POV-Ray : Newsgroups : povray.off-topic : Lamp me one Server Time
3 Nov 2026 14:31:04 EST (-0500)
  Lamp me one (Message 1 to 26 of 26)
Subject: Lamp me one
Date: 5 Feb 2008 07:57:15
Message: <47a85d2b@news.povray.org>
I just learned PHP. I feel unclean...
[Seriously. The *introductory tutorial* is littered with warnings about
obscure functionallity which used to be broken but now isn't, and
strange features that used to work one way but now work a slightly
different way. I'm almost scared to write anything with this...]
Still, for some reason PHP is extremely popular, so I guess it would be
useful to learn it. Certainly if most of the complex control logic is
implemented in a real programming language, PHP looks quite good for
stitching complex blocks of HTML together with relative ease.
http://blog.orphi.me.uk/
Subject: Re: Lamp me one
Date: 5 Feb 2008 09:27:35
Message: <47a87257@news.povray.org>
And here's a small pointless toy I just developed...
<html>
<head>
   <title>PHP Test #4 (Output)</title>
</head>
<body>
<h1>PHP Test #4 (Output)</h1>
<p>
<a href="Test4-In.html">Return to input form</a>
</p>
<h2>Input</h2>
<pre><?php echo htmlspecialchars($_POST['code']); ?></pre>
<p>Length: <?php echo strlen($_POST['code']); ?> characters.</p>
<h2>Frequency Table</h2>
<?php
$table = array();
$in = $_POST['code'];
for ($pos=0; $pos < strlen($in); $pos++)
   $symbol = $in[$pos];
   if (isset($table[$symbol])) $table[$symbol] = $table[$symbol] + 1;
   else $table[$symbol] = 1;
<table border="1">
   <tr>
     <th>Symbol</th>
     <th>Count</th>
     <th>Probability</th>
     <th>Bits</th>
   </tr>
<?php
foreach ($table as $symbol => $count)
   echo '<tr><td align="center">‘<code>';
   echo htmlspecialchars($symbol);
   echo '</code>’</td><td align="right">';
   echo $count;
   echo '</td><td align="right">';
   echo (int)($count / strlen($in) * 100);
   echo '%</td><td align="right">';
   echo abs(log($count / strlen($in)) / log(2));
   echo '</td></tr>';
   echo "\n";
   <tr>
     <td align="center">Total</td>
     <td align="right"><?php echo strlen($in); ?></td>
     <td align="right">100%</td>
     <td align="right">0</td>
   </tr>
</table>
</body>
</html>
Date: 5 Feb 2008 09:56:47
Message: <47a8792b@news.povray.org>
> useful to learn it.
  You won't like it. It looks a bit like C++.
Date: 5 Feb 2008 09:58:14
Message: <47a87982@news.povray.org>
  Don't mix HTML and PHP. That's just asking for maintenance nightmares.
>    echo $count;
>    echo '</td></tr>';
>    echo "\n";
  You don't need to make a separate 'echo' for each of those things.
Date: 5 Feb 2008 10:04:38
Message: <47a87b06@news.povray.org>
I thought that was the design goal of PHP?
[Er, to be mixed with HTML, that is.]
>>    echo $count;
>>    echo '</td></tr>';
>>    echo "\n";
You do if you only have a 40x40 character text window and a text editor
which malfunctions on long lines...
Date: 5 Feb 2008 10:05:35
Message: <47a87b3f$1@news.povray.org>
>> useful to learn it.
Quoting somebody else:
   "Haskell is really bad - it makes you hate normal languages."
But then, I never really liked scripting languages much, and that was
way before Haskell, so... ;-)
Date: 5 Feb 2008 10:36:30
Message: <47a8827c@news.povray.org>
  Maybe it was, but in practice it's usually a bad idea. I have seen
horrible, horrible examples.
  This may be an acceptable exception:
<?php
  ... lots of PHP code here
<html>
  <?php (something which calls the code above) ?>
</html>
  No you don't:
echo
 'hello ' .
 $user .
 ", how are you?\n";
  At least it saves you from writing 'echo' a million times.
