Try staring cross-eyed at this image for a while...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#ABCD#ABCD#ABCD#ABCD#ABCD#BCDE#BCDE#BCDE#BDE#FBDE#FBDE#FBDE#FBDE#F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#6789#6789#6789#6789#6789#6789#6789#6789#6789#6789#6789#6789#6
http://blog.orphi.me.uk/
Very good. Transcendental, in fact. ;-)
10 points to Bill for telling me my work transcends the rational world...
The irrational world too.
I dunno what to say...
Just the other day I found a site that had a similar example ... When
did you discover this (or the program to create this?)
Nice, though I prefer looking at it cock-eyed ("parallel eyed") to make the
motive stand out rather than being sunken in.
Rune
http://runevision.com
I wrote the program that generates these just a few minutes before
posting. Usually I make them by hand, but today I couldn't be bothered,
so I threw something together in Haskell...
OK. It's quite easy for me to reverse the depth map, so maybe I'll post
another one soon...
Now try to somehow incorporate the actual transcendental sequence into it :)
Sam
"Orchid XP v7" wrote:
>> the motive stand out rather than being sunken in.
> another one soon...
Well, my point was that I liked it as it was, though I was using it a
different way than intended. :)
Rune
All I see is the easter bunny :(
...Ben Chambers
www.pacificwebguy.com
> it :)
I was going to make it out of the digits of Pi - but the digit sequence
repeats too much, which screws up the illusion. (Actually, virtually
every digit sequence I tried repeats too much. Hence the letters...)
I think I need a bigger font size (or a bigger monitor) for this one...
Actually, I find that after I've looked at these sort of images for a minute
or two, I cannot focus on anything for a few minutes - everything is blurred
unless I really strain to make it in focus.
I found that looking at the output in a DOS window, the writing was just
too tiny for the illusion to work. I had to set it to Lucida 24 or
something. (I have a 14" monitor. Which also has an absurdly high gamma
setting BTW...)
And lo on Wed, 09 Jan 2008 16:42:03 -0000, Invisible <voi### [at] dev null> did
spake, saying:
<shrugs> I can't get any of those types of things to work, it's all a
bunch of characters/dots/squiggles to me.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
> spake, saying:
I could never see anything on these. Both character-based and image-based.
Just for you, Rune:
KLMNOKLMNOKLMNOKLMNOKLMNOKLMNOPKLMNOPKLMNOPKLMNOPKLMNOPKLMNOPKMNOP
QRSTUQRSTUQRSTUQRSTUQRSTUQRSTVUQSTVUQSTVUQSTVUQSTVUQSTVUQSTVUQSTVU
WXYZaWXYZaWXYZaWXYZaWXYZaWXYZbaWYZbaWYZbaWYZbaWYZbaWYZbaWYZbaWYZba
cdefgcdefgcdefgcdefgcdefgcdehfgdehfgidehfgidehfgidehfgiehfgiehfgie
jklmnjklmnjklmnjklmnjklmnjklomnklomnpklmnpklmnpklmnpkqlnpkqlnpkqln
rstuvrstuvrstuvrstuvrstuvrswturswturxswurxswurxswurxswurxswurxswur
yz012yz012yz012yz012yz012yz301yz301y4z31y4z31y4z31y4z31y4z31y4z31y
56789567895678956789567895#6795#6795A#695A#695A#695A#695A#695A#695
BCDEFBCDEFBCDEFBCDEFBCDEFBGCDFBGCDFBHGCDFBHGCDFBHGCDBHGCDBHGCDBHGC
IJKLMIJKLMIJKLMIJKLMIJKLMNIJLMNIJLMNOILMNOILMNOILMPNOLMPNOLMPNOLMP
QRSTUQRSTUQRSTUQRSTUQRSTUVQRTUVQRTUVQRTUVQRTUVQRTUVWQRUVWQRUVWQRUV
XYZabXYZabXYZacbXYacbXYadcbYadcbYadcbYadcbYadcbYadcebYdcebYdcebYdc
fghijfghijfgkhifglkhfglkmhflkmhflkmhflkmhflkmhflkmhnflmhnflmhnflmh
opqrsopqrsoptqroputqopuvtqpuvtqpuvtqpuvtqpuvtqpuvtqwputqwputqwputq
xyz01xyz01x2yz1x2y3z12y43z2y43z2y43z52y3z52y3z52y36z5y36z5y36z5y36
789#A789#A7B89A7B89AC7B8AC7B8AC7B8AC7DB8AC7DB8AC7DB8C7DB8C7DB8C7DB
EFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIEFGHIE
JKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJKLMNJ
The idea is to simply look at the image cross-eyed, so you see double,
and make the repeats line up exactly.
