Well anyway, today I *finally* got my Excel spreadsheet working again!
It stopped working when I upgraded from Office 97 to Office 2003.
Specifically, my VBA macro was disabled. (Damn it, I spent *hours*
writing that thing! I *want* it to work!!)
Apparently it's disabled as a security measure. You'd *think* there
would be a button you could just press to say that *this* macro is OK to
run. (That's what Office 97 had.) But no, apparently that would be too easy.
Google did at least manage to find me a relevant article without much ado.
http://msdn2.microsoft.com/en-us/library/aa141471(office.10).aspx
It turns out that the correct process for enabling a macro that you
wrote to run on your own PC is as follows:
1. Find the product installation CD.
2. Install the certificate tools.
(By default they install VBA but not the tools apparently necessary to
actually enable it to run. But then, have you *seen* VBA? I guess the
assumption that you won't want to use it is fairly safe...)
3. Nagivate several system folders. (You know, the ones where Windows
Explorer insists "This is dangerous. We have hidden it for your own
safety. Do you *really* want to touch this stuff? We warned you!")
4. Run the certificate creation tool. This creates a self-signed
certificate which you cannot export or back up. (Yay!)
5. Open the spreadsheet.
6. Open the VB Editor.
7. Find the right menu item.
8. Select the certificate you just created and add the signature.
9. Save the spreadsheet.
10. Close the spreadsheet.
11. Reopen the spreadsheet.
(The instructions fail to mention that the code being signed doesn't
help you until the *next* time you open the thing...)
I wonder - how do you develop new code if it's always disabled until you
sign it? (And - one hopes - every time you change it this invalidates
the signature...)
All this fuss just so I can click a button to put today's date in a cell
on the spreadsheet... sheesh!
Or you could just have gone to Options -> Security and turned down Macro
security to Medium, then at least you get the old style "do you want to run
this or not" box for unsigned macros...
And lo on Thu, 06 Dec 2007 10:41:58 -0000, Invisible <voi### [at] dev null> did
spake, saying:
> easy.
As Scott said you just turn down the security options from "I'm an idiot
protect me" to "I'm a grown-up let me make my own decisions"
> ado.
or you could have checked your posts as I've told you how to do this twice
now :-)
or run a search for selfcert.exe
Um you mean except when you go to sign it, view details and pick "Copy to
file"?
Tools|Digital Signature.. at least on 2k, hardly surprising.
Well yeah by default the macros are disabled so you need to reopen it for
the signature to be taken into account then it should say signed by blah
trust this certificate and that's it.
> the signature...)
It gets re-signed if the certificate that originally signed it is present,
so someone else souldn't re-sign the code and distribute it unless they
were using your computer/login, besides you should lock the project for
viewing anyway.
But all that hassle was a one-off you've now got a certificate to sign
anything VBA with.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Well I pretty much assumed it would be an on/off settings, and even I am
not too keen on turning the security off completely.
>> ado.
> twice now :-)
I followed the instructions you gave me for Office 97 and they didn't
work. (I forget where exactly it fails.) The instructions I found here
actually worked.
Actually I used a command prompt, but hey.
> to file"?
I did follow the instructions for backing up the certificate, but
apparently "the private key is marked as not exportable and cannot be
saved". So you can save the certificate itself, just not the key. Very
helpful.
It's easy once you figure out it's under Tools, yes.
>> you sign it? (And - one hopes - every time you change it this
>> invalidates the signature...)
> present, so someone else souldn't re-sign the code and distribute it
> unless they were using your computer/login, besides you should lock the
> project for viewing anyway.
Interesting. So if you change something when you didn't mean to, it
updates the signature? Oh dear...
>> cell on the spreadsheet... sheesh!
> anything VBA with.
Until the next time I reinstall Windoze...
PS. Does OpenOffice provide a scripting language?
Several of them, it seems:
http://framework.openoffice.org/scripting/index.html
I never used that, though...
Vincent
"OpenOffice Basic"? Oh, that's original...
