POV-Ray : Newsgroups : povray.off-topic : Strange PC behaviour Server Time
18 Aug 2025 11:13:08 EDT (-0400)
  Strange PC behaviour (Message 1 to 10 of 40)
Subject: Strange PC behaviour
Date: 9 Feb 2008 02:52:49
Message: <47ad5bd1@news.povray.org>
It all started with blackouts. No, it wasn't the power company. The PC would
spontaneously reset itself. It became more and more frequent. then it
wouldn't start up again unless I unplugged the power cable. Soon the PC
started crashing while Windows was loading.. . and after that all I could
get was CMOS. and then I couldn't even get the PC switched on.... After
removing the CMOS battery for a couple of minutes I could switch on the PC
again. With Windows badly damaged I had to reformat the HDD and reinstall
Windows a couple of times. Every time I install Windows it works fine for a
while and then starts crashing untill I can't start the PC up anymore. Last
night I tried installing Linux and it crashed with 20minutes of install
remaining.
I can't afford a new PC at the moment at all, so is there anything I can do?
I have a Athlon XP 2400 Socket A using the onboard 128Mb SiS graphics card
and a 250W power supply.
-Nekar Xenos-
Subject: Re: Strange PC behaviour
Date: 9 Feb 2008 05:07:23
Message: <gpuqq3hpkvuekv5nv0mogagda0i5rsvdaf@4ax.com>
On Sat, 9 Feb 2008 09:52:50 +0200, "Nekar Xenos" <nek### [at] gmailcom> wrote:
That does not sound good.
You could take it to a pc repair shop or start replacing components yourself.
But you could end up rebuilding it completely if you do that. For a start I
would reseat everything, look at the PCBs for dry joints and overheating. If
you're not technical the first option is safer. If you do it yourself be
prepared for a lot of pain :)
Regards
Date: 9 Feb 2008 05:16:54
Message: <47ad7d96@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> wrote in message
news:gpuqq3hpkvuekv5nv0mogagda0i5rsvdaf@4ax.com...
>>do?
> yourself.
I was hoping maybe some-one had had the same symptoms might be able to
diagnose the problem more quickly. :)
> I
>dry joints
>and overheating. If
:S
-Nekar Xenos-
Date: 9 Feb 2008 06:34:31
Message: <47ad8fc7$1@news.povray.org>
Check the capacitors at the motherboard and replace the faulty ones.
This one's OK:
http://www.edu.helsinki.fi/malu/kirjasto/mbl/sahko/elektrolyyttikonnsaattorin_purku.gif
and this one is not:
http://img.photobucket.com/albums/v711/whurd/Bad.jpg
See the top - at the last picture it's "growing". They also can even leak:
http://www.asti-usa.com/support/appnotes/65.html (pictures at the end of
the document)
Sounds like the timing (motherboard's age) could hit the end of the
latest worst season of capacitors.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 9 Feb 2008 06:40:56
Message: <47ad9148$1@news.povray.org>
Which OS?
By default, Windows XP doesn't display the Blue Screen of Death, it just
instantly reboots.
I've seen that a few times. It's *usually* a motherboard fault. (Not
always.)
> Soon the PC
> again.
Yeah, sounds like a motherboard fault of some kind. Diagnosing exactly
what is going to be lots of fun...
> remaining.
Have you tried running a memory test? There's a small possibility that
might be the cause - although I doubt it - but if it is, that's easier
to fix than replacing the whole motherboard.
Replace the motherboard with something that's compatible with your
existing stuff - if you can find such a board...
http://blog.orphi.me.uk/
Date: 9 Feb 2008 09:57:36
Message: <47adbf60@news.povray.org>
In case of memory fault it is needed to also remember the possibility of
malfunctioning memory controller. So if Nekar will get new memory
modules, my advice would be to make sure they can be returned, if the
fault won't go away.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 9 Feb 2008 10:31:54
Message: <47adc76a@news.povray.org>
> remaining.
If an OS install crashes where before it did not, you have a hardware
problem.  Since the symptoms are relived by a successful OS install, the
problem involves a gradual corruption of the hard drive's contents,
which could be caused by bad memory, bad CPU, or a bad MB.
We can't really troubleshoot your problem through newsgroup messages, so
you'll have to take it to a technician.
John
Date: 9 Feb 2008 11:10:43
Message: <47add083@news.povray.org>
"Nekar Xenos" <nek### [at] gmailcom> wrote in message
news:47ad7d96@news.povray.org...
If you live anywhere near Randburg, take it to Zaps at Brightwater. They're
pretty good.
It could be the power supply's fried. I had similar symptons with a work
PC - random reboots. Could also be something gone toast on the motherboard.
Have you been having a lot of power cuts? They're hell on computers,
especially if mains surges as it comes back (not unusual)
If you don't have a UPS, even a small 5 minute one, get one. It will
probably save you a lot of money over the next few years.
Date: 9 Feb 2008 15:27:09
Message: <47ae0c9d$1@news.povray.org>
> would spontaneously reset itself. It became more and more frequent. then
> it wouldn't start up again unless I unplugged the power cable. Soon the
> PC started crashing while Windows was loading.. . and after that all I
> could get was CMOS. and then I couldn't even get the PC switched on....
> After removing the CMOS battery for a couple of minutes I could switch
> on the PC again. With Windows badly damaged I had to reformat the HDD
> and reinstall Windows a couple of times. Every time I install Windows it
> works fine for a while and then starts crashing untill I can't start the
> PC up anymore. Last night I tried installing Linux and it crashed with
> 20minutes of install remaining.
> do?
> card and a 250W power supply.
Disassemble the machine, clean it very thoroughly, and put it back
together.
I had a machine that was behaving similarly and it turned out that there
was something shorting something out on the system board (best guess);
giving it a good vacuum fixed it - haven't had a problem since.
Jim
Date: 9 Feb 2008 16:44:39
Message: <47ae1ec7$1@news.povray.org>
I had the same sort of problems with my HP machine. Then, after a while
of increasingly frustrating crashes and inability to see the keyboard
after booting and such, it made a little squeak and a puff of smoke, and
the power supply needed to be replaced.
     On what day did God create the body thetans?
