POV-Ray : Newsgroups : povray.off-topic : Another physical puzzle Server Time
20 Oct 2026 02:19:35 EDT (-0400)
  Another physical puzzle (Message 1 to 26 of 26)
Subject: Another physical puzzle
Date: 1 Jan 2008 19:13:32
Message: <477ad72c$1@news.povray.org>
You are sitting in a canoe, in a swimming pool, holding a cannon ball in
your lap. You throw the cannonball overboard, and it sinks to the
bottom. Does the level of water in the pool go up, go down, or stay the
same?
(I've asked this of probably a dozen or more scuba dive instructors, and
only one has gotten it right. The reasoning behind the correct answer is
obvious once you hear it. I don't remember if I got it right when I
heard it.)
     It's not feature creep if you put it
     at the end and adjust the release date.
Subject: Re: Another physical puzzle
Date: 1 Jan 2008 22:00:40
Message: <9ivln315r131mcentc5f1v0m6dnl3cpneq@4ax.com>
Is the canoe traveling near the speed of light?
Date: 1 Jan 2008 22:07:21
Message: <477affe9$1@news.povray.org>
I lol'd.
Date: 1 Jan 2008 23:33:29
Message: <477b1419@news.povray.org>
> same?
The water goes up (then down again) in a mostly parabolic manner since
the bowling ball would make a large splash :-)
I won't spoil the real answer for anyone still thinking about it, but
here's another fun physical puzzle that I remember:
If you've been on the beach, you've probably noticed that the sand dries
out around you foot when you step on it, why is this?  Wouldn't you
expect a small puddle of water to form around your foot instead?
Date: 1 Jan 2008 23:40:07
Message: <477b15a7@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:477ad72c$1@news.povray.org...
> same?
I believe it should stay the same.
Date: 2 Jan 2008 00:03:02
Message: <MPG.21e4c8ed2b1f3e4698a0d3@news.povray.org>
In article <477b1419@news.povray.org>, wampler+pov### [at] uwashingtonedu
says...
n
> > same?
It does get wetter, just *outside* the range of displacement from the
pressure you apply to the sand. And, if you stand there long enough that
the grains can rearrange to be less compacted, you *will* end up with
your puddle.
void main () {
  If Schrödingers_cat is alive or version > 98 {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 2 Jan 2008 02:41:57
Message: <477b4045@news.povray.org>
>> same?
Incorrect.  Hint - The cannon ball sinks to the bottom.  Think about
what was preventing it doing so before.
Date: 2 Jan 2008 03:36:59
Message: <477b4d2b$1@news.povray.org>
> your puddle.
Indeed, but that doesn't really explain why it dries out initially.
Contrast it with stepping in wet mud for example, or on a wet carpet.
(as far as I understand the phenomenon, by the way, I believe that your
explanation of why the puddle eventually forms is incorrect).
Date: 2 Jan 2008 03:47:37
Message: <477b4fa9@news.povray.org>
> same?
  A classic.
  The answer can be deduced by thinking about volume and weight.
  In the canoe the ball displaces an amount of water proportional to
the weight of the ball. In the water it displaces an amount proportional
to the volume of the ball.
  So the question is basically reduced to: Which is denser, the cannonball
or water?
Date: 2 Jan 2008 07:14:44
Message: <477b8034@news.povray.org>
> or water?
That's where I was headed. Does the cannonball displace more
water "underwater" than in the boat, and the difference being
volume*(DENSITYcannonball-DENSITYwater)/DENSITYwater?
Date: 2 Jan 2008 09:33:36
Message: <477ba0bf@news.povray.org>
  No, it displaces less when underwater because its volume is "less" than
its weight, when compared to the water.
Date: 2 Jan 2008 11:31:23
Message: <477bbc5b$1@news.povray.org>
Right. And you know that *because* it sinks.  The water level wouldn't
change if the thing you threw over floated.
Date: 2 Jan 2008 11:42:59
Message: <477bbf13$1@news.povray.org>
Darren New nous apporta ses lumieres en ce 2008/01/01 19:13:
> same?
> heard it.)
The level will go down.
When in your hand, you displace a volume of water that have the mass of the
cannonball. When you drop it, the displace a volume of water egual to it's own
volume. The cannonball have a higher density than the water as it sink.
You know you've been raytracing too long when you wonder if ground fog or
athmosphere will look better for your company's market share pie chart.
Christoph Rieder
Date: 2 Jan 2008 12:35:00
Message: <web.477bcab13e72ddaf40d56c170@news.povray.org>
Rethinking.
Using symbols:
Ph20= density of water
Pfe= density of cannonball
Mball= mass of canonball
IN CANOE:
displacement = Mball /(Ph2o)
UNDERWATER:
displacement = Mball / (Pfe)
But I'm not even sure if that's completely right now.
Date: 2 Jan 2008 13:08:37
Message: <toknn3tcapecfo23qsmgj54ot9dfbmk2se@4ax.com>
In the boat the cannonball displaces its own mass of water. In the water the
cannonball displaces its own volume of water.
Do I need to go on? :)
Regards
Date: 2 Jan 2008 15:55:59
Message: <477bfa5f@news.povray.org>
gregjohn <pte### [at] yahoocom> wrote:
> IN CANOE:
  No. In the canoe the ball displaces an amount of water equal to the
weight of the ball.