And lo on Thu, 06 Dec 2007 12:23:41 -0000, Invisible <voi### [at] dev null> did
spake, saying:
>> idiot protect me" to "I'm a grown-up let me make my own decisions"
No amazingly they did add an adult option alongside the absolutes.
>>> ado.
>> twice now :-)
> actually worked.
Hmm okay.
>> to file"?
> helpful.
Try makecert instead.
or read the article you linked to :-)
Phil Cook
>> actually worked.
> Hmm okay.
Well, to be honest it's getting quite hard to find information about
Office 97. Hopefully Office 2003 will be an easier proposition...
>> helpful.
It's not there.
And lo on Thu, 06 Dec 2007 12:57:53 -0000, Invisible <voi### [at] dev null> did
spake, saying:
>>> actually worked.
>> Hmm okay.
Well at least until Office 2010
>>> helpful.
> It's not there.
GIYF
Phil Cook
It's descriptive. You'd be happier if it was called, I don't know,
"OpenOffice Splash"?
Jim
Actually, Office 97 had a way for a macro to turn on the "don't disallow
macros" flag. A true security cluster-fk. Like, huh? Disallow macros,
unless the macro with the malware in it says to allow macros?
No. The tools to let it run, but not the tools to make new macros. Just
like having by default a Java VM runtime installed without installing
the Java compiler.
> sign it?
The same way you develop new code if it's always unrunnable until you
compile it.
> the signature...)
Yes. That's the point of it.
It's not feature creep if you put it
at the end and adjust the release date.
And MS could have made it easier by identifying the minimum subset of
macro functions that are necessary for virus propagation, and
eliminating enough of those functions to make virus propagation impossible.
Simply never writing macros to normal.dot would have stopped the
propagation of many viruses, and depriving macros of the ability to
disable menu commands would have helped, too.
John
It's not the first time when MS's concept of fixing a security hole is
to either ignore it (by argumenting it's not a problem) or going completely
overboard, instead of actually fixing the problem itself.
Somehow it gives the impression of a beginner and proud-of-itself
programmer who is given a bug report. He either is too proud to admit
the problem, or can't imagine a better solution to it than to disable
half of the functionality of the program. You know, like those cases you
can constantly read at the daily WTF.
I basically agree with everything you two have said.
How about you ask the user before letting a macro perform a potentially
risky action? (Unless it's signed of course.)
OTOH, some idiots will click anything put in front of them, so... how
about just turn off all potentially unsafe functionallity unless the
macro is signed, and say "hey, get the macro author to sign this if you
really want it to work"? (But provide no way to actually enable the
macro just by clicking the window.)
The vast majority of macros are for auto-generating document content. If
you turn off the ability to access other files / documents and disable
changing the user's settings, it's pretty much impossible for a
malicious macro to do anything except screw up the document it's already
infected. Dude, how hard is that?
But hey, why do that when you can just completely disable all macro
functionallity?
(Question: Has anybody ever actually *seen* a macro virus? I'm told they
exist, but I've never ever come across one...)
And lo on Fri, 07 Dec 2007 09:58:06 -0000, Invisible <voi### [at] dev null> did
spake, saying:
I believe that's called Vista ;-)
Then you'd just get the 'unsafe' macros being signed, unless you want to
force everyone to buy a certificate?
Except where you want a macro to be able to access other documents and
files and change settings. For example IIRC in one version of Word to
print out a document to a non-default printer via VBA requires you to
change the default printer to the one you want to print to then change it
back again.
> functionallity?
Because it's easier
In the early days when they were new, sure. Not so much nowadays.
Phil Cook
Aside from the recurring buffer overruns bugs (it seems like one of
those pop up every month[1]), every security hole appears to involve a
feature that MS added for its own benefit, and not for the user's.
IE is a good example of this. Frankly, everything that isn't directly
related to displaying content formatted in HTML should be relegated to
plug-ins that the user can shut off at will. That includes automatic
download, install, JavaCurse^H^H^H^H^HScript, and so on.
