In article <476f74a7$1@news.povray.org>, ben### [at] pacificwebguy com says...
> The longest part of actually burning the CD is writing a message in
> P.O-T while I wait for it. Usually, the CD is done burning before I'm
> done typing :)
Until/unless you get one like mine. Went from 98 -> XP, and it just
stopped working. Same setup, same positions on the cable, same jumpers,
and it worked fine to install. Got a new one. Same fracking problem.
Detected, installed, insists its a CD, won't show anything but directory
names on the disk (no matter which type of disk), and won't autoplay...
Know what the problem was? The old 52x CD drive was set up as the
"slave" to it, and for some reason in that configuration the damn CD
drive would work, but the DVD drive wouldn't. Switched the 52x CD to
master and the **new** drive to slave, now it works...
I mean, how the $@#$#@$#@ stupid is that, and why are we still using
1980s drive cable systems in a machine that can use PnP USB devices,
which almost never have this fracking problem? lol
But yeah, when they work right, they are gold. ;)
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Do the master / slave jumpers still have an effect when you use the SATA
cables?
...Ben Chambers
www.pacificwebguy.com
Chambers nous apporta ses lumieres en ce 2007/12/25 13:50:
> cables?
SATA don't have master/slave as there is only one device per cable.
ATA can have 2 devices connected, some use jumpers, some are "hard whired" as
master and others have what's called "cable cellect" where the slave / master
status depends on what connector is used.
I'm interested in the fact that the less secure a man is, the more likely he is
to have extreme prejudice. (Clint Eastwood)
In article <4773c668$1@news.povray.org>, Tom Austin <taustin> says...
> BSG fan?
> Tom
Yeah. But I just like the fact that you can say f*** and the language
police don't know it. Same with Frelling. lol
void main () {
else
