OK, so check this out... At home I have a wireless optical mouse. I've
had it for several years now, and it has always worked perfectly.
However, a few weeks ago I reinstalled Windoze. And ever since that
point in time, the mouse hasn't worked properly. Most of the time it
works normally, but every now and then it suddenly stops working
completely. The light on the base station still twinkles when I move it
or press the buttons, but the computer fails to respond. (Keyboard
commands work, just not mouse commands.)
The *only* thing that fixes this condition is a reboot. No amount of
reconnecting the USB cable has any effect.
Obviously, this is intensely frustrating, far beyond my powers of
description. Last night I was playing an official TF2 match, and my
mouse quit working. That means I now can't shoot, steer, look around, or
talk to my teammates over Ventrillo.
[In spite of this - and much to my amusement - I managed to actually
capture a control point. Basically I staggered in there sideways and
nobody tried to stop me. And my teammates had done almost all the work
first... Basically the two teams clashed, everybody died, and then I
stumbled in. What fluke!]
Anyway, does *anybody* have *any* idea why reinstalling Windoze has made
my mouse malfunction so badly??
http://blog.orphi.me.uk/
I would check the drivers for the mouse, USB ports and any other "mainboard"
type drivers. There might be some different version now than before the
reinstall.
Then I'd try a different mouse, just to see.
When it stops working, is the mouse still "there" (ie in device manager) or
does Windows think it has gone?
>> made my mouse malfunction so badly??
> "mainboard" type drivers. There might be some different version now
> than before the reinstall.
When I originally installed Windoze, I used the CDs that came in the
box. However, I now have a dual-core CPU, and [I forget exactly what
happened] I couldn't get Windoze to work properly without using the
latest motherboard drivers. Go figure.
So, new motherboard drivers. (The mouse itself doesn't have any drivers
- or rather, it does, but I've never used them. The drivers are to
activate the 15 buttons that I don't use. 3 buttons is enough for me...)
Yeah, if I had one...
> or does Windows think it has gone?
It's very hard to check.
10 years ago, I used a sophisticated operating system called AmigaOS. It
was possible to operate this without a mouse, because there was a set of
keyboard shortcuts for moving the mouse pointer and clicking mouse
buttons. However, to my absolute frustration [indeed, near rage],
Windoze doesn't appear to support such a feature. So you have to guess
what keyboard shortcuts every individual program uses [assuming it
provides any at all]. Grrr!!
I do have a very vague recallection that maybe I had the mouse plugged
into the PS/2 port before, whereas now it's in a USB port. However, I
*cannot* find the USB-PS/2 adaptor anywhere, so...
> 10 years ago, I used a sophisticated operating system called AmigaOS...
Try this:
Windows + Break/Pause (or go through My Computer to control panel)
Right arrow key twice
Tab
Space
Tab
Then use the arrow keys (right is expand) to search through.
It's the same in all windows programs that use standard forms.
"Invisible" <voi### [at] dev null> wrote in message
news:478b4cd5$1@news.povray.org...
> buttons. However, to my absolute frustration [indeed, near rage], Windoze
> doesn't appear to support such a feature. So you have to guess what
> keyboard shortcuts every individual program uses [assuming it provides any
> at all]. Grrr!!
The keybaord shortcuts are the letters that are underlined when you press
the "Alt" key.
Fyi You can always use "Tab" and the arrow keys to scroll between
highlighted options and Space-Bar to select.
To get Windows to always underline the shortcuts without using a mouse:
press the Windows button (between L-Ctrl and L-Alt)
Navigate to Control-Panel with the arrow keys.
Navigate to "Appearance and Themes" and then "Display"
Press "Tab" until the top tabs is highlighted.
Now use your < > arrow keys to navigate to "Appearance"
Press "Tab" untill "Effects" is highlighted and press the Space Bar.
Press "Tab" untill "Hide underlined letters for keyboard navigation untill I
press the Alt key"
I hope this helps...
-Nekar Xenos-
Because Windows is as buggy as an outhouse in the summer?
John
Tried new batteries?
If it was the batteries,
1. The receive light wouldn't be twinkling.
2. Rebooting the PC wouldn't fix the problem.
3. It wouldn't have suddenly started happening at exactly the time I
changed some software.
FWIW, yes, I have changed the batteries several times. However, usually
when the batteries fail, the mouse starts to gradually move slower than
usual before actually stopping. This is quite different...
Why does that surprise you?
"Hi, I'd like you to run on this motherboard, but I'm not going to tell you
what it does or how to make it do anything"
Try installing them anyway. It might be that the default drivers aren't
totally compatible with your mouse.
