POV-Ray : Newsgroups : povray.off-topic : photos Server Time
20 Oct 2026 02:19:35 EDT (-0400)
  photos (Message 1 to 21 of 21)
Subject: photos
Date: 3 Jan 2008 20:00:03
Message: <477d8513$1@news.povray.org>
In a Windows environment,
say I have a bunch of photographs stored on directories...
suppose I want to store the photos and give them attributes such that
I could retreive subsets of them using different filters on those
attributes in a flexible, 'relational' way...
is there currently any solution | method | common practice for doing
this?
assume I know nothing
-Jim
Subject: Re: photos
Date: 3 Jan 2008 21:16:14
Message: <477d96ee$1@news.povray.org>
I have heard very good things about a product called "ThumbsPlus" a
while back. You might want to look into that. It was cheap enough for a
friend to buy it for me without me asking. (Never actually installed it,
tho.)
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: photos
Date: 3 Jan 2008 21:31:32
Message: <477d9a84$1@news.povray.org>
> this?
> -Jim
I'm about to write a database-based application for the family holiday
pics. Maybe even something web-based on the LAN so that my sister can
add the tags when she's bored.
Subject: Re: photos
Date: 3 Jan 2008 22:05:01
Message: <web.477da2082a9bcdbb29e441010@news.povray.org>
> this?
> -Jim
Is this something like what you're looking for?...
http://www.albumburger.com/en/index.asp
I hope it helps.
Best Regards,
Mike C.
Subject: Re: photos
Date: 3 Jan 2008 23:53:51
Message: <477dbbdf$1@news.povray.org>
I did one (a while ago) that stored the information in parallel ".info"
files, and from which you could generate a whole web site to put on a
CD. You're welcome to it, if you want. :-)
There's also "JAlbum", which is free and apparently stores the comments
in a ID3-like tag in the JPEG file directly.
Subject: Re: photos
Date: 4 Jan 2008 06:45:22
Message: <477e1c52$1@news.povray.org>
> tho.)
I use ThumbsPlus, but not for its database feature.  It's just not
practical when it only gets stored on a file local to a particular
computer and you have over 200,000 images to tag.  And while you can add
information in the file itself with Explorer or such, it does change the
filedate, making *that* information irrelevant (always interesting to
check out the earliest images in whatever subset of your collection).
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
Subject: Re: photos
Date: 4 Jan 2008 09:51:44
Message: <477e4800$1@news.povray.org>
>>this?
>>-Jim
> I hope it helps.
> Best Regards,
> Mike C.
Thanks but no, this is a pleasing little app. but too limited.
Specifically there is not a way to assign attributes other than the
categories the album provides, also only resolutions up to 1024 are
supported.  Probably I don't really know what I am looking for.  Better
would be some sort of ad hoc way to store attributes about an existing
directory and have that directory be retrievable as a hyper-link.  Not
sure if such a thing would be possible.
Subject: Re: photos
Date: 4 Jan 2008 10:12:22
Message: <477e4cd6$1@news.povray.org>
Not sure what you are saying but it sounds closer to my purpose.
Parallel .info files?
This looks promising
Subject: Re: photos
Date: 4 Jan 2008 10:13:16
Message: <477e4d0c@news.povray.org>
>> this?
>> -Jim
How would it work?
Subject: Re: photos
Date: 4 Jan 2008 10:13:43
Message: <477e4d27$1@news.povray.org>
I use Adobe Photoshop Album, where I can put tags on photos, and combine
different tags to filter them. It is easy and flexible. But it is not
free (and it seems Adobe is no longer selling it, but photoshop elements
only...).
Otherwise, is not google Picassa able to do what you need ?
Thibaut
> this?
> -Jim
Subject: Re: photos
Date: 4 Jan 2008 10:18:25
Message: <477e4e41$1@news.povray.org>
Well now, for about £8,000 you can buy a copy of the Oracle database
product. This enables you to store each image in a row of a big table,
and you can then cross-reference any kind of metadata you desire in the
usual relational-database mannar. For an extra few £100, you can get a
product that will enable you to build a HTML interface to query all this
data in a flexible way.