Disabling half of the functionality in IE would be a pretty good idea.
John
Or perhaps... you know... providing a way to uninstall IE? ;-)
http://blog.orphi.me.uk/
There is: Uninstall Windows.
"Orchid XP v7" <voi### [at] dev null> wrote in message
news:475f19d0$1@news.povray.org...
Add/remove programs -> Add/Remove Windows Components. Uncheck Internet
Explorer.
(At least on my windows 2000 box)
> Explorer.
Did you read the description of that "component" carefully? The only
thing that will remove is the SHORTCUT.
"Nicolas Alvarez" <nic### [at] gmail is the best com> wrote in message
news:475f676a$1@news.povray.org...
> > Explorer.
Ah, no. That would explain the 0k.
I know there is a way, did it some time back on a previous install. Can't
remember now. Left it on this one cause there's too many sites still that
won't work with firefox.
IE itself is a thin layer on top of a whole bunch of libraries that a
whole lot of other things depend on. Like the help system, for example,
as well as a bunch of download mechanisms. I don't think you ever
actually managed to pull the tentacles of IE out of Windows. It would be
like that scene from 20,000 Leagues with the giant squid, except it also
has its tentacles plugged into Auntie Em, who yelps every time you tug.
As Warp said, you'll have to uninstall Windows to do that. If somehow you
actually managed to remove IE completely, then a whole load of other stuff
would break. WinPOV Help would be one thing, explorer would probably break
too.
I think it started with Win98 and went only downhill from there.
With Win98 MS had this braindead idea that they should make the desktop
and most applications to look&feel like webpages (or at least support making
them so). This, of course, is exactly the wrong direction to go.
Webpages are very limited in functionality because HTML is very limited
in functionality. There are many, many things you can't implement in a
webpage because HTML was and still is purposefully simple. In a desktop GUI
trying to emulate a webpage is exactly the wrong direction to go, and it
should be the other way around: Webpages should aim to work like desktops,
not the other way around.
What I really hate about Microsoft's braindead ideas is that most people
seem happy to blindly copy them. Windows 3 had several good design and
behavior decisions which were dropped from subsequent Windowses just for
the sake of change, just for the sake of making it look&feel *different*,
in many cases at the cost of reduced usability.
Just as an example is the behavior of menus and sub-menus: In Win3 it was
standard practice that if you opened a menu and it had a sub-menu, you had
to click on the name of the sub-menu to open it, and then it stayed open
for as long as you clicked something else.
Well, MS had this "great" idea to change this behavior from clicking to
hovering instead: Sub-menus open by hovering the sub-menu name and they
close when you unhover. Opening it with hovering is not completely bad
(although it becomes irritating when the sub-menu has something which takes
time to build, such as some of the sub-menus of the context menu of windows
explorer), but closing the sub-menu by unhovering is the most braindead
idea ever. You hover the name of the sub-menu, then start moving the mouse
to the right (or in some cases to the left...) to get to it, accidentally
unhover the name of the sub-menu by accident, and it closes. How this could
ever be a good idea is beyond by comprehension. You have to be really
proficient at aiming with the mouse in order to keep the sub-menu open. Not
all people are.
Speaking of context menus, that's another step backwards MS took:
Previously you could open a context menu by right-clicking and then,
while keeping the mouse button down, select the item you wanted and then
release the mouse button and it would select it. This was a nice power-user
feature. For example selecting "Back" in a web browser was fast and easy
this way. Just press, move a bit down, release.
But no, they had to change this. Now you can't do that. You have to press,
then release, then move down, then press, then release. Not a big deal, but
very irritating when you got used to the old behavior. The new behavior is
awkward.
The biggest problem with this is that everyone is blindly copying these
braindead design decisions everywhere, often even in non-windows software.
For example KDE has the hover-to-open-and-close-submenus idea implemented,
which is irritating.
