POV-Ray : Newsgroups : povray.off-topic : A random interjection: the Halting Problem Server Time
10 Apr 2026 02:30:15 EDT (-0400)
  A random interjection: the Halting Problem (Message 1 to 10 of 17)
Subject: A random interjection: the Halting Problem
Date: 29 Dec 2007 12:18:35
Message: <4776816b$1@news.povray.org>
The Halting Problem states, loosely, that there is no algorithm that can
take an arbitrary computer program and decide [in finite time] whether
that program will run forever or come to a half after a finite time.
The HP does *not* say that it's impossible to tell whether a program
halts. It is quite possible to tell that certain programs do in fact
halt. And it is also quite possible to tell that others are never going
to halt. The HP says that it is impossible to tell FOR EVERY POSSIBLE
PROGRAM. Big difference.
To illustrate, consider the following program:
Let A = 0.2499
Let B = 0.01
Let X = 0
Let Y = 0
While (X*X + Y*Y < 4.0)
   T = X*X - Y*Y + A
   Y = 2*X*Y + B
   X = T
Halt
Does this halt? Or does it run forever?
You know what? If you change the first two lines, you change how long
the program runs for. For some choices of A and B, the program stops
instantly. For others, it runs for hours or even days and then stops.
And for yet others, it runs provably FOREVER.
You might think that some simple mathematical structure describes the
set of points for which the program does or doesn't stop. You might even
try to graph this set of points to try to work out its structure.
Fortunately, you needn't bother. Somebody has already done it for you:
http://tinyurl.com/2ca4o9
Think you can decide whether an arbitrary point on the screen is black
or white in finite time? If you do, I imagine there are people who would
be seriously interested to hear from you... ;-)
For each point on the screen, there is essentially a program - the
program that determines the level set to which that point belongs. To
repeat what I said above: for many points, it is *easy* to determine
whether the program will halt. The HP doesn't say otherwise. What it
says is that you cannot tell for *every* point. And, indeed, looking at
the image, you can quickly see that whether you run the program directly
or try to do some tricky geometric stuff, with a boundary this
complicated, it's going to take a hell of a long time in some cases.
And, by extension, some cases will unavoidably take an infinite amount
of time...
http://blog.orphi.me.uk/
Subject: Re: A random interjection: the Halting Problem
Date: 29 Dec 2007 13:42:17
Message: <47769509@news.povray.org>
  All complexity class definitions talk about the generic case, not if
there exists at least one case for which the complexity bound does not hold.
  For example, sorting elements using only comparisons between pairs of
elements cannot be done faster than in n*log n steps.
  Of course that means that it's not possible to create an algorithm
which sorts, using comparison only, all possible inputs faster than that.
It doesn't mean there doesn't exist any input which could not be sorted
faster than that using comparisons (an already sorted input is the simplest
case, which can be "sorted" with a linear amount of steps).
  The halting problem belongs to the worst possible complexity class: The
one of unsolvable problems. Of course that doesn't mean there exist no
inputs for which it is solvable. It means that there exist inputs for
which it's not.
Date: 29 Dec 2007 15:01:00
Message: <4776a77c@news.povray.org>
> which it's not.
That's an interesting way of putting it. I'll have to remember that one...
There seems to be a general misunderstanding that the halting problem
says it's impossible to determine the output for any program at all.
Obviously, this is not the case. Similarly, there seems to be a
misunderstanding that it's "impossible" to solve a 5th order polynomial
algebraicly. It's not. ;-)
Date: 29 Dec 2007 15:17:18
Message: <4776ab4e@news.povray.org>
  I wouldn't say you constitute what is referred to with "general". ;)
Date: 29 Dec 2007 19:00:19
Message: <4776df93$1@news.povray.org>
Which has the implication that computers will never be capable of
handling the process of software engineering without some level of human
assistance.
John
Date: 29 Dec 2007 19:30:14
Message: <4776E69F.5000406@hotmail.com>
John VanSickle wrote:
>> can take an arbitrary computer program and decide [in finite time]
>> whether that program will run forever or come to a half after a finite
>> time.
> assistance.
You might as well claim that it means that no human can either.
Date: 29 Dec 2007 23:23:45
Message: <47771d51@news.povray.org>
> that program will run forever or come to a half after a finite time....
After a significant degree of staring at this, I have reached the
conclusion that the arrow can never be more than halfway there from
here...  http://en.wikipedia.org/wiki/Arrow_of_time  ...
--Sherry Shaw
#macro T(E,N)sphere{x,.4rotate z*E*60translate y*N pigment{wrinkles scale
.3}finish{ambient 1}}#end#local I=0;#while(I<5)T(I,1)T(1-I,-1)#local I=I+
1;#end camera{location-5*z}plane{z,37 pigment{granite color_map{[.7rgb 0]
[1rgb 1]}}finish{ambient 2}}//                                   TenMoons
Date: 30 Dec 2007 03:52:10
Message: <47775c3a@news.povray.org>
> assistance.
  Humans are bound to the same limitations as computers. If it has been
proven that a certain problem is not solvable, a human cannot solve it
either.
Date: 30 Dec 2007 06:03:04
Message: <47777AF1.6090802@hotmail.com>
>> assistance.
> either.
See, sometimes we do agree ;)
Date: 30 Dec 2007 10:47:19
Message: <4777bd87$1@news.povray.org>
> either.
Curiosly, they just happen to be having this exact debate on one of the
Haskell mailing lists right now. (Evidently some people actually believe
that the human mind is capable of deductions that are beyond
Turing-completeness. Naturally, they offer no basis for this belief
beyond the fact that computers don't program themselves yet...)