The character-based ones are hard, because unless you have the right
size typeface, it's almost impossible to see. Also, you can only
generate fairly large steps in depth, which easily throws the illusion
off. FWIW, the algorithm for generating random dot images is identical
(but with colours instead of characters).
Try this:
PQRSTPQRSTPQRSPQRSUPQRSUPQRUPQRVUPQRVUPQRVUPQRVUPQRVUPQRVUPQRVUPQR
WXYZaWXYZaWXYZWXYZbWXYZbWXYbWXYcbWXYcbWXYcbWXYcbWXYcbWXYcbWXYcbWXY
defghdefghdefgdefgidefgidefidefjidefjidefjidefjidefjidefjidefjidef
klmnoklmnoklmnklmnpklmnpklmpklmqpklmqpklmqpklmqpklmqpklmqpklmqpklm
rstuvrstuvrstuvstuvwstuvwsuvwsxuvwsxuvwsxuvwsxuvwsxuvwsxuvwsxuvwsx
yz012yz012yz012y012y031y031y4031y4031y4031y4031y4031y4031y4031y403
56789567895678956795679567#9567#9567#9567#9567#9567#9567#9567#9567
ABCDEABCDEABCDEABCDEBCDEFBCDEFBCDEFBCDEFBCDEFBCDEFBCDEFBCDEFBCDEFB
GHIJKGHIJKGHIJKGHIJKHIJKLHIJKLHIJKLHIJKLHIJKLHIJKLHIJKLHIJKLHIJKLH
MNOPQMNOPQMNOPQMNOPQNOPQRNOPQRNOPQRNOPQRNOPQRNOPQRNOPQRNOPQRNOPQRN
STUVWSTUVWSTUVWSTUVWTUVWXTUVWXTUVWXTUVWXTUVWXTUVWXTUVWXTUVWXTUVWXT
YZabcYZabcYZabcYZabcZabcdZabcdZabcdZabcdZabcdZabcdZabcdZabcdZabcdZ
efghiefghiefghiefghifghijfghijfghijfghijfghijfghijfghijfghijfghijf
klmnoklmnoklmnoklmnolmnoplmnoplmnoplmnoplmnoplmnoplmnoplmnoplmnopl
qrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuqrstuq
vwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzvwxyzv
012340123401234012340123401234012340123401234012340123401234012340
The right half is completely blank, the left half contains a simple image.
If you cross your eyes, each little star at the bottom becomes a *pair*
of stars. If you move your eyes such that the stars appear to exactly
overlap, then you've either returned to normal focus, or you've unlocked
the image. (The hard part is moving to look at other bits of it without
going back into normal focus.)
Do this for long enough, and you will develop a nasty headache. ;-)
"Invisible" <voi### [at] dev null> wrote in message
news:47864740$1@news.povray.org...
> Just for you, Rune:
Nice motive. :)
I think you didn't get my point though. I preferred the previous image,
because when I looked at it the way I prefer (parallel-eyed rather than
cross-eyed) then the motive appeared as I preferred (bulging out rather than
being carved in). There were two reversals, which meant I liked it just the
way it was, even though I used it a different way than intended. :)
Rune
>> image-based.
If you have one eye that behaves differently to the other, you will
never see one. You can be e.g. shortsighted, as long as both eyes are
equally shortsighted! If both your eyes are the same, practice is all
that's required...
> never see one.
That reminds me of a lecturer we had at uni. One eye would look at you,
and the other eye would look 45° to the left of you. Very damn weird...
>>>> a bunch of characters/dots/squiggles to me.
>>> image-based.
> that's required...
Yep - never ever been able to see one.
I understand the principle, but again... never ever been able to see one.
Tom
>> it :)
3.141592653 3.141592653 3.141592653 3.141592653 3.141592653 3.1415926
5897932384625897932384625897932384625897932384625897932384625897932384
3.141592653 3.11592653 3.11592653 3.11592653 3.111592653 3.111592653
5897932384625879323846258793238462587932384625879332384625879332384625
3.141592653 .1141526533 .1141526533 .1415526533 .1415526533 .14155265
5897932384625897932846225897932846225879322846225879322846225879322846
3.141592653 3.141526533 3.141526533 31415526533 31415526533 314155265
3.141592653 3.141526533 3.141526533 3.415226533 3.415226533 3.4152265
5897932384625897933846225897933846225897338446225873338446225873338446
3.141592653 3.145926553 3.145926553 3.1492655533.11492655533.11492655
5897932384625897323846625897323846625897328466258997328466258997328466
Mike Raiford wrote:
Mmm... your ASCII art is better than mine...
Good one! The digits get quite confused, but I suppose it can't be
helped in a situation like this :)
Sam