Windows isn't that hard to run without a mouse. Some apps have poor
shortcuts, but most do have them. I recall the fun of using my university
machine (win 98) for a week without a mouse, after I poured coffee over the
mouse.
I just tried to get to the device manager without using the mouse, Took
around 20 keystrokes.
There are just a few useful shortcuts that you need to remember
Ctrl-Esc opens the start menu. (as does the win key if you have that)
Alt-spacebar brings up the move/resize menu for any window
Tab moves you from pane to pane in things like device manager or explorer
and from one anchor to another in a web browser
Why not?
Because for the last 4 years it's worked perfectly fine with the
existing drivers, and now suddenly it won't. It's not like drivers
suddenly stop working after X years...
OK. I'll see if I can find the disk...
> mouse.
The point being, if you have keys to move the mouse and click the
button, *every* program can be completely operated using only the
keyboard. That includes e.g. games [where the developers don't think
about mouseless operation].
Hmm... I wonder if anybody has developed a small 3rd party solution to this?
> Why not?
Why would software make the batteries go flat?
> The point being, if you have keys to move the mouse and click the button,
> *every* program can be completely operated using only the keyboard.
But *really* slowly, compared to using Tab to cycle through the available
things to click on, or using Alt+shortcut.
> this?
Control Panel -> Accessibility -> Mouse -> "Use MouseKeys".
>> Why not?
It wouldn't. But it's certainly not impossible the batteries ran flat at
the time you changed software.
BTW did you try running Windows in safe mode for a while to see if the same
thing happens?
>> keyboard.
> But *really* slowly
Oh yeah, sure. Having real keyboard shotcuts is faster when they're
there, but being able to do the thing at all is better than nothing...
>> this?
Ah. Interesting...
>>> Why not?
> at the time you changed software.
No, just really unlikely. ;-) Anyway, as I said, changing the batteries
was the first thing I did - until I noticed that the activity light is
still going, indicating the signal *is* being received.
> same thing happens?
No - but I could do...
Invisible nous apporta ses lumieres en ce 2008/01/14 06:51:
>> manager) or does Windows think it has gone?
New hardware, going from single core to dual core, new mother board drivers.
The environment of your mouse have changed dramaticaly. There may be some
conflict somewhere.
Even if you don't need almost all of the funtionality, try installing the latest
drivers, maybe using the personalised setup if there is one.
Last night my wife met me at the front door. She was wearing a Sexy negligee.
The only trouble was, she was coming home.
Rodney Dangerfield
Orchid XP v7 nous apporta ses lumieres en ce 2008/01/14 17:46:
What software did you change? Maybe the changed software is misbehaving, puting,
altering or removing some system hooks, and not preserving the correct ones.
I've seen that a LOT. Programs altering some thing, then restoring that thing to
what the developer *assumed* to be "universal" settings, but not the ones that
you need to have a workable configuration.
You know you've been raytracing too long when you read each of these quotes.
Mike Weber
news:478c7e3c$1@news.povray.org...
Ah. I got the impression that you had bought a new motherboard.
*imagines trying to navigate mouse with keyboard* *shudder*
Give me short cut keys any day
On Tue, 15 Jan 2008 18:18:40 +0200, "Gail Shaw" <initialsurname@sentech sa dot
IIRC it was part of the win 2.x or 3.x setup. Not everyone had a mouse in those
days.
I've just noticed that there is some junk DNA left.
Put a windows app in restore mode (not maximised) with the mouse click the
top-left most icon and select size. You can then resize the window with the
cursor keys. I can't remember how to access this menu with the keyboard.
Regards
Nope. Only new thing is the CPU. (Was 1-core, now 2-core.) Since I did
that, the existing drivers don't work reliably any more...
Much faster if specific keyboard shortcuts exist - but if they don't,
it's better than having to reboot the entire PC to get control back
[quitting POV-Ray in the process].
news:478ce1aa$1@news.povray.org...
Last time my mouse ran the batteries flat (and I didn't have charged spares)
I used the machine for the rest of the day with no mouse. It wasn't
difficult. There are enough shortcut keys built into windows to navigate
most apps (unless you're doing some photoshop or 3d modeller work)
On Tue, 15 Jan 2008 16:28:43 +0000, Stephen wrote:
> I
Alt+Space IIRC.
Jim
>> I
>Alt+Space IIRC.
>Jim
Right as usual
Regards
OK. I'll bite. Then why did you reinstall Windows?
> this?
I wouldn't be surprised if the "accessibility" features allow it.
It's not feature creep if you put it
at the end and adjust the release date.
I was hoping to - get this - improve stability...
>>> I
>>Alt+Space IIRC.
