Does anybody here know anything about ODBC?
http://blog.orphi.me.uk/
run away run away
"Invisible" <voi### [at] dev null> wrote in message
news:47612e2b$1@news.povray.org...
Open Database Connectivity.
A standard API for connecting to various forms of data sources. Generally
slower than OleDB, but easier to find drivers for more esoteric systems.
Was there anything specific you wanted to know?
There appear to be ODBC drivers for accessing CSV files and so forth.
So does that mean I can perform arbitrary SQL queries on a CSV file?
Tom Austin wrote:
> run away run away
So-noted.
I know a bit. There are probably others here who know more. A more specific
context would probably be helpful. Are you looking to learn more about the
subject in general? Is there a specific problem you need to solve?
A reasonably short and to the point intro can be found here:
http://www.unixodbc.org/doc/ProgrammerManual/Tutorial/
Best Regards,
Mike C.
news:476132a3$1@news.povray.org...
Yup. Excel spreadsheets, xml files, assorted databases, active directory,
etc...
Probably. How complex a statement depends on the capabilities of the driver
in question. If it has a manula/help file, read it.
> etc...
...right. So you're saying the type of queries I can do can vary by ODBC
driver?
I guess I was assuming that an ODBC driver is like a graphics driver -
either you have graphics or you don't. (Oh, and some of the more exotic
features might not be available, like 3D acceleration or hardware overlays.)
Basically I want to develop a program that talks to a database. I was
going to use ODBC to do this. But I don't have a database set up right
now, so I was wondering if I could test it with a simple text file until
I get round to setting up a real database. [Obviously a CSV file isn't
going to even approach the speed of a half decent database engine. But I
can test whether data goes in and data comes out.]
Alternatively, does anybody know how to configure PostgreSQL? Because I
can't get the damn thing to work properly...
"Invisible" <voi### [at] dev null> a écrit dans le message de news:
47614210$1@news.povray.org...
> now, so I was wondering if I could test it with a simple text file until I
> get round to setting up a real database. [Obviously a CSV file isn't going
> to even approach the speed of a half decent database engine. But I can
You can do some limited database work with text files (or Excel files etc.),
but that will mostly be limited to actions that can be done without
requiring indexes, i.e. SELECT and INSERT statements rather than UPDATE and
DELETE for instance. For testing a database, you'll need a database. MS
Access will do, and MySQL takes a couple of minutes to install on a PC.
G.
PostreSQL also takes a couple of minutes to set up. Unforuntately, I
can't make it do anything once it's installed.
MySQL isn't transactional = I'm not really interested.
Maybe I'll just use M$ Access. [Obviously that means I can only use
computers which have M$ Access.]
It is if you use InnoDB engine tables. Note, it's about five times
slower, but it's transactional.
It's not feature creep if you put it
at the end and adjust the release date.
Last I heard, it's transactional yet still not 100% ACID-compliant.
news:47615af1$1@news.povray.org...
No, you just need the access ODBC driver (which comes with the standad MDAC
package) You'll need a copy of access to create the database, you don't to
access the file over ODBC (or OleDB).
Not sure about the licencing implications, but I'm guessing you aren't too
concerned about that either.
Other option you can try is to download SQL Server Express. It's limited in
size of DBs it can handle, but is fine for testing.
If you download the management studio pack as well, you get a nice GUI
frontend for it. Otherwise you'll have to access it through command line
Hmm, interesting.
So you're only paying for the GUI frontend, but the database engine? (If
indeed it warrents the term "engine"...)
Or, alternatively, you can apparently download the full version of
Oracle for free - provided you promise to never ever use it "for real",
only "for test purposes". Apparently. And I already know how to work
Oracle...
But yes, Access would probably be much simpler just for test purposes.
news:476160fb@news.povray.org...
in
> Oracle...
You can get a full version of SQL server for $50, feature equivalent to
Enterprise edition, just not licenced for production usage. Only really
worthwhile for people who work with SQL a lot.
I know there's a free version of Oracle, wasn't aware it was all the
features of the top version..
SQL Express is a restricted feature set, but it can be used anywhere,
including on production systems, free.
Yeah. I was surprised too. But, apparently, when you "buy" Oracle they
send you a "media kit" that contains all the products, but only license
you to install the one you paid for. Hmm, I wonder how they can tell?
I plan to use PostgreSQL for the final thing, or maybe Oracle, but right
now I just wanna test. ;-)
Well, no, but it's transactional. The A and I and D parts, I think. I'm
not sure whether it has support for the C part, since it insists on
having defaults for every data type, so things like declaring a column
"not null" and not providing a value isn't an error.
