45fb3$1@news.povray.org>
OK, so I had a go at unscrambling this...
cox n = foldr (\x y -> 128 * y + x) 0 n
de n = un (\x -> (x `mod` 128, x `div` 128), (==0)) n
coll = un (\zs -> (take 35 zs, drop 35 zs), (==""))
pe (n,m) x = s (p (n `div` 2, m) x) `mod` m
p (n,m) x = if n==0
               then 1
               else (if even n then pe (n,m) x else po (n,m) x)
po (n,m) x = (x * p (n-1, m) x) `mod` m
un (f,p) n = if p n then [] else (let (a,b) = f n in a : un (f,p) b)
(g,s) = (\x -> x, \x -> x*x)
That last line is the best. I didn't even realise you could *do* that!
Very odd...
Right, so, let's do some analysis here.
- "g" is the identity function, and "s" is the square function.
- Apparently "un" is a list unfold function. It takes an integer and a
pair of functions. The second function tells it when to stop unfolding;
the first one actually does the unfold.
-- "coll" uses "un" to split a text string into blocks of 25 characters.
So idea why.
-- "cox" appears to be using a list fold to convert a list into a giant
code number. (Note that it works with arbitrary precision integers.)
"de" looks like it's trying to do the reverse operation.
- The "p" function appears to be trying to decide whether to call "pe"
or "po" depending on whether n is odd or even.
Date: 14 Feb 2008 12:18:15
Message: <47b477d7$1@news.povray.org>
>> their hands....
Do they still hold that?  I remember examples from the past of things
like a morse code translator and a source "picture" that was an ASCII
train.
Jim
Date: 14 Feb 2008 12:20:38
Message: <47b47866$1@news.povray.org>
>>> their hands....
> train.
I remember one that read data from stdin, and outputted it reversed
(last character first). And the sourcecode of the program compiled if
you reverted its characters.
Date: 14 Feb 2008 12:50:55
Message: <47b47f7f$1@news.povray.org>
>>>> on their hands....
>>> you?
>> train.
I remember a couple that were like that - one that when compiled and was
fed the source code generated another program (in another language, IIRC)
that could then be compiled and run to translate the code into a third
language.
Jim
Date: 14 Feb 2008 14:07:47
Message: <47b49182@news.povray.org>
  I asked because 'let' sounded to me like an assignment, which is not
functional. (In many languages, eg. afaik lisp and scheme, 'let' is an
explicit variable assignment, and an admitted deviation from pure
functionality.)
Date: 14 Feb 2008 14:40:01
Message: <47b49911@news.povray.org>
> functional.
I'm pretty sure you're right about Lisp. But in Haskell, it's not an
assignment - although it does look like one.
In Haskell, "let" introduced local variables. For example,
   solve2 a b c =
     let det2 = b*b - 4*a*c
         det  = sqrt det2
         a2   = 2*a
     in  [(0-b-det)/a2, (0-b+det)/a2]
Now that looks pretty damn identical to the following JavaScript fragment:
   function solve2(a, b, c)
     var det2 = b*b - 4*a*c;
     var det  = Math.sqrt(det2);
     var a2   = 2*a;
     return Array((0-b-dat)/a2, (0-b+det)/a2));
So what's the difference? Well, let's try this:
     var a2   = 2*a;
Hmm, that's not going to work properly... However, the corresponding
Haskell works exactly as before:
   solve2 a b c =
     let det  = sqrt det2
         det2 = b*b - 4*a*c
         a2   = 2*a
So in Haskell, the ordering doesn't matter. But maybe you're not
convinced yet. OK, well try this:
   foo x y =
     let xs = x : ys
         ys = y : xs
     in  xs
Notice how these definitions are muturally recursive. No matter which
way round you write this in JavaScript, it won't work properly:
   function foo(x,y)
     var xs = new Node(x, ys);
     var ys = new Node(y, xs);
     return xs;
But in Haskell it works just fine, and returns a circular linked list.
This works exactly because it's a definition, not an assignment.
(You'll also be unsurprised to hear that you're not allowed to define
the same name twice in a single let-block. But I wanted to emphasize
that the difference is much deeper than that.)
Date: 14 Feb 2008 14:50:00
Message: <web.47b49a919e92b6c266f20de80@news.povray.org>
whoa!  Haskell is becoming another Perl or Brainf*ck.
Date: 14 Feb 2008 14:54:37
Message: <47b49c7d@news.povray.org>
Nah. You can write increadibly cryptic stuff in *any* language. ;-)
I'm sure somebody could come up with some POV-Ray SDL like this if they
tried hard enough...
Date: 14 Feb 2008 14:55:00
Message: <web.47b49c5b9e92b6c266f20de80@news.povray.org>
yes!  very cool!  Looks like Perl/Python 2 way assignment, but of course there's
no assignment here, it's 2 functions defined in the same line by 2 tuples!