Fortunately other systems have yet to copy the most braindead GUI ideas
from MS. For example menus which change contents every time you use them.
(I can't even begin to imagine how anyone could think that's a good idea.
When MS wants to make changes just for the sake of changes, just to make
a new Windows look different than the previous one, they will stop at
nothing.)
Mmm. That's not an inherantly bad idea...
"Darren New" <dne### [at] san rr com> wrote in message
news:475f6e3b$1@news.povray.org...
Yeah, I know. I don't think the whole mess was missing. I know I've had
machines where internet explorer wasn't there.
Is all fine til some braindead installer decides to invoke IE directly,
rather than calling for the app that reads htm pages
Well, they *are* trying to make a profit. It's understandable, even if
suboptimal. :-)
> hovering instead:
Yah, I hate that too. Actually, I think there's a switch you can set to
say don't do that, but I don't know if it disappears the menu if you
move away after you click. I'll have to try that.
Smalltalk did one better years earlier. Context menus not only open
under the mouse, but position themself so that the previously chosen
menu selection is under the cursor. If you're pasting the same thing
into a dozen windows (because, say, you haven't yet automated
broadcasting restarts to your server farm), you don't wind up with the
mouse down in your lap before you're done.
> nothing.)
Yah, well, that's for-fee software for ya. Gotta get people to buy the
newer version, ya know.
> you actually managed to remove IE completely, then a whole load of other
> stuff would break. WinPOV Help would be one thing, explorer would
> probably break too.
What, you mean like if you turned RPC off? :-}
>> other stuff would break. WinPOV Help would be one thing, explorer
>> would probably break too.
Huh?
WinPOV Help is a .chm file. HTML Help. The viewer uses the IE rendering
engine to show pages. Uninstall IE completely, including its rendering
engine, and no more HTML help for you.
> Huh?
Turning RPC off reputedly causes Windoze-based PCs to malfunction to the
point of being unuseable. Great if you want to close this large security
hole...
news:47617baa$1@news.povray.org...
> > Huh?
> hole...
It's not that large a security hole. Unless you fiddle with the default
security, it's remote process communication on your own machine.
RPC is used by various processes of windows to communicate with each other
>>> Huh?
>> hole...
Depends on your definition of "large".
As I understand it, anybody who can guess what your admin password is
can have unlimited access to your PC via RPC. Nice...
news:47617e7a$1@news.povray.org...
> can have unlimited access to your PC via RPC. Nice...>
Anyone who's guessed your admin password owns your machine regardless.
del \\machine\c$\*.* /S
And that's not even considering them walking up to the machine (if its not a
server) and loging in. Or if it is a server, usign remote desktop/terminal
services
Strong admin password, perhaps?
Which, as I understand it, only works because RPC is enabled.
If you can't remotely talk to the machine, you can't do anything to it.
> services
I was thinking more of the millions of people who have PCs in their
homes, probably with a blank or default admin password, who have no idea
that random people on the Internet can use that password to remotely do
stuff to it.
RPC includes things like programs talking to the graphics subsystem,
login process talking to the protected storage process, and console
programs talking to CRSS (console simulation subsystem).
Kind of like eliminating pipes and sockets on Unix.
Orchid XP v7 nous apporta ses lumieres en ce 2007/12/13 15:47:
>> not a
>> desktop/terminal
>> services
> stuff to it.
Turning RPC off mean that your programms can't accept any input from your
keyboard and mouse. It mean that your programms can't even create ther main
window, let alone display anything in them. It mean that you can't access the disks.
It mean that Windows itself can't accept keyboard and mouse inputs and can't
access the display. It mean that the various parts of Windows can't communicate
with each other. Most calls for DLL functions use RPC. Any call to code at an
address that is more than 64K away may be a "remote" call.
A system that ask for a password, with a blank password, is more secure than the
same system with a weak password. The reason is that when a password is asked,
you don't just hit "enter", you try to find a password... and that cracker
applications are not made to try the blank password.
Wiccan: An it harm none, let shit happen.