I'll note that the features that are restricted are performance
features, not SQL features as such. E.g., it'll only process one request
at a time, only run on one core, won't do hot backups, stuff like that.
But in theory anything you write on "real" SQL Server will run without
change on SQL Express, as long as timing isn't an issue.
I used SQL Express in one project I did where other things (wireless
bandwidth, primarily) kept us down to a couple of transactions a second,
and it worked fine.
What is it, you are trying to do? In English please, not feature babble.
"Transactional" is a very basic functionallity for any product claiming
to be a "database".
Basically it's very difficult to design a system such that multiple
users can access the data at once, and yet not screw it up. This hard
problem is one of the many things a database is supposed to solve. So a
database that fails to solve this problem doesn't really interest me
very much.
47626794@news.povray.org...
> "Transactional" is a very basic functionallity for any product claiming to
> be a "database".
Actually it really depends on the purpose of the database. Read-only
databases that get updated twice a year or single-user databases may not
require transactional abilities at all.
G.
>> be a "database".
Ultimately, I guess it depends on your definition of "database".
Under certain definitions, a CSV file is a database. There are people
who develop "in-memory databases", yet under some definitions there's no
such thing. (Since some definitions require "recoverable" and "robust".)
For the thing I'm trying to do, transactional (and recoverable, etc) is
very important. If I was trying to catelog my CD collection, MySQL would
probably be quite a good fit...
Invisible wrote:
> "Transactional" is a ..
BABBLE, BABBLE
WHAT are you trying to do? It's a very simple question.
Tom Galvin wrote:
> BABBLE, BABBLE
I'm going to build [yet another] helpdesk application.
Yes. :-)
Jim
> very important.
I think your info about mysql is out of date.
Invisible wrote:
> Tom Galvin wrote:
>> BABBLE, BABBLE
Then mysql is more than adequate to the task.
Why not use a helpdesk that already exists, uses mysql, is available
under the gpl, and is cross platform.
http://www.oneorzero.com/
Darren New wrote:
>> is very important.
Well, last I checked, MySQL is a "toy database" on a par with Access.
(Do they even support nested SELECT statements yet?) There's nothing
"wrong" with that, it's just not the type of product I'm looking for.
I disagree.
I'll take a look. It's probably too complicated though. (Needs to be
something a 4 year old can play with and not break.)
"Orchid XP v7" <voi### [at] dev null> wrote in message
news:4763b9d9$1@news.povray.org...
Something that looks like the image here?
http://www.jupiterimages.com/popup2.aspx?navigationSubType=itemdetails&itemID=22191158
;oD
-Nekar Xenos-
> I disagree.
Why is it not? What features do you need that the latest MySQL doesn't
support?
> ;oD
LOL! Might be a bit beyond their mental capacity... ;-)
>> I disagree.
> support?
I'm sure MySQL is great if you just want to catelogue your CD
collection. But if you're going to have multiple people access it at
once, you need transactions or you'll end up with a data integrity
nightmare.
(In this instance, it also needs to be possible to back up the database
without shuting it down. And to recover if there's a crash. And all
those other kinds of things.)
news:4763b965$1@news.povray.org...
> Darren New wrote:
> >> is very important.
MySQL is a database service, unlike access. It supports multiple users
without the data files becoming corrupt every second day.
Access data files don't require anything applications installed to use them,
so they're very handy for data storage in single-user desktop applications
As of MySQL 4.1. Two versions before present
news:4763c335$1@news.povray.org...
> nightmare.
OK, now I'm sure you're having us all on.
Where on earth did you get the idea that mySQL can't handle multiple
concurrent users?
http://dev.mysql.com/doc/refman/5.0/en/transactional-commands.html
http://dev.mysql.com/doc/refman/5.0/en/innodb-transaction-model.html
And note that's version 5.0. Latest is 6.0
http://dev.mysql.com/doc/refman/5.0/en/backup.html
http://dev.mysql.com/doc/refman/5.0/en/backup-strategy-example.html
http://dev.mysql.com/doc/refman/5.0/en/point-in-time-recovery.html
http://dev.mysql.com/doc/refman/5.0/en/table-maintenance.html
Tell, me. Did you do any research on mySQL before making these claims?
On Sat, 15 Dec 2007 14:31:24 +0200, "Gail Shaw" <initialsurname@sentech sa dot
Does Andrew ever research anything before asking?
Remember p.o.t. is your friend :)
Regards
I heard that MySQL is this cool free database that's taking over the
world. The KNOPPIX CDs contain it, so I thought I'd sit down and have a
play.