>>Jim
> Right as usual
Wow, and I didn't even have to boot Windows up. Of course, it helps that
the same keystroke does the same thing in GNOME. ;-)
Jim
Yeah, poor little rat is all lost in the new house... :(
I suggest the following:
- Upgrade your BIOS if you haven't already, most MoBo(MotherBoard)
manufacturers recommend you to do so when you upgrade from 1 to 2 or
from 2 to 4. This is not very important, but is recommendable to avoid
incompatibility issues and maybe to add small/big improvements to your
MoBo functionality.
- Check in the BIOS Setup a option for "USB Mouse Support" if it has one.
- Download new drivers or use the current ones, just don't configure all
the buttons or set them to do nothing and configure the 3 buttons you
use to work as you have now, but probably you wont have to do anything
as those 3 buttons defaults are good enough, except maybe the
middle/third one. I don't think it would be too hard to do.
- You said you put some new software, what software? new version
Windows? if so that maybe is the reason.
After many weeks of searching (!), I finally found a USB to PS/2 adaptor
and plugged my mouse back into the PS/2 port. So far it was worked
utterly flawlessly ever since. Go figure!
Hmmm.. I have the cheapie mouse that came with an IBM computer that has
a terrible time with it's optical sensor. Every once in a while the
cursor will jump a far distance from where I was for no good reason.
Never has happened on the various MS opticals I've used, but this one
does it repeatedly.
maybe this has something to do with it
http://www.neystadt.org/john/humor/IBM-Mouse-Balls.htm
lol, yeah that happened to me too: at my work I'm using a USB mouse that
didn't even move when connected to the USB port but with a USB --> PS2
adapter the things is alive and kicking. Looks like the USB interface of
the mouse is not working well enough for the USB port but enough to
"hand shake" with the PS2 interface. I really would like to know why
this happens.
I loved your: "So far it was worked utterly flawlessly ever since. Go
figure!" heheheh :D
If the adaptor is simple, there's virtually no electronics in it, and
what you really have is a mouse that will do either, with the signals
going over different pins.
> I really would like to know why this happens.
Check your BIOS for "legacy USB support" - that means to recognise mouse
and keyboard on USB ports. That's all I can think of offhand.
On what day did God create the body thetans?
hmm, I think may have very simple electronics since both are serial
ports and would explain why the flawlessness of the buggy USB mouse
interface. At least is what I think.
Already did Darren, i'm a PC tech so was the first thing to check :)
You never read the USB spec, did you? It's actually rather complex. :-)
That it's serial is like saying "SATA is serial" or "SONET is serial."
Cool. Heck, *I* didn't know what it meant six months ago. :-)
aren't they? maybe complexfor the very high speeds but AFAK they are
serial techs, similar to PCI-Express.
good for you :)
Saul Luizaga wrote:
>> :-) That it's serial is like saying "SATA is serial" or "SONET is
>> serial."
I don't know about PCI-Express, but I'm just saying the fact that
they're serial doesn't make them "simple". The USB spec is something
like 250 pages or so, and that's just for the basics shared by all USB
devices, like the ability to plug in, be recognised, and sync with the host.
(SONET is what telcos use to put voice and data over fiber, multiplexed.
It's not simple either. :)
>> serial."
USB has a whole communications protocol to go with it. Think about
TCP/IP and how complicated that is, and you get some idea of how much
work a typical USB device has to do in order to work. Sure, the
*physical* signalling is a simple serial bus, but if you want to *do*
anything with it... ;-)
*continues stalking Darren*
>>> serial."
And also think of the hundreds of protocols you can talk over TCP.
Well, yeah, beyond the basic USB spec, there's the Mass Storage Device
protocol (pendrives and external HD enclosures) and the Human Interface
Device protocol (keyboards and mice) and various printer and scanner
protocols (those tend to be proprietry) and...
For example, did you know that a USB device is supposed to "ask
permission" before drawing more than X amount of current? (Most USB mug
warmers disregard that part of the spec.) The idea being that if you
have a powered hub, it can warn the attached device "no, don't do that"
if the total load would be too great.
And that's something that *all* USB devices are supposed to do. Also,
you can plug USB hubs into USB hubs to create quite extensive tangles of
devices. And yet, the host has to be able to address each device
individually. So an addressing and routing problem exists. Not nearly as
severe as on the Internet (there is only 1 master and many slaves here,
which simplifies greatly), but it's still nontrivial to overcome. Each
USB device needs to end up with a unique ID so you can talk to it, and
all the intervening hubs need to know how to route traffic to it correctly.
USB is *way* more than "just a serial protocol"...
Yes, and that's about the *only* interesting fact I knew about it :)
Not even that, when you consider USB 2 and USB 1 over the same wires.