Date: 5 Feb 2008 10:45:35
Message: <47a8849f$1@news.povray.org>
I can imagine...
The PHP tutorial explains how you can do "really cool" things like this:
<?php if ($somecondition) { ?>
Lots of HTML here...
<?php } else { ?>
lots more HTML here...
<?php } ?>
Which... uh... well I can imagine it becoming messy quite fast.
> <?php
> <html>
> </html>
Yeah, that seems more like the model to follow. (In fact, some of the
user comments I've seen suggest that all the "real code" should be in
include files instead and just called from the HTML pages.)
>   No you don't:
> echo
>  'hello ' .
>  $user .
>  ", how are you?\n";
Ooo... you can do that?
Date: 5 Feb 2008 10:51:34
Message: <47a88606$1@news.povray.org>
Invisible escribió:
> Warp wrote:
>>   No you don't:
>> echo
>>  'hello ' .
>>  $user .
>>  ", how are you?\n";
Yes, and you can also pass multiple arguments to 'echo' (ie. what Warp
said, but with a comma instead of the concat operator). It's probably a
millisecond faster to do it that way too.
http://blog.libssh2.org/index.php?/archives/28-How-long-is-a-piece-of-string.html
Date: 5 Feb 2008 11:27:42
Message: <47a88e7e$1@news.povray.org>
"Invisible" <voi### [at] devnull> a écrit dans le message de news:
47a87b06@news.povray.org...
I second Warp. You can mix HTML and PHP in the same page but it's likely to
turn into some horrible mess before you know it.
The trick is to build long text strings in PHP (that include the HTML tags
and everything you want to see on screen) and then echo the result.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 5 Feb 2008 11:38:43
Message: <47a89113$1@news.povray.org>
I can believe that...
Really? It seems being able to write a basically normal HTML page with
just the odd snippet of PHP here and there to insert some computed value
is the main appeal of the language. Trying to build giant strings tends
to be awkward.
Date: 5 Feb 2008 11:39:40
Message: <47a89149@news.povray.org>
  Even if some library or whatever just echoes/prints everything it
produces (instead of returning a string), there's a way to redirect
that printing to a string. (I don't remember now the exact command
for that, though.)
Date: 5 Feb 2008 12:06:15
Message: <47a89787$1@news.povray.org>
> for that, though.)
ob_start();
function_that_prints_stuff();
$string = ob_get_clean();
ob_get_clean is like getting the string with ob_get_contents, and then
throwing away the buffer with ob_end_clean. There is a dozen functions
for output buffering, so be sure to rtfm :)
Date: 5 Feb 2008 21:44:26
Message: <47a91f0a@news.povray.org>
Good! That means you have a sense of elegance. :-)  But we knew that.
Yes. You should be.
That and the complete clusterfuck that the naming of all the
functionality has.
Because, sadly, it has huge quivering gobs of useful libraries in it.
Don't do that on a real project. Use actual data-like templates. The
problem is that the person writing the code isn't the person who decides
what goes in the HTML.
     On what day did God create the body thetans?
Date: 5 Feb 2008 22:04:47
Message: <47a923cf$1@news.povray.org>
http://www.odi.ch/prog/design/php/index.php
http://www.odi.ch/prog/design/php/guide.php
I disagree with "no reason to use PHP5". PHP5 has a lot of great
features (most of what the previous section says PHP4 lacks), and PHP4
is officially unmaintained since 01/01/2008.
"As PHP does not have a namespace facility like Java packages"
PHP6 will. WAY too late, but credits to them...
All the rest is quite good advice IMHO.
Date: 6 Feb 2008 04:53:38
Message: <47a983a2$1@news.povray.org>
> Yes. You should be.
Hmm, well, it's not so bad if you purposely avoid all the unpredictable
edge cases. But what if you have to work on somebody else's code? My
God, it doesn't bear thinking about...
> functionality has.
Beings a whole new being to "it's massively clustered". ;-)
Yes, I noticed that.
