POV-Ray : Newsgroups : povray.off-topic : VBA (Very Bad Answer?) Server Time
20 Jan 2026 17:30:18 EST (-0500)
  VBA (Very Bad Answer?) (Message 1 to 10 of 36)
Subject: VBA (Very Bad Answer?)
Date: 6 Dec 2007 05:41:54
Message: <4757d1f2$1@news.povray.org>
Well anyway, today I *finally* got my Excel spreadsheet working again!
It stopped working when I upgraded from Office 97 to Office 2003.
Specifically, my VBA macro was disabled. (Damn it, I spent *hours*
writing that thing! I *want* it to work!!)
Apparently it's disabled as a security measure. You'd *think* there
would be a button you could just press to say that *this* macro is OK to
run. (That's what Office 97 had.) But no, apparently that would be too easy.
Google did at least manage to find me a relevant article without much ado.
http://msdn2.microsoft.com/en-us/library/aa141471(office.10).aspx
It turns out that the correct process for enabling a macro that you
wrote to run on your own PC is as follows:
1. Find the product installation CD.
2. Install the certificate tools.
(By default they install VBA but not the tools apparently necessary to
actually enable it to run. But then, have you *seen* VBA? I guess the
assumption that you won't want to use it is fairly safe...)
3. Nagivate several system folders. (You know, the ones where Windows
Explorer insists "This is dangerous. We have hidden it for your own
safety. Do you *really* want to touch this stuff? We warned you!")
4. Run the certificate creation tool. This creates a self-signed
certificate which you cannot export or back up. (Yay!)
5. Open the spreadsheet.
6. Open the VB Editor.
7. Find the right menu item.
8. Select the certificate you just created and add the signature.
9. Save the spreadsheet.
10. Close the spreadsheet.
11. Reopen the spreadsheet.
(The instructions fail to mention that the code being signed doesn't
help you until the *next* time you open the thing...)
I wonder - how do you develop new code if it's always disabled until you
sign it? (And - one hopes - every time you change it this invalidates
the signature...)
All this fuss just so I can click a button to put today's date in a cell
on the spreadsheet... sheesh!
Subject: Re: VBA (Very Bad Answer?)
Date: 6 Dec 2007 06:32:24
Message: <4757ddc8$1@news.povray.org>
Or you could just have gone to Options -> Security and turned down Macro
security to Medium, then at least you get the old style "do you want to run
this or not" box for unsigned macros...
Date: 6 Dec 2007 06:59:59
Message: <op.t2wwvlwac3xi7v@news.povray.org>
And lo on Thu, 06 Dec 2007 10:41:58 -0000, Invisible <voi### [at] devnull> did
spake, saying:
> easy.
As Scott said you just turn down the security options from "I'm an idiot
protect me" to "I'm a grown-up let me make my own decisions"
> ado.
or you could have checked your posts as I've told you how to do this twice
now :-)
or run a search for selfcert.exe
Um you mean except when you go to sign it, view details and pick "Copy to
file"?
Tools|Digital Signature.. at least on 2k, hardly surprising.
Well yeah by default the macros are disabled so you need to reopen it for
the signature to be taken into account then it should say signed by blah
trust this certificate and that's it.
> the signature...)
It gets re-signed if the certificate that originally signed it is present,
so someone else souldn't re-sign the code and distribute it unless they
were using your computer/login, besides you should lock the project for
viewing anyway.
But all that hassle was a one-off you've now got a certificate to sign
anything VBA with.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 6 Dec 2007 07:23:42
Message: <4757e9ce@news.povray.org>
Well I pretty much assumed it would be an on/off settings, and even I am
not too keen on turning the security off completely.
>> ado.
> twice now :-)
I followed the instructions you gave me for Office 97 and they didn't
work. (I forget where exactly it fails.) The instructions I found here
actually worked.
Actually I used a command prompt, but hey.
> to file"?
I did follow the instructions for backing up the certificate, but
apparently "the private key is marked as not exportable and cannot be
saved". So you can save the certificate itself, just not the key. Very
helpful.
It's easy once you figure out it's under Tools, yes.
>> you sign it? (And - one hopes - every time you change it this
>> invalidates the signature...)
> present, so someone else souldn't re-sign the code and distribute it
> unless they were using your computer/login, besides you should lock the
> project for viewing anyway.
Interesting. So if you change something when you didn't mean to, it
updates the signature? Oh dear...
>> cell on the spreadsheet... sheesh!
> anything VBA with.
Until the next time I reinstall Windoze...
PS. Does OpenOffice provide a scripting language?
Date: 6 Dec 2007 07:42:21
Message: <4757ee2d$1@news.povray.org>
Several of them, it seems:
http://framework.openoffice.org/scripting/index.html
I never used that, though...
Vincent
Date: 6 Dec 2007 07:50:02
Message: <4757effa$1@news.povray.org>
"OpenOffice Basic"? Oh, that's original...
Date: 6 Dec 2007 07:55:11
Message: <op.t2wzd90ec3xi7v@news.povray.org>
And lo on Thu, 06 Dec 2007 12:23:41 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>> idiot protect me" to "I'm a grown-up let me make my own decisions"
No amazingly they did add an adult option alongside the absolutes.
>>> ado.
>> twice now :-)
> actually worked.
Hmm okay.
>> to file"?
> helpful.
Try makecert instead.
or read the article you linked to :-)
Phil Cook
Date: 6 Dec 2007 07:57:55
Message: <4757f1d3@news.povray.org>
>> actually worked.
> Hmm okay.
Well, to be honest it's getting quite hard to find information about
Office 97. Hopefully Office 2003 will be an easier proposition...
>> helpful.
It's not there.
Date: 6 Dec 2007 09:14:12
Message: <op.t2w2zac4c3xi7v@news.povray.org>
And lo on Thu, 06 Dec 2007 12:57:53 -0000, Invisible <voi### [at] devnull> did
spake, saying:
>>> actually worked.
>>  Hmm okay.
Well at least until Office 2010
>>> helpful.
> It's not there.
GIYF
Phil Cook
Date: 6 Dec 2007 12:37:44
Message: <47583368$1@news.povray.org>
It's descriptive.  You'd be happier if it was called, I don't know,
"OpenOffice Splash"?
Jim
