POV-Ray : Newsgroups : povray.off-topic : Any Java experts? Server Time
20 Jan 2026 13:57:37 EST (-0500)
  Any Java experts? (Message 1 to 8 of 8)
Subject: Any Java experts?
Date: 17 Jan 2008 14:05:25
Message: <478fa6f5@news.povray.org>
Is there anyone who can tell me why the following code sometimes (not
always) throws a NullPointerException
Using Java(TM) SE Runtime Environment (build 1.6.0_02-b06)
Node currentNode = Universe.space[i][j]; // Have checked and this is never
null.
if (currentNode.hasShip()) { // <-- This line sometimes throws a
g.drawChars(Labels, 0, 1, i*GridSizeX+GridSizeX/2, j*GridSizeY);
if (currentNode.hasAsteroid() ) {
g.drawChars(Labels, 1, 1, i*GridSizeX+1, j*GridSizeY);
And here's an abbreviated version of the Node class. The local variable
localShip is never instantiated.
public class Node {
private Ship localShip;
private Asteroid localAsteroid;
boolean hasAsteroid() {
if (localAsteroid!=null)
return true;
else
return false;
boolean hasShip() {
if (localShip!=null)
return true;
else
return false;
Subject: Re: Any Java experts?
Date: 17 Jan 2008 16:15:21
Message: <478fc569$1@news.povray.org>
Gail Shaw wrote:
> boolean hasShip() {
> return true;
> else
> return false;
This cannot possibly throw a null pointer exception.
never
 > null.
The only way for a null pointer exception to occur is if currentNode is
null.
Looks like whatever initialises Universe.space isn't doing it right, or
has some kind of intermittent bug or something. (Alternatively, the
exception isn't comming from where you say it is.)
Realistically, you'll probably need to run the code through a debugger
and make it halt execution when it hits the exception, then poke around
and examine the system state...
http://blog.orphi.me.uk/
Date: 17 Jan 2008 22:25:17
Message: <47901c1d$1@news.povray.org>
> null.
Then you should have an assertion in there to that effect. :-)
Your exception isn't being caused at this line. Or your JVM is broken.
Or currentNode is winding up a subclass of Node with different code.
Print everything just before you get there, or wrap the whole
questionable chunk in a try/catch and print out everything when it throws.
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 18 Jan 2008 04:44:51
Message: <47907513$1@news.povray.org>
>> never
>> null.
...Java has assertions now? Wow, neat. Are they broken?
Date: 18 Jan 2008 11:37:14
Message: <4790d5ba@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:478fc569$1@news.povray.org...
> Gail Shaw wrote:
> > boolean hasShip() {
> > return true;
> > else
> > return false;
Yeah, that's what I thought. Eclipse keeps giving me a null pointer excption
and pointing at that line.
Really odd thing is that the exception isn't halting execution.
> never
>  > null.
> null.
Which it's not. I have print statements checking that. Removed them from the
post for clarity
Date: 18 Jan 2008 11:41:55
Message: <4790d6d3@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:47901c1d$1@news.povray.org...
never
> > null.
Could, but the way the initialisation of the Universe works, if any Node was
null, things would break a lot earlier than this.
I have print statements. Removed from post for clarity.
Both are possibilities I've considered.
Nothing inherits from Node.
I'll do that. Probably find the excption's migrated elsewhere.
What I find really odd is that the exception doesn't terminate execution,
which I thought it should (would in C#)
Unless the exception's coming from elsewhere (the IDE possibly, or some
graphical component)
Date: 18 Jan 2008 18:39:57
Message: <479138cd@news.povray.org>
Try running it not under eclipse, then?
Maybe it's throwing in a thread, and eclipse can't figure that out?
Date: 18 Jan 2008 18:40:15
Message: <479138df$1@news.povray.org>
Orchid XP v7 wrote:
>>> never
>>> null.
> ....Java has assertions now? Wow, neat. Are they broken?
Every language has assertions. Some just have it built in.
