POV-Ray : Newsgroups : povray.off-topic : Mocap! Server Time
19 Apr 2026 22:24:03 EDT (-0400)
  Mocap! (Message 1 to 3 of 3)
Subject: Mocap!
Date: 23 Jan 2008 21:29:00
Message: <4797f7ec@news.povray.org>
Hello.
What's the most popular or standard, or most unencumbered format for motion
capture files? (I have this vague recollection that there's more than one).
Is there also a standard  or more popular syntax within that format?
thanks.
Subject: Re: Mocap!
Date: 28 Jan 2008 17:31:38
Message: <479e57ca$1@news.povray.org>
Greg M. Johnson wrote:
> Hello.
> thanks.
I'm not sure what the standard is, and I suspect that it depends on what
software you're using.  I tend to like a .csv (comma separated values)
file specifying the character DOFs for each frame combined with a .skel
specifying the transformation hierarchy.  I use these because they're
both pretty simple ASCII formats, so you can write your own parsers for
them.
Your best bet for getting the most commonly used formats would be to
take a look at what's used in CMU's motion capture database:
http://mocap.cs.cmu.edu/
http://mocap.cs.cmu.edu/tools.php
There are also tools available to read some of the more popular
formation.  You might take a look at Dance, as it says it outputs to POV
as well:
http://www.magix.ucla.edu/dance/
I'm curious, what are you using the mocap for?
Subject: Re: Mocap!
Date: 29 Jan 2008 00:21:17
Message: <479eb7cd$1@news.povray.org>
Not that I know much about the format, but the only format I've seen
supported by multiple programs is "BVH". Even Second Life uses that.
Apparently, if you understand motion capture well, it's a pretty
straightforward format.
HTH.
     On what day did God create the body thetans?
