POV-Ray : Newsgroups : povray.off-topic : Error message Server Time
10 Apr 2026 02:29:48 EDT (-0400)
  Error message (Message 1 to 10 of 18)
Subject: Error message
Date: 4 Jan 2008 05:55:07
Message: <477e108b$1@news.povray.org>
OK, what is the purpose of an error message?
You *might* be tempted to say that it's meant to tell you that an error
has occurred. But actually, it's more than that. It's supposed to tell
you *what* error occurred! (Usually the fact that _something_ went wrong
is damn obvious.)
Take the following error message, for example:
PERC 4/SC Controller 0, Array Disk 0:1 Sense Key = 3, Sense Code = 11,
Sense Qualifier = 0. If this disk is part of a non-redundant virtual
disk, the data for this block cannot be recovered. The disk will require
replacement and data restore. If this disk is part of a redundant
virtual disk, the data in this block will be reallocated.
...WTF?
So... is my data gone or not? If it is, why is it gone? If it isn't,
what's the problem? (And if there isn't a problem, why are you giving me
an error message?)
Seriously - YOU'RE THE ARRAY CONTROLLER! You KNOW whether this is part
of a redundant virtual disk or not. Why can't you just show me only the
relevant parts of the error message??
Hmm. "The data in this block will be reallocated." What does that *mean*
anyway? Can you recover the data or not?
As you can see, this is a pretty useless error message. It basically
says "Event X has happened. If condition Y is true then this represents
an error, otherwise it doesn't." In other words, this error might not
even *be* an error. So it's failed purpose #1 - telling you an error has
occurred. It also utterly fails purpose #2 - WHY is any of this
happening in the first place? Presumably a block on the disk was
unreadable - but it doesn't SAY so anywhere.
Sadly, this kind of thing seems extremely common. Developers don't seem
to think it's important for people to know what an error condition
actually means or what the implications are.
Oh, did I mention? It's a Dell server.
http://blog.orphi.me.uk/
Subject: Re: Error message
Date: 4 Jan 2008 07:47:30
Message: <op.t4eohjwgc3xi7v@news.povray.org>
And lo on Fri, 04 Jan 2008 10:55:06 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> is damn obvious.)
No no no, the priorities are as follows
1) Tell the user an error has occured
2) Tell the user what the system/programme is going to do regarding said
error
3) Tell the user what the error actually is
4) Suggest a course of action that the user can take to solve it.
Trouble is everyone gets to around the second item then things get
complicated and they turn to something else. Hence error messages telling
you that msgscr32 has caused a fault in kernel32 at point 0000 FFFF... to
which every general user will respond, but I'm not running any programmes
called msgsvr32 or kernel are they viruses should I search for and delete
them?
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 4 Jan 2008 11:42:55
Message: <477e620f$1@news.povray.org>
> is damn obvious.)
My favourite is still the most classical Windows error message, which
says "Unexpected error".
-clip-
Actually, it's a perfect error message. It says that disk 0:1 is broken
and needs to be replaced. It also tells as misc information that if you
weren't running RAID, it's bye-bye -time.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 4 Jan 2008 14:58:02
Message: <477e8fca$1@news.povray.org>
This disk had a problem.
> Sense Key = 3, Sense Code = 11, Sense Qualifier = 0.
This is what you need to look up in the standard specs, or the
documentation for the disk, to see precisely the problem.
If this is your only copy, you're hosed.
> The disk will require replacement and data restore.
If so, go fix it.
If I already have a second copy, I'll make a second copy somewhere else
on the failing disk. But you should probably get a second disk ready to
replace the failing one.
Aren't you system admin? Don't you know how to tell if you have a
redundant disk? :-)
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 4 Jan 2008 16:07:17
Message: <477ea005@news.povray.org>
> If so, go fix it.
>> If this disk is part of a redundant virtual disk, the data in this
> redundant disk? :-)
More importantly, DOESN'T THE DISK CONTROLLER KNOW?? And if so, why is
it giving me two options? Why not just tell me the one that's applicable?
As it happens, I got this error while rebuilding a RAID-1 set. So...
does this mean the data was recovered or not?
Date: 4 Jan 2008 16:53:23
Message: <477eaad3$1@news.povray.org>
From 2-disk array, of which one disk has been changed, can fail either
disk with all data or disk with no data. It's up to which disk failed to
tell if the data has survived.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 4 Jan 2008 18:54:33
Message: <477ec739$1@news.povray.org>
Not necessarily. You've never heard of software raid?
I think it means you're screwed, since you didn't have a mirrored disk
(yet).
Date: 4 Jan 2008 19:18:50
Message: <477eccea$1@news.povray.org>
I would guess it means it succeded, but that one of the
platters has a physical scratch, it didn't know if data had
been lost, (but it wasn't, it was mirrored on the other HD),
and portions of the platter are now marked as scratched,
and won't be used. I'm not sure how long after getting
a scratch a HD will last... maybe a long time. It's worth an
error message to me.
Date: 5 Jan 2008 04:25:56
Message: <477f4d24@news.povray.org>
> (yet).
It can't be known by us (it could by Andrew). Let's say we have disk 0
and disk 1. Disk 1 dies and gets replaced by disk 2, so we'll have disks
0 and 2. Now we'll get the error message. IF the message comes for disk
0, we're screwed, if the messages comes for disk 2, we're not screwed,
but running on one disk again (and taking one hell of backups right away
- again, to stay at the latest point of data).
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 5 Jan 2008 06:18:09
Message: <477f6771$1@news.povray.org>
Yes. But this isn't. This is a hardware RAID solution, and the message
is from the software that talks to the RAID controller.
> (yet).
OK. Cool. Now... if there's a problem with the disk, why wasn't it
reported sooner? (Like, while there were still 2 working disks?)