Haskell is amazing...
> Very odd...
man, just run this madness and see what it does...
Date: 14 Feb 2008 14:59:43
Message: <47b49daf$1@news.povray.org>
I should have realised that this was possible - I've just never seen it
at the top-level before.
It's kinda nice to be able to write things like
   (a',b',c',d') = (b,c,d,a)
to do a rotation. All those C programmers are sitting there defining
temporary variables to handle the shuffle, while I can just tell the
compiler exactly what I want the end result to be, and it just does it...
Interestingly, the compiler infers some rather strange types for those
functions. Clearly \x -> x is id, yet the compiler infers a less general
type than this - presumably due to the tupling. Or perhaps to the other
call sites in the program, I'm not sure...
>> Very odd...
And how do you suggest I do that, given that there's no obvious "entry
point"?
Date: 14 Feb 2008 15:00:01
Message: <web.47b49cfe9e92b6c266f20de80@news.povray.org>
I don't think readable means much when all you get is "un" or "po".  You could
change those for kanji and it'd make about as much sense...
of course, you could try to guess:  perhaps "un" is to unfoo something and "po"
to position something.  not much better...
Date: 14 Feb 2008 15:02:23
Message: <47b49e4f$1@news.povray.org>
On Thu, 14 Feb 2008 14:46:25 -0500, nemesis wrote:
> Brainf*ck.
Now there's a language I'm unfamiliar with - who wrote the book on that
one? ;-)
Jim
Date: 14 Feb 2008 15:02:38
Message: <47b49e5e@news.povray.org>
> So idea why.
Well *obviously* I actually meant to type 35...
Date: 14 Feb 2008 15:03:29
Message: <47b49e91@news.povray.org>
>> Brainf*ck.
> one? ;-)
As the name suggests, it's a language specifically designed to be
incomprehensible. [Unlike, say, the SKI calculus, which *is*
incomprehensible, but not by design...]
Date: 14 Feb 2008 15:05:45
Message: <47b49f19$1@news.povray.org>
On Thu, 14 Feb 2008 20:02:40 +0000, Orchid XP v7 wrote:
>> characters. So idea why.
What, even with separate keys on the keyboard? <scnr> <g>
Jim
Date: 14 Feb 2008 15:06:22
Message: <47b49f3e@news.povray.org>
On Thu, 14 Feb 2008 20:03:31 +0000, Orchid XP v7 wrote:
>>> Brainf*ck.
>> one? ;-)
Well, yes, but at the same time, there must be a definitive reference on
it.  Or is it the "ipsum lorem" text that's considered definitive? ;-)
Jim
Date: 14 Feb 2008 15:06:37
Message: <47b49f4d$1@news.povray.org>
Care to count how many characters I typed *correctly*? ;-)
Date: 14 Feb 2008 15:07:41
Message: <47b49f8d$1@news.povray.org>
Nah, I just couldn't resist the temptation to call you on it. ;-)
Jim
Date: 14 Feb 2008 15:08:34
Message: <47b49fc2$1@news.povray.org>
Oh yes, of course...
http://www.muppetlabs.com/~breadbox/bf/
Date: 14 Feb 2008 15:15:53
Message: <47b4a179@news.povray.org>
>     var a2   = 2*a;
>   solve2 a b c =
>     let det  = sqrt det2
>         det2 = b*b - 4*a*c
>         a2   = 2*a
http://rinkworks.com/stupid/cs_programming.shtml
"An introductory programming student once asked me to look at his
program and figure out why it was always churning out zeroes as the
result of a simple computation. I looked at the program, and it was
pretty obvious:
begin
     readln("Number of Apples", apples);
     readln("Number of Carrots", carrots);
     readln("Price for 1 Apple", a_price);
     readln("Price for 1 Carrot", c_price);
     writeln("Total for Apples", a_total);
     writeln("Total for Carrots", c_total);
     writeln("Total", total);
     total := a_total + c_total;
     a_total := apples * a_price;
     c_total := carrots + c_price;
end;
  * Me: "Well, your program can't print correct results before they're
computed."
  * Him: "Huh? It's logical what the right solution is, and the computer
should reorder the instructions the right way."
So he was right after all...
Date: 14 Feb 2008 15:20:02
Message: <47b4a272@news.povray.org>
Orchid XP v7 <voi### [at] devnull> wrote:
> >> Brainf*ck.
> > one? ;-)
> incomprehensible.
  Personally I like the idea behind Befunge more. The only problem I have
with Befunge is that it's way too difficult to do anything practical with
it (because it uses a stack which you can't index, and it lacks support
for variables).
Date: 14 Feb 2008 15:25:01
Message: <web.47b4a3259e92b6c266f20de80@news.povray.org>
> functional.
it introduces a new lexically scoped binding for a constant "function".  It's
not like you can't give values names in functional languages.  Come on, giving
names is the simplest means of abstraction there is!
