POV-Ray : Newsgroups : povray.off-topic : Bitrate and other settings for H.264? Server Time
3 Nov 2026 14:33:37 EST (-0500)
  Bitrate and other settings for H.264? (Message 1 to 7 of 7)
Subject: Bitrate and other settings for H.264?
Date: 3 Feb 2008 21:44:32
Message: <47a67c10$1@news.povray.org>
So I finally have the hard drive space to start ripping my DVDs to my PC
(in a few months, I'll buy 3 1TB disks for a raid 5 array, to store all
my media on - but for now, I'll just rip part of my collection).  I'm
using TMPGEnc to encode them as .mp4 files for iTunes, and I'm trying to
figure out good settings for them.
Unfortunately, creating various setups, testing them, and comparing them
is rather time consuming.
Does anyone have some suggestions for what I should use?
I tried 800kb average, 1500 max for full resolution rips, but on scenes
with a lot of movement this ends up with quite blocky results.  I'm
thinking of upping this to 1500 average, 2500max.
Also, some of my stuff doesn't need full resolution, so I drop the frame
size down to 480x320 (from 720x480).  For this, so far it seems that 350
average is good enough, but again I'd like to hear from others who have
been through this.
Any advice?
And does it really help that much using 2 pass VBR, instead of 1 pass?
(I'm willing to live with the additional encoding time if it makes a
difference, but I haven't tried two side by side encodes to see the
quality difference).
...Ben Chambers
ben at pacific web guy dot com (no spaces)
www.pacificwebguy.com
Subject: Re: Bitrate and other settings for H.264?
Date: 4 Feb 2008 04:38:41
Message: <47a6dd21$1@news.povray.org>
By an ironic twist of fate, last night I was staring at my PC trying to
figure out how to convince ArcSoft DVD Creator to create DVDs that
aren't horribly blocky. It's currently using "ArcSoft SmartRender(tm)
automatic bitrate selection", but there is a manual option. Hmm, I
wonder what the maximum bitrate for a DVD is?
...according to Wikipedia, 9.8 Mbit/sec. I have a feeling it won't be
possible to get a crisp, sharp picture at that bitrate. :-(
http://blog.orphi.me.uk/
Date: 4 Feb 2008 16:04:54
Message: <47a77df6$1@news.povray.org>
These might be useful:
http://dvd-hq.info/Calculator.html
http://www.videohelp.com/calc.htm
Tor Olav
http://subcube.com
Date: 4 Feb 2008 19:35:01
Message: <web.47a7ae3fe6e72575261d9700@news.povray.org>
Well, I ended up doing some test encodes and comparing a 1 1/2 minute sequence
from Transformers.  I uncovered a few things:
1) 2-pass VBR makes a HUGE difference over 1-pass VBR at low bitrates (I didn't
compare high bitrates).
2) Using a bitrate of >3000 yields no distinguishable improvements for visually
intensive movies (Transformers, Crouching Tiger Hidden Dragon, etc)
3) A bitrate of 1500 seems enough for other movies (Love Actually, When Harry
Met Sally, etc)
4) A lower resolution (480x320) and lower bitrate (750) is sufficient for things
such as episodes of Friends, and cartoons like The Hobbit or Winnie the Pooh.
I left it encoding some movies overnight, and I'll verify them this week to make
sure that the settings are adequate.
And Tor, thanks for the links, but I'm not concerned about the final image
size so much as the minimum quality settings needed to avoid encoding
artifacts.
.....Chambers
Date: 4 Feb 2008 20:13:01
Message: <47a7b81d$1@news.povray.org>
> artifacts.
If you don't care about the file size, why are you setting the bitrate?
Set the quality or the quantizer instead. The bitrate is about how much
video data it needs per second, and it's used for example to make sure a
movie fits a CD.
Date: 4 Feb 2008 21:26:46
Message: <47a7c966@news.povray.org>
Nicolas Alvarez wrote:
>> image
>> artifacts.
> movie fits a CD.
Because a) the version of TMPGEnc I'm using doesn't have a "Constant
Quality" setting for h.264 files, and b) using a "constant quantization"
method causes the resulting video to not play on my machine.
Although, I just saw that outputting a quicktime .mov file (instead of
.mp4) allows me to use h.264, and use a quality setting there.  I think
I'll try that next...
...Ben Chambers
Date: 5 Feb 2008 01:21:34
Message: <47a8006e$1@news.povray.org>
Bah, Quicktime files take about twice as long to encode, and end up
about twice the size of a 5000 kbit video stream in .mp4 format, without
looking any better (and I'm scaling the final version up to fit my
screen, so any errors should be painfully obvious).
...Ben Chambers
