POV-Ray : Newsgroups : povray.off-topic : Lamp me one Server Time
20 Jan 2026 12:13:35 EST (-0500)
  Lamp me one (Message 1 to 10 of 26)
Subject: Lamp me one
Date: 5 Feb 2008 07:57:15
Message: <47a85d2b@news.povray.org>
I just learned PHP. I feel unclean...
[Seriously. The *introductory tutorial* is littered with warnings about
obscure functionallity which used to be broken but now isn't, and
strange features that used to work one way but now work a slightly
different way. I'm almost scared to write anything with this...]
Still, for some reason PHP is extremely popular, so I guess it would be
useful to learn it. Certainly if most of the complex control logic is
implemented in a real programming language, PHP looks quite good for
stitching complex blocks of HTML together with relative ease.
http://blog.orphi.me.uk/
Subject: Re: Lamp me one
Date: 5 Feb 2008 09:27:35
Message: <47a87257@news.povray.org>
And here's a small pointless toy I just developed...
<html>
<head>
   <title>PHP Test #4 (Output)</title>
</head>
<body>
<h1>PHP Test #4 (Output)</h1>
<p>
<a href="Test4-In.html">Return to input form</a>
</p>
<h2>Input</h2>
<pre><?php echo htmlspecialchars($_POST['code']); ?></pre>
<p>Length: <?php echo strlen($_POST['code']); ?> characters.</p>
<h2>Frequency Table</h2>
<?php
$table = array();
$in = $_POST['code'];
for ($pos=0; $pos < strlen($in); $pos++)
   $symbol = $in[$pos];
   if (isset($table[$symbol])) $table[$symbol] = $table[$symbol] + 1;
   else $table[$symbol] = 1;
<table border="1">
   <tr>
     <th>Symbol</th>
     <th>Count</th>
     <th>Probability</th>
     <th>Bits</th>
   </tr>
<?php
foreach ($table as $symbol => $count)
   echo '<tr><td align="center">‘<code>';
   echo htmlspecialchars($symbol);
   echo '</code>’</td><td align="right">';
   echo $count;
   echo '</td><td align="right">';
   echo (int)($count / strlen($in) * 100);
   echo '%</td><td align="right">';
   echo abs(log($count / strlen($in)) / log(2));
   echo '</td></tr>';
   echo "\n";
   <tr>
     <td align="center">Total</td>
     <td align="right"><?php echo strlen($in); ?></td>
     <td align="right">100%</td>
     <td align="right">0</td>
   </tr>
</table>
</body>
</html>
Date: 5 Feb 2008 09:56:47
Message: <47a8792b@news.povray.org>
> useful to learn it.
  You won't like it. It looks a bit like C++.
Date: 5 Feb 2008 09:58:14
Message: <47a87982@news.povray.org>
  Don't mix HTML and PHP. That's just asking for maintenance nightmares.
>    echo $count;
>    echo '</td></tr>';
>    echo "\n";
  You don't need to make a separate 'echo' for each of those things.
Date: 5 Feb 2008 10:04:38
Message: <47a87b06@news.povray.org>
I thought that was the design goal of PHP?
[Er, to be mixed with HTML, that is.]
>>    echo $count;
>>    echo '</td></tr>';
>>    echo "\n";
You do if you only have a 40x40 character text window and a text editor
which malfunctions on long lines...
Date: 5 Feb 2008 10:05:35
Message: <47a87b3f$1@news.povray.org>
>> useful to learn it.
Quoting somebody else:
   "Haskell is really bad - it makes you hate normal languages."
But then, I never really liked scripting languages much, and that was
way before Haskell, so... ;-)
Date: 5 Feb 2008 10:36:30
Message: <47a8827c@news.povray.org>
  Maybe it was, but in practice it's usually a bad idea. I have seen
horrible, horrible examples.
  This may be an acceptable exception:
<?php
  ... lots of PHP code here
<html>
  <?php (something which calls the code above) ?>
</html>
  No you don't:
echo
 'hello ' .
 $user .
 ", how are you?\n";
  At least it saves you from writing 'echo' a million times.
Date: 5 Feb 2008 10:45:35
Message: <47a8849f$1@news.povray.org>
I can imagine...
The PHP tutorial explains how you can do "really cool" things like this:
<?php if ($somecondition) { ?>
Lots of HTML here...
<?php } else { ?>
lots more HTML here...
<?php } ?>
Which... uh... well I can imagine it becoming messy quite fast.
> <?php
> <html>
> </html>
Yeah, that seems more like the model to follow. (In fact, some of the
user comments I've seen suggest that all the "real code" should be in
include files instead and just called from the HTML pages.)
>   No you don't:
> echo
>  'hello ' .
>  $user .
>  ", how are you?\n";
Ooo... you can do that?
Date: 5 Feb 2008 10:51:34
Message: <47a88606$1@news.povray.org>
> Warp wrote:
>>   No you don't:
>> echo
>>  'hello ' .
>>  $user .
>>  ", how are you?\n";
Yes, and you can also pass multiple arguments to 'echo' (ie. what Warp
said, but with a comma instead of the concat operator). It's probably a
millisecond faster to do it that way too.
http://blog.libssh2.org/index.php?/archives/28-How-long-is-a-piece-of-string.html
Date: 5 Feb 2008 11:27:42
Message: <47a88e7e$1@news.povray.org>
47a87b06@news.povray.org...
I second Warp. You can mix HTML and PHP in the same page but it's likely to
turn into some horrible mess before you know it.
The trick is to build long text strings in PHP (that include the HTML tags
and everything you want to see on screen) and then echo the result.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