> UNDERWATER:
  In the water the ball displaces an amount of water equal to the
volume of the ball.
  The amount of water which weights the same as the ball is larger than
the amount of water which has the same volume as the ball.
Date: 2 Jan 2008 19:05:00
Message: <web.477c262e3e72ddaf34d207310@news.povray.org>
> > IN CANOE:
> weight of the ball.
That's what I said, only more precisely.
Date: 2 Jan 2008 20:50:29
Message: <477c3f65@news.povray.org>
> same?
> heard it.)
It goes down as measured against the edge of the pool.  While in the
canoe, the cannonball displaces its mass in water, but in the water it
displaces only its volume.  Since the cannonball is denser than water,
it displaces more while in the canoe than in the water.  Since there is
less displaced water, the water level of the pool goes down.
John
Date: 3 Jan 2008 15:38:18
Message: <MPG.21e6f57f5d0ce9a698a0d6@news.povray.org>
In article <477b4045@news.povray.org>, pgf### [at] optusnetcomau says...
in
e
> >> same?
Umm. I don't see how that would be incorrect. While in the boat the
*boat's* hull has to displace an amount of water sufficient to account
for the added weight of the ball... Ok, you have a point. The
displacement from the ball is going to be different "in" the boat than
in the water, since one depends on the *weight* being shifted, while the
other depends entirely on the *size* of the object. The question then
is, will the displacement of the boat, from the cannon balls weight, be
larger or smaller than the displacement of the cannon ball itself?
Without knowing the size of the boat, the actual weight of the ball, and
thus what the displacement will be from that, its not possible to
project if the water will be "more" or "less" displaced by the inclusion
of an entire cannon ball in the pool, versus a few millimeters of boat
sinking slightly more into the water from the weight.
I.e., insufficient information to make a ruling.
void main () {
  else
Date: 3 Jan 2008 15:47:21
Message: <477d49d8@news.povray.org>
  The size of the boat nor the weight of the ball make any difference on
the original question: The original question didn't ask how much the water
level changes, it only asks if the water raises or lowers. To answer this
question the only information needed is whether the cannonball has higher
density than water or not. Since cannonballs are made of metal, the answer
is yes. Thus its weight displaces more water than its volume, and thus
the answer is that the water level lowers.
Date: 3 Jan 2008 15:56:48
Message: <MPG.21e6f9fd603c5b6098a0d7@news.povray.org>
In article <477d49d8@news.povray.org>, war### [at] tagpovrayorg says...
d
n
r
r
Yeah. Read that later. Its not like I a) spend a lot of time thinking
about these sorts of problems, or b) took physics in high school. Took a
second English course, where I got to read all Sci-Fi stuff instead, so
I still count as a nerd. ;) lol
void main () {
  else
Date: 3 Jan 2008 20:13:25
Message: <477d8835$1@news.povray.org>
Here's the solution as I recall it:
The sand on the beach is actually in a more or less maximally compressed
state before you step on it.  When you step on the sand, you compress it
downward slightly, and to allow for this the sand under your foot
expands outward somewhat.  Since the sand was about as dense as it could
get at the beginning the end result of this downward compression and
lateral expansion is that small gaps open up between the grains and the
sand underneath your foot and its density actually *decreases*.  The
water that was in that sand thus doesn't fill the whole empty volume
anymore and drops to below the surface of the sand, causing the top of
the sand to dry.
Date: 3 Jan 2008 21:06:06
Message: <477d948e$1@news.povray.org>
The cannonball sinks. That's why I included that part. :-)
(I used to say "bowling ball", until someone pointed out that most
bowling balls actually float.)
Date: 5 Jan 2008 13:00:44
Message: <477fc5cc@news.povray.org>
> ball in your lap. You throw the cannonball overboard, and it
> sinks to the bottom. Does the level of water in the pool go up,
> go down, or stay the same?
> instructors, and only one has gotten it right. The reasoning
> behind the correct answer is obvious once you hear it. I don't
> remember if I got it right when I heard it.)
>   Darren New / San Diego, CA, USA (PST)
Well that's interesting:
If one cannon ball level imperceptibly lowers;
If MANY cannon balls the swiiming pool will
fill tis cavity and eventually overflow;
Graphing the water level versus number of
cannon balls does not result in a linear
image.
Bonus points:
1. How many cannon balls before dip becomes rise?
(assume  CB V= .001 swimming pools and
CB density equals 7.87 g/mL)
2. What is the type name of such curves?
3. What kind of person would assume a swimming
pool could be *drained* by dropping cannon balls
into it?
Date: 5 Jan 2008 13:28:01
Message: <477fcc31@news.povray.org>
  That can't happen in the problem because the canoe cannot stay afloat
with all those cannonballs.
Date: 7 Jan 2008 00:18:23
Message: <4781b61f$1@news.povray.org>
> image.
> Bonus points:
> into it?
1: If all the cannon balls are in the canoe to start with, then I don't
even see the canoe staying afloat.
2: Given 1, I would assume this is the 'magic canoe' type of curve. =)
3: The pool could not be completely drained by dropping equal sized
cannon balls into it. If the balls fall in a random close packing form,
the best you could get is about 65% of the volume of water out of the pool.