I was expecting great things. Maybe too great. What I actually found is
that by default "commit" and "rollback" are no-op, and transaction
handling is an "optional feature" that you have to explicitly enable.
I decided that any database that considers something so fundamentally
important to be "optional" is obviously not a very serious effort. Then
I looked at the release notes and it says "yay! we now support unions",
and I'm like "my God - you're kidding, right?"
At that point, I lost interest.
> Darren New wrote:
>>> etc) is very important.
> Access. (Do they even support nested SELECT statements yet?)
> There's nothing "wrong" with that, it's just not the type of
AAARGH !!
As I said, your info is out of date. You're about four major releases
behind. Now they have distributed clusters and everything. Kind of
"start simple and work up to something worth using."
It still has annoying features, but "toy" it isn't.
> nightmare.
Damn you're dense. :-) Really. MySql does all that sort of stuff.
Indeed, I have a process that monitors the hot spare every 30 seconds
and tells me if it gets more than 60 seconds behind the live master. My
read-only heavy queries run against the hot spare instead of the live
read/write database. I'm doing financial transactions that need to audit.
Really. Your information is at least 5 years out of date. You're
complaining that you just wish Windows supported true multitasking.
Honestly, of the 30 or so tables currently in my application, there's
about 5 that need transactional consistency. I don't need it in the
debugging logs. I don't need it in the (equivalent of) web access logs.
I don't need it in the tables that's collecting the real-time feeds off
the various partners, nor off the custom hardware. Those are all
append-only (for the most part) tables.
But where I need it, I turn it on, and take the penalty of speed over
correctness. Enforcing transactions is high overhead if you don't need
it. If all your table write-accesses are to a single row, why would you
want to lock things?
Well, my application will probably only be about 5 tables, and it's
simple enough that speed is unlikely to be a problem. So why make things
more difficult than necessary?
Why do you need to lock things to enforce transactional integrity?
Locking is only one (suboptimal) way to solve the problem.
Then use the innodb table type, and be happy.
The RDBMS locks things to enforce transactional integrity. I don't do it
explicitly. I merely start a transaction, and the appropriate rows get
locked.
Whatever you do to enforce transactional integrity? It takes resources.
>> things more difficult than necessary?
It just worries me that the designers of this system fundamentally think
that transaction integrity is so unimportant that it's not even the
default, that's all.
> locked.
That's only one way of implementing transactional integrity. (And, IMO,
not a very good way.)
Now that at least is a valid statement.
"Orchid XP v7" <voi### [at] dev null> a écrit dans le message de news:
47642e2a$1@news.povray.org...
It's not the default because it's not needed in many database applications.
Frankly, it looks like you just discovered the word "database" yesterday,
fell in love with a couple of buzzwords even though you still have strictly
no idea about what a database it and how it works (this thread started about
*** CSV files *** being used for testing your database). Sorry mate, but you
can't spout utter nonsense about MySQL and Access being "toys" and be taken
seriously after that. Get some experience first.
G.
> play.
There is a difference between stating that a program can not do
something and asking the p.o-t for their opinion and experience. In
practice the result here is the same, mainly because there are a lot of
friendly people here that have com to know you over the years. IRL your
mileage may vary. One of the main differences IRL is that the former
tends shuts down all communication, while the latter invites the other
to participate in an exchange of ideas.
He does program in Haskell.
You forgot reinventing the wheel.
He's writing a helpdesk! That's IT 101.
If it's for fun, that's one thing. If it's to meet a business need,
then put in one that has been tested, debugged and gained a little
maturity. Your users will thank you, and the person who takes the job
after you will be deligheted not to inherit a undocumented
haskell/oracle monster.
> I disagree.
Hmmm who should I listen to? Gail the professional DBA, who is flown all
over the world for database technology conferences, with many years of
experience, or Andrew? Sorry mate.
Glad you are so openminded.
Here's another one that runs on Active Server Pages with an MS Access
Database or MS SQL backend.
http://www.liberum.org/
It's been running at major companies for years with great reliability
and users love it. Some people even modified it to use mysql.
Know something? The default is also to commit after every statement on
most DBs too. So? :-)
Yes, MySql *started out* tremendously simplified. But it's like you're
complaining about how DOS looses disk clusters if you don't close the
file properly, while evaluating XP.
Actually, I think there are a number of ways to do it, depending on the
table. You can even use explicit locks to enforce at least the I of ACID
on the non-transactional tables.
Yah. In my experience, it's about a 5:1 ratio. When I realized that, I
changed most of my tables to non-transactional. There's nothing I'm
running on the tables that isn't idempotent.