...I mean, if you're looking for the most OTT solution available, this
has got to be fairly close. ;-)
On a slightly *less* insane note, you could probably build some kind of
PHP thing where you submit photos, it gives each one a unique name, puts
it in a folder somewhere, and stores some metadata about it in a MySQL
database and gives you a web interface to query it. In fact, heck,
somebody has probably already made such a thing somewhere...
http://blog.orphi.me.uk/
Subject: Re: photos
Date: 4 Jan 2008 14:28:50
Message: <477e88f2$1@news.povray.org>
>>> holiday pics. Maybe even something web-based on the LAN so that my
>>> sister can add the tags when she's bored.
>> ".info" files, and from which you could generate a whole web site to
>> put on a CD. You're welcome to it, if you want. :-)
vacation/mexico/MomAndDad.jpg will have it's tagging information stored
in vacation/mexico/MomAndData.info
It's a bit clunky, but not too bad, and has the advantage that you can
go and reuse the information elsewhere, since it's a trivial format.
Plus, it has features like "keep this image, but don't include it in the
index pages" and so on.  Sorts by date and by name (IIRC), and things
like that.
Also used by a server I built that basically did what Flickr does, only
on a small scale. Lets you upload images, comment on them, etc.
Subject: Re: photos
Date: 4 Jan 2008 14:54:16
Message: <477e8ee8$1@news.povray.org>
> this?
> -Jim
google picasa is what I use to keep my photos...  but I don't know if it
is what youa re after.
Tom
Subject: Re: photos
Date: 4 Jan 2008 21:07:02
Message: <477ee646@news.povray.org>
Suppose I don't mind populating the MySQL database with the metadata
independent of the 'importing' or 'submitting' or 'photo acquiring'
process whatever it might be.  What pieces would be needed to query the
database and return path names as hyperlinks.  This would require PHP?
Subject: Re: photos
Date: 4 Jan 2008 21:11:58
Message: <477ee76e$1@news.povray.org>
> like that.
Sounds interesting.  I have been playing with Picasa and I think I will
use it for some things I want to do.  But I have other situations I am
not sure yet it could handle.  Like zipping and unzipping folders.  It
seems like once the folder goes away, so does the metadata.  I am
thinking there are was in which 'clunky' is better.
Subject: Re: photos
Date: 5 Jan 2008 00:14:43
Message: <477f1243$1@news.povray.org>
Jim Charter wrote:
> Sounds interesting.
http://s3.amazonaws.com/darren/PicEdit.zip
It's a 32K chunk of Tcl and a 700K chunk of jpeg handling binary
executable for Windows. If you have Tcl and TclLib installed, it should
just do its thing if you install the image extension.
I'm pretty sure it should work under Linux too.
You might have to futz with the source to configure some of the stuff.
Run the program without any arguments for help.
Subject: Re: photos
Date: 5 Jan 2008 06:20:03
Message: <477f67e3@news.povray.org>
Jim Charter wrote:
>> of PHP thing where you submit photos, it gives each one a unique name,
>> puts it in a folder somewhere, and stores some metadata about it in a
>> MySQL database and gives you a web interface to query it.
You could do that in a web-based way using essentially any server-side
scripting technique you like (PHP, ASP, Perl, Haskell CGI...)
Alternatively, MySQL might have tools that allow you to do this more
easily; I'm not aware of any, but I haven't looked for one either.
Subject: Re: photos
Date: 5 Jan 2008 06:47:26
Message: <477f6e4e$1@news.povray.org>
Yes. You also could push the images to the MySQL db, but is there any point?
Or, like Andrew said, any other server-side scripting language. Plus's
for PHP are that it's easy and that it has native support for talking
with MySQL. Minus for PHP is that it's also easy to create serious,
potential security holes.
Eero "Aero" Ahonen
   http://www.zbxt.net
Subject: Re: photos
Date: 5 Jan 2008 16:57:39
Message: <477ffd53$1@news.povray.org>
Darren New wrote:
> Jim Charter wrote:
>> Sounds interesting.
Thanks!  Off to install Tcl
Subject: Re: photos
Date: 5 Jan 2008 19:14:37
Message: <47801d6d@news.povray.org>
BTW, apparently Tcl 8.5.0.0 was *just* released by ActiveState. In
contrast to all earlier versions, this comes as a minimal install along
with an automated mechanism for accessing the Teapot (the Tcl equivalent
of CPAN).
You might want to start with 8.4.mumble from ActiveState, which includes
pretty much everything except the image extension.
Subject: Re: photos
Date: 5 Jan 2008 21:10:29
Message: <47803895$1@news.povray.org>
> of CPAN).
thanks for the heads-up, that's in fact what I did, some of the old
instincts still intact. ;)