In Haskell, accessing a database involves downloading source code,
trying to sort out a huge undocumented dependency hell, trying to make
the thing compile and using voodoo dolls. And then you *might* be able
to access a database.
In PHP, you just... install PHP. And it works. Immediately.
Gee, which one would you choose?
I guess this is why we have Type-I and Type-II languages. *sigh*
Hmm. That sounds like an interesting problem to attempt to solve...
Date: 6 Feb 2008 06:52:41
Message: <47a99f89$1@news.povray.org>
Ooo... POST data has all single-quote characters escaped by prefixing
with a backslash, and PHP doesn't unescape them before giving the string
back to you. That's a nice feature.
Date: 6 Feb 2008 07:05:51
Message: <47a9a29f$1@news.povray.org>
"Uhm.. err.. I have never thought about this you may anser now. And that
is exactly the point! Any unwary programmer will write codde like the
line above and introduce severe security and stability problems in his
code."
Irony, much? You're talking about unwary programmers and you apparently
haven't spent much effort proof-reading what you just typed. ;-)
"No major other language requires you to redeclare global variables
inside a function..."
Apparently Tcl isn't "major". ;-) It has precisely the same irritating
feature.
"I am writing this guide to provide useful ways how to best structure
your code."
Not your sentences, then?
Date: 6 Feb 2008 22:46:33
Message: <47aa7f19$1@news.povray.org>
>> decides what goes in the HTML.
Meh. I use a templating thing.  I have a call to which you pass a
template name, a style, an array of name->value pairs, and an array of
name->function mappings.
The template name and style maps (eventually) to a file, with stuff like
<p>Welcome, <{name}>!</p>
<p><red><{{errormessage}}>></red></p>
Lines with <{{stuff}}> where there's no "stuff" key in the name->value
array disappear completely. The rest get substituted. If the name has a
"*" on the end, it doesn't get HTML-escaped, so you can pass raw HTML
from the code. The name->function lets you do things like "display
values greater than five minutes in red" or "NULL turns into 'N/A'"
On top of that, I built one that takes a head, row, and foot template,
as well as a record resource (as returned by mysql_query()) and
generates the whole page.
Date: 6 Feb 2008 22:48:43
Message: <47aa7f9b$1@news.povray.org>
> feature.
It's not irritating, it's modular!  ;-)
Seriously, if you don't declare variables first, there really isn't a
particularly good way of creating a global from inside a procedure, is
there?
Date: 6 Feb 2008 23:20:06
Message: <47aa86f6$1@news.povray.org>
Darren New escribió:
>> feature.
> there?
$GLOBALS['varname'] = "stuff";
(no, I'm not being serious)
Date: 7 Feb 2008 04:17:47
Message: <47aaccbb$1@news.povray.org>
> there?
Yeah there is: Declare variables first. :-P
Date: 7 Feb 2008 12:09:26
Message: <47ab3b46$1@news.povray.org>
>> there?
Sure. That's what [global] gets you.
Anyway, [global] is a special case of [upvar] and just basically has
default arguments. Complaining you have to use [global] in Tcl is silly.
PHP has no [upvar], and PHP has "superglobals" which you don't have to
redeclare inside procedures, so it's just a mess.
Date: 13 Feb 2008 03:06:55
Message: <slrnfr598v.6l7.bisqwit@bisqwit.iki.fi>
On 5 Feb 2008 10:36:30 -0500, Warp wrote:
> echo
>  'hello ' .
>  $user .
>  ", how are you?\n";
Or rather:
echo
  'hello ',
  $user,
  ", how are you?\n";
Or in this case:
  echo "Hello, $user, how are you?\n";
Interesting article touching the issue:
Joel Yliluoma - http://iki.fi/bisqwit/
Date: 13 Feb 2008 03:34:40
Message: <slrnfr5at0.6l7.bisqwit@bisqwit.iki.fi>
Oh, already posted. :o
Date: 13 Feb 2008 03:49:52
Message: <slrnfr5bpg.6l7.bisqwit@bisqwit.iki.fi>
\"Magic quotes\". Extremely annoying. Disable at sight.