Assignment is only bad when it happens all the time, at all levels, by multiple
points in code mutating a single location, which can lead to undesired
side-effects as the source of many bugs and sync problems.  As a rule of thumb,
in functional languages new locations are created rather than altering the
contents of previous ones, unless when it's not wise on the performance side.
Date: 14 Feb 2008 15:26:47
Message: <47b4a407$1@news.povray.org>
> pretty obvious:
> begin
> end;
> computed."
The trouble is, as soon as you start assigning more than one value to
something, it suddenly matters *when* you read it's value. And that
means if you start reordering things, everything goes horribly wrong.
Haskell does not permit you to assign more than one value to any given
variable. Thus, Haskell is able to chase down dependencies (even
circular ones) and Do The Right Thing(tm). So it really is a math-style
definition that always holds rather than an imperative-style assignment
at a specific point in time.
Date: 14 Feb 2008 15:29:41
Message: <47b4a4b5@news.povray.org>
>    solve2 a b c =
>      let det  = sqrt det2
>          det2 = b*b - 4*a*c
>          a2   = 2*a
  I wonder what something along the lines of this would do:
foo a =
  let res = if a<2 then 1 else a*foo(a-1)
  in res
Date: 14 Feb 2008 15:30:00
Message: <web.47b4a3a79e92b6c266f20de80@news.povray.org>
> > functional.
In Scheme and Lisp, let introduces new lexical scoped bindings for values, just
like in Haskell.  Except someone can use set! on them and break all referential
transparency apart...
Message: <web.47b4a49d9e92b6c266f20de80@news.povray.org>
> point"?
run one of them, perhaps "un", on some RSA key?
Date: 14 Feb 2008 15:30:38
Message: <47b4a4ee$1@news.povray.org>
Woah. Some of these are pretty "special" BTW... :-D
Date: 14 Feb 2008 15:31:22
Message: <47b4a51a$1@news.povray.org>
>>> functional.
Ah, OK.
IIRC there's also a bunch of functions for modifying lists in-place that
Haskell also doesn't have...
Date: 14 Feb 2008 15:33:08
Message: <47b4a583@news.povray.org>
  Maybe I confused "let" with "set".
Date: 14 Feb 2008 15:35:00
Message: <web.47b4a5b79e92b6c266f20de80@news.povray.org>
googled:
I don't lose time with that kind of stuff...
Date: 14 Feb 2008 15:35:18
Message: <47b4a606$1@news.povray.org>
> foo a =
>   in res
Looks like YAFFI [Yet Another Factorial Function] to me. ;-)
[And yes, for anybody else reading it, it works just fine...]
Date: 14 Feb 2008 15:40:00
Message: <web.47b4a67c9e92b6c266f20de80@news.povray.org>
> begin
> end;
> computed."
a functional programmer with no prior exposure to the imperative paradigm?!
Haskell is creating mindless monsters! :D
Date: 14 Feb 2008 15:41:49
Message: <47b4a78d$1@news.povray.org>
Hey, this was probably a long time ago! Maybe he was a Prolog
programmer? ;-)
*runs*
Date: 14 Feb 2008 16:21:57
Message: <47b4b0f5$1@news.povray.org>
>> on it.  Or is it the "ipsum lorem" text that's considered definitive?
> googled:
I think you just broke my brain.  And here I was thinking it was a joke
you made up. :-)
Jim
Date: 14 Feb 2008 16:22:18
Message: <47b4b10a$1@news.povray.org>
Now I *have* seen it all. :-)
Jim
Date: 14 Feb 2008 16:23:48
Message: <47b4b164@news.povray.org>
Does exactly what it says on the tin.
> And here I was thinking it was a joke you made up. :-)
Oh no, it's definitely not a joke. ;-)
Date: 14 Feb 2008 16:27:11
Message: <47b4b22f$1@news.povray.org>
>> googled:
You mean he f**ked your brain?
Date: 14 Feb 2008 16:30:35
Message: <47b4b2fb$1@news.povray.org>
It's tinned, to?  Wow. :-)
Well, for some values of 'joke' anyways. ;-)
Jim
Date: 14 Feb 2008 16:30:44
Message: <47b4b304$1@news.povray.org>
>>> googled:
More or less, yes.
Jim
Date: 15 Feb 2008 04:15:31
Message: <47b55833@news.povray.org>
Yet Another Factorial Function Implementation.
Damn it, I should just stop typing! >_<
Date: 15 Feb 2008 04:16:15
Message: <47b5585f@news.povray.org>
Nah. The Iota calculus is much harder. ;-)
Date: 15 Feb 2008 12:52:30
Message: <47b5d15e$1@news.povray.org>
I gave up at integral calculus.  Too much memorisation.
Jim
